[GRASS-SVN] r55154 - in grass/trunk: lib/python/pygrass/docs man/sphinx mswindows mswindows/external/rbatch mswindows/osgeo4w
Thu Feb 21 18:43:05 PST 2013
Author: hamish
Date: 2013-02-21 18:43:04 -0800 (Thu, 21 Feb 2013)
New Revision: 55154
   grass/trunk/lib/python/pygrass/docs/make.bat
   grass/trunk/man/sphinx/make.bat
   grass/trunk/mswindows/env.bat
   grass/trunk/mswindows/external/rbatch/#Rscript.bat
   grass/trunk/mswindows/external/rbatch/R.bat
   grass/trunk/mswindows/external/rbatch/Rcmd.bat
   grass/trunk/mswindows/external/rbatch/Rgui.bat
   grass/trunk/mswindows/external/rbatch/RguiStart.bat
   grass/trunk/mswindows/external/rbatch/Rscript.bat
   grass/trunk/mswindows/external/rbatch/Rtidy.bat
   grass/trunk/mswindows/external/rbatch/Rtools.bat
   grass/trunk/mswindows/external/rbatch/RtoolsVersion.bat
   grass/trunk/mswindows/external/rbatch/Rversions.bat
   grass/trunk/mswindows/external/rbatch/Stangle.bat
   grass/trunk/mswindows/external/rbatch/Sweave.bat
   grass/trunk/mswindows/external/rbatch/copydir.bat
   grass/trunk/mswindows/external/rbatch/movedir.bat
   grass/trunk/mswindows/external/rbatch/rterm.bat
   grass/trunk/mswindows/osgeo4w/msys.bat
   grass/trunk/mswindows/osgeo4w/postinstall.bat
   grass/trunk/mswindows/osgeo4w/preremove.bat
svn props using module_svn_propset.sh, especially eol-style=CRLF
Modified: grass/trunk/lib/python/pygrass/docs/make.bat
--- grass/trunk/lib/python/pygrass/docs/make.bat	2013-02-22 02:36:57 UTC (rev 55153)
+++ grass/trunk/lib/python/pygrass/docs/make.bat	2013-02-22 02:43:04 UTC (rev 55154)
@@ -1,190 +1,190 @@
- at ECHO OFF
-REM Command file for Sphinx documentation
-if "%SPHINXBUILD%" == "" (
-	set SPHINXBUILD=sphinx-build2
-set BUILDDIR=_build
-set ALLSPHINXOPTS=-d %BUILDDIR%/doctrees %SPHINXOPTS% .
-set I18NSPHINXOPTS=%SPHINXOPTS% .
-if NOT "%PAPER%" == "" (
-	set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
-	set I18NSPHINXOPTS=-D latex_paper_size=%PAPER% %I18NSPHINXOPTS%
-if "%1" == "" goto help
-if "%1" == "help" (
-	:help
-	echo.Please use `make ^<target^>` where ^<target^> is one of
-	echo.  html       to make standalone HTML files
-	echo.  dirhtml    to make HTML files named index.html in directories
-	echo.  singlehtml to make a single large HTML file
-	echo.  pickle     to make pickle files
-	echo.  json       to make JSON files
-	echo.  htmlhelp   to make HTML files and a HTML help project
-	echo.  qthelp     to make HTML files and a qthelp project
-	echo.  devhelp    to make HTML files and a Devhelp project
-	echo.  epub       to make an epub
-	echo.  latex      to make LaTeX files, you can set PAPER=a4 or PAPER=letter
-	echo.  text       to make text files
-	echo.  man        to make manual pages
-	echo.  texinfo    to make Texinfo files
-	echo.  gettext    to make PO message catalogs
-	echo.  changes    to make an overview over all changed/added/deprecated items
-	echo.  linkcheck  to check all external links for integrity
-	echo.  doctest    to run all doctests embedded in the documentation if enabled
-	goto end
-if "%1" == "clean" (
-	for /d %%i in (%BUILDDIR%\*) do rmdir /q /s %%i
-	del /q /s %BUILDDIR%\*
-	goto end
-if "%1" == "html" (
-	%SPHINXBUILD% -b html %ALLSPHINXOPTS% %BUILDDIR%/html
-	if errorlevel 1 exit /b 1
-	echo.
-	echo.Build finished. The HTML pages are in %BUILDDIR%/html.
-	goto end
-if "%1" == "dirhtml" (
-	%SPHINXBUILD% -b dirhtml %ALLSPHINXOPTS% %BUILDDIR%/dirhtml
-	echo.
-	echo.Build finished. The HTML pages are in %BUILDDIR%/dirhtml.
