[GRASS-SVN] r56564 - grass-addons/grass7/vector/v.net.turntable
Sun Jun 2 11:59:11 PDT 2013
Author: turek
Date: 2013-06-02 11:59:10 -0700 (Sun, 02 Jun 2013)
New Revision: 56564
   grass-addons/grass7/vector/v.net.turntable/main.c
   grass-addons/grass7/vector/v.net.turntable/ttb.c
v.net.turntable: indent
Modified: grass-addons/grass7/vector/v.net.turntable/main.c
--- grass-addons/grass7/vector/v.net.turntable/main.c	2013-06-02 17:14:10 UTC (rev 56563)
+++ grass-addons/grass7/vector/v.net.turntable/main.c	2013-06-02 18:59:10 UTC (rev 56564)
@@ -26,9 +26,9 @@
 #include <grass/glocale.h>
-IDEA: This module could be included into v.net module
-     (both modules do service for vector network analyses)???
+   IDEA: This module could be included into v.net module
+   (both modules do service for vector network analyses)???
 void close_db(void *p)
@@ -46,7 +46,8 @@
     struct field_info *fi;
     struct Option *opt_in_map, *opt_out_map;
-    struct Option *opt_ttb_name, *opt_afield, *opt_tfield, *opt_tucfield, *opt_type;
+    struct Option *opt_ttb_name, *opt_afield, *opt_tfield, *opt_tucfield,
+	*opt_type;
     char *database_name, *driver_name;
     int i_field_num, field_num, i_field, type;
@@ -121,29 +122,32 @@
     type = Vect_option_to_types(opt_type);
-    afield   = Vect_get_field_number(&InMap, opt_afield->answer);
-    tfield   = Vect_get_field_number(&InMap, opt_tfield->answer);
+    afield = Vect_get_field_number(&InMap, opt_afield->answer);
+    tfield = Vect_get_field_number(&InMap, opt_tfield->answer);
     tucfield = Vect_get_field_number(&InMap, opt_tucfield->answer);
-    if(!Vect_get_field (&InMap, afield))
-        G_fatal_error(_("Arc layer <%s> does not exists in map <%s>."),
-                         opt_afield->answer, opt_out_map->answer);
+    if (!Vect_get_field(&InMap, afield))
+	G_fatal_error(_("Arc layer <%s> does not exists in map <%s>."),
+		      opt_afield->answer, opt_out_map->answer);
-    if(Vect_get_field (&InMap, tfield))
-        G_warning(_("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tlayer data."),
-                     opt_tfield->answer, opt_out_map->answer);
+    if (Vect_get_field(&InMap, tfield))
+	G_warning(_
+		  ("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tlayer data."),
+		  opt_tfield->answer, opt_out_map->answer);
-    if(Vect_get_field (&InMap, tucfield))
-        G_warning(_("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tuclayer data."),
-                    opt_tucfield->answer, opt_out_map->answer);
+    if (Vect_get_field(&InMap, tucfield))
+	G_warning(_
+		  ("Layer <%s> already exists in map <%s>.\nIt will be overwritten by tuclayer data."),
+		  opt_tucfield->answer, opt_out_map->answer);
     ttb_name = NULL;
     if (!opt_ttb_name->answer) {
-    G_asprintf(&ttb_name, "%s_%s_turntable_%s",
-               opt_out_map->answer, opt_tfield->answer, opt_afield->answer);
+	G_asprintf(&ttb_name, "%s_%s_turntable_%s",
+		   opt_out_map->answer, opt_tfield->answer,
+		   opt_afield->answer);
     else {
-    ttb_name = G_store(opt_out_map->answer);
+	ttb_name = G_store(opt_out_map->answer);
     if (Vect_open_new(&OutMap, opt_out_map->answer, WITHOUT_Z) < 1) {
@@ -159,11 +163,11 @@
 	if (Vect_map_check_dblink(&InMap, i_field_num, NULL) == 0)
 	    continue;
-    if(field_num == -1)
-	   field_num = i_field_num;
+	if (field_num == -1)
+	    field_num = i_field_num;
-    if(field_num != tfield && field_num != tucfield)
-        Vect_copy_tables(&InMap, &OutMap, field_num);
+	if (field_num != tfield && field_num != tucfield)
+	    Vect_copy_tables(&InMap, &OutMap, field_num);
     if (field_num < 0) {
@@ -218,7 +222,7 @@
     Vect_close(&OutMap);
-    /*TODO why must be closed and opened again?*/
+    /*TODO why must be closed and opened again? */
     Vect_open_old(&OutMap, opt_out_map->answer, G_mapset());
     Vect_build(&OutMap);
Modified: grass-addons/grass7/vector/v.net.turntable/ttb.c
--- grass-addons/grass7/vector/v.net.turntable/ttb.c	2013-06-02 17:14:10 UTC (rev 56563)
+++ grass-addons/grass7/vector/v.net.turntable/ttb.c	2013-06-02 18:59:10 UTC (rev 56564)
@@ -14,7 +14,7 @@
     int n_points = Vect_get_num_line_points(points);
     if (n_points < 2)
-        return (-9.0);
+	return (-9.0);
     Vect_line_get_point(points, 0, &x_start, &y_start, &z);
     Vect_line_get_point(points, n_points - 1, &x_end, &y_end, &z);
@@ -23,9 +23,9 @@
     y = y_end - y_start;
     if (y == 0.0 && x == 0.0)
-        return (0.0);
+	return (0.0);
     else
-        return (atan2(y, x));
+	return (atan2(y, x));
 /*\brief Compute angle of two lines, which is defined by start and end point of the lines.
