[GRASS-SVN] r57099 - in grass/trunk/gui/wxpython: core mapdisp vnet
Sun Jul 14 01:34:28 PDT 2013
Author: annakrat
Date: 2013-07-14 01:34:28 -0700 (Sun, 14 Jul 2013)
New Revision: 57099
Removed:
   grass/trunk/gui/wxpython/core/events.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
   grass/trunk/gui/wxpython/vnet/dialogs.py
   grass/trunk/gui/wxpython/vnet/vnet_core.py
wxGUI: remove gUpdateMap events and replace by signals
Deleted: grass/trunk/gui/wxpython/core/events.py
--- grass/trunk/gui/wxpython/core/events.py	2013-07-14 08:23:17 UTC (rev 57098)
+++ grass/trunk/gui/wxpython/core/events.py	2013-07-14 08:34:28 UTC (rev 57099)
@@ -1,45 +0,0 @@
- at package core.events
- at brief General events
-Put here only truly general events. Once you find that your event can be
-generated in more than one class, put your event here. Otherwise,
-leave it in your class file. Events are expected to be grass/gis related.
-General notice:
-Command events are propagated to parent windows. However, they do not propagate
-beyond dialogs. Events do not propagate at all.
-Command events works only with windows, not EvtHandlers, so for other objects
-than windows you need to have extra parameter - guiparent - which can be used
-for creating command events.
-\code
-mapEvent = gMapCreated(self._guiparent.GetId(), ...)
-wx.PostEvent(self._guiparent, mapEvent)
-\endcode
- at todo naming conventions for events
-(C) 2012 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Vaclav Petras <wenzeslaus gmail.com>
-from wx.lib.newevent import NewCommandEvent
-from wx.lib.newevent import NewEvent
-# Post it to BufferedWindow instance, which you want to update.
-# For relevant attributes for the event see
-# mapdisp.mapwindow.BufferedWindow UpdateMap method arguments.
-# If event does not contain attribute corresponding to argument with default
-# value, the default value will be used.
-# Arguments with no default value must be among event attributes
-# in order to be the event processed.
-# TODO implement to NVIZ GLWindow
-# TODO change direct calling of UpdateMap method to posting this event
-gUpdateMap, EVT_UPDATE_MAP = NewEvent()
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-07-14 08:23:17 UTC (rev 57098)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-07-14 08:34:28 UTC (rev 57099)
@@ -36,7 +36,6 @@
 from core.gcmd          import RunCommand, GException, GError, GMessage
 from core.debug         import Debug
 from core.settings      import UserSettings
-from core.events        import EVT_UPDATE_MAP
 from gui_core.mapwindow import MapWindow
 from core.utils         import GetGEventAttribsForHandler
@@ -100,7 +99,6 @@
         self.Bind(wx.EVT_PAINT,           self.OnPaint)
         self.Bind(wx.EVT_SIZE,            self.OnSize)
         self.Bind(wx.EVT_IDLE,            self.OnIdle)
-        self.Bind(EVT_UPDATE_MAP,         self.OnUpdateMap)
         self._bindMouseEvents()
@@ -605,17 +603,6 @@
     def IsAlwaysRenderEnabled(self):
         return self.alwaysRender
-    def OnUpdateMap(self, event):
-        """!Called when this class receives core.events.gUpdateMap event.
-        kwargs, missing_args = GetGEventAttribsForHandler(self.UpdateMap, event)
-        if missing_args:
-            Debug.msg (1, "Invalid call of EVT_UPDATE_MAP event.")
