[GRASS-SVN] r55369 - grass-addons/grass7/gui/wxpython/newgui
Wed Mar 13 14:57:42 PDT 2013
Author: rashadkm
Date: 2013-03-13 14:57:41 -0700 (Wed, 13 Mar 2013)
New Revision: 55369
   grass-addons/grass7/gui/wxpython/newgui/api_test.py
   grass-addons/grass7/gui/wxpython/newgui/frame.py
newgui(toolbar decoupled)
Modified: grass-addons/grass7/gui/wxpython/newgui/api_test.py
--- grass-addons/grass7/gui/wxpython/newgui/api_test.py	2013-03-13 19:05:23 UTC (rev 55368)
+++ grass-addons/grass7/gui/wxpython/newgui/api_test.py	2013-03-13 21:57:41 UTC (rev 55369)
@@ -38,15 +38,23 @@
 from gui_core.mapdisp   import MapFrameBase
 import gettext
 import core.render as render
-from core.render        import Map, MapLayer
+from render2        import Map, MapLayer
 from core.gcmd          import RunCommand, GMessage
 from core.debug          import Debug
-from lmgr.lmgr_layertree import LMIcons
+from lmgr.layertree import LMIcons
 from gui_core.toolbars   import BaseIcons
 from icons.icon          import MetaIcon
 from core.utils          import GetLayerNameFromCmd
+class ToolBarNames:
+    NEWDISPLAY = { "monitor-create" :   [wx.NewId(),     _('Start new map display')] }
+    WORKSPACENEW = { "create" :         [wx.NewId(),     _('Create new workspace (Ctrl+N)')] }
+    WORKSPACEOPEN ={ "open" :           [wx.NewId(),     _('Open existing workspace file (Ctrl+O')] }
+    WORKSPACESAVE ={ "save" :           [wx.NewId(),     _('Save current workspace to file (Ctrl+S)')] }
+    ADDRASTER = { "layer-raster-add" :  [wx.NewId(),     _("Add raster map layer")] }
+    ADDVECTOR = { "layer-vector-add" :  [wx.NewId(),     _("Add vector map layer")] }
 class MySingleMapFrame(MapFrameBase):
     """! Frame with one map window.
@@ -82,26 +90,44 @@
         vbox = wx.BoxSizer(wx.HORIZONTAL)
         p = wx.Panel(self,-1)
         #self.ltree = LayerTree(self, self.Map)
         # initialize region values
         self._initMap(Map = self.Map)
         self._lmgr = LayerManager(p,self.Map)
         self.MapWindow = BufferedWindow2(p, giface = giface, id = id, Map = self.Map)
+        self.toolbar = None
         vbox.Add(self._lmgr, 1, wx.EXPAND | wx.ALL, 20)
         vbox.Add(self.MapWindow, 1, wx.EXPAND | wx.ALL, 20)
         p.SetSizer(vbox)
+    def CreateWxToolBar(self):
+        self.toolbar = self.CreateToolBar()
+    def AddToolBarItem(self, tname, func):
+        if self.toolbar is None:
+            raise "ToolBar not created"
+        label = tname.keys()[0]
+        tid = tname.values()[0][0]
+        tooltip = tname.values()[0][1]
+        self.toolbar.AddLabelTool(tid, label, self.GetIcon(label), shortHelp = tooltip)
+        wx.EVT_TOOL( self, tid, func )
+    def GetIcon(self, tname):
+        return MetaIcon(img = tname).GetBitmap()
     def GetLayerByIndex(self, index):
         return self.GetLayerManager().GetLayerByIndex(index)
Modified: grass-addons/grass7/gui/wxpython/newgui/frame.py
--- grass-addons/grass7/gui/wxpython/newgui/frame.py	2013-03-13 19:05:23 UTC (rev 55368)
+++ grass-addons/grass7/gui/wxpython/newgui/frame.py	2013-03-13 21:57:41 UTC (rev 55369)
@@ -22,7 +22,9 @@
 from api_test           import MySingleMapFrame
-from core.render        import MapLayer
+from api_test       import ToolBarNames
+from render2        import MapLayer
+from lmgr.toolbars         import LMWorkspaceToolbar
 class MyFrame(MySingleMapFrame):
     """!main frame
@@ -42,10 +44,18 @@
         self.cmd =["d.rast", "map=aspect at PERMANENT"]
         self.rlayer = MapLayer(ltype = 'raster', cmd = self.cmd, Map = self.GetMap(), name = "elevation")
         self.AddLayer(self.rlayer)
+        #LMWorkspaceToolbar(self)
+        self.CreateWxToolBar()
+        self.AddToolBarItem(ToolBarNames.NEWDISPLAY, self.dummyfunc)
+        self.AddToolBarItem(ToolBarNames.WORKSPACENEW,self.dummyfunc)
+        self.AddToolBarItem(ToolBarNames.ADDRASTER,self.dummyfunc)
+        self.AddToolBarItem(ToolBarNames.ADDVECTOR,self.dummyfunc)
         #print self.GetLayerByIndex(0).name
         #print self.GetCurrentIndex()
+    def dummyfunc(self,event):
+        xx =1
+        print xx
 def main():
