[GRASS-SVN] r54635 - grass/trunk/man
Tue Jan 15 03:03:21 PST 2013
Author: martinl
Date: 2013-01-15 03:03:21 -0800 (Tue, 15 Jan 2013)
New Revision: 54635
   grass/trunk/man/Makefile
   grass/trunk/man/build_class.py
   grass/trunk/man/build_full_index.py
   grass/trunk/man/build_html.py
   grass/trunk/man/build_index.py
   grass/trunk/man/build_topics.py
fix build_index scripts: report current year (GRASS_VERSION_DATE)
Modified: grass/trunk/man/Makefile
--- grass/trunk/man/Makefile	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/Makefile	2013-01-15 11:03:21 UTC (rev 54635)
@@ -43,11 +43,11 @@
 .PHONY: manpages
 define build
-GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" $(PYTHON) ./build_$(1).py $(2)
+GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" $(PYTHON) ./build_$(1).py $(2) $(GRASS_VERSION_DATE)
 endef
 define build_topics
-GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" $(PYTHON) ./build_topics.py $(HTMLDIR)
+GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" $(PYTHON) ./build_topics.py $(HTMLDIR) $(GRASS_VERSION_DATE)
 endef
 $(HTMLDIR)/topics.html: $(ALL_HTML)
Modified: grass/trunk/man/build_class.py
--- grass/trunk/man/build_class.py	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/build_class.py	2013-01-15 11:03:21 UTC (rev 54635)
@@ -16,6 +16,9 @@
 #for all module groups:
 cls = sys.argv[1]
 modclass = sys.argv[2]
+year = None
+if len(sys.argv) > 3:
+    year = sys.argv[3]
 filename = modclass + ".html"
@@ -37,7 +40,7 @@
     			      desc = desc))
 f.write("</table>\n")
-write_html_footer(f, "index.html")
+write_html_footer(f, "index.html", year)
 f.close()
 replace_file(filename)
Modified: grass/trunk/man/build_full_index.py
--- grass/trunk/man/build_full_index.py	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/build_full_index.py	2013-01-15 11:03:21 UTC (rev 54635)
@@ -9,6 +9,10 @@
 from build_html import *
+year = None
+if len(sys.argv) > 1:
+    year = sys.argv[1]
 os.chdir(html_dir)
 classes = []
@@ -49,7 +53,7 @@
 				      desc = desc))
 f.close()
Modified: grass/trunk/man/build_html.py
--- grass/trunk/man/build_html.py	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/build_html.py	2013-01-15 11:03:21 UTC (rev 54635)
@@ -7,6 +7,7 @@
 import sys
 import os
 import string
+from datetime import datetime
 ## TODO: better fix this in include/Make/Html.make, see bug RT #5361
@@ -162,7 +163,7 @@
 r"""<br><br>
 <hr>
 <p><a href="${index_url}">Help Index</a> | <a href="topics.html">Topics Index</a> | <a href="full_index.html">Full Index</a><br>
-© 2003-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a>, GRASS GIS ${grass_version} Reference Manual</p>
+© 2003-${year} <a href="http://grass.osgeo.org">GRASS Development Team</a>, GRASS GIS ${grass_version} Reference Manual</p>
 </body>
 </html>
@@ -329,9 +330,13 @@
     box_color = "#e1ecd0"
     f.write(overview_tmpl.substitute(box_color = box_color))
-def write_html_footer(f, index_url):
+def write_html_footer(f, index_url, year = None):
+    if year is None:
+        cur_year = default_year
+    else:
+        cur_year = year
     f.write(footer_tmpl.substitute(grass_version = grass_version,
-                                   index_url = index_url))
+                                   index_url = index_url, year = cur_year))
 def get_desc(cmd):
     f = open(cmd, 'r')
@@ -369,5 +374,6 @@
     grass_version = ver.split().strip()
 grass_mmver = '.'.join(ver.split('.')[0:2])
 macosx = "darwin" in os.environ['ARCH'].lower()
+default_year = "0000" # str(datetime.now().year)
Modified: grass/trunk/man/build_index.py
--- grass/trunk/man/build_index.py	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/build_index.py	2013-01-15 11:03:21 UTC (rev 54635)
@@ -14,10 +14,12 @@
 filename = "index.html"
 f = open(filename + ".tmp", 'wb')
+year = None
 write_html_header(f, "GRASS GIS %s Reference Manual" % grass_version, True)
 write_html_cmd_overview(f)
 f.close()
Modified: grass/trunk/man/build_topics.py
--- grass/trunk/man/build_topics.py	2013-01-14 23:08:19 UTC (rev 54634)
+++ grass/trunk/man/build_topics.py	2013-01-15 11:03:21 UTC (rev 54635)
@@ -10,8 +10,10 @@
 import string
 path = sys.argv[1]
+year = None
+if len(sys.argv) > 2:
+    year = sys.argv[2]
 keywords = {}
@@ -56,7 +58,7 @@
         keyfile.write(desc1_tmpl.substitute(cmd = mod, desc = desc,
                                             basename = mod.replace('.html','')))
     keyfile.write("</table>\n")
-    write_html_footer(keyfile, "index.html")
+    write_html_footer(keyfile, "index.html", year)
 topicsfile.write("</ul>\n")
-write_html_footer(topicsfile, "index.html")
+write_html_footer(topicsfile, "index.html", year)
 topicsfile.close()
