[GRASS-SVN] r57173 - grass-addons/grass7/vector/v.surf.mass
Tue Jul 16 06:32:32 PDT 2013
Author: mmetz
Date: 2013-07-16 06:32:32 -0700 (Tue, 16 Jul 2013)
New Revision: 57173
Added:
   grass-addons/grass7/vector/v.surf.mass/Makefile
   grass-addons/grass7/vector/v.surf.mass/globals.h
   grass-addons/grass7/vector/v.surf.mass/main.c
   grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html
add pycnophylactic interpolation module
Added: grass-addons/grass7/vector/v.surf.mass/Makefile
--- grass-addons/grass7/vector/v.surf.mass/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.surf.mass/Makefile	2013-07-16 13:32:32 UTC (rev 57173)
@@ -0,0 +1,13 @@
+MODULE_TOPDIR = ../..
+PGM = v.surf.mass
+LIBES = $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(SEGMENTLIB) $(MATHLIB)
+DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(SEGMENTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/grass7/vector/v.surf.mass/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/vector/v.surf.mass/globals.h
--- grass-addons/grass7/vector/v.surf.mass/globals.h	                        (rev 0)
+++ grass-addons/grass7/vector/v.surf.mass/globals.h	2013-07-16 13:32:32 UTC (rev 57173)
@@ -0,0 +1,26 @@
+#include <grass/raster.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/segment.h>
+#include <grass/glocale.h>
+/* lattice cell */
+struct lcell
+    int area; 		/* area id */
+    double interp;	/* interpolated value */
+    double adj;		/* adjustment */
+/* mass area */
+struct marea
+    int count;		/* number of cells in the area */
+    double value;	/* original value */
+    double interp;	/* cumulative interpolated values */
+    double adj;		/* cumulative adjustments */
+    double avgdiff;	/* difference between interpolated and original */
+    int count_neg;	/* count of negatives */
Property changes on: grass-addons/grass7/vector/v.surf.mass/globals.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/vector/v.surf.mass/main.c
--- grass-addons/grass7/vector/v.surf.mass/main.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.surf.mass/main.c	2013-07-16 13:32:32 UTC (rev 57173)
@@ -0,0 +1,533 @@
+ * MODULE:       v.surf.mass
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      Mass-preserving area interpolation
+ * COPYRIGHT:    (C) 2013 by by the GRASS Development Team
+ *               This program is free software under the
+ *               GNU General Public License (>=v2).
+ *               Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include "globals.h"
+#define SEGSIZE 64
+int main(int argc, char *argv[])
+    const char *mapset, *column;
+    int row, col, nrows, ncols, rrow, ccol, nrow, ncol;
+    SEGMENT out_seg;
+    int out_fd;
+    DCELL *drastbuf;
+    double seg_size;
+    int seg_mb, segments_in_memory;
+    int doit, iter, maxiter;
+    double threshold, maxadj;
+    int negative = 0, have_neg;
+    int layer;
+    int i, j, nareas;
+    struct marea *areas;
+    struct Map_info In;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    struct Cell_head window;
+    struct History history;
+    struct lcell thiscell;
+    double outside_val, value, interp, avgdiff;
+    struct GModule *module;
+    struct Option *in_opt, *out_opt, *dfield_opt, *col_opt,
+	*memory_opt, *iter_opt, *threshold_opt;
+	/* border condition */
+    struct Flag *withz_flag; /* allow negative */
+    int more, sqltype = 0, ctype = 0;
+    struct field_info *Fi;
+    dbDriver *driver;
+    dbColumn *dbcolumn;
+    dbCursor cursor;
+    dbTable *dbtable;
+    dbValue *dbvalue;
+    dbString dbstring;
+    char *buf = NULL;
+    size_t bufsize = 0;
+    /* Options declarations */
+    module = G_define_module();
+    G_add_keyword(_("vector"));
+    G_add_keyword(_("surface"));
+    G_add_keyword(_("interpolation"));
+    module->description =
+	_("Performs mass-preserving area interpolation.");
