[GRASS-SVN] r57329 - grass/trunk/scripts/v.krige
Wed Jul 31 02:16:24 PDT 2013
Author: martinl
Date: 2013-07-31 02:16:24 -0700 (Wed, 31 Jul 2013)
New Revision: 57329
   grass/trunk/scripts/v.krige/v.krige.py
v.krige: import globalvar only if needed
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py	2013-07-30 16:02:02 UTC (rev 57328)
+++ grass/trunk/scripts/v.krige/v.krige.py	2013-07-31 09:16:24 UTC (rev 57329)
@@ -97,7 +97,6 @@
 if __name__ == "__main__":
     sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
-from core import globalvar
 if not os.environ.has_key("GISBASE"):
     print "You must be in GRASS GIS to run this program."
@@ -313,6 +312,7 @@
         argv = sys.argv[1:] # stripping first item, the full name of this script
         # wxGUI call
         if not os.getenv("GRASS_WXBUNDLED"):
+            from core import globalvar
             globalvar.CheckForWx()
         import vkrige as GUI