-	goto end
-if "%1" == "singlehtml" (
-	%SPHINXBUILD% -b singlehtml %ALLSPHINXOPTS% %BUILDDIR%/singlehtml
-	echo.
-	echo.Build finished. The HTML pages are in %BUILDDIR%/singlehtml.
-	goto end
-if "%1" == "pickle" (
-	%SPHINXBUILD% -b pickle %ALLSPHINXOPTS% %BUILDDIR%/pickle
-	echo.
-	echo.Build finished; now you can process the pickle files.
-	goto end
-if "%1" == "json" (
-	%SPHINXBUILD% -b json %ALLSPHINXOPTS% %BUILDDIR%/json
-	echo.
-	echo.Build finished; now you can process the JSON files.
-	goto end
-if "%1" == "htmlhelp" (
-	%SPHINXBUILD% -b htmlhelp %ALLSPHINXOPTS% %BUILDDIR%/htmlhelp
-	echo.
-	echo.Build finished; now you can run HTML Help Workshop with the ^
-.hhp project file in %BUILDDIR%/htmlhelp.
-	goto end
-if "%1" == "qthelp" (
-	%SPHINXBUILD% -b qthelp %ALLSPHINXOPTS% %BUILDDIR%/qthelp
-	echo.
-	echo.Build finished; now you can run "qcollectiongenerator" with the ^
-.qhcp project file in %BUILDDIR%/qthelp, like this:
-	echo.^> qcollectiongenerator %BUILDDIR%\qthelp\PyGrass.qhcp
-	echo.To view the help file:
-	echo.^> assistant -collectionFile %BUILDDIR%\qthelp\PyGrass.ghc
-	goto end
-if "%1" == "devhelp" (
-	%SPHINXBUILD% -b devhelp %ALLSPHINXOPTS% %BUILDDIR%/devhelp
-	echo.
-	goto end
-if "%1" == "epub" (
-	%SPHINXBUILD% -b epub %ALLSPHINXOPTS% %BUILDDIR%/epub
-	echo.
-	echo.Build finished. The epub file is in %BUILDDIR%/epub.
-	goto end
-if "%1" == "latex" (
-	%SPHINXBUILD% -b latex %ALLSPHINXOPTS% %BUILDDIR%/latex
-	echo.
-	echo.Build finished; the LaTeX files are in %BUILDDIR%/latex.
-	goto end
-if "%1" == "text" (
-	%SPHINXBUILD% -b text %ALLSPHINXOPTS% %BUILDDIR%/text
-	echo.
-	echo.Build finished. The text files are in %BUILDDIR%/text.
-	goto end
-if "%1" == "man" (
-	%SPHINXBUILD% -b man %ALLSPHINXOPTS% %BUILDDIR%/man
-	echo.
-	echo.Build finished. The manual pages are in %BUILDDIR%/man.
-	goto end
-if "%1" == "texinfo" (
-	%SPHINXBUILD% -b texinfo %ALLSPHINXOPTS% %BUILDDIR%/texinfo
-	echo.
-	echo.Build finished. The Texinfo files are in %BUILDDIR%/texinfo.
-	goto end
-if "%1" == "gettext" (
-	%SPHINXBUILD% -b gettext %I18NSPHINXOPTS% %BUILDDIR%/locale
-	echo.
-	echo.Build finished. The message catalogs are in %BUILDDIR%/locale.
-	goto end
-if "%1" == "changes" (
-	%SPHINXBUILD% -b changes %ALLSPHINXOPTS% %BUILDDIR%/changes
-	echo.
-	echo.The overview file is in %BUILDDIR%/changes.
-	goto end
-if "%1" == "linkcheck" (
-	%SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% %BUILDDIR%/linkcheck
-	echo.
-	echo.Link check complete; look for any errors in the above output ^
-or in %BUILDDIR%/linkcheck/output.txt.
-	goto end
-if "%1" == "doctest" (
-	%SPHINXBUILD% -b doctest %ALLSPHINXOPTS% %BUILDDIR%/doctest
-	echo.
-	echo.Testing of doctests in the sources finished, look at the ^
-results in %BUILDDIR%/doctest/output.txt.
-	goto end
-:end
+ at ECHO OFF
+REM Command file for Sphinx documentation
+if "%SPHINXBUILD%" == "" (
+	set SPHINXBUILD=sphinx-build2
+set BUILDDIR=_build
+set ALLSPHINXOPTS=-d %BUILDDIR%/doctrees %SPHINXOPTS% .
+set I18NSPHINXOPTS=%SPHINXOPTS% .
