[GRASS-SVN] r54785 - grass/trunk/lib/python/pygrass/modules
Sun Jan 27 08:05:26 PST 2013
Author: zarch
Date: 2013-01-27 08:05:25 -0800 (Sun, 27 Jan 2013)
New Revision: 54785
   grass/trunk/lib/python/pygrass/modules/__init__.py
Move stdin, stdout, stderr from attributes of the Module class in to the inputs and outputs attributes
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py	2013-01-27 12:47:42 UTC (rev 54784)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py	2013-01-27 16:05:25 UTC (rev 54785)
@@ -50,23 +50,10 @@
     'integer': int,
     'float': float,
     'double': float,
+    'all': lambda x: x,
-def stdout2dict(stdout, sep='=', default=None, val_type=None, vsep=None):
-    """Return a dictionary where entries are separated
-    by newlines and the key and value are separated by `sep' (default: `=').
-    Use the grass.core.parse_key_val function
-    sep: key/value separator
-    default: default value to be used
-    val_type: value type (None for no cast)
-    vsep: vertical separator (default os.linesep)
-    return grass.script.core.parse_key_val(stdout, sep, default,
-                                           val_type, vsep)
 class ParameterError(Exception):
     pass
@@ -197,6 +184,8 @@
             else:
                 str_err = 'The Parameter <%s> does not accept multiple inputs'
                 raise TypeError(str_err % self.name)
+        elif self.typedesc == 'all':
+            self._value = value
         elif isinstance(value, self._type):
             if hasattr(self, 'values'):
                 if value in self.values:
@@ -435,8 +424,17 @@
         self.run_ = True
         self.finish_ = True
         self.stdin_ = None
+        self.stdin = None
         self.stdout_ = None
         self.stderr_ = None
+        diz = {'name': 'stdin', 'required': False,
+               'multiple': False, 'type': 'all',
+               'value': None}
+        self.inputs['stdin'] = Parameter(diz=diz)
+        diz['name'] = 'stdout'
+        self.outputs['stdout'] = Parameter(diz=diz)
+        diz['name'] = 'stderr'
+        self.outputs['stderr'] = Parameter(diz=diz)
         self.popen = None
         if args or kargs:
@@ -482,13 +480,13 @@
             self.run_ = kargs['run_']
             del(kargs['run_'])
         if 'stdin_' in kargs:
-            self.stdin_ = kargs['stdin_']
+            self.inputs['stdin'].value = kargs['stdin_']
             del(kargs['stdin_'])
         if 'stdout_' in kargs:
-            self.stdout_ = kargs['stdout_']
+            self.outputs['stdout'].value = kargs['stdout_']
             del(kargs['stdout_'])
         if 'stderr_' in kargs:
-            self.stderr_ = kargs['stderr_']
+            self.outputs['stdout'].value = kargs['stderr_']
             del(kargs['stderr_'])
         if 'finish_' in kargs:
             self.finish_ = kargs['finish_']
@@ -591,20 +589,26 @@
         return args
     def run(self, node=None):
+        if self.inputs['stdin'].value:
+            self.stdin = self.inputs['stdin'].value
+            self.stdin_ = subprocess.PIPE
+        if self.outputs['stdout'].value:
+            self.stdout_ = self.outputs['stdout'].value
+        if self.outputs['stderr'].value:
+            self.stderr_ = self.outputs['stderr'].value
         cmd = self.make_cmd()
-        if self.stdin_:
-            self.stdin = self.stdin_
-            self.stdin_ = subprocess.PIPE
-        self.popen = subprocess.Popen(cmd, stdin=self.stdin_,
+        self.popen = subprocess.Popen(cmd,
+                                      stdin=self.stdin_,
                                       stdout=self.stdout_,
                                       stderr=self.stderr_)
-        if self.stdin_:
-            self.stdout, self.stderr = self.popen.communicate(input=self.stdin)
-        else:
-            if self.finish_:
-                self.popen.wait()
-            self.stdout, self.stderr = self.popen.communicate()
+        if self.finish_:
+            self.popen.wait()
+        stdout, stderr = self.popen.communicate(input=self.stdin)
+        self.outputs['stdout'].value = stdout if stdout else ''
+        self.outputs['stderr'].value = stderr if stderr else ''
 _CMDS = list(grass.script.core.get_commands()[0])
 _CMDS.sort()
