[GRASS-SVN] r54606 - grass/trunk/scripts/r.in.wms
Sat Jan 12 08:13:46 PST 2013
Author: martinl
Date: 2013-01-12 08:13:46 -0800 (Sat, 12 Jan 2013)
New Revision: 54606
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.in.wms/wms_base.py
r.in.wms: fix 'region' option (patch by Stepan Turek)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2013-01-12 11:38:56 UTC (rev 54605)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2013-01-12 16:13:46 UTC (rev 54606)
@@ -177,10 +177,15 @@
 def GetRegionParams(opt_region):
     # set region
-    if opt_region:
-        if not grass.find_file(name = opt_region, element = 'windows', mapset = '.' )['name']:
-            grass.fatal(_("Region <%s> not found") % opt_region)
+    if opt_region:
+        reg_spl = opt_region.strip().split('@', 1)
+        reg_mapset = '.'
+        if len(reg_spl) > 1:
+            reg_mapset = reg_spl[1]
+        if not grass.find_file(name = reg_spl[0], element = 'windows', mapset = reg_mapset)['name']:
+             grass.fatal(_("Region <%s> not found") % opt_region)
     if opt_region:
         s = grass.read_command('g.region',
                                 quiet = True,
@@ -209,8 +214,13 @@
     else:
         from wms_base import GRASSImporter
         options['region'] = GetRegionParams(options['region'])
+        fetched_map = wms.GetMap(options, flags)
+        grass.message(_("Importing raster map into GRASS..."))
+        if not fetched_map:
+            grass.warning(_("Nothing to import.\nNo data has been downloaded from wms server."))
+            return
         importer = GRASSImporter(options['output'])
-        fetched_map = wms.GetMap(options, flags)
         importer.ImportMapIntoGRASS(fetched_map)
     return 0
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py	2013-01-12 11:38:56 UTC (rev 54605)
+++ grass/trunk/scripts/r.in.wms/wms_base.py	2013-01-12 16:13:46 UTC (rev 54606)
@@ -430,16 +430,10 @@
     def ImportMapIntoGRASS(self, raster):
         """!Import raster into GRASS.
-        grass.message(_("Importing raster map into GRASS..."))
-        if not raster:
-            grass.warning(_("Nothing to import.\nNo data has been downloaded from wms server."))
-            return
         # importing temp_map into GRASS
         if grass.run_command('r.in.gdal',
                              quiet = True,
+                             overwrite = True,
                              input = raster,
                              output = self.opt_output) != 0:
             grass.fatal(_('%s failed') % 'r.in.gdal')
@@ -480,6 +474,7 @@
         if grass.find_file(self.opt_output + '.red', element = 'cell', mapset = '.')['file']:
             if grass.run_command('r.composite',
                                  quiet = True,
+                                 overwrite = True,
                                  red = self.opt_output + '.red',
                                  green = self.opt_output +  '.green',
                                  blue = self.opt_output + '.blue',