+if NOT "%PAPER%" == "" (
+	set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
+	set I18NSPHINXOPTS=-D latex_paper_size=%PAPER% %I18NSPHINXOPTS%
+if "%1" == "" goto help
+if "%1" == "help" (
+	:help
+	echo.Please use `make ^<target^>` where ^<target^> is one of
+	echo.  html       to make standalone HTML files
+	echo.  dirhtml    to make HTML files named index.html in directories
+	echo.  singlehtml to make a single large HTML file
+	echo.  pickle     to make pickle files
+	echo.  json       to make JSON files
+	echo.  htmlhelp   to make HTML files and a HTML help project
+	echo.  qthelp     to make HTML files and a qthelp project
+	echo.  devhelp    to make HTML files and a Devhelp project
+	echo.  epub       to make an epub
+	echo.  latex      to make LaTeX files, you can set PAPER=a4 or PAPER=letter
+	echo.  text       to make text files
+	echo.  man        to make manual pages
+	echo.  texinfo    to make Texinfo files
+	echo.  gettext    to make PO message catalogs
+	echo.  changes    to make an overview over all changed/added/deprecated items
+	echo.  linkcheck  to check all external links for integrity
+	echo.  doctest    to run all doctests embedded in the documentation if enabled
+	goto end
+if "%1" == "clean" (
+	for /d %%i in (%BUILDDIR%\*) do rmdir /q /s %%i
+	del /q /s %BUILDDIR%\*
+	goto end
+if "%1" == "html" (
+	%SPHINXBUILD% -b html %ALLSPHINXOPTS% %BUILDDIR%/html
+	if errorlevel 1 exit /b 1
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/html.
+	goto end
+if "%1" == "dirhtml" (
+	%SPHINXBUILD% -b dirhtml %ALLSPHINXOPTS% %BUILDDIR%/dirhtml
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/dirhtml.
+	goto end
+if "%1" == "singlehtml" (
+	%SPHINXBUILD% -b singlehtml %ALLSPHINXOPTS% %BUILDDIR%/singlehtml
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/singlehtml.
+	goto end
+if "%1" == "pickle" (
+	%SPHINXBUILD% -b pickle %ALLSPHINXOPTS% %BUILDDIR%/pickle
+	echo.
+	echo.Build finished; now you can process the pickle files.
+	goto end
+if "%1" == "json" (
+	%SPHINXBUILD% -b json %ALLSPHINXOPTS% %BUILDDIR%/json
+	echo.
+	echo.Build finished; now you can process the JSON files.
+	goto end
+if "%1" == "htmlhelp" (
+	%SPHINXBUILD% -b htmlhelp %ALLSPHINXOPTS% %BUILDDIR%/htmlhelp
+	echo.
+	echo.Build finished; now you can run HTML Help Workshop with the ^
+.hhp project file in %BUILDDIR%/htmlhelp.
+	goto end
+if "%1" == "qthelp" (
+	%SPHINXBUILD% -b qthelp %ALLSPHINXOPTS% %BUILDDIR%/qthelp
+	echo.
+	echo.Build finished; now you can run "qcollectiongenerator" with the ^
+.qhcp project file in %BUILDDIR%/qthelp, like this:
+	echo.^> qcollectiongenerator %BUILDDIR%\qthelp\PyGrass.qhcp
+	echo.To view the help file:
+	echo.^> assistant -collectionFile %BUILDDIR%\qthelp\PyGrass.ghc
+	goto end
+if "%1" == "devhelp" (
+	%SPHINXBUILD% -b devhelp %ALLSPHINXOPTS% %BUILDDIR%/devhelp
+	echo.
+	goto end
+if "%1" == "epub" (
+	%SPHINXBUILD% -b epub %ALLSPHINXOPTS% %BUILDDIR%/epub
+	echo.
+	echo.Build finished. The epub file is in %BUILDDIR%/epub.
+	goto end
+if "%1" == "latex" (
+	%SPHINXBUILD% -b latex %ALLSPHINXOPTS% %BUILDDIR%/latex
+	echo.
+	echo.Build finished; the LaTeX files are in %BUILDDIR%/latex.
+	goto end
+if "%1" == "text" (
+	%SPHINXBUILD% -b text %ALLSPHINXOPTS% %BUILDDIR%/text
+	echo.
+	echo.Build finished. The text files are in %BUILDDIR%/text.
+	goto end
+if "%1" == "man" (
+	%SPHINXBUILD% -b man %ALLSPHINXOPTS% %BUILDDIR%/man
+	echo.
+	echo.Build finished. The manual pages are in %BUILDDIR%/man.