@@ -40,8 +40,8 @@
    \return -9.0 if line is defined by one point or has same start and end point
-double compute_lines_angle(struct line_pnts *line_pnts_from, int from_dir,
-                            struct line_pnts *line_pnts_to, int to_dir)
+double compute_lines_angle(struct line_pnts *line_pnts_from, int from_dir,
+			   struct line_pnts *line_pnts_to, int to_dir)
     double angle_from, angle_to;
     double angle;
@@ -55,78 +55,82 @@
     Vect_line_get_point(line_pnts_from, n_points_from - 1, &x2, &y2, &z);
     if (x1 == x2 && y1 == y2)
-         return -9.0;
+	return -9.0;
     Vect_line_get_point(line_pnts_to, 0, &x1, &y1, &z);
     Vect_line_get_point(line_pnts_to, n_points_to - 1, &x2, &y2, &z);
-    if (x1== x2 && y1 == y2)
-         return -9.0;
+    if (x1 == x2 && y1 == y2)
+	return -9.0;
     if (from_dir > 0)
-        Vect_line_reverse(line_pnts_from);
+	Vect_line_reverse(line_pnts_from);
     if (to_dir < 0)
-        Vect_line_reverse(line_pnts_to);
+	Vect_line_reverse(line_pnts_to);
     angle_from = compute_line_nodes_angle(line_pnts_from);
     angle_to = compute_line_nodes_angle(line_pnts_to);
     if (angle_from == -9.0)
-        angle = angle_from;
+	angle = angle_from;
     else if (angle_to == -9.0)
-        angle = angle_to;
+	angle = angle_to;
     else {
-        angle = angle_from - angle_to;
+	angle = angle_from - angle_to;
-        if (angle > M_PI)
-            angle = -2 * M_PI + angle;
+	if (angle > M_PI)
+	    angle = -2 * M_PI + angle;
-        if (angle < -M_PI)
-            angle = 2 * M_PI + angle;
+	if (angle < -M_PI)
+	    angle = 2 * M_PI + angle;
     /* reverse it back to original order */
     if (from_dir > 0)
     if (to_dir < 0)
     return angle;
 /*\brief Add line uturns into turntable.
-    Add two records into turntable because every line has two possible U-turns.
-int add_uturn(dbDriver * driver, char *ttb_name, int * next_ttb_cat, int ln_cat, int isec_start_cat, int isec_end_cat){
+   Add two records into turntable because every line has two possible U-turns.
