[GRASS-SVN] r56786 - grass/trunk/gui/wxpython/gui_core
    svn_grass at osgeo.org
    Tue Jun 18 08:04:30 PDT 2013
Author: annakrat
Date: 2013-06-18 08:04:30 -0700 (Tue, 18 Jun 2013)
New Revision: 56786
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
wxGUI: show color table thumbnails in r.colors combo box
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2013-06-18 13:54:47 UTC (rev 56785)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2013-06-18 15:04:30 UTC (rev 56786)
@@ -88,7 +88,7 @@
 from grass.script import core as grass
 from grass.script import task as gtask
-from gui_core.widgets import StaticWrapText, ScrolledPanel
+from gui_core.widgets import StaticWrapText, ScrolledPanel, ColorTablesComboBox
 from gui_core.ghelp   import HelpPanel
 from gui_core         import gselect
 from core             import gcmd
@@ -1053,9 +1053,14 @@
                                             flag = wx.ADJUST_MINSIZE, border = 0)
                         else:
                             # list of values (combo)
-                            cb = wx.ComboBox(parent = which_panel, id = wx.ID_ANY, value = p.get('default',''),
-                                             size = globalvar.DIALOG_COMBOBOX_SIZE,
-                                             choices = valuelist, style = wx.CB_DROPDOWN)
+                            if p['name'] == 'color':
+                                cb = ColorTablesComboBox(parent=which_panel, value=p.get('default',''),
+                                                         size=globalvar.DIALOG_COMBOBOX_SIZE,
+                                                         choices=valuelist)
+                            else:
+                                cb = wx.ComboBox(parent=which_panel, id=wx.ID_ANY, value=p.get('default',''),
+                                                 choices=valuelist, style=wx.CB_DROPDOWN)
                             if value:
                                 cb.SetValue(value) # parameter previously set
                             which_sizer.Add(item = cb, proportion = 0,
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2013-06-18 13:54:47 UTC (rev 56785)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2013-06-18 15:04:30 UTC (rev 56786)
@@ -35,6 +35,7 @@
 import wx
 import wx.lib.mixins.listctrl as listmix
 import wx.lib.scrolledpanel as SP
+import wx.combo
 try:
     import wx.lib.agw.flatnotebook   as FN
 except ImportError:
@@ -1196,3 +1197,53 @@
                 pass
         return data
+class ColorTablesComboBox(wx.combo.OwnerDrawnComboBox):
+    """!ComboBox with drawn color tables (created by thumbnails.py).
+    Used in r(3).colors dialog.
+    def OnDrawItem(self, dc, rect, item, flags):
+        """!Overridden from OwnerDrawnComboBox.
+        Called to draw each item in the list.
+        if item == wx.NOT_FOUND:
+            # painting the control, but there is no valid item selected yet
+            return
+        r = wx.Rect(*rect)  # make a copy
+        r.Deflate(3, 5)
+        # for painting the items in the popup
+        bitmap = self.GetColorTableBitmap(self.GetString(item))
+        if bitmap:
+            dc.DrawBitmap(bitmap, r.x, r.y + (r.height - bitmap.GetHeight()) / 2)
+        dc.DrawText(self.GetString(item),
+                    r.x + bitmap.GetWidth() + 10,
+                    (r.y + 0) + (r.height - dc.GetCharHeight()) / 2)
+    def OnMeasureItem(self, item):
+        """!Overridden from OwnerDrawnComboBox, should return the height.
+        Needed to display an item in the popup, or -1 for default.
+        return 24
+    def GetColorTableBitmap(self, colorTable):
+        """!Returns bitmap with colortable for given nacolor table name.
+        @param colorTable name of color table
+        if not hasattr(self, 'bitmaps'):
+            self.bitmaps = {}
+        if colorTable in self.bitmaps:
+            return self.bitmaps[colorTable]
+        path = os.path.join(os.getenv("GISBASE"), "docs", "html", "Colortable_%s.png" % colorTable)
+        if os.path.exists(path):
+            bitmap = wx.Bitmap(path)
+            self.bitmaps[colorTable] = bitmap
+            return bitmap
+        return None
