[GRASS-SVN] r56890 - in grass/trunk/lib/vector: . Vlib diglib neta rtree
Sun Jun 23 12:25:48 PDT 2013
Author: mmetz
Date: 2013-06-23 12:25:47 -0700 (Sun, 23 Jun 2013)
New Revision: 56890
   grass/trunk/lib/vector/Vlib/dgraph.c
   grass/trunk/lib/vector/Vlib/e_intersect.c
   grass/trunk/lib/vector/diglib/head.c
   grass/trunk/lib/vector/diglib/portable.c
   grass/trunk/lib/vector/neta/articulation_point.c
   grass/trunk/lib/vector/neta/path.c
   grass/trunk/lib/vector/rtree/node.c
   grass/trunk/lib/vector/vectorlib.dox
update vectorlib.dox
Modified: grass/trunk/lib/vector/Vlib/dgraph.c
--- grass/trunk/lib/vector/Vlib/dgraph.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/Vlib/dgraph.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -222,8 +222,8 @@
     int looped;
     /* double EPSILON = 0.00000001; */
     double EPSILON = GRASS_EPSILON;
-    double *x, *y;
-    double x1, y1, x2, y2;
+    double *x, *y, az1, az2, bz1, bz2;
+    double x1, y1, z1, x2, y2, z2;
     int res;
     /*int res2
@@ -237,6 +237,7 @@
     np = Points->n_points;
     x = Points->x;
     y = Points->y;
+    az1 = az2 = bz1 = bz2 = 0;
     si = create_si_struct(np - 1);
@@ -252,6 +253,17 @@
 		segment_intersection_2d(x[i], y[i], x[i + 1], y[i + 1], x[j],
 					y[j], x[j + 1], y[j + 1], &x1, &y1,
 					&x2, &y2);
+	    res =
+		Vect_segment_intersection(x[i], y[i], az1,
+		                          x[i + 1], y[i + 1], az2,
+					  x[j], y[j], bz1,
+					  x[j + 1], y[j + 1], bz2,
+					  &x1, &y1, &z1, &x2, &y2, &z2, 0);
 	    /*            res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
 	       if ((res != res2) || ((res != 0) && (x1!=x1_ || y1!=y1_)) ) {
 	       G_debug(1, "exact=%d orig=%d", res, res2);
Modified: grass/trunk/lib/vector/Vlib/e_intersect.c
--- grass/trunk/lib/vector/Vlib/e_intersect.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/Vlib/e_intersect.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -745,6 +745,31 @@
 	return 0;
+    /* swap endpoints if needed */
+    /* if segments are vertical, we swap x-coords with y-coords */
+    vertical = 0;
+    if (ax1 > ax2) {
+	SWAP(ax1, ax2);
+	SWAP(ay1, ay2);
+    else if (ax1 == ax2) {
+	vertical = 1;
+	if (ay1 > ay2)
+	    SWAP(ay1, ay2);
+	SWAP(ax1, ay1);
+	SWAP(ax2, ay2);
+    if (bx1 > bx2) {
+	SWAP(bx1, bx2);
+	SWAP(by1, by2);
+    else if (bx1 == bx2) {
+	if (by1 > by2)
+	    SWAP(by1, by2);
+	SWAP(bx1, by1);
+	SWAP(bx2, by2);
     d = D;
     if (d != 0) {
 	G_debug(DLEVEL, "    general position");
@@ -805,31 +830,6 @@
     /* segments are colinear. check for overlap */
-    /* swap endpoints if needed */
-    /* if segments are vertical, we swap x-coords with y-coords */
-    vertical = 0;
-    if (ax1 > ax2) {
-	SWAP(ax1, ax2);
-	SWAP(ay1, ay2);
-    else if (ax1 == ax2) {
-	vertical = 1;
-	if (ay1 > ay2)
-	    SWAP(ay1, ay2);
-	SWAP(ax1, ay1);
-	SWAP(ax2, ay2);
-    if (bx1 > bx2) {
-	SWAP(bx1, bx2);
-	SWAP(by1, by2);
-    else if (bx1 == bx2) {
-	if (by1 > by2)
-	    SWAP(by1, by2);
-	SWAP(bx1, by1);
-	SWAP(bx2, by2);
     G_debug(DLEVEL, "    collinear segments");
     if ((bx2 < ax1) || (bx1 > ax2)) {
Modified: grass/trunk/lib/vector/diglib/head.c
--- grass/trunk/lib/vector/diglib/head.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/diglib/head.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -75,6 +75,7 @@
     G_debug(2, "coor body offset %"PRI_OFF_T, dig_ftell(&(Map->dig_fp)));
     return 1;
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/diglib/portable.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -192,15 +192,13 @@
 		if (off_t_order == ENDIAN_LITTLE) {
 		    if (c1[port_off_t_size - 1] & 0x80)
 			memset(c2, 0xff, sizeof(off_t));
+		    memcpy(c2, c1, port_off_t_size);
 		else {
 		    if (c1[0] & 0x80)
-		if (off_t_order == ENDIAN_LITTLE)
-		    memcpy(c2, c1, port_off_t_size);
-		else
 		    memcpy(c2 + nat_off_t - port_off_t_size, c1, port_off_t_size);
 		c1 += port_off_t_size;
 		c2 += sizeof(off_t);
@@ -287,15 +285,13 @@
 		if (lng_order == ENDIAN_LITTLE) {
 		    if (c1[PORT_LONG - 1] & 0x80)
 			memset(c2, 0xff, sizeof(long));
+		    memcpy(c2, c1, PORT_LONG);
 		else {
 		    if (c1[0] & 0x80)
-		if (lng_order == ENDIAN_LITTLE)
