[GRASS-SVN] r57075 - grass-addons/grass7/raster/r.wf
Sat Jul 13 06:54:41 PDT 2013
Author: neteler
Date: 2013-07-13 06:54:41 -0700 (Sat, 13 Jul 2013)
New Revision: 57075
Added:
   grass-addons/grass7/raster/r.wf/r.wf.py
Removed:
r.wf: fix extension
Deleted: grass-addons/grass7/raster/r.wf/r.wf
--- grass-addons/grass7/raster/r.wf/r.wf	2013-07-12 19:58:10 UTC (rev 57074)
+++ grass-addons/grass7/raster/r.wf/r.wf	2013-07-13 13:54:41 UTC (rev 57075)
@@ -1,136 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       r.wf.py
-# AUTHOR(S):    Massimo Di Stefano, Francesco Di Stefano, Margherita Di Leo
-# PURPOSE:      The module produces the Width Function of a basin. The Width
-#               Function W(x) gives the number of the cells in a basin at a
-#               flow distance x from the outlet (distance-area function)
-# COPYRIGHT:    (c) 2010 Massimo Di Stefano, Francesco Di Stefano, Margherita Di Leo
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-# REQUIRES:     Matplotlib
-#                 http://matplotlib.sourceforge.net/
-#%module
-#% description:
-#% keywords: raster
-#%end
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,raster,raster
-#% key_desc: name
-#% description: Distance to outlet map (from r.stream.distance)
-#% required: yes
-#%end
-#%option
-#% key: image
-#% type: string
-#% gisprompt: new_file,file,input
-#% key_desc: image
-#% description: output plot (png)
-#% required: yes
-#%END
-import sys
-import os
-import matplotlib #required by windows
-matplotlib.use('wx') #required by windows
-import matplotlib.pyplot as plt
-import grass.script as grass
-import numpy as np
-def main():
-    stats = grass.read_command('r.stats', input = options['map'], sep = 'space', nv = '*', nsteps = '255', flags = 'Anc').split('\n')[:-1]
-    # res = cellsize
-    res = float(grass.read_command('g.region', rast = options['map'], flags = 'm').strip().split('\n')[4].split('=')[1])
-    zn = np.zeros((len(stats),4),float)
-    kl = np.zeros((len(stats),2),float)
-    prc = np.zeros((9,2),float)
-    for i in range(len(stats)):
-        if i == 0:
-            zn[i,0],  zn[i,1] = map(float, stats[i].split(' '))
-            zn[i,1] = zn[i,1]
-            zn[i,2] = zn[i,1] * res
-        if i != 0:
-            zn[i,2] = zn[i,1] + zn[i-1,2]
-            zn[i,3] = zn[i,1] * (res**2)
-    totcell = sum(zn[:,1])
-    print "Tot. cells", totcell
-    totarea = totcell * (res**2)
-    print "Tot. area", totarea
-    maxdist = max(zn[:,0])
-    print "Max distance", maxdist
-        kl[i,0] = zn[i,0]
-        kl[i,1] = zn[i,2] / totcell
-    # quantiles
-    prc[0,0] , prc[0,1] = findint(kl,0.05) , 0.05
-    prc[1,0] , prc[1,1] = findint(kl,0.15) , 0.15
-    prc[2,0] , prc[2,1] = findint(kl,0.3) , 0.3
-    prc[3,0] , prc[3,1] = findint(kl,0.4) , 0.4
-    prc[4,0] , prc[4,1] = findint(kl,0.5) , 0.5
-    prc[5,0] , prc[5,1] = findint(kl,0.6) , 0.6
-    prc[6,0] , prc[6,1] = findint(kl,0.7) , 0.7
-    prc[7,0] , prc[7,1] = findint(kl,0.85) , 0.85
-    prc[8,0] , prc[8,1] = findint(kl,0.95) , 0.95
-    # plot
-    plotImage(zn[:,0], zn[:,3], options['image']+'_width_function.png','-','x','W(x)','Width Function')
-    print "==========================="
-    print "Whidth Function | quantiles"
-    print '%.0f' %findint(kl,0.05) , "|", 0.05
-    print '%.0f' %findint(kl,0.15) , "|", 0.15
-    print '%.0f' %findint(kl,0.3) , "|", 0.3
-    print '%.0f' %findint(kl,0.4) , "|", 0.4
-    print '%.0f' %findint(kl,0.5) , "|", 0.5
-    print '%.0f' %findint(kl,0.6) , "|", 0.6
-    print '%.0f' %findint(kl,0.7) , "|", 0.7
-    print '%.0f' %findint(kl,0.85) , "|", 0.85
-    print '%.0f' %findint(kl,0.95) , "|", 0.95
-    print '\n'
-    print 'Done!'