+    in_opt = G_define_standard_option(G_OPT_V_INPUT);
+    in_opt->label = _("Name of input vector point map");
+    dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+    col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+    col_opt->key = "column";
+    col_opt->required = NO;
+    col_opt->description =
+	_("Name of attribute column with values to approximate");
+    col_opt->guisection = _("Settings");
+    out_opt = G_define_standard_option(G_OPT_R_OUTPUT);
+    out_opt->required = YES;
+    iter_opt = G_define_option();
+    iter_opt->key = "iterations";
+    iter_opt->type = TYPE_INTEGER;
+    iter_opt->answer = "100";
+    iter_opt->required = NO;
+    threshold_opt = G_define_option();
+    threshold_opt->key = "threshold";
+    threshold_opt->type = TYPE_DOUBLE;
+    threshold_opt->answer = "1e-8";
+    threshold_opt->required = NO;
+    memory_opt = G_define_option();
+    memory_opt->key = "memory";
+    memory_opt->type = TYPE_INTEGER;
+    memory_opt->required = NO;
+    memory_opt->answer = "300";
+    memory_opt->description = _("Maximum memory to be used for raster output (in MB)");
+    withz_flag = G_define_flag();
+    withz_flag->key = 'z';
+    withz_flag->description = _("Use centroid z coordinates for approximation (3D vector maps only)");
+    withz_flag->guisection = _("Settings");
+    G_gisinit(argv[0]);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    maxiter = atoi(iter_opt->answer);
+    threshold = atof(threshold_opt->answer);
+    outside_val = .0;
+    /* Open input vector */
+    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
+    Vect_set_open_level(2);	/* WITH TOPOLOGY */
+    if (1 > Vect_open_old(&In, in_opt->answer, mapset))
+	G_fatal_error(_("Unable to open vector map <%s> at the topological level"),
+		      in_opt->answer);
+    nareas = Vect_get_num_areas(&In);
+    if (nareas == 0)
+	G_fatal_error(_("No areas in input vector <%s>"), in_opt->answer);
+    layer = Vect_get_field_number(&In, dfield_opt->answer);
+    column = col_opt->answer;
+    /* check availability of z values */
+    if (withz_flag->answer && !Vect_is_3d(&In)) {
+	G_fatal_error(_("Input vector is not 3D, can not use z coordinates"));
+    else if (!withz_flag->answer && (layer <= 0 || column == NULL))
+	G_fatal_error(_("Option '%s' with z values or '-%c' flag must be given"),
+                      col_opt->key, withz_flag->key);
+    if (withz_flag->answer)
+	layer = 0;
+    /* raster output */
+    out_fd = Rast_open_new(out_opt->answer, DCELL_TYPE);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    Rast_get_window(&window);
+    /* Alloc raster matrix */
+    seg_mb = atoi(memory_opt->answer);
+    if (seg_mb < 3)
+	G_fatal_error(_("Memory in MB must be >= 3"));
+    seg_size = sizeof(struct lcell);
+    seg_size = (seg_size * SEGSIZE * SEGSIZE) / (1 << 20);
+    segments_in_memory = seg_mb / seg_size + 0.5;
+    G_debug(1, "%d %dx%d segments held in memory", segments_in_memory, SEGSIZE, SEGSIZE);
+    if (segment_open(&out_seg, G_tempfile(),
+		     nrows, ncols, SEGSIZE, SEGSIZE,
+		     sizeof(struct lcell), segments_in_memory) != 1)
+	G_fatal_error(_("Can not create temporary file"));
+    /* initialize */
+    G_message(_("Initializing..."));
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    db_init_string(&dbstring);
+    areas = G_malloc(sizeof(struct marea) * (nareas + 1));
+    if (!areas)
+	G_fatal_error(_("Out of memory"));
+    G_message(_("Reading values..."));
+    /* read values from attribute table or z */
+    driver = NULL;
+    if (layer > 0) {
+	Fi = Vect_get_field(&In, layer);
+	if (Fi == NULL)
+	    G_fatal_error(_("Cannot read layer info"));
+	driver = db_start_driver_open_database(Fi->driver, Fi->database);
+	if (driver == NULL)
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+			  Fi->database, Fi->driver);