+int add_uturn(dbDriver * driver, char *ttb_name, int *next_ttb_cat,
+	      int ln_cat, int isec_start_cat, int isec_end_cat)
     int i, isec;
     dbString db_buf;
     char buf[DB_SQL_MAX];
     db_init_string(&db_buf);
     ln_cat = abs(ln_cat);
     isec = isec_end_cat;
-    for(i = 0; i < 2; ++i) {
-        if(i == 1) {
-            ln_cat = -1 * ln_cat;
-            isec = isec_start_cat;
-        /* cat, ln_from, ln_to, cost, isec, angle */
-        sprintf(buf,
-                "INSERT INTO %s values ( %d, %d, %d, %f, %d, %f);",
-                ttb_name, (*next_ttb_cat), ln_cat, ln_cat * -1, 0.0,
-                isec, M_PI);
-        db_set_string(&db_buf, buf);
+    for (i = 0; i < 2; ++i) {
+	if (i == 1) {
+	    ln_cat = -1 * ln_cat;
+	    isec = isec_start_cat;
+	/* cat, ln_from, ln_to, cost, isec, angle */
+	sprintf(buf,
+		"INSERT INTO %s values ( %d, %d, %d, %f, %d, %f);",
+		ttb_name, (*next_ttb_cat), ln_cat, ln_cat * -1, 0.0,
+		isec, M_PI);
+	db_set_string(&db_buf, buf);
-        G_debug(3, "Adding u-turn into turntable:\n%s", db_get_string(&db_buf));
+	G_debug(3, "Adding u-turn into turntable:\n%s",
+		db_get_string(&db_buf));
-        if (db_execute_immediate(driver, &db_buf) != DB_OK){
-            db_free_string(&db_buf);
-            return -1;
-        ++(*next_ttb_cat);
+	if (db_execute_immediate(driver, &db_buf) != DB_OK) {
+	    db_free_string(&db_buf);
+	    return -1;
+	++(*next_ttb_cat);
@@ -135,11 +139,13 @@
 /*\brief Add turns for two lines into turntable.
-    Add two records into turntable because we can take the turn from two opposite directions.
-int add_turns(dbDriver * driver, char *ttb_name, int * next_ttb_cat,
-             int ln_i_cat, struct line_pnts *line_pnts_i, int ln_j_cat, struct line_pnts *line_pnts_j, int isec_cat){
+   Add two records into turntable because we can take the turn from two opposite directions.
+int add_turns(dbDriver * driver, char *ttb_name, int *next_ttb_cat,
+	      int ln_i_cat, struct line_pnts *line_pnts_i, int ln_j_cat,
+	      struct line_pnts *line_pnts_j, int isec_cat)
     int i, combinations;
     int ln_f, ln_t;
     dbString db_buf;
@@ -156,13 +162,11 @@
     /* compute angle if the lines angle is computed from ln_from_cat to ln_to_cat */
     if (ln_to_cat == ln_i_cat)
-        angle =
-        compute_lines_angle(line_pnts_j, ln_j_dir,
-                            line_pnts_i,  ln_i_dir);
+	angle =
+	    compute_lines_angle(line_pnts_j, ln_j_dir, line_pnts_i, ln_i_dir);
     else
-        angle =
-            compute_lines_angle(line_pnts_i, ln_i_dir,
-                                line_pnts_j, ln_j_dir);
+	angle =
+	    compute_lines_angle(line_pnts_i, ln_i_dir, line_pnts_j, ln_j_dir);
     ln_i_cat = abs(ln_i_cat);
     ln_j_cat = abs(ln_j_cat);
@@ -170,55 +174,54 @@
     ln_from_cat = ln_i_cat;
     ln_to_cat = ln_j_cat;
-    /*Find right lines nodes (positive or negative), will be connected by the turn.*/
+    /*Find right lines nodes (positive or negative), will be connected by the turn. */
     if (ln_j_dir < 0 && ln_i_dir < 0)
-        ln_to_cat *= -1;
+	ln_to_cat *= -1;
     else if (ln_j_dir > 0 && ln_i_dir > 0)
-        ln_from_cat *= -1;
+	ln_from_cat *= -1;
     else if (ln_j_dir < 0) {
-        ln_to_cat = ln_i_cat;
-        ln_from_cat = ln_j_cat;
+	ln_to_cat = ln_i_cat;
+	ln_from_cat = ln_j_cat;
     ln_f = ln_from_cat;
     ln_t = ln_to_cat;
-    /*Create first turn from i to j, then create turn in the opposite direction.*/
+    /*Create first turn from i to j, then create turn in the opposite direction. */
-        /* connect right nodes for opposite turn */
-        if(i == 1) {
