[GRASS-SVN] r57308 - in grass-addons/grass6: imagery imagery/i.spec.unmix raster raster/r.latlong
Sat Jul 27 13:44:34 PDT 2013
Author: neteler
Date: 2013-07-27 13:44:34 -0700 (Sat, 27 Jul 2013)
New Revision: 57308
Added:
   grass-addons/grass6/raster/r.latlong/
Removed:
   grass-addons/grass6/imagery/i.latlong/
   grass-addons/grass6/imagery/Makefile
   grass-addons/grass6/imagery/i.spec.unmix/main.c
   grass-addons/grass6/raster/Makefile
   grass-addons/grass6/raster/r.latlong/description.html
i.latlong: renamed to r.latlong for consistency
Modified: grass-addons/grass6/imagery/Makefile
--- grass-addons/grass6/imagery/Makefile	2013-07-27 20:37:46 UTC (rev 57307)
+++ grass-addons/grass6/imagery/Makefile	2013-07-27 20:44:34 UTC (rev 57308)
@@ -1,7 +1,6 @@
 MODULE_TOPDIR = ..
 SUBDIRS = \
-	i.latlong \
 	i.homography \
 	i.landsat.dehaze \
 	i.points.auto \
Modified: grass-addons/grass6/imagery/i.spec.unmix/main.c
--- grass-addons/grass6/imagery/i.spec.unmix/main.c	2013-07-27 20:37:46 UTC (rev 57307)
+++ grass-addons/grass6/imagery/i.spec.unmix/main.c	2013-07-27 20:44:34 UTC (rev 57308)
@@ -88,7 +88,7 @@
     module->keywords = _("imagery, spectral unmixing");
     module->description =
-	_("Perfroms Spectral mixture analysis of satellite/aerial images");
+	_("Performs Spectral mixture analysis of satellite/aerial images");
     parm.group = G_define_standard_option(G_OPT_I_GROUP);
@@ -115,7 +115,6 @@
     parm.iter->description = _("Name of raster map to hold number of iterations");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
Modified: grass-addons/grass6/raster/Makefile
--- grass-addons/grass6/raster/Makefile	2013-07-27 20:37:46 UTC (rev 57307)
+++ grass-addons/grass6/raster/Makefile	2013-07-27 20:44:34 UTC (rev 57308)
@@ -28,6 +28,7 @@
 	r.in.xyz.auto \
 	r.ipso \
 	r.isoregions \
+	r.latlong \
 	r.mcda.ahp \
 	r.mcda.electre\
 	r.mcda.fuzzy \
Modified: grass-addons/grass6/raster/r.latlong/description.html
--- grass-addons/grass6/imagery/i.latlong/description.html	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass-addons/grass6/raster/r.latlong/description.html	2013-07-27 20:44:34 UTC (rev 57308)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>i.latlong</em> creates a latitude (degree decimal) map, or longitude
+<em>r.latlong</em> creates a latitude (degree decimal) map, or longitude
 if the -l flag is used, from any map in any projection using PROJ.4 library.
 This is an input to <em>r.sun</em> and <em>i.evapo.potrad</em>.
@@ -15,7 +15,7 @@
 <div class="code"><pre>
 g.region rast=elevation -p
-i.latlong input=elevation output=latitude
+r.latlong input=elevation output=latitude
 </pre></div>
 <h2>SEE ALSO</h2>
