[GRASS-SVN] r56893 - in grass/trunk/lib/python/pygrass: gis vector
Sun Jun 23 13:00:43 PDT 2013
Author: zarch
Date: 2013-06-23 13:00:42 -0700 (Sun, 23 Jun 2013)
New Revision: 56893
   grass/trunk/lib/python/pygrass/gis/region.py
   grass/trunk/lib/python/pygrass/vector/basic.py
Add '_repr_html_' to Region class and Bbox
Modified: grass/trunk/lib/python/pygrass/gis/region.py
--- grass/trunk/lib/python/pygrass/gis/region.py	2013-06-23 19:51:12 UTC (rev 56892)
+++ grass/trunk/lib/python/pygrass/gis/region.py	2013-06-23 20:00:42 UTC (rev 56893)
@@ -9,6 +9,7 @@
 import grass.script as grass
 from grass.pygrass.errors import GrassError
+from grass.pygrass.shell.conversion import dict2html
 class Region(object):
@@ -168,7 +169,7 @@
     @property
     def zone(self):
         """Return the zone of projection
         >>> reg = Region()
         >>> reg.zone
         0
@@ -178,19 +179,28 @@
     @property
     def proj(self):
         """Return a code for projection
         >>> reg = Region()
         >>> reg.proj
         99
         return self.c_region.contents.proj
+    @property
+    def cells(self):
+        """Return the number of cells"""
+        return self.rows * self.cols
     #----------MAGIC METHODS----------
     def __repr__(self):
         return 'Region(n=%g, s=%g, e=%g, w=%g, nsres=%g, ewres=%g)' % (
                self.north, self.south, self.east, self.west,
                self.nsres, self.ewres)
+    def _repr_html_(self):
+        return dict2html(dict(self.items()), keys=self.keys(),
+                         border='1', kdec='b')
     def __unicode__(self):
         return grass.pipe_command("g.region", flags="p").communicate()[0]
@@ -205,22 +215,14 @@
                 return False
         return True
-    def iteritems(self):
-        return [('projection', self.proj),
-                ('zone', self.zone),
-                ('north', self.north),
-                ('south', self.south),
-                ('west', self.west),
-                ('east', self.east),
-                ('top', self.top),
-                ('bottom', self.bottom),
-                ('nsres', self.nsres),
-                ('ewres', self.ewres),
-                ('tbres', self.tbres),
-                ('rows', self.rows),
-                ('cols', self.cols),
-                ('cells', self.rows * self.cols)]
+    def keys(self):
+        return ['proj', 'zone', 'north', 'south', 'west', 'east',
+                'top', 'bottom', 'nsres', 'ewres', 'tbres', 'rows',
+                'cols', 'cells']
+    def items(self):
+        return [(k, self.__getattribute__(k)) for k in self.keys()]
     #----------METHODS----------
     def zoom(self, raster_name):
         """Shrink region until it meets non-NULL data from this raster map:"""
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py	2013-06-23 19:51:12 UTC (rev 56892)
+++ grass/trunk/lib/python/pygrass/vector/basic.py	2013-06-23 20:00:42 UTC (rev 56893)
@@ -8,7 +8,9 @@
 import grass.lib.vector as libvect
 from collections import Iterable
 class Bbox(object):
     """Instantiate a Bounding Box class that contains
     a ctypes pointer to the C struct bound_box, that could be used
@@ -109,6 +111,13 @@
         return "Bbox({n}, {s}, {e}, {w})".format(n=self.north, s=self.south,
                                                  e=self.east, w=self.west)
+    def keys(self):
+        return ['north', 'south', 'west', 'east', 'top', 'bottom']
     def contains(self, point):
         """Return True if the object is contained by the BoundingBox. ::
@@ -125,17 +134,15 @@
                                               self.c_bbox))
     def items(self):
-        return [('north', self.north), ('south', self.south),
-                ('east', self.east), ('west', self.west),
-                ('top', self.top), ('bottom', self.bottom)]
-    def nsewtb(self, is3d=False):
+    def nsewtb(self, tb=True):
         """Return a list
-        If is3d parameter is False return only:
+        If tb parameter is False return only:
         north, south, east, west
-        if is3d:
+        if tb:
             return (self.north, self.south, self.east, self.west,
                     self.top, self.bottom)
         else:
