[GRASS-SVN] r55127 - grass/trunk/raster/r.in.xyz
Wed Feb 20 02:01:24 PST 2013
Author: hamish
Date: 2013-02-20 02:01:24 -0800 (Wed, 20 Feb 2013)
New Revision: 55127
   grass/trunk/raster/r.in.xyz/r.in.xyz.html
preserve tense
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html	2013-02-20 09:52:07 UTC (rev 55126)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html	2013-02-20 10:01:24 UTC (rev 55127)
@@ -4,12 +4,14 @@
 into a new raster map. The user may choose from a variety of statistical
 methods in creating the new raster. Gridded data provided as a stream of
 x,y,z points may also be imported.
 <p>
-Please note that the current region extents and resolution are used for
-the import. It is therefore recommended to first use the <em>-s</em>
-flag to get the extents of the input points to be imported, then
-adjust the current region accordingly and only now proceed with the
+Please note that the current region extents and resolution are used for
+the import. It is therefore recommended to first use the <em>-s</em>
+flag to get the extents of the input points to be imported, then
+adjust the current region accordingly, and only then proceed with the
 actual import.
 <p>
 <em>r.in.xyz</em> is designed for processing massive point cloud datasets,
 for example raw LIDAR or sidescan sonar swath data. It has been tested with