-            ln_f = ln_to_cat * -1;
-            ln_t = ln_from_cat * -1;
+	/* connect right nodes for opposite turn */
+	if (i == 1) {
+	    ln_f = ln_to_cat * -1;
+	    ln_t = ln_from_cat * -1;
-        sprintf(buf,
-                "INSERT INTO %s values ( %d, %d, %d, %f, %d,",
-                ttb_name, (*next_ttb_cat), ln_f, ln_t, 0.0,
-                isec_cat);
+	sprintf(buf,
+		"INSERT INTO %s values ( %d, %d, %d, %f, %d,",
+		ttb_name, (*next_ttb_cat), ln_f, ln_t, 0.0, isec_cat);
-        if (angle == -9.0)
-            db_append_string(&db_buf, "NULL)");
-        else {
-            /* the angle is on the other side in opposite turn (e. g. left -> right)*/
-            if(i == 1)
-                angle *= -1;
+	if (angle == -9.0)
+	    db_append_string(&db_buf, "NULL)");
+	else {
+	    /* the angle is on the other side in opposite turn (e. g. left -> right) */
+	    if (i == 1)
+		angle *= -1;
-            sprintf(buf, "%f)", angle);
-            db_append_string(&db_buf, buf);
+	    sprintf(buf, "%f)", angle);
+	    db_append_string(&db_buf, buf);
-        G_debug(3, "Adding turn into turntable:\n%s", db_get_string(&db_buf));
+	G_debug(3, "Adding turn into turntable:\n%s", db_get_string(&db_buf));
-            return -1;
+	    return -1;
@@ -228,8 +231,8 @@
 void populate_turntable(dbDriver * driver, struct Map_info *InMap,
-                        struct Map_info *OutMap, char *ttb_name,
-                        int tfield, int tucfield, int a_field, int arc_type)
+			struct Map_info *OutMap, char *ttb_name,
+			int tfield, int tucfield, int a_field, int arc_type)
     struct ilist list;
@@ -237,8 +240,9 @@
     int *features_id;
     int n_node_lines, n_features, i_line, j_line, next_ttb_cat, i_ucat,
-        i_rew_lines, n_lines;
-    int n_nodes, pivot_node, outside_node, isec_start_ucat, isec_end_ucat, node1, node2;
+	i_rew_lines, n_lines;
+    int n_nodes, pivot_node, outside_node, isec_start_ucat, isec_end_ucat,
+	node1, node2;
     int ln_i_id, ln_j_id, ln_i_ucat, ln_j_ucat;
     int ltype_i, ltype_j;
@@ -254,10 +258,10 @@
     cats_j = Vect_new_cats_struct();
     n_lines = 0;
-    if(arc_type & GV_LINE)
-        n_lines += Vect_get_num_primitives(InMap, GV_LINE);
-    if(arc_type & GV_BOUNDARY)
-        n_lines += Vect_get_num_primitives(InMap, GV_BOUNDARY);
+    if (arc_type & GV_LINE)
+	n_lines += Vect_get_num_primitives(InMap, GV_LINE);
+    if (arc_type & GV_BOUNDARY)
+	n_lines += Vect_get_num_primitives(InMap, GV_BOUNDARY);
     /*Converts feature input map id into current id in output map.
        When the feature is rewritten, it's original state still exists
@@ -270,7 +274,7 @@
     n_features = Vect_get_num_lines(InMap);
     G_debug(3, "Found %d line features in <%s> vector map", n_features,
-            InMap->name);
+	    InMap->name);
     features_id = G_malloc(sizeof(int) * n_features);
     G_zero(features_id, sizeof(int) * n_features);
@@ -295,248 +299,256 @@
     /* Every node represents one intersection. */
     for (pivot_node = 1; pivot_node <= n_nodes; pivot_node++) {
-        n_node_lines = Vect_get_node_n_lines(InMap, pivot_node);
+	n_node_lines = Vect_get_node_n_lines(InMap, pivot_node);
-        G_debug(3, "Found %d lines connected to node with id %d",
-                n_node_lines, pivot_node);
+	G_debug(3, "Found %d lines connected to node with id %d",
+		n_node_lines, pivot_node);
-        /*Creates record in turntable for every possible turn
-           in intersection defined by node and lines which meets on the node.
+	/*Creates record in turntable for every possible turn
+	   in intersection defined by node and lines which meets on the node.
