[GRASS-SVN] r56659 - grass/trunk
Sun Jun 9 10:01:53 PDT 2013
Author: neteler
Date: 2013-06-09 10:01:53 -0700 (Sun, 09 Jun 2013)
New Revision: 56659
   grass/trunk/config.guess
   grass/trunk/config.sub
   grass/trunk/configure
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess	2013-06-09 16:41:32 UTC (rev 56658)
+++ grass/trunk/config.guess	2013-06-09 17:01:53 UTC (rev 56659)
@@ -2,7 +2,7 @@
 # Attempt to guess a canonical system name.
 #   Copyright 1992-2013 Free Software Foundation, Inc.
-timestamp='2013-02-12'
+timestamp='2013-05-16'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -132,6 +132,27 @@
 UNAME_SYSTEM=`(uname -s) 2>/dev/null`  || UNAME_SYSTEM=unknown
 UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
+case "${UNAME_SYSTEM}" in
+Linux|GNU|GNU/*)
+	# If the system lacks a compiler, then just pick glibc.
+	# We could probably try harder.
+	LIBC=gnu
+	eval $set_cc_for_build
+	cat <<-EOF > $dummy.c
+	#include <features.h>
+	#if defined(__UCLIBC__)
+	LIBC=uclibc
+	#elif defined(__dietlibc__)
+	LIBC=dietlibc
+	#else
+	LIBC=gnu
+	#endif
+	EOF
+	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
+esac
 # Note: order is significant - the case branches are not exclusive.
 case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
@@ -853,21 +874,21 @@
 	exit ;;
     *:GNU:*:*)
 	# the GNU system
-	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
+	echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-${LIBC}`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
 	exit ;;
     *:GNU/*:*:*)
 	# other systems with GNU libc and userland
-	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
+	echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-${LIBC}
 	exit ;;
     i*86:Minix:*:*)
 	echo ${UNAME_MACHINE}-pc-minix
 	exit ;;
     aarch64:Linux:*:*)
-	echo ${UNAME_MACHINE}-unknown-linux-gnu
+	echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
 	exit ;;
     aarch64_be:Linux:*:*)
 	UNAME_MACHINE=aarch64_be
 	exit ;;
     alpha:Linux:*:*)
 	case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
@@ -880,59 +901,54 @@
 	  EV68*) UNAME_MACHINE=alphaev68 ;;
 	esac
 	objdump --private-headers /bin/sh | grep -q ld.so.1
-	if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
-	echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+	if test "$?" = 0 ; then LIBC="gnulibc1" ; fi
 	exit ;;
+    arc:Linux:*:* | arceb:Linux:*:*)
+	exit ;;
     arm*:Linux:*:*)
 	if echo __ARM_EABI__ | $CC_FOR_BUILD -E - 2>/dev/null \
 	    | grep -q __ARM_EABI__
 	then
 	else
 	    if echo __ARM_PCS_VFP | $CC_FOR_BUILD -E - 2>/dev/null \
 		| grep -q __ARM_PCS_VFP
 	    then
-		echo ${UNAME_MACHINE}-unknown-linux-gnueabi
+		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabi
 	    else
-		echo ${UNAME_MACHINE}-unknown-linux-gnueabihf
+		echo ${UNAME_MACHINE}-unknown-linux-${LIBC}eabihf
 	    fi
 	fi
 	exit ;;
     avr32*:Linux:*:*)
 	exit ;;
     cris:Linux:*:*)
-	echo ${UNAME_MACHINE}-axis-linux-gnu
+	echo ${UNAME_MACHINE}-axis-linux-${LIBC}
 	exit ;;
     crisv32:Linux:*:*)
 	exit ;;
     frv:Linux:*:*)
 	exit ;;
     hexagon:Linux:*:*)
 	exit ;;
     i*86:Linux:*:*)
-	LIBC=gnu
-	eval $set_cc_for_build
-	sed 's/^	//' << EOF >$dummy.c
-	#ifdef __dietlibc__
-	LIBC=dietlibc
-	#endif
-EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
-	echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+	echo ${UNAME_MACHINE}-pc-linux-${LIBC}
 	exit ;;
     ia64:Linux:*:*)
 	exit ;;
     m32r*:Linux:*:*)
 	exit ;;
     m68*:Linux:*:*)
 	exit ;;
     mips:Linux:*:* | mips64:Linux:*:*)
@@ -951,57 +967,63 @@
 	#endif
 EOF
 	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
-	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-${LIBC}"; exit; }
     or1k:Linux:*:*)
 	exit ;;
     or32:Linux:*:*)
 	exit ;;
     padre:Linux:*:*)
-	echo sparc-unknown-linux-gnu
+	echo sparc-unknown-linux-${LIBC}
 	exit ;;
     parisc64:Linux:*:* | hppa64:Linux:*:*)
-	echo hppa64-unknown-linux-gnu
+	echo hppa64-unknown-linux-${LIBC}
 	exit ;;
     parisc:Linux:*:* | hppa:Linux:*:*)
 	# Look for CPU level
 	case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
-	  PA7*) echo hppa1.1-unknown-linux-gnu ;;
-	  PA8*) echo hppa2.0-unknown-linux-gnu ;;
-	  *)    echo hppa-unknown-linux-gnu ;;
+	  PA7*) echo hppa1.1-unknown-linux-${LIBC} ;;
+	  PA8*) echo hppa2.0-unknown-linux-${LIBC} ;;
+	  *)    echo hppa-unknown-linux-${LIBC} ;;
 	esac
 	exit ;;
     ppc64:Linux:*:*)
-	echo powerpc64-unknown-linux-gnu
+	echo powerpc64-unknown-linux-${LIBC}
 	exit ;;
     ppc:Linux:*:*)
-	echo powerpc-unknown-linux-gnu
+	echo powerpc-unknown-linux-${LIBC}
 	exit ;;
+    ppc64le:Linux:*:*)
+	echo powerpc64le-unknown-linux-${LIBC}
+	exit ;;
+    ppcle:Linux:*:*)
+	echo powerpcle-unknown-linux-${LIBC}
+	exit ;;
     s390:Linux:*:* | s390x:Linux:*:*)
-	echo ${UNAME_MACHINE}-ibm-linux
+	echo ${UNAME_MACHINE}-ibm-linux-${LIBC}
 	exit ;;
     sh64*:Linux:*:*)
 	exit ;;
     sh*:Linux:*:*)
 	exit ;;
     sparc:Linux:*:* | sparc64:Linux:*:*)
 	exit ;;
     tile*:Linux:*:*)
 	exit ;;
     vax:Linux:*:*)
-	echo ${UNAME_MACHINE}-dec-linux-gnu
+	echo ${UNAME_MACHINE}-dec-linux-${LIBC}
 	exit ;;
     x86_64:Linux:*:*)
 	exit ;;
     xtensa*:Linux:*:*)
 	exit ;;
     i*86:DYNIX/ptx:4*:*)
 	# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
@@ -1234,19 +1256,21 @@
 	exit ;;
     *:Darwin:*:*)
 	UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
-	case $UNAME_PROCESSOR in
-	    i386)
-		if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
-		  if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
-		      (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
-		      grep IS_64BIT_ARCH >/dev/null
-		  then
-		      UNAME_PROCESSOR="x86_64"
-		  fi
-		fi ;;
-	    unknown) UNAME_PROCESSOR=powerpc ;;
-	esac
+	if test "$UNAME_PROCESSOR" = unknown ; then
+	    UNAME_PROCESSOR=powerpc
+	fi
+	if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+	    if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
