[GRASS-SVN] r56873 - in grass-addons/grass7/imagery: . i.eb.z0m
Sat Jun 22 01:10:37 PDT 2013
Author: ychemin
Date: 2013-06-22 01:10:37 -0700 (Sat, 22 Jun 2013)
New Revision: 56873
Added:
   grass-addons/grass7/imagery/i.eb.z0m/
   grass-addons/grass7/imagery/i.eb.z0m/Makefile
   grass-addons/grass7/imagery/i.eb.z0m/i.eb.z0m.html
   grass-addons/grass7/imagery/i.eb.z0m/main.c
   grass-addons/grass7/imagery/i.eb.z0m/z0m.c
   grass-addons/grass7/imagery/Makefile
upgraded to G7, merged i.eb.z0m and i.eb.z0m0
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile	2013-06-22 04:38:21 UTC (rev 56872)
+++ grass-addons/grass7/imagery/Makefile	2013-06-22 08:10:37 UTC (rev 56873)
@@ -4,6 +4,7 @@
 SUBDIRS = \
 	i.eb.h_sebal95 \
+	i.eb.z0m \
 	i.edge \
 	i.evapo.potrad \
 	i.evapo.senay \
Added: grass-addons/grass7/imagery/i.eb.z0m/Makefile
--- grass-addons/grass7/imagery/i.eb.z0m/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.z0m/Makefile	2013-06-22 08:10:37 UTC (rev 56873)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.eb.z0m
+LIBES = $(GISLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/imagery/i.eb.z0m/i.eb.z0m.html
--- grass-addons/grass7/imagery/i.eb.z0m/i.eb.z0m.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.z0m/i.eb.z0m.html	2013-06-22 08:10:37 UTC (rev 56873)
@@ -0,0 +1,28 @@
+<h2>DESCRIPTION</h2>
+<em>i.eb.z0m</em> calculates the momentum roughness length (z0m) and optionally the surface roughness for heat transport (z0h) as per SEBAL requirements from bastiaanssen (1995).
+Default: calculating from a NDVI with an deterministic equation, as seen in Bastiaanssen (1995).
+Flag -p : calculating from a SAVI with an empirical equation, as seen in Pawan (2004).
+This is a typical input to sensible heat flux computations of any energy balance modeling.
+<h2>NOTES</h2>
+The NDVI map input and the ndvi_max operation set, is only to get a linear relationship from NDVI to vegetation height. The latter being related to z0m by a factor 7.
+If you happen to have a vegetation height (hv) map, then z0m=hv/7 and z0h=0.1*z0m.
+<h2>TODO</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.eb.h0.html">i.eb.h0</a><br>
+</em>
+<h2>AUTHORS</h2>
+Yann Chemin
+<br>
+<p>
+<i>Last changed: 2013-06-29</i>
Added: grass-addons/grass7/imagery/i.eb.z0m/main.c
--- grass-addons/grass7/imagery/i.eb.z0m/main.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.z0m/main.c	2013-06-22 08:10:37 UTC (rev 56873)
@@ -0,0 +1,236 @@
+ * MODULE:       i.eb.z0m
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculates the momentum roughness length
+ *               as seen in Bastiaanssen (1995), Pawan (2004)
+ * COPYRIGHT:    (C) 2002-2013 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+double z0m_pawan(double sa_vi);
+double z0m_bastiaanssen(double ndvi, double ndvi_max, double hv_ndvimax,
+	      double hv_desert);
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    char *mapset;		/*mapset name */
+    int nrows, ncols;
+    int row, col;
+    int heat = 0;	/*Flag for surf. roughness for heat transport output */
+    struct GModule *module;
+    struct Option *input1, *input2, *input3, *input4;
+    struct Option *output1, *output2;
+    struct Flag *flag1, *flag2;
+    struct History history;	/*metadata */
+    char *name;			/*input raster name */
+    char *result1, *result2;	/*output raster name */
+    /*File Descriptors */
+    int infd_ndvi;
+    int outfd1, outfd2;
+    char *ndvi;
+    char *z0m, *z0h;
+    double coef_z0h, hv_max, hmr;
+    int i = 0, j = 0;
+    void *inrast_ndvi;
+    DCELL * outrast1, *outrast2;
+    RASTER_MAP_TYPE data_type_ndvi;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("imagery"));
+    G_add_keyword(_("roughness length"));
+    G_add_keyword(_("energy balance"));
+    G_add_keyword(_("SEBAL"));
+    module->description =
+	_("Momentum roughness length (z0m) and surface roughness for heat transport (z0h) as seen in Bastiaanssen (2004)");
+    /* Define the different options */
+    input1 = G_define_standard_option(G_OPT_R_INPUT);
+    input1->key = _("ndvi");
+    input1->description = _("Name of the NDVI map [-1.0;1.0], SAVI if -p flag");
+    input2 = G_define_option();
+    input2->key = _("coef");
+    input2->type = TYPE_DOUBLE;
+    input2->required = NO;
+    input2->gisprompt = _("parameter,value");
+    input2->description =
+	_("Value of the conversion factor from z0m and z0h (Bastiaanssen (2005) used 0.1), for -f flag");
+    input2->answer = _("0.1");
+    input3 = G_define_option();
+    input3->key = _("hv_max");