+	if (db_get_column(driver, Fi->table, column, &dbcolumn) != DB_OK) {
+	    db_close_database_shutdown_driver(driver);
+	    G_fatal_error(_("Unable to get column <%s>"), column);
+	sqltype = db_get_column_sqltype(dbcolumn);
+	ctype = db_sqltype_to_Ctype(sqltype);
+	if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
+	    G_fatal_error(_("Column <%s> must be numeric"), column);
+    i = 0;
+    areas[i].count = 0;
+    areas[i].value = outside_val;
+    areas[i].interp = 0;
+    areas[i].adj = 0;
+    areas[i].avgdiff = 0;
+    for (i = 1; i <= nareas; i++) {
+	areas[i].adj = 0;
+	if (driver) {
+	    if (Vect_get_area_cats(&In, i, Cats) == 0) {
+		int found = 0;
+		value = .0;
+		for (j = 0; j < Cats->n_cats; j++) {
+		    if (Cats->field[j] != layer)
+			continue;
+		    G_rasprintf(&buf, &bufsize, "SELECT %s FROM %s WHERE %s = %d",
+			        column, Fi->table, Fi->key, Cats->cat[j]);
+		    db_set_string(&dbstring, buf);
+		    if (db_open_select_cursor
+				    (driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+			db_close_database(driver);
+			db_shutdown_driver(driver);
+			G_fatal_error(_("Cannot select attributes for cat = %d"),
+			              Cats->cat[j]);
+		    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+			G_fatal_error(_("Unable to fetch data from table"));
+		    dbtable = db_get_cursor_table(&cursor);
+		    dbcolumn = db_get_table_column(dbtable, 0);
+		    dbvalue = db_get_column_value(dbcolumn);
+		    if (!db_test_value_isnull(dbvalue)) {
+			switch (ctype) {
+			case DB_C_TYPE_INT: {
+			    value += db_get_value_int(dbvalue);
+			    break;
+			case DB_C_TYPE_DOUBLE: {
+			    value += db_get_value_double(dbvalue);
+			    break;
+			found = 1;
+		    db_close_cursor(&cursor);
+		G_debug(1, "value from table: %g", value);
+		if (found)
+		    areas[i].value = value;
+	else {
+	    int centroid = 0;
+	    centroid = Vect_get_area_centroid(&In, i);
+	    if (centroid > 0) {
+		Vect_read_line(&In, Points, Cats, centroid);
+		areas[i].value = Points->z[0];
+    if (driver)
+    G_message(_("Find area id for each cell"));
+    for (row = 0; row < nrows; row++) {
+	double x, y;
+	G_percent(row, nrows, 2);
+	y = Rast_row_to_northing(row + 0.5, &window);
+	for (col = 0; col < ncols; col++) {
+	    x = Rast_col_to_easting(col + 0.5, &window);
+	    value = outside_val;
+	    thiscell.interp = value;
+	    thiscell.adj = 0.0;
+	    thiscell.area = Vect_find_area(&In, x, y);
+	    if (thiscell.area > 0) {
+		thiscell.interp = areas[thiscell.area].value;
+		areas[thiscell.area].count++;
+	    segment_put(&out_seg, &thiscell, row, col);
+    Vect_close(&In);
+    G_message(_("Adjust cell values"));
+	    segment_get(&out_seg, &thiscell, row, col);
+	    if (areas[thiscell.area].count > 0 &&
+	        !Rast_is_d_null_value(&thiscell.interp)) {
+		value = thiscell.interp / areas[thiscell.area].count;
+    G_message(_("Mass-preserving interpolation"));
+    doit = 1;
+    iter = 0;
+    while (doit) {
+	int l_row = -1, l_col = -1;
+	maxadj = 0;
+	iter++;
+	G_message(_("Pass %d"), iter);
+	    areas[i].interp = .0;
+	    areas[i].adj = .0;
+	    areas[i].avgdiff = .0;
+	/* Step 1 */
+		int count = 0;
+		value = .0;
+		interp = .0;
+		for (rrow = -1; rrow < 2; rrow++) {
+		    nrow = row + rrow;
+		    for (ccol = -1; ccol < 2; ccol++) {
+			ncol = col + ccol;
+			if (nrow >= 0 && nrow < nrows &&
+			    ncol >= 0 && ncol < ncols) {
+			    if (nrow == row && ncol == col)
+				continue;
+			    segment_get(&out_seg, &thiscell, nrow, ncol);
+			    if (!Rast_is_d_null_value(&thiscell.interp)) {
+				value += thiscell.interp;
+				count++;
+		if (count) {
+			value /= count;
+			value -= thiscell.interp;
+			/* relax */
+			/* value /= 8; */
+			thiscell.adj = value;
+			if (thiscell.area && !negative &&
