[GRASS-SVN] r54583 - grass-addons/grass7/raster/r.modis/r.modis.import
Tue Jan 8 08:53:44 PST 2013
Author: lucadelu
Date: 2013-01-08 08:53:43 -0800 (Tue, 08 Jan 2013)
New Revision: 54583
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
remove pdb for testing from r.modis.import.py
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2013-01-08 16:34:03 UTC (rev 54582)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2013-01-08 16:53:43 UTC (rev 54583)
@@ -303,9 +303,7 @@
 def analyze(pref, an, cod, parse, write):
     """ Analyze the MODIS data using QA if present """
     if pref.find('.tif') != -1:
-        pref = pref.rstrip('.tif')
-    import pdb
-    pdb.set_trace()
+        pref = pref.rstrip('.tif')
     prod = product().fromcode(cod)
     if not prod['spec_qa']:
         grass.warning(_("There is no QA layer, analysis and filtering will be skipped"))
@@ -319,7 +317,6 @@
         val.append(findfile(pref, v))
         if q:
             qa.append(findfile(pref, q))
-    pdb.set_trace()
     for n in range(len(val)):
         if val[n] == None:
             grass.warning(_("Some error occur"))
@@ -333,7 +330,6 @@
         elif string.find(cod, '11A1') >= 0 or string.find(cod, '11A2') >= 0 \
         or string.find(cod, '11B1') >= 0:
             mapc = "%s.2 = (%s * 0.0200) - 273.15" % (valname, valfull)
-        pdb.set_trace()
         grass.mapcalc(mapc)
         if an == 'noqa':
             #grass.run_command('g.remove', quiet=True, rast = valfull)
@@ -370,7 +366,6 @@
                     finalmap += "&& %s.2 <= 1.000" % valname
             finalmap += ",%s.2, null() )" % valname
             # grass.message("mapc finalmap: %s" % finalmap)
-            pdb.set_trace()
             grass.mapcalc(finalmap)
             grass.run_command('g.rename', quiet=True, overwrite=write,
                               rast=(valname, valname + '.orig'))