-		    memcpy(c2, c1, PORT_LONG);
-		else
 		    memcpy(c2 + nat_lng - PORT_LONG, c1, PORT_LONG);
 		c1 += PORT_LONG;
 		c2 += sizeof(long);
@@ -372,15 +368,13 @@
 		if (int_order == ENDIAN_LITTLE) {
 		    if (c1[PORT_INT - 1] & 0x80)
 			memset(c2, 0xff, sizeof(int));
+		    memcpy(c2, c1, PORT_INT);
 		else {
 		    if (c1[0] & 0x80)
-		if (int_order == ENDIAN_LITTLE)
-		    memcpy(c2, c1, PORT_INT);
-		else
 		    memcpy(c2 + nat_int - PORT_INT, c1, PORT_INT);
 		c1 += PORT_INT;
 		c2 += sizeof(int);
@@ -457,15 +451,13 @@
 		if (shrt_order == ENDIAN_LITTLE) {
 		    if (c1[PORT_SHORT - 1] & 0x80)
 			memset(c2, 0xff, sizeof(short));
+		    memcpy(c2, c1, PORT_SHORT);
 		else {
 		    if (c1[0] & 0x80)
-		if (shrt_order == ENDIAN_LITTLE)
-		    memcpy(c2, c1, PORT_SHORT);
-		else
 		    memcpy(c2 + nat_shrt - PORT_SHORT, c1, PORT_SHORT);
 		c1 += PORT_SHORT;
 		c2 += sizeof(short);
Modified: grass/trunk/lib/vector/neta/articulation_point.c
--- grass/trunk/lib/vector/neta/articulation_point.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/neta/articulation_point.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -100,11 +100,12 @@
 			min_tin[node_id] = min_tin[to];
 		    current_edge[node_id] = dglEdgeset_T_Next(&current[node_id]);	/*proceed to the next edge */
-		for (; current_edge[node_id]; current_edge[node_id] = dglEdgeset_T_Next(&current[node_id])) {	/* try next edges */
+		/*try next edges */
+		for (; current_edge[node_id]; current_edge[node_id] = dglEdgeset_T_Next(&current[node_id])) {
 		    dglInt32_t *to =
 			dglEdgeGet_Tail(graph, current_edge[node_id]);
 		    if (to == parent[node_id])
-			continue;	/*skip parrent */
+			continue;	/*skip parent */
 		    int to_id = dglNodeGet_Id(graph, to);
 		    if (tin[to_id]) {	/*back edge, cannot be a bridge/articualtion point */
Modified: grass/trunk/lib/vector/neta/path.c
--- grass/trunk/lib/vector/neta/path.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/neta/path.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -22,7 +22,7 @@
 #include <grass/neta.h>
-   \brief Computes shortests paths to every node from  nodes in "from".
+   \brief Computes shortests paths to every node from nodes in "from".
    Array "dst" contains the length of the path or -1 if the node is not
    reachable. Prev contains edges from predecessor along the shortest
@@ -36,8 +36,8 @@
    \return 0 on success
    \return -1 on failure
-int NetA_distance_from_points(dglGraph_s * graph, struct ilist *from,
-			      int *dst, dglInt32_t ** prev)
+int NetA_distance_from_points(dglGraph_s *graph, struct ilist *from,
+			      int *dst, dglInt32_t **prev)
     int i, nnodes;
     dglHeap_s heap;
@@ -45,6 +45,7 @@
     nnodes = dglGet_NodeCount(graph);
     dglEdgesetTraverser_s et;
+    /* initialize costs and edge list */
     for (i = 1; i <= nnodes; i++) {
 	dst[i] = -1;
 	prev[i] = NULL;
@@ -55,13 +56,13 @@
     for (i = 0; i < from->n_values; i++) {
 	int v = from->value[i];
-	if (dst[v] == 0)
+	if (dst[v] == -2)
 	    continue;		/*ingore duplicates */
-	dst[v] = 0;
+	dst[v] = -2;		/* make sure all from nodes are processed first */
 	dglHeapData_u heap_data;
 	heap_data.ul = v;
-	dglHeapInsertMin(&heap, 0, ' ', heap_data);
+	dglHeapInsertMin(&heap, -2, ' ', heap_data);
     while (1) {
 	dglInt32_t v, dist;
@@ -80,13 +81,26 @@
 	dglEdgeset_T_Initialize(&et, graph,
 				dglNodeGet_OutEdgeset(graph,
 						      dglGetNode(graph, v)));
+	if (dglGet_NodeAttrSize(graph) > 0) {
+	    dglInt32_t ncost;
+	    memcpy(&ncost, dglNodeGet_Attr(graph, dglGetNode(graph, v)),
+		   sizeof(ncost));
+	    /* do not route paths through closed nodes */
+	    if (ncost < 0 && dist >= 0)
+		continue;
+	    dist += ncost;
 	for (edge = dglEdgeset_T_First(&et); edge;
 	     edge = dglEdgeset_T_Next(&et)) {
 	    dglInt32_t *to = dglEdgeGet_Tail(graph, edge);
 	    dglInt32_t to_id = dglNodeGet_Id(graph, to);
 	    dglInt32_t d = dglEdgeGet_Cost(graph, edge);
-	    if (dst[to_id] == -1 || dst[to_id] > dist + d) {
+	    if (dst[to_id] < 0 || dst[to_id] > dist + d) {
 		dst[to_id] = dist + d;
 		prev[to_id] = edge;
 		heap_data.ul = to_id;
@@ -105,7 +119,7 @@
    \brief Find a path (minimum number of edges) from 'from' to 'to' using only edges in 'edges'.