-def plotImage(x,y,image,type,xlabel,ylabel,title):
-    plt.plot(x, y, type)
-    plt.ylabel(ylabel)
-    plt.xlabel(xlabel)
-    plt.xlim( min(x), max(x) )
-    plt.ylim( min(y), max(y) )
-    plt.title(title)
-    plt.grid(True)
-    plt.savefig(image)
-    plt.close('all')
-def findint(kl,f):
-    Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
-    z1 , z2 , f1 , f2 = kl[float(Xf[0])][0] , kl[float(Xf[0]-1)][0] , kl[float(Xf[0])][1] , kl[float(Xf[0]-1)][1]
-    z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
-    return z
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
Copied: grass-addons/grass7/raster/r.wf/r.wf.py (from rev 57074, grass-addons/grass7/raster/r.wf/r.wf)
--- grass-addons/grass7/raster/r.wf/r.wf.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.wf/r.wf.py	2013-07-13 13:54:41 UTC (rev 57075)
@@ -0,0 +1,136 @@
+#!/usr/bin/env python
+# MODULE:       r.wf.py
+# AUTHOR(S):    Massimo Di Stefano, Francesco Di Stefano, Margherita Di Leo
+# PURPOSE:      The module produces the Width Function of a basin. The Width
+#               Function W(x) gives the number of the cells in a basin at a
+#               flow distance x from the outlet (distance-area function)
+# COPYRIGHT:    (c) 2010 Massimo Di Stefano, Francesco Di Stefano, Margherita Di Leo
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# REQUIRES:     Matplotlib
+#                 http://matplotlib.sourceforge.net/
+#%module
+#% description:
+#% keywords: raster
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,raster,raster
+#% key_desc: name
+#% description: Distance to outlet map (from r.stream.distance)
+#% required: yes
+#%end
+#%option
+#% key: image
+#% type: string
+#% gisprompt: new_file,file,input
+#% key_desc: image
+#% description: output plot (png)
+#% required: yes
+#%END
+import sys
+import os
+import matplotlib #required by windows
+matplotlib.use('wx') #required by windows
+import matplotlib.pyplot as plt
+import grass.script as grass
+import numpy as np
+def main():
+    stats = grass.read_command('r.stats', input = options['map'], sep = 'space', nv = '*', nsteps = '255', flags = 'Anc').split('\n')[:-1]
+    # res = cellsize
+    res = float(grass.read_command('g.region', rast = options['map'], flags = 'm').strip().split('\n')[4].split('=')[1])
+    zn = np.zeros((len(stats),4),float)
+    kl = np.zeros((len(stats),2),float)
+    prc = np.zeros((9,2),float)
+    for i in range(len(stats)):
+        if i == 0:
+            zn[i,0],  zn[i,1] = map(float, stats[i].split(' '))
+            zn[i,1] = zn[i,1]
+            zn[i,2] = zn[i,1] * res
+        if i != 0:
+            zn[i,2] = zn[i,1] + zn[i-1,2]
+            zn[i,3] = zn[i,1] * (res**2)
+    totcell = sum(zn[:,1])
+    print "Tot. cells", totcell
+    totarea = totcell * (res**2)
+    print "Tot. area", totarea
+    maxdist = max(zn[:,0])
+    print "Max distance", maxdist
+        kl[i,0] = zn[i,0]
+        kl[i,1] = zn[i,2] / totcell
+    # quantiles
+    prc[0,0] , prc[0,1] = findint(kl,0.05) , 0.05
+    prc[1,0] , prc[1,1] = findint(kl,0.15) , 0.15
+    prc[2,0] , prc[2,1] = findint(kl,0.3) , 0.3
+    prc[3,0] , prc[3,1] = findint(kl,0.4) , 0.4
+    prc[4,0] , prc[4,1] = findint(kl,0.5) , 0.5
+    prc[5,0] , prc[5,1] = findint(kl,0.6) , 0.6
+    prc[6,0] , prc[6,1] = findint(kl,0.7) , 0.7
+    prc[7,0] , prc[7,1] = findint(kl,0.85) , 0.85
+    prc[8,0] , prc[8,1] = findint(kl,0.95) , 0.95
+    # plot
+    plotImage(zn[:,0], zn[:,3], options['image']+'_width_function.png','-','x','W(x)','Width Function')
+    print "==========================="
+    print "Whidth Function | quantiles"
+    print '%.0f' %findint(kl,0.05) , "|", 0.05
+    print '%.0f' %findint(kl,0.15) , "|", 0.15
+    print '%.0f' %findint(kl,0.3) , "|", 0.3
+    print '%.0f' %findint(kl,0.4) , "|", 0.4
+    print '%.0f' %findint(kl,0.5) , "|", 0.5
+    print '%.0f' %findint(kl,0.6) , "|", 0.6
+    print '%.0f' %findint(kl,0.7) , "|", 0.7
+    print '%.0f' %findint(kl,0.85) , "|", 0.85
+    print '%.0f' %findint(kl,0.95) , "|", 0.95
+    print '\n'
+    print 'Done!'
+def plotImage(x,y,image,type,xlabel,ylabel,title):
+    plt.plot(x, y, type)
+    plt.ylabel(ylabel)
+    plt.xlabel(xlabel)
+    plt.xlim( min(x), max(x) )
+    plt.ylim( min(y), max(y) )
+    plt.title(title)
+    plt.grid(True)
+    plt.savefig(image)
+    plt.close('all')
+def findint(kl,f):
+    Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
+    z1 , z2 , f1 , f2 = kl[float(Xf[0])][0] , kl[float(Xf[0]-1)][0] , kl[float(Xf[0])][1] , kl[float(Xf[0]-1)][1]
+    z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
+    return z
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.wf/r.wf.py
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
