[GRASS-SVN] r56654 - grass/branches/releasebranch_6_4
Sun Jun 9 09:25:37 PDT 2013
Author: neteler
Date: 2013-06-09 09:25:37 -0700 (Sun, 09 Jun 2013)
New Revision: 56654
   grass/branches/releasebranch_6_4/config.guess
   grass/branches/releasebranch_6_4/config.sub
   grass/branches/releasebranch_6_4/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_6_4/config.guess
--- grass/branches/releasebranch_6_4/config.guess	2013-06-09 13:23:39 UTC (rev 56653)
+++ grass/branches/releasebranch_6_4/config.guess	2013-06-09 16:25:37 UTC (rev 56654)
@@ -1,14 +1,12 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-#   2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-#   2011, 2012 Free Software Foundation, Inc.
+#   Copyright 1992-2013 Free Software Foundation, Inc.
-timestamp='2012-09-25'
+timestamp='2013-05-16'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
+# the Free Software Foundation; either version 3 of the License, or
 # (at your option) any later version.
 # This program is distributed in the hope that it will be useful, but
@@ -22,20 +20,18 @@
 # As a special exception to the GNU General Public License, if you
 # distribute this file as part of a program that contains a
 # configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner.  Please send patches (context
-# diff format) to <config-patches at gnu.org> and include a ChangeLog
-# entry.
+# the same distribution terms that you use for the rest of that
+# program.  This Exception is an additional permission under section 7
+# of the GNU General Public License, version 3 ("GPLv3").
-# This script attempts to guess a canonical system name similar to
-# config.sub.  If it succeeds, it prints the system name on stdout, and
-# exits with 0.  Otherwise, it exits with 1.
+# Originally written by Per Bothner.
 # You can get the latest version of this script from:
 # http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
+# Please send patches with a ChangeLog entry to config-patches at gnu.org.
 me=`echo "$0" | sed -e 's,.*/,,'`
 usage="\
@@ -54,9 +50,7 @@
 GNU config.guess ($timestamp)
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
-Free Software Foundation, Inc.
+Copyright 1992-2013 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -138,6 +132,27 @@
 UNAME_SYSTEM=`(uname -s) 2>/dev/null`  || UNAME_SYSTEM=unknown
 UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
+case "${UNAME_SYSTEM}" in
+Linux|GNU|GNU/*)
+	# If the system lacks a compiler, then just pick glibc.
+	# We could probably try harder.
+	LIBC=gnu
+	eval $set_cc_for_build
+	cat <<-EOF > $dummy.c
+	#include <features.h>
+	#if defined(__UCLIBC__)
+	LIBC=uclibc
+	#elif defined(__dietlibc__)