-            return
-        self.UpdateMap(**kwargs)
     def UpdateMap(self, render = True, renderVector = True):
         """!Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py	2013-07-14 08:23:17 UTC (rev 57098)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py	2013-07-14 08:34:28 UTC (rev 57099)
@@ -40,7 +40,6 @@
 from core             import globalvar, utils
 from core.gcmd        import RunCommand, GMessage
-from core.events      import gUpdateMap
 from dbmgr.base       import DbMgrBase
@@ -71,10 +70,9 @@
         wx.Dialog.__init__(self, parent, id, style=style, title = title, **kwargs)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
-        self.parent  = parent
-        self.mapDisp  = giface.GetMapDisplay()
-        self.mapWin = giface.GetMapWindow().GetMapWindow()
-        self._giface = giface
+        self.parent  = parent
+        self.mapWin = giface.GetMapWindow()
+        self.giface = giface
         # contains current analysis result (do not have to be last one, when history is browsed),
         # it is instance of VectMap class
@@ -292,8 +290,7 @@
             cmd = self.GetLayerStyle()
             self.tmp_result.AddRenderLayer(cmd)
-        up_map_evt = gUpdateMap(render = True, renderVector = True)
-        wx.PostEvent(self.mapWin, up_map_evt)
+        self.giface.updateMap.emit(render=True, renderVector=True)
     def _createOutputPage(self):
         """!Tab with output console"""
@@ -606,8 +603,7 @@
                                                         opacity = 1.0,    render = True,
                                                         pos = -1)
     def UseTurns(self):
         if self.useTurns.IsChecked():
@@ -849,8 +845,7 @@
         self._updateResultDbMgrPage()
         self._updateDbMgrData()
     def OnShowResult(self, event):
         """!Show/hide analysis result"""
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py	2013-07-14 08:23:17 UTC (rev 57098)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py	2013-07-14 08:34:28 UTC (rev 57099)
@@ -26,7 +26,6 @@
 from core             import utils
 from core.gconsole    import CmdThread, EVT_CMD_DONE, GConsole
 from gui_core.gselect import VectorDBInfo
@@ -42,8 +41,8 @@
         self.data = {}
         self.guiparent = guiparent
         self.goutput = GConsole(guiparent = guiparent)
@@ -60,7 +59,7 @@
         self.history = VNETHistory(self.guiparent, self.vnet_data, self.tmp_maps)
         self.analyses = VNETAnalyses(self.vnet_data, self.RunAnDone, self.goutput, self.tmp_maps)
-        self.snap_nodes = SnappingNodes(self.vnet_data, self.tmp_maps, self.mapWin)
+        self.snap_nodes = SnappingNodes(self.giface, self.vnet_data, self.tmp_maps, self.mapWin)
         self.ttbCreated = Signal('VNETManager.ttbCreated')
         self.analysisDone = Signal('VNETManager.analysisDone')
@@ -82,11 +81,9 @@
         self.vnet_data.CleanUp()
         if update:
         else:
+            self.giface.updateMap.emit(render=False, renderVector=False)
     def GetPointsManager(self):
         return self.vnet_data.GetPointsData()
@@ -157,8 +154,7 @@
         else:
             self.results["vect_map"].DeleteRenderLayer()
     def GetAnalysisProperties(self, analysis = None):
         return self.vnet_data.GetAnalysisProperties(analysis = analysis)
@@ -191,8 +187,7 @@
         cmd, cmd_colors = self.vnet_data.GetLayerStyle()
         self.results["vect_map"].AddRenderLayer(cmd, cmd_colors)
     def GetHistStep(self):
         return self.history.GetHistStep()
@@ -234,23 +229,19 @@
         self.vnet_data.GetPointsData().SetPointDrawSettings()
         if not self.results["vect_map"]  or \
            not self.tmp_maps.HasTmpVectMap(self.results["vect_map"].GetVectMapName()):
-            up_map_evt = gUpdateMap(render = False, renderVector = False)
         elif self.results["vect_map"].GetRenderLayer():
-            wx.PostEvent(self.mapWin, up_map_evt)#TODO optimization
+            #TODO optimization
         else:
     def PointsChanged(self, method, kwargs):
     def CreateTttb(self, params):
         outputMap = params["output"]
@@ -377,8 +368,7 @@
                 RunCommand(layerStyleVnetColors[0],
                         **layerStyleVnetColors[1])
         else:
 class VNETAnalyses:
     def __init__(self, data, onAnDone, goutput, tmp_maps):
@@ -418,8 +408,7 @@
         cmdPts = []
         for cat in cats:
             if  len(catPts[cat[0]]) < 1:#TODO
-                GMessage(parent = self.guiparent,
-                         message=_("Please choose '%s' and '%s' point.") % (cats[0][1], cats[1][1]))
+                GMessage(message=_("Please choose '%s' and '%s' point.") % (cats[0][1], cats[1][1]))
                 return False
             cmdPts.append(catPts[cat[0]][0])
@@ -993,8 +982,9 @@
 class SnappingNodes(wx.EvtHandler):
-    def __init__(self, data, tmp_maps, mapWin):
+    def __init__(self, giface, data, tmp_maps, mapWin):
         self.data = data
         self.tmp_maps = tmp_maps
         self.mapWin = mapWin
@@ -1019,8 +1009,7 @@
             if self.tmp_maps.HasTmpVectMap("vnet_snap_points"):
                 self.snapPts.DeleteRenderLayer()
             if self.snapData.has_key('cmdThread'):
                 self.snapData['cmdThread'].abort()
@@ -1050,8 +1039,7 @@
                 return -1
         elif self.snapPts.VectMapState() == 0:
-                dlg = wx.MessageDialog(parent = self.parent,
-                                       message = _("Temporary map '%s' was changed outside " +
+                dlg = wx.MessageDialog(message = _("Temporary map '%s' was changed outside " +
                                                     "vector analysis tool.\n"
                                                     "Do you really want to activate " +
                                                     "snapping and overwrite it? ") % \
@@ -1104,8 +1092,7 @@
         else:
             self.snapPts.AddRenderLayer()
             self.snapping.emit(evt = "computing_points_done")
@@ -1117,7 +1104,6 @@
             self.snapPts.SaveVectMapState()