-           It also takes in account  U-turns. */
+	   It also takes in account  U-turns. */
-        for (i_line = 0; i_line < n_node_lines; i_line++) {
+	for (i_line = 0; i_line < n_node_lines; i_line++) {
-            ln_i_id = Vect_get_node_line(InMap, pivot_node, i_line);
+	    ln_i_id = Vect_get_node_line(InMap, pivot_node, i_line);
-            /*Line was not written into output map. */
-            if (features_id[abs(ln_i_id) - 1] < 1) {
-                ltype_i = Vect_read_line(InMap, line_pnts_i, cats_i, abs(ln_i_id));
-                /* If line does not belong into arc layer, skip it. */
-                if (Vect_field_cat_get(cats_i, a_field, &list) < 0 || !(ltype_i & arc_type))
-                    continue;
+	    /*Line was not written into output map. */
+	    if (features_id[abs(ln_i_id) - 1] < 1) {
+		ltype_i =
+		    Vect_read_line(InMap, line_pnts_i, cats_i, abs(ln_i_id));
-                /* Delete categories in tfield and tucfield if they are in input map defined. */
-                Vect_field_cat_del(cats_i, tfield, -1);
-                Vect_field_cat_del(cats_i, tucfield, -1);
+		/* If line does not belong into arc layer, skip it. */
+		if (Vect_field_cat_get(cats_i, a_field, &list) < 0 ||
+		    !(ltype_i & arc_type))
+		    continue;
-            /*If i line was already written into output map,
-               we need to take it's categories from the output map with categories
-               for tlayer and tuclayer. */
-            else {
+		/* Delete categories in tfield and tucfield if they are in input map defined. */
+		Vect_field_cat_del(cats_i, tfield, -1);
+		Vect_field_cat_del(cats_i, tucfield, -1);
-                ltype_i = Vect_read_line(OutMap, line_pnts_i, cats_i,
-                                         features_id[abs(ln_i_id) - 1]);
-                Vect_cat_get(cats_i, tucfield, &ln_i_ucat);
-                /* add line direction information to ucat */
-                if(ln_i_id < 0)
-                    ln_i_ucat *= -1;
+	    /*If i line was already written into output map,
+	       we need to take it's categories from the output map with categories
+	       for tlayer and tuclayer. */
+	    else {
+		ltype_i = Vect_read_line(OutMap, line_pnts_i, cats_i,
+					 features_id[abs(ln_i_id) - 1]);
+		Vect_cat_get(cats_i, tucfield, &ln_i_ucat);
-            for (j_line = i_line; j_line < n_node_lines; j_line++) {
+		/* add line direction information to ucat */
+		if (ln_i_id < 0)
+		    ln_i_ucat *= -1;
-                ln_j_id = Vect_get_node_line(InMap, pivot_node, j_line);
-                /* write line, which have not been written into new map yet. */
-                if (features_id[abs(ln_j_id) - 1] < 1) {
-                    /* Get line from input map. */
-                    ltype_j = Vect_read_line(InMap, line_pnts_j, cats_j, abs(ln_j_id));
+	    for (j_line = i_line; j_line < n_node_lines; j_line++) {
-                    if (Vect_field_cat_get(cats_j, a_field, &list) < 0 || !(ltype_i & arc_type))
-                        continue;
+		ln_j_id = Vect_get_node_line(InMap, pivot_node, j_line);
-                    Vect_field_cat_del(cats_j, tfield, -1);
-                    Vect_field_cat_del(cats_j, tucfield, -1);
+		/* write line, which have not been written into new map yet. */
+		if (features_id[abs(ln_j_id) - 1] < 1) {
+		    /* Get line from input map. */
+		    ltype_j =
+			Vect_read_line(InMap, line_pnts_j, cats_j,
+				       abs(ln_j_id));
-                    /* Write U-turn for every not yet written line. */
+		    if (Vect_field_cat_get(cats_j, a_field, &list) < 0 ||
+			continue;
-                    /* Assign unique category (assigned only when feature is written). */
-                    Vect_cat_set(cats_j, tucfield, i_ucat);
+		    Vect_field_cat_del(cats_j, tfield, -1);
+		    Vect_field_cat_del(cats_j, tucfield, -1);
-                    /* Assign turn category in turntable for the U-turn. */
-                    Vect_cat_set(cats_j, tfield, next_ttb_cat);
-                    Vect_cat_set(cats_j, tfield, next_ttb_cat + 1);
+		    /* Write U-turn for every not yet written line. */
-                    /* If i line and j line are different, we also need to insert a turn which is defined
-                       by these two edges, therefore we need to add new tfield category to j line, which is corresponding
-                       to the turn. */
-                    if (ln_j_id != ln_i_id) {
+		    /* Assign unique category (assigned only when feature is written). */
+		    Vect_cat_set(cats_j, tucfield, i_ucat);
-                    ln_j_ucat = i_ucat;
-                    if(ln_j_id < 0)
-                        ln_j_ucat *= -1;
+		    /* Assign turn category in turntable for the U-turn. */
+		    Vect_cat_set(cats_j, tfield, next_ttb_cat);
+		    Vect_cat_set(cats_j, tfield, next_ttb_cat + 1);
-                    /* We create two nodes in turntable for every line. These nodes have
-                       positive and negative values, with their absolute values identical.
