[GRASS-SVN] r55137 - in grass/branches/releasebranch_6_4/gui/wxpython: core gui_core
Wed Feb 20 15:10:57 PST 2013
Author: annakrat
Date: 2013-02-20 15:10:57 -0800 (Wed, 20 Feb 2013)
New Revision: 55137
   grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
wxGUI: fix #1605
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2013-02-20 20:10:07 UTC (rev 55136)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2013-02-20 23:10:57 UTC (rev 55137)
@@ -331,6 +331,51 @@
     return layers
+def GetAllVectorLayers(vector):
+    """!Returns list of all vector layers as strings.
+    @param vector name of vector map
+    layers = []
+    if not vector:
+        return layers
+    fullname = grass.find_file(name = vector, element = 'vector')['fullname']
+    if not fullname:
+        Debug.msg(3, "utils.GetAllVectorLayers(): vector map <%s> not found" % vector)
+        return layers
+    ret, out, msg = RunCommand('v.category',
+                               getErrorMsg = True,
+                               read = True,
+                               quiet = True,
+                               option = 'report',
+                               flags = 'g',
+                               input = fullname)
+    print out
+    if ret != 0:
+        sys.stderr.write(_("Vector map <%(map)s>: %(msg)s\n") % { 'map' : fullname, 'msg' : msg })
+        return layers
+    Debug.msg(1, "utils.GetAllVectorLayers(): ret %s" % ret)
+    for line in out.splitlines():
+        if 'all' not in line:
+            continue
+        try:
+            layer = line.split(' ')[0]
+        except IndexError:
+            continue
+        # use this to get layer names
+        # but only when all modules use Vect_get_field2()
+        # which is not the case right now
+        layers.append(layer)
+    Debug.msg(3, "utils.GetAllVectorLayers(): vector=%s -> %s" % \
+                  (fullname, ','.join(layers)))
+    return layers
 def Deg2DMS(lon, lat, string = True, hemisphere = True, precision = 3):
     """!Convert deg value to dms string
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py	2013-02-20 20:10:07 UTC (rev 55136)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py	2013-02-20 23:10:57 UTC (rev 55137)
@@ -48,7 +48,7 @@
 from core.gcmd     import RunCommand, GError, GMessage
 from core.utils    import GetListOfLocations, GetListOfMapsets, GetFormats
-from core.utils    import GetSettingsPath, GetValidLayerName, ListSortLower, GetVectorNumberOfLayers
+from core.utils    import GetSettingsPath, GetValidLayerName, ListSortLower, GetAllVectorLayers
 from core.settings import UserSettings
 from core.debug    import Debug
@@ -681,7 +681,7 @@
         if vector:
-            layers = GetVectorNumberOfLayers(vector)
+            layers = GetAllVectorLayers(vector)
         else:
             layers = list()
