[GRASS-SVN] r56959 - in grass/trunk/raster3d: . r3.neighbors r3.neighbors/test_suite
Sun Jun 30 15:26:22 PDT 2013
Author: huhabla
Date: 2013-06-30 15:26:22 -0700 (Sun, 30 Jun 2013)
New Revision: 56959
Added:
   grass/trunk/raster3d/r3.neighbors/
   grass/trunk/raster3d/r3.neighbors/Makefile
   grass/trunk/raster3d/r3.neighbors/main.c
   grass/trunk/raster3d/r3.neighbors/r3.neighbors.html
   grass/trunk/raster3d/r3.neighbors/test_suite/
   grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
   grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_average.ref
   grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_sum.ref
   grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_average.ref
   grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_sum.ref
   grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_null_sum.ref
   grass/trunk/raster3d/Makefile
New module to perform voxel neighborhood operations
Modified: grass/trunk/raster3d/Makefile
--- grass/trunk/raster3d/Makefile	2013-06-30 00:59:17 UTC (rev 56958)
+++ grass/trunk/raster3d/Makefile	2013-06-30 22:26:22 UTC (rev 56959)
@@ -10,6 +10,7 @@
 	r3.mask \
 	r3.mkdspf \
 	r3.null \
+	r3.neighbors \
 	r3.out.ascii \
 	r3.out.bin \
 	r3.out.netcdf \
Added: grass/trunk/raster3d/r3.neighbors/Makefile
--- grass/trunk/raster3d/r3.neighbors/Makefile	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/Makefile	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r3.neighbors
+LIBES = $(RASTERLIB) $(RASTER3DLIB) $(GISLIB) $(STATSLIB)
+DEPENDENCIES = $(RASTERDEP) $(RASTER3DDEP) $(GISDEP) $(STATSDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster3d/r3.neighbors/main.c
--- grass/trunk/raster3d/r3.neighbors/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/main.c	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,310 @@
+ * MODULE:       r3.neighbors
+ * AUTHOR(S):    Original author
+ *               Soeren Gebbert soerengebbert <at> googlemail <dot> co
+ *               with code from r.series and r.neighbors for parameter menu handling
+ * PURPOSE:      Makes each voxel value a function of the values assigned to the voxels
+ *               around it, and stores new voxel values in an output 3D raster map
+ * COPYRIGHT:    (C) 2013 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/raster3d.h>
+#include <grass/stats.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+int nx, ny, nz;					/* Number of cells in x, y and z direction */
+int x_dist, y_dist, z_dist;		/* Distance of cells from the center
+								   to the edge of the moving window */
+int x_size, y_size, z_size;		/* The size of the moving window in x,
+								   y and z direction */
+int size;                       /* The maximum size of the value buffer */
+struct menu
+	stat_func *method;			/* routine to compute new value */
+	char *name;					/* method name */
+	char *text;					/* menu display - full description */
+} menu[] = {
+        {c_ave, "average", "average value"},
+        {c_median, "median", "median value"},
+        {c_mode, "mode", "most frequently occuring value"},
+        {c_min, "minimum", "lowest value"},
+        {c_max, "maximum", "highest value"},
+        {c_range, "range", "range value"},
+        {c_stddev, "stddev", "standard deviation"},
+        {c_sum, "sum", "sum of values"},
+        {c_count, "count", "count of non-NULL values"},
+        {c_var, "variance", "statistical variance"},
+        {c_divr, "diversity", "number of different values"},
+        {c_intr, "interspersion", "number of values different than center value"},
+        {c_quart1, "quart1", "first quartile"},
+        {c_quart3, "quart3", "third quartile"},
+        {c_perc90, "perc90", "ninetieth percentile"},
+        {c_quant, "quantile", "arbitrary quantile"},
+        {NULL, NULL, NULL}
+static char *build_method_list(void)
+	char *buf = G_malloc(1024);
+	char *p = buf;
+	int i;
+	for (i = 0; menu[i].name; i++) {
+		char *q;
+		if (i)
+			*p++ = ',';
+		for (q = menu[i].name; *q; p++, q++)
+			*p = *q;
+	*p = '\0';
+	return buf;
+static int find_method(const char *method_name)
+	int i;
+		if (strcmp(menu[i].name, method_name) == 0)
+			return i;