+		    /* If i line and j line are different, we also need to insert a turn which is defined
+		       by these two edges, therefore we need to add new tfield category to j line, which is corresponding
+		       to the turn. */
+		    if (ln_j_id != ln_i_id) {
-                       Every node corresponds to opposite line direction. The positive node
-                       matches the direction of line. The negative node matches the opposite direction.
+		    ln_j_ucat = i_ucat;
-                       Imagine that you are standing on some road/line before a intersection wanting to cross it.
-                       If you are going to cross intersection, which is in line direction,
-                       you are standing on the POSITIVE NODE. If you would cross the intersection from any other line
-                       to the line, you would come into the NEGATIVE NODE.
+		    if (ln_j_id < 0)
+			ln_j_ucat *= -1;
-                       These two nodes are connected with U-turns, which are two for both direction.
-                       Every U-turn direction belongs to the another intersection. U-turn from the POSITIVE NODE
-                       to the NEGATIVE one belongs to the intersection we are going to cross. The other U-turn belongs
-                       to a intersection in opposite end of the line.
+		    /* We create two nodes in turntable for every line. These nodes have
+		       positive and negative values, with their absolute values identical.
-                       Turntable columns:
+		       Every node corresponds to opposite line direction. The positive node
+		       matches the direction of line. The negative node matches the opposite direction.
-                       cat - category in tfield (layer with turntable), which are hold by both ln_from and ln_to lines
-                       ln_from - unique category in tucfield assigned to the line
-                       ln_to - unique category in tucfield assigned to the line
-                       cost - cost for turn from ln_from to ln_to
-                       isec - point category in tucfield, which represents the intersection, where the turn belongs
-                       angle - in radians, see comments in compute_lines_angle function, it is PI for U-turns
+		       Imagine that you are standing on some road/line before a intersection wanting to cross it.
+		       If you are going to cross intersection, which is in line direction,
+		       you are standing on the POSITIVE NODE. If you would cross the intersection from any other line
+		       to the line, you would come into the NEGATIVE NODE.
-                    /* Find second node (outside_node) of the line. */
-                    Vect_get_line_nodes(InMap, abs(ln_j_id), &node1, &node2);
+		       These two nodes are connected with U-turns, which are two for both direction.
+		       Every U-turn direction belongs to the another intersection. U-turn from the POSITIVE NODE
+		       to the NEGATIVE one belongs to the intersection we are going to cross. The other U-turn belongs
+		       to a intersection in opposite end of the line.
-                    if (node1 == pivot_node)
-                        outside_node = node2;
-                    else
-                        outside_node = node1;
+		       Turntable columns:
-                    /* Decide intersection where U-turns belongs. */
-                    if (ln_j_id < 0) {
-                        isec_start_ucat = outside_node + n_lines;
-                        isec_end_ucat = pivot_node + n_lines;
-                    else {
-                        isec_start_ucat = pivot_node + n_lines;
-                        isec_end_ucat = outside_node + n_lines;
+		       cat - category in tfield (layer with turntable), which are hold by both ln_from and ln_to lines
+		       ln_from - unique category in tucfield assigned to the line
+		       ln_to - unique category in tucfield assigned to the line
+		       cost - cost for turn from ln_from to ln_to
+		       isec - point category in tucfield, which represents the intersection, where the turn belongs
+		       angle - in radians, see comments in compute_lines_angle function, it is PI for U-turns
-                    /* If i and j lines are identical, write these categories also into i line,
-                       otherwise they would be forgotten during rewriting of i line. */
-                    if (ln_j_id == ln_i_id) {
-                        Vect_cat_set(cats_i, tfield, next_ttb_cat);
-                        Vect_cat_set(cats_i, tfield, next_ttb_cat + 1);
-                        Vect_cat_set(cats_i, tucfield, i_ucat);
+		    /* Find second node (outside_node) of the line. */
+		    Vect_get_line_nodes(InMap, abs(ln_j_id), &node1, &node2);
-                    if (add_uturn(driver, ttb_name, &next_ttb_cat, abs(ln_j_ucat), isec_start_ucat, isec_end_ucat) < 0) {
-                        G_free(features_id);
+		    if (node1 == pivot_node)
+			outside_node = node2;
+		    else
+			outside_node = node1;
-                        Vect_destroy_line_struct(line_pnts_i);
-                        Vect_destroy_line_struct(line_pnts_j);
-                        Vect_destroy_cats_struct(cats_i);
-                        Vect_destroy_cats_struct(cats_j);
+		    /* Decide intersection where U-turns belongs. */
+		    if (ln_j_id < 0) {
+			isec_start_ucat = outside_node + n_lines;
+			isec_end_ucat = pivot_node + n_lines;
+		    else {
+			isec_start_ucat = pivot_node + n_lines;
+			isec_end_ucat = outside_node + n_lines;
-                        G_fatal_error(_("Unable to insert data into turntable."));
-                    /* increment unique category number for next line, which will be written */
-                    ++i_ucat;
+		    /* If i and j lines are identical, write these categories also into i line,
+		       otherwise they would be forgotten during rewriting of i line. */
+		    if (ln_j_id == ln_i_id) {
+			Vect_cat_set(cats_i, tfield, next_ttb_cat);
+			Vect_cat_set(cats_i, tfield, next_ttb_cat + 1);
+			Vect_cat_set(cats_i, tucfield, i_ucat);
-                       by these two edges, therefore we need to add new category to j line, which is corresponding
-                       to the turn.
