[GRASS-SVN] r56605 - grass-addons/grass7/vector/v.net.alloc2
Wed Jun 5 04:34:59 PDT 2013
Author: turek
Date: 2013-06-05 04:34:59 -0700 (Wed, 05 Jun 2013)
New Revision: 56605
Added:
   grass-addons/grass7/vector/v.net.alloc2/v.net.alloc2.html
Removed:
   grass-addons/grass7/vector/v.net.alloc2/v.net.alloc.html
v.net.alloc2: set right manual name
Deleted: grass-addons/grass7/vector/v.net.alloc2/v.net.alloc.html
--- grass-addons/grass7/vector/v.net.alloc2/v.net.alloc.html	2013-06-05 11:27:34 UTC (rev 56604)
+++ grass-addons/grass7/vector/v.net.alloc2/v.net.alloc.html	2013-06-05 11:34:59 UTC (rev 56605)
@@ -1,157 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.net.alloc</em> allocates subnets for nearest centers
-(direction from center). center nodes must be opened (costs >= 0).
-Costs of center nodes are used in the calculation.
-<p>
-Costs may be either line lengths, or attributes saved in a
-database table. These attribute values are taken as costs of whole
-segments, not as costs to traverse a length unit (e.g. meter) of the
-segment. For example, if the speed limit is 100 km / h, the cost to
-traverse a 10 km long road segment must be calculated as
-<br>
-length / speed = 10 km / (100 km/h) = 0.1 h.
-<br>
-Supported are cost assignments for both arcs and nodes,
-and also different costs for both directions of a vector line.
-For areas, costs will be calculated along boundary lines.
-<p>
-The input vector needs to be prepared with <em>v.net operation=connect</em>
-in order to connect points representing center nodes to the network.
-<p>There is the option of applying the <a href="v.net.turntable.html">v.net.turntable</a> module on the input layer first. This means the input layer is expanded by turntable with costs of every possible turn on any possible node (intersection) in both directions. Note that after this expansion it is required to apply the -t flag. This flag enables additional parameters tlayer and tuclayer that are otherwise ignored.
-<h2>NOTES</h2>
-Nodes and arcs can be closed using cost = -1.
-<p>
-Center nodes can also be assigned to vector nodes using
-<em><a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a></em>.
-<h2>EXAMPLES</h2>
-<p>1. Subnetwork allocation using distance:
-<p><img src="v_net_alloc.png" alt="v.net.alloc example using distance" border="1">
-<br>
-<p>2. Subnetwork allocation using traveling time:
-<p><img src="v_net_alloc_time.png" alt="v.net.alloc example using time" border="1">
-<br>
-<p>Example 1: <em>Calculating subnets for 3 center nodes using distances</em>
-<div class="code"><pre>
-# Spearfish
-# center nodes:
-echo "591235.5|4926306.62|1
-596591.8|4917042.5|2
-602722.9|4923544.2|3" | v.in.ascii in=- out=centernodes
-g.copy vect=roads,myroads
-# connect points to network
-v.net myroads points=centernodes out=myroads_net op=connect thresh=200
-# allocate, specifying range of center cats (easier to catch all):
-v.net.alloc myroads_net out=myroads_net_alloc ccats=1-100000 nlayer=2
-# report categories
-v.category myroads_net_alloc option=report
-</pre></div>
-To display the result, run for example:
-# show result
-g.region vect=myroads_net
-d.mon x0
-d.vect myroads_net layer=1
-# the result has to be selected by category number of the relevant node:
-d.vect myroads_net_alloc cat=1 col=red layer=1
-d.vect myroads_net_alloc cat=2 col=green layer=1
-d.vect myroads_net_alloc cat=3 col=yellow layer=1
-# center nodes
-d.vect myroads_net col=red icon=basic/triangle fcol=green size=12 layer=2
-</pre></div>
-<p>Example 2: <em>Calculating subnets for 3 center nodes using traveling time</em><br>
-# Spearfish
-# center nodes:
-# create lines map connecting points to network
-v.net myroads points=centernodes out=myroads_net op=connect thresh=500 alayer=1 nlayer=2
-# set up costs
-# create unique categories for each road in layer 3
-v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line
-# add new table for layer 3
-v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision"
-# copy road type to layer 3
-v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label
-# upload road length in miles
-v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles
-# set speed limits in miles / hour
-v.db.update myroads_net_time layer=3 col=speed val="5.0"
-v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'"
-v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'"
-v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'"
-v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'"
-v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'"
-# define traveling costs as traveling time in minutes:
-# set forward costs
-v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
-# set backward costs
-v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
-# subnetwork allocation with fastest paths
-v.net.alloc in=myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost out=myroads_net_alloc_time ccats=1-3
-</pre></div>
-# show result
-d.mon x0
-d.vect myroads_net type=line layer=1
-d.vect myroads_net_alloc_time cat=1 col=red layer=1
-d.vect myroads_net_alloc_time cat=2 col=green layer=1
-d.vect myroads_net_alloc_time cat=3 col=yellow layer=1
-# center nodes
-d.vect myroads_net_time col=red icon=basic/triangle fcol=green size=12 type=point layer=2
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="d.path.html">d.path</a></em>,
-<em><a href="v.net.html">v.net</a></em>,
-<em><a href="v.net.iso.html">v.net.iso</a></em>,
-<em><a href="v.net.path.html">v.net.path</a></em>,
-<em><a href="v.net.steiner.html">v.net.steiner</a></em>,
-<em><a href="v.net.salesman.html">v.net.salesman</a></em>
-<h2>AUTHOR</h2>
-Radim Blazek, ITC-Irst, Trento, Italy<br>
-Documentation: Markus Neteler, Markus Metz
-<p><i>Last changed: $Date: 2013-05-23 21:59:24 +0200 (Thu, 23 May 2013) $</i>
Copied: grass-addons/grass7/vector/v.net.alloc2/v.net.alloc2.html (from rev 56603, grass-addons/grass7/vector/v.net.alloc2/v.net.alloc.html)
--- grass-addons/grass7/vector/v.net.alloc2/v.net.alloc2.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.net.alloc2/v.net.alloc2.html	2013-06-05 11:34:59 UTC (rev 56605)
@@ -0,0 +1,157 @@
+<h2>DESCRIPTION</h2>
+<em>v.net.alloc</em> allocates subnets for nearest centers
+(direction from center). center nodes must be opened (costs >= 0).