+		(CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+		grep IS_64BIT_ARCH >/dev/null
+	    then
+		case $UNAME_PROCESSOR in
+		    i386) UNAME_PROCESSOR=x86_64 ;;
+		    powerpc) UNAME_PROCESSOR=powerpc64 ;;
+		esac
+	    fi
+	fi
 	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
 	exit ;;
     *:procnto*:*:* | *:QNX:[0123456789]*:*)
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub	2013-06-09 16:41:32 UTC (rev 56658)
+++ grass/trunk/config.sub	2013-06-09 17:01:53 UTC (rev 56659)
@@ -2,7 +2,7 @@
 # Configuration validation subroutine script.
+timestamp='2013-04-24'
@@ -252,7 +252,7 @@
 	| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
 	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
 	| am33_2.0 \
-	| arc \
+	| arc | arceb \
 	| arm | arm[bl]e | arme[lb] | armv[2-8] | armv[3-8][lb] | armv7[arm] \
 	| avr | avr32 \
 	| be32 | be64 \
@@ -366,7 +366,7 @@
 	| aarch64-* | aarch64_be-* \
 	| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
 	| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
-	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* | arceb-* \
 	| arm-*  | armbe-* | armle-* | armeb-* | armv*-* \
 	| avr-* | avr32-* \
 	| be32-* | be64-* \
Modified: grass/trunk/configure
--- grass/trunk/configure	2013-06-09 16:41:32 UTC (rev 56658)
+++ grass/trunk/configure	2013-06-09 17:01:53 UTC (rev 56659)
@@ -12355,7 +12355,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 12369 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12377: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 12387 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -12368,7 +12419,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12372: checking whether to use openDWG" >&5
+echo "configure:12423: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12388,7 +12439,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12392: checking for location of openDGW includes" >&5
+echo "configure:12443: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12414,15 +12465,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12418: checking for $ac_hdr" >&5
+echo "configure:12469: checking for $ac_hdr" >&5
-#line 12421 "configure"
+#line 12472 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12477: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12456,7 +12507,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12460: checking for location of openDWG library" >&5
+echo "configure:12511: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12497,7 +12548,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12501: checking whether to use POSIX threads" >&5
+echo "configure:12552: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12517,7 +12568,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12521: checking for location of POSIX threads includes" >&5
+echo "configure:12572: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12543,15 +12594,15 @@
 do
-echo "configure:12547: checking for $ac_hdr" >&5
+echo "configure:12598: checking for $ac_hdr" >&5
-#line 12550 "configure"
+#line 12601 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12585,7 +12636,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12589: checking for location of POSIX threads library" >&5
+echo "configure:12640: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12610,10 +12661,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12614: checking for pthread_create" >&5
+echo "configure:12665: checking for pthread_create" >&5
-#line 12617 "configure"
+#line 12668 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -12636,7 +12687,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12663,13 +12714,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12667: checking for pthread_create in -lpthread" >&5
+echo "configure:12718: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12673 "configure"
+#line 12724 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12680,7 +12731,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12730,7 +12781,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12734: checking whether to use OpenMP" >&5
+echo "configure:12785: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12751,7 +12802,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12755: checking for location of OpenMP includes" >&5
+echo "configure:12806: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12777,15 +12828,15 @@
 do
-echo "configure:12781: checking for $ac_hdr" >&5
+echo "configure:12832: checking for $ac_hdr" >&5
-#line 12784 "configure"
+#line 12835 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12823,7 +12874,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12827: checking for location of OpenMP library" >&5
+echo "configure:12878: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12848,10 +12899,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12852: checking for GOMP_parallel_start" >&5
+echo "configure:12903: checking for GOMP_parallel_start" >&5
-#line 12855 "configure"
+#line 12906 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12874,7 +12925,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12901,13 +12952,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12905: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12956: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12911 "configure"
+#line 12962 "configure"
@@ -12918,7 +12969,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12991,7 +13042,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12995: checking whether to use OpenCL" >&5
+echo "configure:13046: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -13011,7 +13062,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13015: checking for location of OpenCL includes" >&5
+echo "configure:13066: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13038,15 +13089,15 @@
 do
-echo "configure:13042: checking for $ac_hdr" >&5
+echo "configure:13093: checking for $ac_hdr" >&5
-#line 13045 "configure"