+	LIBC=dietlibc
+	#else
+	LIBC=gnu
+	#endif
+	EOF
+	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
+esac
 # Note: order is significant - the case branches are not exclusive.
 case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
@@ -859,21 +874,21 @@
 	exit ;;
     *:GNU:*:*)
 	# the GNU system
-	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
+	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-${LIBC}`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
 	exit ;;
     *:GNU/*:*:*)
 	# other systems with GNU libc and userland
-	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
+	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-${LIBC}
 	exit ;;
     i*86:Minix:*:*)
 	echo ${UNAME_MACHINE}-pc-minix
 	exit ;;
     aarch64:Linux:*:*)
-	echo ${UNAME_MACHINE}-unknown-linux-gnu
+	echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
 	exit ;;
     aarch64_be:Linux:*:*)
 	UNAME_MACHINE=aarch64_be
 	exit ;;
     alpha:Linux:*:*)
 	case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
@@ -886,59 +901,54 @@
 	  EV68*) UNAME_MACHINE=alphaev68 ;;
 	esac
 	objdump --private-headers /bin/sh | grep -q ld.so.1
-	if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
-	echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+	if test "$?" = 0 ; then LIBC="gnulibc1" ; fi
 	exit ;;
+    arc:Linux:*:* | arceb:Linux:*:*)
+	exit ;;
     arm*:Linux:*:*)
 	if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
 	    | grep -q __ARM_EABI__
 	then
 	else
 	    if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
 		| grep -q __ARM_PCS_VFP
 	    then
-		echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabi
 	    else
-		echo ${UNAME_MACHINE}-unknown-linux-gnueabihf
+		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabihf
 	    fi
 	fi
 	exit ;;
     avr32*:Linux:*:*)
 	exit ;;
     cris:Linux:*:*)
-	echo ${UNAME_MACHINE}-axis-linux-gnu
+	echo ${UNAME_MACHINE}-axis-linux-${LIBC}
 	exit ;;
     crisv32:Linux:*:*)
 	exit ;;
     frv:Linux:*:*)
 	exit ;;
     hexagon:Linux:*:*)
 	exit ;;
     i*86:Linux:*:*)
-	LIBC=gnu
-	eval $set_cc_for_build
-	sed 's/^	//' << EOF >$dummy.c
-	#ifdef __dietlibc__
-	LIBC=dietlibc
-	#endif
-EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
-	echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+	echo ${UNAME_MACHINE}-pc-linux-${LIBC}
 	exit ;;
     ia64:Linux:*:*)
 	exit ;;
     m32r*:Linux:*:*)
 	exit ;;
     m68*:Linux:*:*)
 	exit ;;
     mips:Linux:*:* | mips64:Linux:*:*)
@@ -957,54 +967,63 @@
 	#endif
 EOF
 	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
-	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-${LIBC}"; exit; }
+    or1k:Linux:*:*)
+	exit ;;
     or32:Linux:*:*)
 	exit ;;
     padre:Linux:*:*)
-	echo sparc-unknown-linux-gnu
+	echo sparc-unknown-linux-${LIBC}
 	exit ;;
     parisc64:Linux:*:* | hppa64:Linux:*:*)
-	echo hppa64-unknown-linux-gnu
+	echo hppa64-unknown-linux-${LIBC}
 	exit ;;
     parisc:Linux:*:* | hppa:Linux:*:*)
 	# Look for CPU level
 	case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
-	  PA7*) echo hppa1.1-unknown-linux-gnu ;;
-	  PA8*) echo hppa2.0-unknown-linux-gnu ;;
-	  *)    echo hppa-unknown-linux-gnu ;;
+	  PA7*) echo hppa1.1-unknown-linux-${LIBC} ;;
+	  PA8*) echo hppa2.0-unknown-linux-${LIBC} ;;
+	  *)    echo hppa-unknown-linux-${LIBC} ;;
 	esac
 	exit ;;
     ppc64:Linux:*:*)
-	echo powerpc64-unknown-linux-gnu
+	echo powerpc64-unknown-linux-${LIBC}
 	exit ;;
     ppc:Linux:*:*)
-	echo powerpc-unknown-linux-gnu
+	echo powerpc-unknown-linux-${LIBC}
 	exit ;;
+    ppc64le:Linux:*:*)
+	echo powerpc64le-unknown-linux-${LIBC}
+	exit ;;
+    ppcle:Linux:*:*)
+	echo powerpcle-unknown-linux-${LIBC}
+	exit ;;
     s390:Linux:*:* | s390x:Linux:*:*)
-	echo ${UNAME_MACHINE}-ibm-linux
+	echo ${UNAME_MACHINE}-ibm-linux-${LIBC}
 	exit ;;
     sh64*:Linux:*:*)
 	exit ;;
     sh*:Linux:*:*)
 	exit ;;
     sparc:Linux:*:* | sparc64:Linux:*:*)
 	exit ;;
     tile*:Linux:*:*)
 	exit ;;
     vax:Linux:*:*)
-	echo ${UNAME_MACHINE}-dec-linux-gnu
+	echo ${UNAME_MACHINE}-dec-linux-${LIBC}
 	exit ;;
     x86_64:Linux:*:*)
 	exit ;;
     xtensa*:Linux:*:*)
 	exit ;;
     i*86:DYNIX/ptx:4*:*)
 	# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
@@ -1237,19 +1256,21 @@
 	exit ;;
     *:Darwin:*:*)
 	UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
-	case $UNAME_PROCESSOR in
-	    i386)
-		if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
-		  if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
-		      (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
-		      grep IS_64BIT_ARCH >/dev/null
-		  then
-		      UNAME_PROCESSOR="x86_64"
-		  fi
-		fi ;;
-	    unknown) UNAME_PROCESSOR=powerpc ;;
-	esac
+	if test "$UNAME_PROCESSOR" = unknown ; then
+	    UNAME_PROCESSOR=powerpc
+	fi