+	G_fatal_error(_("Unknown method <%s>"), method_name);
+	return -1;
+typedef struct
+    struct Option *input, *output, *window, *method, *quantile;
+} paramType;
+paramType param;
+static void set_params()
+	param.input = G_define_standard_option(G_OPT_R3_INPUT);
+	param.output = G_define_standard_option(G_OPT_R3_OUTPUT);
+	param.method = G_define_option();
+	param.method->key = "method";
+	param.method->type = TYPE_STRING;
+	param.method->required = YES;
+	param.method->options = build_method_list();
+	param.method->description = _("Aggregate operation");
+	param.method->multiple = NO;
+	param.quantile = G_define_option();
+	param.quantile->key = "quantile";
+	param.quantile->type = TYPE_DOUBLE;
+	param.quantile->required = NO;
+	param.quantile->description =
+		_("Quantile to calculate for method=quantile");
+	param.quantile->options = "0.0-1.0";
+	param.quantile->multiple = NO;
+	param.window = G_define_option();
+	param.window->key = "window";
+	param.window->type = TYPE_INTEGER;
+	param.window->required = YES;
+	param.window->key_desc = "x,y,z";
+	param.window->description =
+		_("The size of the window in x, y and z direction,"
+		  " values must be odd integer numbers, eg: 3,3,3");
+static int gather_values(RASTER3D_Map * map, DCELL * buff, int x,
+                         int y, int z)
+    int i, j, k, l;
+    DCELL value;
+    int start_z = z - z_dist;
+    int start_y = y - y_dist;
+    int start_x = x - x_dist;
+    int end_z = start_z + z_size;
+    int end_y = start_y + y_size;
+    int end_x = start_x + x_size;
+    if (start_z < 0)
+        start_z = 0;
+    if (start_y < 0)
+        start_y = 0;
+    if (start_x < 0)
+        start_x = 0;
+    if (end_z > nz)
+        end_z = nz;
+    if (end_y > ny)
+        end_y = ny;
+    if (end_x > nx)
+        end_x = nx;
+    l = 0;
+    for (i = start_z; i < end_z; i++) {
+        for (j = start_y; j < end_y; j++) {
+            for (k = start_x; k < end_x; k++) {
+                value = (DCELL) Rast3d_get_double(map, k, j, i);
+                if(Rast_is_d_null_value(&value))
+                    continue;
+                buff[l] = value;
+                l++;
+    return l;
+int main(int argc, char **argv)
+	RASTER3D_Map *input;
+	RASTER3D_Map *output;
+	RASTER3D_Region region;
+	struct GModule *module;
+	stat_func *method_fn;
+	double quantile;
+    int x, y, z;
+	/* Initialize GRASS */
+	G_gisinit(argv[0]);
+	module = G_define_module();
+	G_add_keyword(_("raster3d"));
+	G_add_keyword(_("neighbor"));
+	G_add_keyword(_("aggregation"));
+    G_add_keyword(_("statistics"));
+    G_add_keyword(_("filter"));
+    module->description =
+    _("Makes each voxel value a "
+    "function of the values assigned to the voxels "
+    "around it, and stores new voxel values in an output 3D raster map");
+	/* Get parameters from user */
+	set_params();
+	if (G_parser(argc, argv))
+		exit(EXIT_FAILURE);
+	if (NULL == G_find_raster3d(param.input->answer, ""))
+		Rast3d_fatal_error(_("3D raster map <%s> not found"),
+						   param.input->answer);
+	Rast3d_init_defaults();
+	Rast3d_get_window(&region);
+	nx = region.cols;
+	ny = region.rows;
+	nz = region.depths;
+	/* Size fo the moving window */
+	x_size = atoi(param.window->answers[0]);
+	y_size = atoi(param.window->answers[1]);
+	z_size = atoi(param.window->answers[2]);
+    /* Distances in all directions */
+    x_dist = x_size / 2;
+    y_dist = y_size / 2;
+    z_dist = z_size / 2;
+    /* Maximum size of the buffer */
+	size = x_size * y_size * z_size;
+	/* Set the computation method */
+	method_fn = menu[find_method(param.method->answer)].method;
+    if(param.quantile->answer)
+        quantile = atof(param.quantile->answer);
+    else
+        quantile = 0.0;
+	input = Rast3d_open_cell_old(param.input->answer,
+								 G_find_raster3d(param.input->answer, ""),
+								 &region, RASTER3D_TILE_SAME_AS_FILE,
+								 RASTER3D_USE_CACHE_DEFAULT);
+	if (input == NULL)
+		Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+	output =
+		Rast3d_open_new_opt_tile_size(param.output->answer,
+									  RASTER3D_USE_CACHE_X, &region,
+									  DCELL_TYPE, 32);
+	if (output == NULL)
+						   param.output->answer);
