[GRASS-SVN] r57274 - in grass/trunk/db: db.columns db.copy db.select
Thu Jul 25 11:44:07 PDT 2013
Author: mmetz
Date: 2013-07-25 11:44:06 -0700 (Thu, 25 Jul 2013)
New Revision: 57274
   grass/trunk/db/db.columns/main.c
   grass/trunk/db/db.copy/main.c
   grass/trunk/db/db.select/main.c
db.*: add test if table exists where appropriate
Modified: grass/trunk/db/db.columns/main.c
--- grass/trunk/db/db.columns/main.c	2013-07-25 18:37:56 UTC (rev 57273)
+++ grass/trunk/db/db.columns/main.c	2013-07-25 18:44:06 UTC (rev 57274)
@@ -39,6 +39,12 @@
     parse_command_line(argc, argv);
+    if (!db_table_exists(parms.driver, parms.database, parms.table)) {
+	G_warning(_("Table <%s> not found in database <%s> using driver <%s>"),
+		   parms.table, parms.database, parms.driver);
+	exit(EXIT_FAILURE);
     driver = db_start_driver(parms.driver);
     if (driver == NULL)
 	G_fatal_error(_("Unable to start driver <%s>"), parms.driver);
Modified: grass/trunk/db/db.copy/main.c
--- grass/trunk/db/db.copy/main.c	2013-07-25 18:37:56 UTC (rev 57273)
+++ grass/trunk/db/db.copy/main.c	2013-07-25 18:44:06 UTC (rev 57274)
@@ -95,6 +95,14 @@
 	if (select->answer)
 	    G_fatal_error(_("Cannot combine 'from_table' and 'select' options"));
+	if (!db_table_exists(from_driver->answer, from_database->answer,
+	                     from_table->answer)) {
+		       from_table->answer, from_database->answer,
+		       from_driver->answer);
 	if (where->answer) {
 	    ret =
 		db_copy_table_where(from_driver->answer,
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c	2013-07-25 18:37:56 UTC (rev 57273)
+++ grass/trunk/db/db.select/main.c	2013-07-25 18:44:06 UTC (rev 57274)
@@ -48,6 +48,14 @@
+    if (parms.table) {
     /* read from file or stdin ? */
     if (parms.input && strcmp(parms.input, "-") != 0) {
 	fd = fopen(parms.input, "r");
@@ -92,7 +100,7 @@
-    if(parms.test_only)
+    if (parms.test_only)
 	G_verbose_message(_("Test %s."), stat ? _("failed") : _("succeeded"));
     db_close_database(driver);