+Costs of center nodes are used in the calculation.
+<p>
+Costs may be either line lengths, or attributes saved in a
+database table. These attribute values are taken as costs of whole
+segments, not as costs to traverse a length unit (e.g. meter) of the
+segment. For example, if the speed limit is 100 km / h, the cost to
+traverse a 10 km long road segment must be calculated as
+<br>
+length / speed = 10 km / (100 km/h) = 0.1 h.
+<br>
+Supported are cost assignments for both arcs and nodes,
+and also different costs for both directions of a vector line.
+For areas, costs will be calculated along boundary lines.
+<p>
+The input vector needs to be prepared with <em>v.net operation=connect</em>
+in order to connect points representing center nodes to the network.
+<p>There is the option of applying the <a href="v.net.turntable.html">v.net.turntable</a> module on the input layer first. This means the input layer is expanded by turntable with costs of every possible turn on any possible node (intersection) in both directions. Note that after this expansion it is required to apply the -t flag. This flag enables additional parameters tlayer and tuclayer that are otherwise ignored.
+<h2>NOTES</h2>
+Nodes and arcs can be closed using cost = -1.
+<p>
+Center nodes can also be assigned to vector nodes using
+<em><a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a></em>.
+<h2>EXAMPLES</h2>
+<p>1. Subnetwork allocation using distance:
+<p><img src="v_net_alloc.png" alt="v.net.alloc example using distance" border="1">
+<br>
+<p>2. Subnetwork allocation using traveling time:
+<p><img src="v_net_alloc_time.png" alt="v.net.alloc example using time" border="1">
+<br>
+<p>Example 1: <em>Calculating subnets for 3 center nodes using distances</em>
+<div class="code"><pre>
+# Spearfish
+# center nodes:
+echo "591235.5|4926306.62|1
+596591.8|4917042.5|2
+602722.9|4923544.2|3" | v.in.ascii in=- out=centernodes
+g.copy vect=roads,myroads
+# connect points to network
+v.net myroads points=centernodes out=myroads_net op=connect thresh=200
+# allocate, specifying range of center cats (easier to catch all):
+v.net.alloc myroads_net out=myroads_net_alloc ccats=1-100000 nlayer=2
+# report categories
+v.category myroads_net_alloc option=report
+</pre></div>
+To display the result, run for example:
+# show result
+g.region vect=myroads_net
+d.mon x0
+d.vect myroads_net layer=1
+# the result has to be selected by category number of the relevant node:
+d.vect myroads_net_alloc cat=1 col=red layer=1
+d.vect myroads_net_alloc cat=2 col=green layer=1
+d.vect myroads_net_alloc cat=3 col=yellow layer=1
+# center nodes
+d.vect myroads_net col=red icon=basic/triangle fcol=green size=12 layer=2
+</pre></div>
+<p>Example 2: <em>Calculating subnets for 3 center nodes using traveling time</em><br>
+# Spearfish
+# center nodes:
+# create lines map connecting points to network
+v.net myroads points=centernodes out=myroads_net op=connect thresh=500 alayer=1 nlayer=2
+# set up costs
+# create unique categories for each road in layer 3
+v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line
+# add new table for layer 3
+v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision"
+# copy road type to layer 3
+v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label
+# upload road length in miles
+v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles
+# set speed limits in miles / hour
+v.db.update myroads_net_time layer=3 col=speed val="5.0"
+v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'"
+v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'"
+v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'"
+v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'"
+v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'"
+# define traveling costs as traveling time in minutes:
+# set forward costs
+v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
+# set backward costs
+v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
+# subnetwork allocation with fastest paths
+v.net.alloc in=myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost out=myroads_net_alloc_time ccats=1-3
+</pre></div>
+# show result
+d.mon x0
+d.vect myroads_net type=line layer=1
+d.vect myroads_net_alloc_time cat=1 col=red layer=1
+d.vect myroads_net_alloc_time cat=2 col=green layer=1
+d.vect myroads_net_alloc_time cat=3 col=yellow layer=1
+# center nodes
+d.vect myroads_net_time col=red icon=basic/triangle fcol=green size=12 type=point layer=2
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="d.path.html">d.path</a></em>,
+<em><a href="v.net.html">v.net</a></em>,
+<em><a href="v.net.iso.html">v.net.iso</a></em>,
+<em><a href="v.net.path.html">v.net.path</a></em>,
+<em><a href="v.net.steiner.html">v.net.steiner</a></em>,
+<em><a href="v.net.salesman.html">v.net.salesman</a></em>
+<h2>AUTHOR</h2>
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+Documentation: Markus Neteler, Markus Metz
+<p><i>Last changed: $Date: 2013-05-23 21:59:24 +0200 (Thu, 23 May 2013) $</i>