+	Rast3d_min_unlocked(output, RASTER3D_USE_CACHE_X);
+	Rast3d_autolock_on(output);
+	Rast3d_unlock_all(output);
+    DCELL *buff = NULL, value;
+    buff = (DCELL *) calloc(size, sizeof(DCELL));
+    if (buff == NULL)
+        Rast3d_fatal_error(_("Unable to allocate buffer"));
+	for (z = 0; z < nz; z++) {
+		for (y = 0; y < ny; y++) {
+			for (x = 0; x < nx; x++) {
+				/* Gather values in moving window */
+				int num = gather_values(input, buff, x, y, z);
+                /* Compute the resulting value */
+                if(num > 0)
+                    (*method_fn) (&value, buff, num, &quantile);
+                else
+                    Rast_set_d_null_value(&value, 1);
+                /* Write the value */
+				Rast3d_put_double(output, x, y, z, value);
+    free(buff);
+	if (!Rast3d_flush_all_tiles(output))
+		G_fatal_error(_("Error flushing tiles"));
+    Rast3d_autolock_off(output);
+	Rast3d_close(input);
+	Rast3d_close(output);
+	return 0;
Added: grass/trunk/raster3d/r3.neighbors/r3.neighbors.html
--- grass/trunk/raster3d/r3.neighbors/r3.neighbors.html	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/r3.neighbors.html	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,115 @@
+<h2>DESCRIPTION</h2>
+<em><b>r3.neighbors</b></em> looks at each voxel in a 3D raster input
+map layer, and examines the values assigned to the
+voxel in a user-defined "neighborhood" around it.  It
+outputs a new 3D raster map in which each voxel is
+assigned a value that is a (user-specified)
+function of the values in that voxel's neighborhood.  For
+example, each voxel in the output map might be assigned a
+value equal to the average of the values
+appearing in its 3 x 3 x 3 voxel "neighborhood" in the input
+map layer.
+<h3>OPTIONS</h3>
+The user must specify the names of the 3D raster map layers to
+be used for <b>input</b> and <b>output</b>, the
+<b>method</b> used to analyze neighborhood
+values (i.e., the neighborhood function or operation to be
+performed), and the moving <b>window</b> of the neighborhood.
+<p>
+<em>Neighborhood Operation Methods:</em>
+The <b>neighborhood</b> operators determine what new
+value a center voxel in a neighborhood will have after examining
+values inside its neighboring voxels.
+Each voxel in a 3D raster map layer becomes the center voxel of a neighborhood
+as the neighborhood window moves from voxel to voxel throughout the map layer.
+<em><b>r3.neighbors</b></em> can perform the following operations:
+<p><dl>
+<dt><b>average</b>
+<dd>The average value within the neighborhood.
+<dt><b>median</b>
+<dd>The value found half-way through a list of the
+neighborhood's values,
+when these are ranged in numerical order.
+<dt><b>mode</b>
+<dd>The most frequently occurring value in the neighborhood.
+<dt><b>minimum</b>
+<dd>The minimum value within the neighborhood.
+<dt><b>maximum</b>
+<dd>The maximum value within the neighborhood.
+<dt><b>range</b>
+<dd>The range value within the neighborhood.
+<dt><b>stddev</b>
+<dd>The statistical standard deviation of values
+within the neighborhood.
+<dt><b>sum</b>
+<dd>The sum of values within the neighborhood.
+<dt><b>variance</b>
+<dd>The statistical variance of values
+<dt><b>diversity</b>
+<dd>The number of different values within the neighborhood.
+<dt><b>interspersion</b>
+<dd>The percentage of voxels containing values which differ from the values
+assigned to the center voxel in the neighborhood, plus 1.
+</dl>
+<p><br>
+<em>Neighborhood Size:</em>
+The neighborhood moving <b>window</b> specifies which voxel surrounding any given
+voxel fall into the neighborhood for that voxel.
+The <b>window</b> must be three comma separated odd integers. The dimension order is: x,y,z.
+For example: the parameter window=3,3,3 specifies a moving window (a cube) with 27 voxel.
+<p>
+<h2>NOTES</h2>
+The <em><b>r3.neighbors</b></em> program works in the current geographic region.
+It is recommended, but not required,
+that the 3D resolution of the geographic region be the same as that
+of the 3D raster map layer.
+<p>
+<em><b>r3.neighbors</b></em> doesn't propagate NULLs, but computes the
+aggregation over the non-NULL voxels in the neighborhood.
