[GRASS-SVN] r55181 - grass/branches/releasebranch_6_4/gui/wxpython/gui_core
Fri Feb 22 12:27:37 PST 2013
Author: annakrat
Date: 2013-02-22 12:27:35 -0800 (Fri, 22 Feb 2013)
New Revision: 55181
   grass/branches/releasebranch_6_4/gui/wxpython/gui_core/forms.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
wxGUI: fix #1893
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/forms.py	2013-02-22 19:00:00 UTC (rev 55180)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/forms.py	2013-02-22 20:27:35 UTC (rev 55181)
@@ -217,7 +217,6 @@
             if name == 'LayerSelect':
                 if map in cparams and not cparams[map]['layers']:
                     win.InsertLayers(vector = map)
-                    win.Reset()
                     cparams[map]['layers'] = win.GetItems()
             elif name == 'TableSelect':
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py	2013-02-22 19:00:00 UTC (rev 55180)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py	2013-02-22 20:27:35 UTC (rev 55181)
@@ -672,6 +672,8 @@
         # default value
         self.default = default
+        self.current = None
+        self.Bind(wx.EVT_COMBOBOX, self._selectionChanged)
         self.InsertLayers(vector = vector)
@@ -695,15 +697,24 @@
                 layers.insert(0, str(self.default))
             elif self.default not in layers:
                 layers.append(self.default)
         if len(layers) >= 1:
             self.SetItems(layers)
-    def Reset(self):
-        """!Reset value"""
+        self.Select()
+    def _selectionChanged(self, event):
+        """!Selection changed, store value."""
+        self.current = self.GetValue()
+        event.Skip()
+    def Select(self):
+        """!Select value (currently selected or default)"""
         items = self.GetItems()
         if items:
-            if self.default:
+            if self.current is not None and self.current in items:
+                self.SetStringSelection(self.current)
+            elif self.default:
                 self.SetStringSelection(str(self.default))
             else:
                 self.SetSelection(0)