-   Precisely, edge with id I is used iff edges[abs(i)] == 1. List
+   Precisely, edge with id I is used if edges[abs(i)] == 1. List
    stores the indices of lines on the path. Method return number of
    edges or -1 if no path exist.
@@ -148,6 +162,16 @@
 	    break;
 	dglInt32_t *edge, *node = dglGetNode(graph, vertex);
+	    dglInt32_t ncost;
+	    memcpy(&ncost, dglNodeGet_Attr(graph, node), sizeof(ncost));
+	    if (ncost < 0 && vertex != from)
+		continue;
 				dglNodeGet_OutEdgeset(graph, node));
Modified: grass/trunk/lib/vector/rtree/node.c
--- grass/trunk/lib/vector/rtree/node.c	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/rtree/node.c	2013-06-23 19:25:47 UTC (rev 56890)
@@ -36,6 +36,7 @@
 static void RTreeInitNodeBranchM(struct RTree_Branch *b, struct RTree *t)
     RTreeInitRect(&(b->rect), t);
+    memset(&(b->child), 0, sizeof(union RTree_Child));
     b->child.ptr = NULL;
@@ -43,6 +44,7 @@
 static void RTreeInitNodeBranchF(struct RTree_Branch *b, struct RTree *t)
     b->child.pos = -1;
@@ -50,6 +52,7 @@
 static void RTreeInitLeafBranch(struct RTree_Branch *b, struct RTree *t)
     b->child.id = 0;
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox	2013-06-23 19:20:15 UTC (rev 56889)
+++ grass/trunk/lib/vector/vectorlib.dox	2013-06-23 19:25:47 UTC (rev 56890)
@@ -32,7 +32,7 @@
 (points, lines, boundaries, centroids, faces, kernels, and volumes),
 their spatial relations are also stored. In general, topological GIS
 requires a data structure where the common boundary between two
-adjacent areas is stored as a single line, simplifying the vector data
+adjacent areas is stored as a single boundary, simplifying vector data
 maintenance.
@@ -75,19 +75,24 @@
 GRASS vector maps are stored in an <em>arc-node</em> representation,
 consisting of curves called arcs. An arc is stored as a series of
-x,y,z coordinate pairs. The two endpoints of an arc are called
-<em>nodes</em>. Two consecutive x,y,z pairs define an arc segment. The
-user specifies the type of input to GRASS; GRASS doesn't decide. GRASS
+x,y,z coordinate pairs. Two consecutive x,y,z pairs define an arc segment.
+<em>Nodes</em> are created automatically for the two endpoints of an arc.
+The user specifies the type of input to GRASS; GRASS doesn't decide. GRASS
 supports feature type definition which allows for multiple types to
-co-exist in the same map. A centroid is assigned to the area it is
-within/inside (geometrically). An area is defined by one or more
-boundaries that form a losed ring. The category to which an area belongs
+co-exist in the same map. An area is defined by one or more
+boundaries that form a closed ring. A centroid is assigned to the area it is
+within/inside (geometrically). The category to which an area belongs
 is stored with the centroid. Such centroids are stored in the same binary
-'coor' file with other primitives. Each element may have none, one or
-more categories (cats). More cats can be distinguished by field number
-(field, called "layer" at user level).  Single and multi-category
-support on modules level are implemented. The z coordinate is optional
-and both 2D and 3D files may be written.
+'coor' file with other primitives. Areas without centroids are from a
+user's perspective holes within another area, therefore not presented to
+a user as a real area, the equivalent of a polygon in Simple Feature Access.
+Each vector object may have none, one or more categories (cats). More
+categories can be distinguished by field number (field, called "layer"
+at user level). A vector object can also have multiple categories in the
+same layer, an example would be buffers where a single area might belong
+to multiple buffers of multiple buffered features. Single and
+multi-category support on module level is implemented. The z coordinate
+is optional and both 2D and 3D files may be written.
 The following <em>vector feature types (primitives)</em> are defined
 by the vector library (and holds by the coor file; see also \ref