+	goto end
+if "%1" == "texinfo" (
+	%SPHINXBUILD% -b texinfo %ALLSPHINXOPTS% %BUILDDIR%/texinfo
+	echo.
+	echo.Build finished. The Texinfo files are in %BUILDDIR%/texinfo.
+	goto end
+if "%1" == "gettext" (
+	%SPHINXBUILD% -b gettext %I18NSPHINXOPTS% %BUILDDIR%/locale
+	echo.
+	echo.Build finished. The message catalogs are in %BUILDDIR%/locale.
+	goto end
+if "%1" == "changes" (
+	%SPHINXBUILD% -b changes %ALLSPHINXOPTS% %BUILDDIR%/changes
+	echo.
+	echo.The overview file is in %BUILDDIR%/changes.
+	goto end
+if "%1" == "linkcheck" (
+	%SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% %BUILDDIR%/linkcheck
+	echo.
+	echo.Link check complete; look for any errors in the above output ^
+or in %BUILDDIR%/linkcheck/output.txt.
+	goto end
+if "%1" == "doctest" (
+	%SPHINXBUILD% -b doctest %ALLSPHINXOPTS% %BUILDDIR%/doctest
+	echo.
+	echo.Testing of doctests in the sources finished, look at the ^
+results in %BUILDDIR%/doctest/output.txt.
+	goto end
+:end
Property changes on: grass/trunk/lib/python/pygrass/docs/make.bat
___________________________________________________________________
Added: svn:mime-type
   + text/x-bat
Added: svn:eol-style
   + CRLF
Modified: grass/trunk/man/sphinx/make.bat
--- grass/trunk/man/sphinx/make.bat	2013-02-22 02:36:57 UTC (rev 55153)
+++ grass/trunk/man/sphinx/make.bat	2013-02-22 02:43:04 UTC (rev 55154)
@@ -1,190 +1,190 @@
- at ECHO OFF
-	:help
-	goto end
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	echo.^> qcollectiongenerator %BUILDDIR%\qthelp\GRASS70Documentation.qhcp
-	echo.^> assistant -collectionFile %BUILDDIR%\qthelp\GRASS70Documentation.ghc
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-if "%1" == "man" (
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-	echo.
-	goto end
-:end
+ at ECHO OFF
+	:help
+	goto end
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	echo.^> qcollectiongenerator %BUILDDIR%\qthelp\GRASS70Documentation.qhcp
+	echo.^> assistant -collectionFile %BUILDDIR%\qthelp\GRASS70Documentation.ghc
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+if "%1" == "man" (
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+	echo.
+	goto end
+:end
Property changes on: grass/trunk/man/sphinx/make.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/env.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/#Rscript.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/R.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rcmd.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rgui.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/RguiStart.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rscript.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rtidy.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rtools.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/RtoolsVersion.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Rversions.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Stangle.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/Sweave.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/copydir.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/movedir.bat
   + text/x-bat
   + CRLF
Property changes on: grass/trunk/mswindows/external/rbatch/rterm.bat
   + text/x-bat
   + CRLF
Modified: grass/trunk/mswindows/osgeo4w/msys.bat
--- grass/trunk/mswindows/osgeo4w/msys.bat	2013-02-22 02:36:57 UTC (rev 55153)
+++ grass/trunk/mswindows/osgeo4w/msys.bat	2013-02-22 02:43:04 UTC (rev 55154)
@@ -1,203 +1,203 @@
- at echo off
-rem Copyright (C):  2001, 2002, 2003, 2004, 2005  Earnie Boyd
-rem   mailto:earnie at users.sf.net
-rem This file is part of Minimal SYStem
-rem   http://www.mingw.org/msys.shtml
-rem
-rem File:	    msys.bat
-rem Revision:	    2.4
-rem Revision Date:  December 8th, 2005
-rem --- MODIFIED FOR GRASS Aug 2009: Quote path name variables ---
-rem ember to set the "Start in:" field of the shortcut.
-rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
-rem to represent.
-rem ember value of GOTO: is used to know recursion has happened.
-if "%1" == "GOTO:" goto %2
-if NOT "x%WD%" == "x" set WD=
-rem ember command.com only uses the first eight characters of the label.
-goto _WindowsNT
-rem ember that we only execute here if we are in command.com.
-:_Windows
-if "x%COMSPEC%" == "x" set COMSPEC=command.com
-start /min "%COMSPEC%" /e:4096 /c %0 GOTO: _Resume %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-rem ember that we execute here if we recursed.
-:_Resume
-for %%F in (1 2 3) do shift
-if NOT EXIST "%WD%msys-1.0.dll" set WD=.\bin\
-rem ember that we get here even in command.com.
