[GRASS-SVN] r54648 - grass/trunk/general/g.ppmtopng
Tue Jan 15 08:46:35 PST 2013
Author: martinl
Date: 2013-01-15 08:46:35 -0800 (Tue, 15 Jan 2013)
New Revision: 54648
   grass/trunk/general/g.ppmtopng/g.ppmtopng.html
   grass/trunk/general/g.ppmtopng/main.c
g.ppmtopng: update options
            update manual page
Modified: grass/trunk/general/g.ppmtopng/g.ppmtopng.html
--- grass/trunk/general/g.ppmtopng/g.ppmtopng.html	2013-01-15 16:11:54 UTC (rev 54647)
+++ grass/trunk/general/g.ppmtopng/g.ppmtopng.html	2013-01-15 16:46:35 UTC (rev 54648)
@@ -1,8 +1,11 @@
 <h2>DESCRIPTION</h2>
-<p>A utility to convert between PPM/PGM and PNG image formats.
+<p><em>g.ppmtopng</em> isn't meant for end users. It's a utility to
+convert between PPM/PGM and PNG image formats.
 <h2>AUTHOR</h2>
 Glynn Clements
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/general/g.ppmtopng/main.c
--- grass/trunk/general/g.ppmtopng/main.c	2013-01-15 16:11:54 UTC (rev 54647)
+++ grass/trunk/general/g.ppmtopng/main.c	2013-01-15 16:46:35 UTC (rev 54648)
@@ -31,10 +31,10 @@
     input = fopen(filename, "rb");
     if (!input)
-	G_fatal_error(_("unable to open input file %s"), filename);
+	G_fatal_error(_("Unable to open input file %s"), filename);
     if (fscanf(input, "P6 %d %d %d", &width, &height, &maxval) != 3)
-	G_fatal_error(_("invalid input file %s"), filename);
+	G_fatal_error(_("Invalid input file %s"), filename);
     fgetc(input);
@@ -67,18 +67,18 @@
     png_ptr = png_create_write_struct(PNG_LIBPNG_VER_STRING, &jbuf, NULL, NULL);
     if (!png_ptr)
-	G_fatal_error(_("unable to allocate PNG structure"));
+	G_fatal_error(_("Unable to allocate PNG structure"));
     info_ptr = png_create_info_struct(png_ptr);
     if (!info_ptr)
     if (setjmp(png_jmpbuf(png_ptr)))
-	G_fatal_error(_("error writing PNG file"));
+	G_fatal_error(_("Error writing PNG file"));
     output = fopen(filename, "wb");
     if (!output)
-	G_fatal_error(_("unable to open output file %s"), filename);
+	G_fatal_error(_("Unable to open output file %s"), filename);
     png_init_io(png_ptr, output);
@@ -115,23 +115,12 @@
     module = G_define_module();
     G_add_keyword(_("general"));
-    G_add_keyword(_("gui"));
-    module->description = "Converts between PPM/PGM and PNG image formats";
+    G_add_keyword(_("display"));
+    module->description = _("Converts between PPM/PGM and PNG image formats.");
-    opt.in = G_define_option();
-    opt.in->key = "input";
-    opt.in->type = TYPE_STRING;
-    opt.in->required = YES;
-    opt.in->multiple = YES;
-    opt.in->description = _("Name of input file");
-    opt.in->gisprompt = "old_file,file,input";
+    opt.in = G_define_standard_option(G_OPT_F_INPUT);
-    opt.out = G_define_option();
-    opt.out->key = "output";
-    opt.out->type = TYPE_STRING;
-    opt.out->required = YES;
-    opt.out->description = _("Name of output file");
-    opt.out->gisprompt = "new_file,file,output";
+    opt.out = G_define_standard_option(G_OPT_F_OUTPUT);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