-                    if (abs(ln_j_id) != abs(ln_i_id))
-                    /* Write new line into output map and save it's id to be possible to find it and edit it later
-                       (when we get to intersection, which is in other end of the line.) */
-                    features_id[abs(ln_j_id) - 1] =
-                        Vect_write_line(OutMap, ltype_j, line_pnts_j, cats_j);
+		    if (add_uturn
+			(driver, ttb_name, &next_ttb_cat, abs(ln_j_ucat),
+			 isec_start_ucat, isec_end_ucat) < 0) {
+			G_free(features_id);
-                    /* i, j lines  are equal, it consists only U-turn
-                       Absolute values are there because in case of the lines which have same start and end point, we do not want
-                       to create redundant lines between these points. This combination has been already done by uturn method.
-                    if (abs(ln_j_id) == abs(ln_i_id)) {
-                        /* remember unique category also for i line */
-                        ln_i_ucat = ln_j_ucat;
-                        continue;
-                /* skip if i, j lines are same (U-turn was already written) */
-                else if (abs(ln_j_id) == abs(ln_i_id))
-                    continue;
-                /* write new turn combination for already written i, j lines into output map */
-                else {
-                    /* Get modified cats from out map also for j line, which was already written and
-                       cats differ from the former cats in the line in input map. */
-                    ltype_j = Vect_read_line(OutMap, line_pnts_j, cats_j,
-                                             features_id[abs(ln_j_id) - 1]);
+			Vect_destroy_line_struct(line_pnts_i);
+			Vect_destroy_line_struct(line_pnts_j);
+			Vect_destroy_cats_struct(cats_i);
+			Vect_destroy_cats_struct(cats_j);
-                    /* set category in turntable for new turn, which will be written */
+			G_fatal_error(_
+				      ("Unable to insert data into turntable."));
-                    /* get already assigned unique category of the j line
-                       (used for ln_from_cat or ln_to_cat in turntable) */
-                    Vect_cat_get(cats_j, tucfield, &ln_j_ucat);
+		    /* increment unique category number for next line, which will be written */
+		    ++i_ucat;
-                    if(ln_j_id < 0)
-                        ln_j_ucat *= -1;
+		       by these two edges, therefore we need to add new category to j line, which is corresponding
+		       to the turn.
+		    if (abs(ln_j_id) != abs(ln_i_id)) {
-                    /* rewrite j line with added the new category for the turn */
-                    Vect_rewrite_line(OutMap, features_id[abs(ln_j_id) - 1],
-                                      ltype_j, line_pnts_j, cats_j);
+		    /* Write new line into output map and save it's id to be possible to find it and edit it later
+		       (when we get to intersection, which is in other end of the line.) */
+		    features_id[abs(ln_j_id) - 1] =
+			Vect_write_line(OutMap, ltype_j, line_pnts_j, cats_j);
-                    /* Because of rewriting, the id of j line was changed,
-                       therefore we have to update it in features_id. */
-                    features_id[abs(ln_j_id) - 1] = i_ucat + i_rew_lines;
+		    /* i, j lines  are equal, it consists only U-turn
+		       Absolute values are there because in case of the lines which have same start and end point, we do not want
+		       to create redundant lines between these points. This combination has been already done by uturn method.