+#line 13096 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13086,10 +13137,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13090: checking for clGetPlatformInfo" >&5
+echo "configure:13141: checking for clGetPlatformInfo" >&5
-#line 13093 "configure"
+#line 13144 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13112,7 +13163,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13151,15 +13202,15 @@
 do
-echo "configure:13155: checking for $ac_hdr" >&5
+echo "configure:13206: checking for $ac_hdr" >&5
-#line 13158 "configure"
+#line 13209 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13214: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13192,7 +13243,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13196: checking for location of OpenCL library" >&5
+echo "configure:13247: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13216,13 +13267,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13220: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13271: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13226 "configure"
+#line 13277 "configure"
@@ -13233,7 +13284,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13287,7 +13338,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13291: checking for special C compiler options needed for large files" >&5
+echo "configure:13342: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13295,7 +13346,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13299 "configure"
+#line 13350 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13311,7 +13362,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13315: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13366: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13320,7 +13371,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13324 "configure"
+#line 13375 "configure"
@@ -13336,7 +13387,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13340: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13391: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13356,11 +13407,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13360: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13411: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13364 "configure"
+#line 13415 "configure"
@@ -13376,14 +13427,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13387 "configure"
+#line 13438 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13401,7 +13452,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13405: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13456: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13420,11 +13471,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13424: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13475: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13428 "configure"
+#line 13479 "configure"
@@ -13440,14 +13491,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13444: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13495: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13451 "configure"
+#line 13502 "configure"
 #define _LARGE_FILES 1
@@ -13465,7 +13516,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13469: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13520: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13484,25 +13535,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13488: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13539: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13492 "configure"
+#line 13543 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13499: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13550: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13506 "configure"
+#line 13557 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13511,7 +13562,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13566: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13532,25 +13583,25 @@
    fi
-echo "configure:13536: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13587: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13540 "configure"
+#line 13591 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13547: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13598: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13554 "configure"
+#line 13605 "configure"
 #include <stdio.h>
@@ -13559,7 +13610,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13563: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13614: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13582,18 +13633,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13586: checking for fseeko" >&5
+echo "configure:13637: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13590 "configure"
+#line 13641 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13610,10 +13661,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13614: checking if system supports Large Files at all" >&5
+echo "configure:13665: checking if system supports Large Files at all" >&5
-#line 13617 "configure"
+#line 13668 "configure"
 #include <stdio.h>
@@ -13645,7 +13696,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13649: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13700: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13674,7 +13725,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13678: checking whether to use wxWidgets" >&5
+echo "configure:13729: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13695,7 +13746,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13699: checking for $ac_word" >&5
+echo "configure:13750: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13743,7 +13794,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13747: checking wxWidgets version" >&5
+echo "configure:13798: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13766,15 +13817,15 @@
 do
-echo "configure:13770: checking for $ac_hdr" >&5
+echo "configure:13821: checking for $ac_hdr" >&5
-#line 13773 "configure"
+#line 13824 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13829: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