+	if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+	    if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
+		(CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+		grep IS_64BIT_ARCH >/dev/null
+	    then
+		case $UNAME_PROCESSOR in
+		    i386) UNAME_PROCESSOR=x86_64 ;;
+		    powerpc) UNAME_PROCESSOR=powerpc64 ;;
+		esac
+	    fi
+	fi
 	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
 	exit ;;
     *:procnto*:*:* | *:QNX:[0123456789]*:*)
Modified: grass/branches/releasebranch_6_4/config.sub
--- grass/branches/releasebranch_6_4/config.sub	2013-06-09 13:23:39 UTC (rev 56653)
+++ grass/branches/releasebranch_6_4/config.sub	2013-06-09 16:25:37 UTC (rev 56654)
@@ -1,24 +1,18 @@
 #! /bin/sh
 # Configuration validation subroutine script.
-timestamp='2012-10-10'
+timestamp='2013-04-24'
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine.  It does not imply ALL GNU software can.
-# This file is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
+# This file is free software; you can redistribute it and/or modify it
+# under the terms of the GNU General Public License as published by
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+# General Public License for more details.
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, see <http://www.gnu.org/licenses/>.
@@ -26,11 +20,12 @@
-# Please send patches to <config-patches at gnu.org>.  Submit a context
-# diff and a properly formatted GNU ChangeLog entry.
 # Configuration subroutine to validate and canonicalize a configuration type.
 # Supply the specified configuration type as an argument.
@@ -73,9 +68,7 @@
 version="\
 GNU config.sub ($timestamp)
@@ -259,7 +252,7 @@
 	| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
 	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
 	| am33_2.0 \
-	| arc \
+	| arc | arceb \
 	| arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv7[arm] \
 	| avr | avr32 \
 	| be32 | be64 \
@@ -293,16 +286,17 @@
 	| mipsisa64r2 | mipsisa64r2el \
 	| mipsisa64sb1 | mipsisa64sb1el \
 	| mipsisa64sr71k | mipsisa64sr71kel \
+	| mipsr5900 | mipsr5900el \
 	| mipstx39 | mipstx39el \
 	| mn10200 | mn10300 \
 	| moxie \
 	| mt \
 	| msp430 \
 	| nds32 | nds32le | nds32be \
-	| nios | nios2 \
+	| nios | nios2 | nios2eb | nios2el \
 	| ns16k | ns32k \
 	| open8 \
-	| or32 \
+	| or1k | or32 \
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
 	| pyramid \
@@ -372,7 +366,7 @@
 	| aarch64-* | aarch64_be-* \
 	| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
 	| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
-	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* | arceb-* \
 	| arm-*  | armbe-* | armle-* | armeb-* | armv*-* \
 	| avr-* | avr32-* \
 	| be32-* | be64-* \
@@ -410,12 +404,13 @@
 	| mipsisa64r2-* | mipsisa64r2el-* \
 	| mipsisa64sb1-* | mipsisa64sb1el-* \
 	| mipsisa64sr71k-* | mipsisa64sr71kel-* \
+	| mipsr5900-* | mipsr5900el-* \
 	| mipstx39-* | mipstx39el-* \
 	| mmix-* \
 	| mt-* \
 	| msp430-* \
 	| nds32-* | nds32le-* | nds32be-* \
-	| nios-* | nios2-* \
+	| nios-* | nios2-* | nios2eb-* | nios2el-* \
 	| none-* | np1-* | ns16k-* | ns32k-* \
 	| open8-* \
 	| orion-* \
@@ -1026,7 +1021,11 @@
 		basic_machine=i586-unknown
 		os=-pw32
-	rdos)
+	rdos | rdos64)
+		basic_machine=x86_64-pc
+		os=-rdos
+	rdos32)
 		basic_machine=i386-pc
 		os=-rdos
@@ -1353,7 +1352,7 @@
 	-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
 	      | -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
 	      | -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
-	      | -sym* | -kopensolaris* \
+	      | -sym* | -kopensolaris* | -plan9* \
 	      | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
 	      | -aos* | -aros* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
@@ -1499,9 +1498,6 @@
 	-aros*)
 		os=-aros
-	-kaos*)
-		os=-kaos
 	-zvmoe)
 		os=-zvmoe
@@ -1593,6 +1589,9 @@
 	mips*-*)
 		os=-elf
+	or1k-*)
+		os=-elf
 	or32-*)
 		os=-coff
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2013-06-09 13:23:39 UTC (rev 56653)
+++ grass/branches/releasebranch_6_4/configure	2013-06-09 16:25:37 UTC (rev 56654)
@@ -15562,7 +15562,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 15576 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15584: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 15594 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15601: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -15575,7 +15626,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15579: checking whether to use openDWG" >&5
+echo "configure:15630: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15595,7 +15646,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15599: checking for location of openDGW includes" >&5