-:_WindowsNT
-rem Hopefully a temporary workaround for getting MSYS shell to run on x64
-rem (WoW64 cmd prompt sets PROCESSOR_ARCHITECTURE to x86)
-if not "x%PROCESSOR_ARCHITECTURE%" == "xAMD64" goto _NotX64
-set COMSPEC=%WINDIR%\SysWOW64\cmd.exe
-"%COMSPEC%" /c %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-:_NotX64
-if NOT EXIST "%WD%msys-1.0.dll" set WD=%~dps0bin\
-rem echo %WD%
-rem if installed in a directory containing spaces prepare for a world of pain
-for /F %%i IN ('echo %WD%') DO @set PART1=%%i
-if NOT "%PART1%" == "%WD%" (
-   echo Path names containing spaces are not supported -- aborting.
-   pause
-   exit 1
-rem ember Set up option to use rxvt based on value of %1
-set MSYSCON=unknown
-if "x%1" == "x-norxvt" set MSYSCON=sh.exe
-if "x%1" == "x--norxvt" set MSYSCON=sh.exe
-if "x%1" == "x-rxvt" set MSYSCON=rxvt.exe
-if "x%1" == "x--rxvt" set MSYSCON=rxvt.exe
-if NOT "x%MSYSCON%" == "xunknown" shift
-if "x%MSYSCON%" == "xunknown" set MSYSCON=sh.exe
-rem the default is a MSYS (user), not a MINGW (developer) console
-if "x%MSYSTEM%" == "x" set MSYSTEM=MINGW32
-if "%1" == "MINGW32" set MSYSTEM=MINGW32
-if "%1" == "MSYS" set MSYSTEM=MSYS
-if NOT "x%DISPLAY%" == "x" set DISPLAY=
-if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
-if "x%MSYSCON%" == "xsh.exe" goto startsh
-:unknowncon
-echo %MSYSCON% is an unknown option for msys.bat.
-pause
-exit 1
-:notfound
-echo Cannot find the rxvt.exe or sh.exe binary -- aborting.
-pause
-exit 1
-rem If you don't want to use rxvt then rename the file rxvt.exe to something
-rem else.  Then sh.exe will be used instead.
-:startrxvt
-if NOT EXIST "%WD%rxvt.exe" goto startsh
-rem Setup the default colors for rxvt.
-if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
-if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
-if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=Black
-if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=White
-if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
-if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
-if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
-exit
-:startsh
-if NOT EXIST "%WD%sh.exe" goto notfound
-if "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -c "%*"
-exit
-:EOF
-rem ChangeLog:
-rem 2002.03.07  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Move the @echo off to the top.
-rem	* Change the binmode setting to nobinmode.
-rem     * Remove the angle brackets around email address to workaround MS
-rem	buggy command processor.
-rem
-rem 2002.03.12  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add filter logic to find rxvt.exe
-rem
-rem 2002.03.13  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Revert the nobinmode change.
-rem
-rem 2002.03.20  Earnie Boyd  mailto:earnie at users.sf.net
-rem     * Add logic for stating bash.
-rem
-rem 2002.04.11  Earnie Boyd  mailto;earnie at users.sf.net
-rem	* Add logic for setting MSYSTEM value based on parameter.
-rem
-rem 2002.04.15  Olivier Gautherot  mailto:olivier_gautherot at mentorg.com
-rem	* Reduce number test conditions for finding an executable.
-rem
-rem 2002.04.15  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Unset DISPLAY if set before starting shell.
-rem
-rem 2002.04.16  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove use of DEFINED in conditional statments for variables for
-rem	command.com support.
-rem	* Add check for nonexistance of USERNAME variable for Win9x support.
-rem
-rem 2002.04.17  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add foreground and background color defaults based on MSYSTEM value.
-rem
-rem 2002.04.22  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* More Win 9x changes.
-rem
-rem 2002.05.04  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove the SET of USERNAME and HOME.
-rem
-rem 2002.11.18  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add command.com detection and restart with a larger environment to
-rem	avoid errors on w9x.
-rem     Many thanks to Randy W. Sims mailto:RandyS at ThePierianSpring.org.
-rem	See Randy's response to "RE: [Mingw-msys] Installation on WindowsME"
-rem	from 11/06/2002 in the archives of mingw-msys at lists.sf.net.
-rem
-rem 2002.11.19  Paul Garceau  mailto:pgarceau at attbi.com
-rem	* Fix a typo: Change COMPSPEC to COMSPEC.
-rem
-rem 2002.11.25  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove the SET CYGWIN since it doesn't matter any longer.
-rem
-rem 2003.02.03  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Win9x doesn't like ``EXISTS dir'' so change it to ``EXISTS dir\nul''.