+			    areas[thiscell.area].value == 0) {
+			    thiscell.adj = 0;
+			if (thiscell.area)
+			    areas[thiscell.area].adj += value;
+	/* Step 2 */
+	    if (areas[i].count)
+		areas[i].adj = -areas[i].adj / areas[i].count;
+	    areas[i].count_neg = 0;
+	/* Step 3 */
+		    interp = thiscell.interp + thiscell.adj + areas[thiscell.area].adj;
+		    if (negative || (!negative && interp >= 0)) {
+			thiscell.interp = interp;
+			value = thiscell.adj + areas[thiscell.area].adj;
+			if (maxadj < value * value) {
+			    maxadj = value * value;
+			    l_row = row;
+			    l_col = col;
+		    if (!negative && interp < 0)
+			have_neg = 1;
+		    if (thiscell.area) {
+			areas[thiscell.area].interp += thiscell.interp;
+	/* Step 4 */
+	    areas[i].avgdiff = (areas[i].value - areas[i].interp) /
+	                       areas[i].count;
+	    G_debug(3, "Area %d difference: %g", i, areas[i].value - areas[i].interp);
+	/* Step 5 */
+		    interp = thiscell.interp + areas[thiscell.area].avgdiff;
+		    if (!negative && interp < 0) {
+			areas[thiscell.area].count_neg++;
+		    avgdiff = areas[thiscell.area].avgdiff;
+		    interp = thiscell.interp + avgdiff;
+			if (areas[thiscell.area].count_neg > 0) {
+			    if (areas[thiscell.area].count > areas[thiscell.area].count_neg) {
+				avgdiff = avgdiff * areas[thiscell.area].count /
+					  (areas[thiscell.area].count - areas[thiscell.area].count_neg);
+	G_verbose_message(_("Largest squared adjustment: %g"), maxadj);
+	G_verbose_message(_("Largest row, col: %d %d"), l_row, l_col);
+	if (iter >= maxiter || maxadj < threshold)
+	    doit = 0;
+    /* write output */
+    G_message(_("Writing output <%s>"), out_opt->answer);
+    drastbuf = Rast_allocate_d_buf();
+	    drastbuf[col] = thiscell.interp;
+	Rast_put_d_row(out_fd, drastbuf);
+    Rast_close(out_fd);
+    Rast_short_history(out_opt->answer, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(out_opt->answer, &history);
+    G_done_msg(" ");
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/grass7/vector/v.surf.mass/main.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html
--- grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html	2013-07-16 13:32:32 UTC (rev 57173)
@@ -0,0 +1,52 @@
+<h2>DESCRIPTION</h2>
+<em>v.surf.mass</em> creates a raster surface from vector areas,
+preserving the value of the area attribute. For example, if the selected
+area attibute is the population count, the sum of all pixel values in a
+given area is equal to the area's population count.
+<h2>NOTES</h2>
+<p>The current region needs to be prepared with
+<a href="g.region.html">g.region</a>, choosing a resolution such that
+the smallest area is covered by at least four pixels. The current region
+should be completely inside the bounding box of the vector.
+<h2>EXAMPLE</h2>
+<h3>Population count interpolation using the North Carolina sample data</h3>
+<div class="code"><pre>
+# List of attributes for the vector censusblk_swwake
+v.info -c censusblk_swwake
+# Univariate statistics on area sizes,
+# only for areas with a population count > 0
+v.db.univar censusblk_swwake column=AREA perc=1 -e where="TOTAL_POP > 0"
+# The smallest area with some population is 413.8 square meters
+# and with a resolution of 10 meters covered by appr. four pixels
+# (depending on the shape of the area
+# adjust region
+g.region vect=censusblk_swwake res=10 -ap
+# mass-preserving area interpolation
+v.surf.mass input=censusblk_swwake output=census_blk_swwake column=TOTAL_POP iterations=200
+</pre></div>
+<h2>REFERENCES</h2>
+Tobler WR. 1979. Smooth Pycnophylactic Interpolation for Geographical
+Regions. Journal of the American Statistical Association, 74 (367):
+519-530.
+<h2>AUTHORS</h2>
+Markus Metz
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.surf.mass/v.surf.mass.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
