[GRASS-SVN] r56898 - grass/branches/develbranch_6/gui/wxpython/docs
Sun Jun 23 13:13:50 PDT 2013
Author: hamish
Date: 2013-06-23 13:13:50 -0700 (Sun, 23 Jun 2013)
New Revision: 56898
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
historic helpers (thanks Helena), merge from trunk
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2013-06-23 20:11:31 UTC (rev 56897)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2013-06-23 20:13:50 UTC (rev 56898)
@@ -350,7 +350,7 @@
 (the default color is white).
-<h2>To be implement</h2>
+<h2>To be implemented</h2>
 <ul>
   <li>Labels, decoration, etc. (Implemented, but not fully functional)</li>
@@ -365,14 +365,16 @@
 distributed as "Experimental Prototype".
 <p>
-Please note that with wxGTK port of wxPython (Linux systems),
-a problem might appear during wxNviz initialization (nothing is rendered at all)
-or when rendering vectors (bad order of rendering surfaces and vectors).
-If you encounter such problems, try to change a depth buffer number
-in GUI Settings > Map Display  > Advanced (possible numbers are 0, 16, 24, 32).
-It is currently not possible to automatically find out the right number which is working for your computer.
+Please note that with wxGTK port of wxPython (Linux systems), a problem might
+appear during wxNviz initialization (nothing is rendered at all) or when
+rendering vectors (bad order of rendering surfaces and vectors). If you
+encounter such problems, try to change a depth buffer number in GUI Settings
+> Map Display > Advanced (possible numbers are 0, 16, 24, 32). It is
+currently not possible to automatically find out the right number which is
+working for your computer.
 </p>
 <h2>SEE ALSO</h2>
 <em>
@@ -390,15 +392,49 @@
 Command-line module <em><a href="m.nviz.image.html">m.nviz.image</a></em>.
 <br><br>
-Original <a href="nviz.html">TCL/TK-based</a> Nviz.
+Original <a href="nviz.html">Tcl/Tk-based</a> NVIZ.
 <h2>AUTHORS</h2>
+<b>The wxNviz GUI</b>
+<p>
 <a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
 Landa</a>, <a href="http://grasswiki.osgeo.org/wiki/WxNviz_GSoC_2008">Google
 Summer of Code 2008</a> (mentor: Michael Barton)
-and <a href="http://grasswiki.osgeo.org/wiki/WxNviz_GSoC_2010">Google
-Summer of Code 2010</a> (mentor: Helena Mitasova)
+and <a href="http://grasswiki.osgeo.org/wiki/WxNviz_GSoC_2010">2010</a>
+ (mentor: Helena Mitasova)<br>
+Anna Kratochvilova, <a href="http://grasswiki.osgeo.org/wiki/WxNviz_GSoC_2011">Google
+Summer of Code 2011</a> (mentor: Martin Landa)
 <p>
+<b>The OGSF library and NVIZ engine</b>
+<p>
+NVIZ (GRASS's <i>n</i>-dimensional visualization suite) was written
+by Bill Brown, Terry Baker, Mark Astley, and David Gerdes,
+U.S. Army Corps of Engineers Research Laboratories, Champaign,
+Illinois and UI GMS Laboratory, Urbana, IL in the early 1990s.
+<p>
+Original documentation was written by Terry Baker (spring 1995), and
+updated by Mark Astley, based on a document written by Bill Brown.
+Additional design help and funding in the early 1990s by Helena
+Mitasova (CERL). Tcl/Tk support added by Terry Baker. Ported to Linux
+by Jaro Hofierka and others. Conversion from SGI IRIS GL code to
+OpenGL by Justin Hickey. Further program and documentation (2004)
+updates by Bob Covill, Tekmap Consulting. 3D volume support by Tomas
+Paudits with supervision from Jaro Hofierka and Helena Mitasova.
+Fly-through mode, thematic site attributes, and picking by Massimo
+Cuomo (ACS) with updates by Michael Barton. GRASS 6 vector support by
+Radim Blazek. Additional updates by Markus Neteler, Martin Landa,
+Glynn Clements, and Hamish Bowman.
+<p>
+NVIZ evolved from the earlier GRASS program <em>SG3d</em> written
+for Silicon Graphics IRIS GL by Bill Brown and Dave Gerdes at USA
+CERL, 1990-1995 and from the NVIZ Motif version written by Bill Brown
+with contributions by Terrance McGhee.
+<p>
 <i>$Date$</i>