+<p>
+<h2>SEE ALSO</h2>
+<em><a href="g.region.html">g.region</a></em><br>
+<em><a href="r.neighbors.html">r.neighbors</a></em><br>
+<em><a href="r3.mapcalc.html">r3.mapcalc</a></em><br>
+<em><a href="r3.stats.html">r3.stats</a></em><br>
+<em><a href="r3.support.html">r3.support</a></em>
+<h2>AUTHOR</h2>
+Soeren Gebbert
+<p><i>Last changed: $Date: 2011-11-08 22:24:20 +0100 (Di, 08. Nov 2011) $</i>
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
--- grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,33 @@
+#!/bin/sh
+g.region w=0 e=30 s=0 n=30 b=0 t=30 res3=10
+r3.mapcalc --o expr="test_neighbor_float  = float(3)"
+r3.mapcalc --o expr="test_neighbor_double = double(3)"
+r3.mapcalc --o expr="test_neighbor_null = null()"
+# First @test with float values with @precision=2
+r3.neighbors input=test_neighbor_float output=test_neighbor_float_average \
+    method=average window=3,3,3 --o
+r3.out.ascii dp=2 input=test_neighbor_float_average output=test_neighbor_float_average.txt
+r3.neighbors input=test_neighbor_float output=test_neighbor_float_sum \
+    method=sum window=3,3,3 --o
+r3.out.ascii dp=2 input=test_neighbor_float_sum output=test_neighbor_float_sum.txt
+# Second @test with double values
+r3.neighbors input=test_neighbor_double output=test_neighbor_double_average \
+r3.out.ascii dp=2 input=test_neighbor_double_average output=test_neighbor_double_average.txt
+r3.neighbors input=test_neighbor_double output=test_neighbor_double_sum \
+r3.out.ascii dp=2 input=test_neighbor_double_sum output=test_neighbor_double_sum.txt
+# Third @test with null values
+r3.neighbors input=test_neighbor_null output=test_neighbor_null_sum \
+r3.out.ascii dp=2 input=test_neighbor_null_sum output=test_neighbor_null_sum.txt
Property changes on: grass/trunk/raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_average.ref
--- grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_average.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_average.ref	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,20 @@
+version: grass7
+order: nsbt
+north: 30.000000
+south: 0.000000
+east: 30.000000
+west: 0.000000
+top: 30.000000
+bottom: 0.000000
+rows: 3
+cols: 3
+levels: 3
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_sum.ref
--- grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_sum.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_double_sum.ref	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,20 @@
+version: grass7
+order: nsbt
+north: 30.000000
+south: 0.000000
+east: 30.000000
+west: 0.000000
+top: 30.000000
+bottom: 0.000000
+rows: 3
+cols: 3
+levels: 3
+24.00 36.00 24.00
+36.00 54.00 36.00
+24.00 36.00 24.00
+36.00 54.00 36.00
+54.00 81.00 54.00
+36.00 54.00 36.00
+24.00 36.00 24.00
+36.00 54.00 36.00
+24.00 36.00 24.00
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_average.ref
--- grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_average.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_average.ref	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,20 @@
+version: grass7
+order: nsbt
+north: 30.000000
+south: 0.000000
+east: 30.000000
+west: 0.000000
+top: 30.000000
+bottom: 0.000000
+rows: 3
+cols: 3
+levels: 3
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
+3.00 3.00 3.00
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_sum.ref
--- grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_sum.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_float_sum.ref	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,20 @@
+version: grass7
+order: nsbt
+north: 30.000000
+south: 0.000000
+east: 30.000000
+west: 0.000000
+top: 30.000000
+bottom: 0.000000
+rows: 3
+cols: 3
+levels: 3
+24.00 36.00 24.00
+36.00 54.00 36.00
+24.00 36.00 24.00
+36.00 54.00 36.00
+54.00 81.00 54.00
+36.00 54.00 36.00
+24.00 36.00 24.00
+36.00 54.00 36.00
+24.00 36.00 24.00
Added: grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_null_sum.ref
--- grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_null_sum.ref	                        (rev 0)
+++ grass/trunk/raster3d/r3.neighbors/test_suite/test_neighbor_null_sum.ref	2013-06-30 22:26:22 UTC (rev 56959)
@@ -0,0 +1,20 @@
+version: grass7
+order: nsbt
+north: 30.000000
+south: 0.000000
+east: 30.000000
+west: 0.000000
+top: 30.000000
+bottom: 0.000000
+rows: 3
+cols: 3
+levels: 3