-rem	Thanks to Nicolas Weber mailto:nicolasweber at gmx.de.
-rem
-rem 2003.03.06  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -backspacekey switch to rxvt startup.
-rem	* Move RXVT color setup to startrxvt label
-rem
-rem 2004.01.30  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -geometry parameter to work around an off by one issue with
-rem       the default values.
-rem	Thanks to Dave Schuyler mailto:parameter at users.sf.net
-rem
-rem 2004.03.28  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -norxvt or --norxvt switch argument.
-rem	Thanks to Keith Marshall mailto:Keith.Marshall at total.com.
-rem	* Add method to determine absolute path of msys.bat so that we no
-rem	longer need to change to the bin directory.  This allows msys.bat to be
-rem	called from any working directory.
-rem	Thanks to Kevin Mack  mailto:kevin.mack at us.cd-adapco.com
-rem
-rem 2005.07.06  Max TE Woodbury  mailto:mtew at users.sf.net
-rem     * Fixed WD check for command.com systems.
-rem     * Minimized intermediate CMD window to reduce startup flashyness.
-rem     * If rxvt.exe cannot be found, try sh.exe.
-rem
-rem 2005.12.06  Tuomo Latto  mailto:nonperson at users.sf.net
-rem     * Added a temporary workaround for getting MSYS shell to run on x64.
-rem
-rem 2005.12.07  Keith Marshall  mailto:keithmarshall at users.sf.net
-rem     * ``EXISTS %WD%\sh.exe'' should be ``EXISTS %WD%sh.exe''; corrected.
-rem     * Modified Tuomo's patch, to avoid trashing Window settings in Win32.
-rem
-rem 2005.12.08  Tuomo Latto  mailto:nonperson at users.sf.net
-rem     * Keith's modified patch fails on x64; start did funny things.
-rem     Reworked, for correct behaviour on both platforms.
-rem
+ at echo off
+rem Copyright (C):  2001, 2002, 2003, 2004, 2005  Earnie Boyd
+rem   mailto:earnie at users.sf.net
+rem This file is part of Minimal SYStem
+rem   http://www.mingw.org/msys.shtml
+rem
+rem File:	    msys.bat
+rem Revision:	    2.4
+rem Revision Date:  December 8th, 2005
+rem --- MODIFIED FOR GRASS Aug 2009: Quote path name variables ---
+rem ember to set the "Start in:" field of the shortcut.
+rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
+rem to represent.
+rem ember value of GOTO: is used to know recursion has happened.
+if "%1" == "GOTO:" goto %2
+if NOT "x%WD%" == "x" set WD=
+rem ember command.com only uses the first eight characters of the label.
+goto _WindowsNT
+rem ember that we only execute here if we are in command.com.
+:_Windows
+if "x%COMSPEC%" == "x" set COMSPEC=command.com
+start /min "%COMSPEC%" /e:4096 /c %0 GOTO: _Resume %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
+goto EOF
+rem ember that we execute here if we recursed.
+:_Resume
+for %%F in (1 2 3) do shift
+if NOT EXIST "%WD%msys-1.0.dll" set WD=.\bin\
+rem ember that we get here even in command.com.
+:_WindowsNT
+rem Hopefully a temporary workaround for getting MSYS shell to run on x64
+rem (WoW64 cmd prompt sets PROCESSOR_ARCHITECTURE to x86)
+if not "x%PROCESSOR_ARCHITECTURE%" == "xAMD64" goto _NotX64
+set COMSPEC=%WINDIR%\SysWOW64\cmd.exe
+"%COMSPEC%" /c %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
+goto EOF
+:_NotX64
+if NOT EXIST "%WD%msys-1.0.dll" set WD=%~dps0bin\
+rem echo %WD%
+rem if installed in a directory containing spaces prepare for a world of pain
+for /F %%i IN ('echo %WD%') DO @set PART1=%%i
+if NOT "%PART1%" == "%WD%" (
+   echo Path names containing spaces are not supported -- aborting.
+   pause
+   exit 1
+rem ember Set up option to use rxvt based on value of %1
+set MSYSCON=unknown
+if "x%1" == "x-norxvt" set MSYSCON=sh.exe
+if "x%1" == "x--norxvt" set MSYSCON=sh.exe
+if "x%1" == "x-rxvt" set MSYSCON=rxvt.exe
+if "x%1" == "x--rxvt" set MSYSCON=rxvt.exe
+if NOT "x%MSYSCON%" == "xunknown" shift
+if "x%MSYSCON%" == "xunknown" set MSYSCON=sh.exe
+rem the default is a MSYS (user), not a MINGW (developer) console
+if "x%MSYSTEM%" == "x" set MSYSTEM=MINGW32
+if "%1" == "MINGW32" set MSYSTEM=MINGW32
+if "%1" == "MSYS" set MSYSTEM=MSYS
+if NOT "x%DISPLAY%" == "x" set DISPLAY=
+if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
+if "x%MSYSCON%" == "xsh.exe" goto startsh
+:unknowncon
+echo %MSYSCON% is an unknown option for msys.bat.