+		    if (abs(ln_j_id) == abs(ln_i_id)) {
+			/* remember unique category also for i line */
+			ln_i_ucat = ln_j_ucat;
+			continue;
+		/* skip if i, j lines are same (U-turn was already written) */
+		else if (abs(ln_j_id) == abs(ln_i_id))
+		    continue;
+		/* write new turn combination for already written i, j lines into output map */
+		else {
+		    /* Get modified cats from out map also for j line, which was already written and
+		       cats differ from the former cats in the line in input map. */
+		    ltype_j = Vect_read_line(OutMap, line_pnts_j, cats_j,
+					     features_id[abs(ln_j_id) - 1]);
-                    /* increment number of rewritten elements,  for more see initialization of the variable */
-                    ++i_rew_lines;
+		    /* set category in turntable for new turn, which will be written */
-                /* We have to decide which nodes will be connected, which depends on lines directions.
-                   Line direction information is stored in ln_i_id/ln_j_id variables. It the variable is
-                   negative, the line goes into the intersection. If it is positive the line goes from the
-                   intersection. */
+		    /* get already assigned unique category of the j line
+		       (used for ln_from_cat or ln_to_cat in turntable) */
+		    Vect_cat_get(cats_j, tucfield, &ln_j_ucat);
+		    if (ln_j_id < 0)
+			ln_j_ucat *= -1;
-                /* The turn belongs to same intersection regardless the direction. Only exception are the U-turns. */
-                isec_start_ucat = isec_end_ucat = pivot_node + n_lines;
+		    /* rewrite j line with added the new category for the turn */
+		    Vect_rewrite_line(OutMap, features_id[abs(ln_j_id) - 1],
+				      ltype_j, line_pnts_j, cats_j);
+		    /* Because of rewriting, the id of j line was changed,
+		       therefore we have to update it in features_id. */
+		    features_id[abs(ln_j_id) - 1] = i_ucat + i_rew_lines;
-                if (add_turns(driver, ttb_name, &next_ttb_cat,
-                             ln_i_ucat,line_pnts_i, ln_j_ucat, line_pnts_j, isec_start_ucat) < 0) {
+		    /* increment number of rewritten elements,  for more see initialization of the variable */
+		    ++i_rew_lines;
+		/* We have to decide which nodes will be connected, which depends on lines directions.
+		   Line direction information is stored in ln_i_id/ln_j_id variables. It the variable is
+		   negative, the line goes into the intersection. If it is positive the line goes from the
+		   intersection. */
+		/* The turn belongs to same intersection regardless the direction. Only exception are the U-turns. */
+		isec_start_ucat = isec_end_ucat = pivot_node + n_lines;
-            /* rewrite i line */
-            Vect_rewrite_line(OutMap, features_id[abs(ln_i_id) - 1],
-                              ltype_i, line_pnts_i, cats_i);
-            features_id[abs(ln_i_id) - 1] = i_ucat + i_rew_lines;
-            i_rew_lines += 1;
+		if (add_turns(driver, ttb_name, &next_ttb_cat,
+			      ln_i_ucat, line_pnts_i, ln_j_ucat, line_pnts_j,
+			      isec_start_ucat) < 0) {
+		    G_fatal_error(_("Unable to insert data into turntable."));
+	    /* rewrite i line */
+	    Vect_rewrite_line(OutMap, features_id[abs(ln_i_id) - 1],
+			      ltype_i, line_pnts_i, cats_i);
+	    features_id[abs(ln_i_id) - 1] = i_ucat + i_rew_lines;
+	    i_rew_lines += 1;
     /* Create point on every node. */
@@ -544,30 +556,31 @@
-        Vect_get_node_coor(InMap, pivot_node, &x, &y, &z);
+	Vect_get_node_coor(InMap, pivot_node, &x, &y, &z);
-        Vect_reset_line(line_pnts_i);
-        Vect_append_point(line_pnts_i, x, y, z);
+	Vect_reset_line(line_pnts_i);
+	Vect_append_point(line_pnts_i, x, y, z);
-        Vect_reset_cats(cats_i);
+	Vect_reset_cats(cats_i);
-        Vect_write_line(OutMap, GV_POINT, line_pnts_i, cats_i);
-        i_ucat++;
+	Vect_write_line(OutMap, GV_POINT, line_pnts_i, cats_i);
+	i_ucat++;
     /* copy rest of features, to output map */
     while ((ltype_i = Vect_read_next_line(InMap, line_pnts_i, cats_i)) > 0) {
-        /* line features in alayer are already in output map*/
-        if (ltype_i == arc_type && Vect_field_cat_get(cats_i, a_field, &list) != -1)
-            continue;
+	/* line features in alayer are already in output map */
+	if (ltype_i == arc_type &&
+	    Vect_field_cat_get(cats_i, a_field, &list) != -1)
+	    continue;
@@ -580,4 +593,4 @@
     db_commit_transaction(driver);
     return;
\ No newline at end of file