+    input3->type = TYPE_DOUBLE;
+    input3->required = NO;
+    input3->gisprompt = _("parameter,value");
+    input3->description =
+	_("Value of the vegetation height at max(NDVI) i.e. standard C3 crop could be 1.5m, not needed for -p flag");
+    input3->answer = _("1.5");
+    input4 = G_define_option();
+    input4->key = _("hmr");
+    input4->type = TYPE_DOUBLE;
+    input4->required = NO;
+    input4->gisprompt = _("parameter,value");
+    input4->description =
+	_("Value of the micro-relief height (h.m-r.) on flat bare ground, most references point to 2cm, not need for -p flag");
+    input4->answer = _("0.02");
+    output1 = G_define_standard_option(G_OPT_R_OUTPUT);
+    output1->description = _("Name of the output z0m layer");
+    output2 = G_define_standard_option(G_OPT_R_OUTPUT);
+    output2->key = _("z0h");
+    output2->required = NO;
+    output2->description = _("Name of the output z0h layer");
+    flag2 = G_define_flag();
+    flag2->key = 'p';
+    flag2->description = _("Use SAVI input only with equation of Pawan (2004)");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    ndvi = input1->answer;
+    if (input2->answer)
+	coef_z0h = atof(input2->answer);
+    if (input3->answer)
+    	hv_max = atof(input3->answer);
+    if (input4->answer)
+    	hmr = atof(input4->answer);
+    result1 = output1->answer;
+    if (output2->answer)
+	result2 = output2->answer;
+    data_type_ndvi = Rast_map_type(ndvi, "");
+    infd_ndvi = Rast_open_old(ndvi, "");
+    Rast_get_cellhd(ndvi, "", &cellhd);
+    inrast_ndvi = Rast_allocate_buf(data_type_ndvi);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    outrast1 = Rast_allocate_d_buf();
+    Rast_open_new(result1, DCELL_TYPE);
+    if (input2->answer && output2->answer){
+        outrast2 = Rast_allocate_d_buf();
+        Rast_open_new(result2, DCELL_TYPE);
+    DCELL d_ndvi;		/* Input raster */
+    DCELL d_ndvi_max = 0.0;	/* Generated here */
+    /* NDVI Max */
+    if(flag2->answer){
+    	/* skip it */
+    } else {
+        for (row = 0; row < nrows; row++)
+            G_percent(row, nrows, 2);
+            Rast_get_row(infd_ndvi,inrast_ndvi,row,data_type_ndvi);
+	    for (col = 0; col < ncols; col++)
+	        switch (data_type_ndvi) {
+	        case CELL_TYPE:
+		    d_ndvi = (double)((CELL *) inrast_ndvi)[col];
+		    break;
+	        case FCELL_TYPE:
+		    d_ndvi = (double)((FCELL *) inrast_ndvi)[col];
+		    break;
+	        case DCELL_TYPE:
+		    d_ndvi = (double)((DCELL *) inrast_ndvi)[col];
+		    break;
+	        if (Rast_is_d_null_value(&d_ndvi)) {
+		    /* do nothing */
+	        else if ((d_ndvi) > d_ndvi_max && (d_ndvi) < 0.98) {
+		    d_ndvi_max = d_ndvi;
+        G_message("ndvi_max=%f\n", d_ndvi_max);
+    /* Process pixels */
+        DCELL d;
+        DCELL d_z0h;
+        /* read input maps */
+	/*process the data */
+	    case CELL_TYPE:
+		break;
+	    case FCELL_TYPE:
+		break;
+	    case DCELL_TYPE:
+		break;
+		Rast_set_d_null_value(&outrast1[col], 1);
+		if (input2->answer && output2->answer) {
+		    Rast_set_d_null_value(&outrast2[col], 1);
+	    else {
+		/* calculate z0m            */
+		    d = z0m_pawan(d_ndvi);
+                } else {
+		    d = z0m_bastiaanssen(d_ndvi, d_ndvi_max, hv_max, hmr);
+		outrast1[col] = d;
+		    d_z0h = d * coef_z0h;
+		    outrast2[col] = d_z0h;
+	Rast_put_d_row(outfd1, outrast1);
+	    Rast_put_d_row(outfd2, outrast2);
+    G_free(inrast_ndvi);
+    Rast_close(infd_ndvi);
+    G_free(outrast1);
+    Rast_close(outfd1);
+	G_free(outrast2);
+	Rast_close(outfd2);
+    Rast_short_history(result1, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(result1, &history);
+	Rast_short_history(result2, "raster", &history);
+	Rast_write_history(result2, &history);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/imagery/i.eb.z0m/z0m.c
--- grass-addons/grass7/imagery/i.eb.z0m/z0m.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.eb.z0m/z0m.c	2013-06-22 08:10:37 UTC (rev 56873)
@@ -0,0 +1,21 @@
+#include<stdio.h>
+#include<math.h>
+	     double hv_desert)
+    double a, b, z0m;
+    /* hv_ndvimax = crop vegetation height (m) */
+    /* hv_desert=0.002 = desert base vegetation height (m) */
+    a = (log(hv_desert) -
+	 ((log(hv_ndvimax / 7) - log(hv_desert)) / (ndvi_max - 0.02) * 0.02));
+    b = (log(hv_ndvimax / 7) - log(hv_desert)) / (ndvi_max - 0.02) * ndvi;
+    z0m = exp(a + b);
+    return (z0m);
+/* Momentum roughness length (z0m) as seen in Pawan (2004) */
+    return(exp(-5.809 + 5.62 * sa_vi));