+pause
+exit 1
+:notfound
+echo Cannot find the rxvt.exe or sh.exe binary -- aborting.
+pause
+exit 1
+rem If you don't want to use rxvt then rename the file rxvt.exe to something
+rem else.  Then sh.exe will be used instead.
+:startrxvt
+if NOT EXIST "%WD%rxvt.exe" goto startsh
+rem Setup the default colors for rxvt.
+if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
+if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
+if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=Black
+if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=White
+if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
+if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
+if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
+if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
+if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -i
+if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
+exit
+:startsh
+if NOT EXIST "%WD%sh.exe" goto notfound
+if "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -i
+if NOT "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -c "%*"
+exit
+:EOF
+rem ChangeLog:
+rem 2002.03.07  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Move the @echo off to the top.
+rem	* Change the binmode setting to nobinmode.
+rem     * Remove the angle brackets around email address to workaround MS
+rem	buggy command processor.
+rem
+rem 2002.03.12  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add filter logic to find rxvt.exe
+rem
+rem 2002.03.13  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Revert the nobinmode change.
+rem
+rem 2002.03.20  Earnie Boyd  mailto:earnie at users.sf.net
+rem     * Add logic for stating bash.
+rem
+rem 2002.04.11  Earnie Boyd  mailto;earnie at users.sf.net
+rem	* Add logic for setting MSYSTEM value based on parameter.
+rem
+rem 2002.04.15  Olivier Gautherot  mailto:olivier_gautherot at mentorg.com
+rem	* Reduce number test conditions for finding an executable.
+rem
+rem 2002.04.15  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Unset DISPLAY if set before starting shell.
+rem
+rem 2002.04.16  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove use of DEFINED in conditional statments for variables for
+rem	command.com support.
+rem	* Add check for nonexistance of USERNAME variable for Win9x support.
+rem
+rem 2002.04.17  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add foreground and background color defaults based on MSYSTEM value.
+rem
+rem 2002.04.22  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* More Win 9x changes.
+rem
+rem 2002.05.04  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove the SET of USERNAME and HOME.
+rem
+rem 2002.11.18  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add command.com detection and restart with a larger environment to
+rem	avoid errors on w9x.
+rem     Many thanks to Randy W. Sims mailto:RandyS at ThePierianSpring.org.
+rem	See Randy's response to "RE: [Mingw-msys] Installation on WindowsME"
+rem	from 11/06/2002 in the archives of mingw-msys at lists.sf.net.
+rem
+rem 2002.11.19  Paul Garceau  mailto:pgarceau at attbi.com
+rem	* Fix a typo: Change COMPSPEC to COMSPEC.
+rem
+rem 2002.11.25  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Remove the SET CYGWIN since it doesn't matter any longer.
+rem
+rem 2003.02.03  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Win9x doesn't like ``EXISTS dir'' so change it to ``EXISTS dir\nul''.
+rem	Thanks to Nicolas Weber mailto:nicolasweber at gmx.de.
+rem
+rem 2003.03.06  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -backspacekey switch to rxvt startup.
+rem	* Move RXVT color setup to startrxvt label
+rem
+rem 2004.01.30  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -geometry parameter to work around an off by one issue with
+rem       the default values.
+rem	Thanks to Dave Schuyler mailto:parameter at users.sf.net
+rem
+rem 2004.03.28  Earnie Boyd  mailto:earnie at users.sf.net
+rem	* Add -norxvt or --norxvt switch argument.
+rem	Thanks to Keith Marshall mailto:Keith.Marshall at total.com.
+rem	* Add method to determine absolute path of msys.bat so that we no
+rem	longer need to change to the bin directory.  This allows msys.bat to be
+rem	called from any working directory.
+rem	Thanks to Kevin Mack  mailto:kevin.mack at us.cd-adapco.com
+rem
+rem 2005.07.06  Max TE Woodbury  mailto:mtew at users.sf.net
+rem     * Fixed WD check for command.com systems.
+rem     * Minimized intermediate CMD window to reduce startup flashyness.
+rem     * If rxvt.exe cannot be found, try sh.exe.
