[GRASS-SVN] r56726 - grass-addons/grass6/raster/r.in.wms2
Sat Jun 15 22:38:54 PDT 2013
Author: hamish
Date: 2013-06-15 22:38:54 -0700 (Sat, 15 Jun 2013)
New Revision: 56726
   grass-addons/grass6/raster/r.in.wms2/r.in.wms2.py
backwards compatibility with grass6's g.parser
Modified: grass-addons/grass6/raster/r.in.wms2/r.in.wms2.py
--- grass-addons/grass6/raster/r.in.wms2/r.in.wms2.py	2013-06-16 03:47:47 UTC (rev 56725)
+++ grass-addons/grass6/raster/r.in.wms2/r.in.wms2.py	2013-06-16 05:38:54 UTC (rev 56726)
@@ -22,7 +22,7 @@
 #%option
 #% key: url
 #% type: string
-#% description:URL of WMS server
+#% description: URL of WMS server
 #% required: yes
 #%end
@@ -34,15 +34,20 @@
 #% required: yes
 #%end
-#%option G_OPT_R_OUTPUT
+#%option
+#% key: output
+#% type: string
 #% description: Name for output raster map
+#% gisprompt: new,cell,raster
+#% required: yes
+#% key_desc: name
 #%end
 #%option
 #% key: srs
 #% type: integer
 #% description: EPSG number of source projection for request
-#% answer:4326
+#% answer: 4326
 #% guisection: Request properties
 #%end
@@ -55,10 +60,10 @@
 #%option
 #% key: wms_version
-#% type:string
-#% description:WMS standard
-#% options:1.1.1,1.3.0
-#% answer:1.1.1
+#% type: string
+#% description: WMS standard
+#% options: 1.1.1,1.3.0
+#% answer: 1.1.1
 #%end
@@ -75,16 +80,16 @@
 #% key: method
 #% type: string
 #% description: Reprojection method to use
-#% options:near,bilinear,cubic,cubicspline
-#% answer:near
+#% options: near,bilinear,cubic,cubicspline
+#% answer: near
 #%end
 #%option
 #% key: maxcols
-#% type:integer
+#% type: integer
 #% description: Maximum columns to request at a time
-#% answer:400
+#% answer: 400
 #%end
@@ -98,21 +103,21 @@
 #%option
 #% key: urlparams
-#% type:string
+#% type: string
 #% description: Additional query parameters for server
 #%end
 #%option
 #% key: username
-#% type:string
+#% type: string
 #% description: Username for server connection
 #%end
 #%option
 #% key: password
-#% type:string
+#% type: string
 #% description: Password for server connection
 #%end
@@ -147,26 +152,31 @@
 #%option
 #% key: driver
-#% type:string
+#% type: string
 #% description: Driver for communication with server
-#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
-#% answer:WMS_GRASS
+#% options: WMS_GDAL, WMS_GRASS, WMTS_GRASS, OnEarth_GRASS
+#% answer: WMS_GRASS
 #%end
-#%option G_OPT_F_INPUT
+#%option
 #% key: capfile
+#% type: string
+#% key_desc: name
 #% required: no
-#% gisprompt: old,file,bin_input
-#% description: Capabilities file
+#% gisprompt: old_file,file,input
+#% description: Capabilities file (input)
 #%end
-#%option G_OPT_F_OUTPUT
+#%option
 #% key: capfile_output
 #% required: no
+#% gisprompt: old_file,file,file
 #% description: File where capabilities will be saved (only with 'c' flag).
+#% type: string
+#% key_desc: name
 #%end
 import os
 import sys
 sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms2'))