+echo "configure:15650: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15621,15 +15672,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15625: checking for $ac_hdr" >&5
+echo "configure:15676: checking for $ac_hdr" >&5
-#line 15628 "configure"
+#line 15679 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -15663,7 +15714,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15667: checking for location of openDWG library" >&5
+echo "configure:15718: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15710,7 +15761,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15714: checking for special C compiler options needed for large files" >&5
+echo "configure:15765: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15718,7 +15769,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15722 "configure"
+#line 15773 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15734,7 +15785,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15738: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15789: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15743,7 +15794,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15747 "configure"
+#line 15798 "configure"
@@ -15759,7 +15810,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15814: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15779,11 +15830,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15783: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15834: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15787 "configure"
+#line 15838 "configure"
@@ -15799,14 +15850,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15854: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15810 "configure"
+#line 15861 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15824,7 +15875,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15879: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15843,11 +15894,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15847: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15898: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15851 "configure"
+#line 15902 "configure"
@@ -15863,14 +15914,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15867: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15918: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15874 "configure"
+#line 15925 "configure"
 #define _LARGE_FILES 1
@@ -15888,7 +15939,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15892: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15943: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15907,25 +15958,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15911: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15962: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15915 "configure"
+#line 15966 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15973: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15929 "configure"
+#line 15980 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15934,7 +15985,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15938: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15955,10 +16006,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15959: checking if system supports Large Files at all" >&5
+echo "configure:16010: checking if system supports Large Files at all" >&5
-#line 15962 "configure"
+#line 16013 "configure"
 #include <stdio.h>
@@ -15990,7 +16041,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16045: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16019,7 +16070,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16023: checking whether to use Python" >&5
+echo "configure:16074: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16039,7 +16090,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:16043: checking for $ac_word" >&5
+echo "configure:16094: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16081,15 +16132,15 @@
 do
-echo "configure:16085: checking for $ac_hdr" >&5
+echo "configure:16136: checking for $ac_hdr" >&5
-#line 16088 "configure"
+#line 16139 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16159,7 +16210,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16163: checking whether to use wxWidgets" >&5
+echo "configure:16214: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16180,7 +16231,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16184: checking for $ac_word" >&5
+echo "configure:16235: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16228,7 +16279,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16232: checking wxWidgets version" >&5
+echo "configure:16283: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16251,15 +16302,15 @@
 do
-echo "configure:16255: checking for $ac_hdr" >&5
+echo "configure:16306: checking for $ac_hdr" >&5
-#line 16258 "configure"
+#line 16309 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