+rem
+rem 2005.12.06  Tuomo Latto  mailto:nonperson at users.sf.net
+rem     * Added a temporary workaround for getting MSYS shell to run on x64.
+rem
+rem 2005.12.07  Keith Marshall  mailto:keithmarshall at users.sf.net
+rem     * ``EXISTS %WD%\sh.exe'' should be ``EXISTS %WD%sh.exe''; corrected.
+rem     * Modified Tuomo's patch, to avoid trashing Window settings in Win32.
+rem
+rem 2005.12.08  Tuomo Latto  mailto:nonperson at users.sf.net
+rem     * Keith's modified patch fails on x64; start did funny things.
+rem     Reworked, for correct behaviour on both platforms.
+rem
Property changes on: grass/trunk/mswindows/osgeo4w/msys.bat
Modified: svn:eol-style
   - native
   + CRLF
   + text/x-bat
Modified: grass/trunk/mswindows/osgeo4w/postinstall.bat
--- grass/trunk/mswindows/osgeo4w/postinstall.bat	2013-02-22 02:36:57 UTC (rev 55153)
+++ grass/trunk/mswindows/osgeo4w/postinstall.bat	2013-02-22 02:43:04 UTC (rev 55154)
@@ -1,15 +1,15 @@
-set ICON=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\etc\gui\icons\grass_osgeo.ico
-set ICON_CMD=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\etc\gui\icons\grass_cmd.ico
-set BATCH=%OSGEO4W_ROOT%\bin\@GRASS_EXECUTABLE at .bat
-textreplace -std -t "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .bat
-textreplace -std -t "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE@
-textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
-mkdir "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@"
-xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ GUI.lnk"   "%BATCH%" "-gui" \ "Launch GRASS GIS @VERSION@ with wxGUI" 1 "%ICON%"
-xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ Command Line.lnk"  "%BATCH%" "-text" \ "Launch GRASS GIS @VERSION@ in text mode" 1 "%ICON_CMD%"
-xxmklink "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk" "%BATCH%"  "-gui" \ "Launch GRASS GIS @VERSION@ with wxGUI" 1 "%ICON%"
-del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .bat.tmpl
-del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .tmpl
+set ICON=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\etc\gui\icons\grass_osgeo.ico
+set ICON_CMD=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\etc\gui\icons\grass_cmd.ico
+set BATCH=%OSGEO4W_ROOT%\bin\@GRASS_EXECUTABLE at .bat
+textreplace -std -t "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .bat
+textreplace -std -t "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE@
+textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
+mkdir "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@"
+xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ GUI.lnk"   "%BATCH%" "-gui" \ "Launch GRASS GIS @VERSION@ with wxGUI" 1 "%ICON%"
+xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ Command Line.lnk"  "%BATCH%" "-text" \ "Launch GRASS GIS @VERSION@ in text mode" 1 "%ICON_CMD%"
+xxmklink "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk" "%BATCH%"  "-gui" \ "Launch GRASS GIS @VERSION@ with wxGUI" 1 "%ICON%"
+del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .bat.tmpl
+del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE at .tmpl
Property changes on: grass/trunk/mswindows/osgeo4w/postinstall.bat
   + text/x-bat
   + CRLF
Modified: grass/trunk/mswindows/osgeo4w/preremove.bat
--- grass/trunk/mswindows/osgeo4w/preremove.bat	2013-02-22 02:36:57 UTC (rev 55153)
+++ grass/trunk/mswindows/osgeo4w/preremove.bat	2013-02-22 02:43:04 UTC (rev 55154)
@@ -1,12 +1,12 @@
-del "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ GUI.lnk"
-del "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ Command Line.lnk"
-rmdir "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@"
-del "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk"
-del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE@
-del "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
-del "%OSGEO4W_ROOT%"\apps\msys\bin\libintl3.dll
-del "%OSGEO4W_ROOT%"\apps\msys\bin\libiconv2.dll
-del "%OSGEO4W_ROOT%"\apps\msys\bin\regex2.dll
+del "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ GUI.lnk"
+del "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@\GRASS @VERSION@ Command Line.lnk"
+rmdir "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION@"
+del "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk"
+del "%OSGEO4W_ROOT%"\bin\@GRASS_EXECUTABLE@
+del "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
+del "%OSGEO4W_ROOT%"\apps\msys\bin\libintl3.dll
+del "%OSGEO4W_ROOT%"\apps\msys\bin\libiconv2.dll
+del "%OSGEO4W_ROOT%"\apps\msys\bin\regex2.dll
Property changes on: grass/trunk/mswindows/osgeo4w/preremove.bat
   + text/x-bat
   + CRLF
