[GRASS-SVN] r55404 - grass/trunk/lib/init
Sat Mar 16 10:37:26 PDT 2013
Author: martinl
Date: 2013-03-16 10:37:26 -0700 (Sat, 16 Mar 2013)
New Revision: 55404
   grass/trunk/lib/init/variables.html
document GRASS_VECTOR_OGR env variable
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2013-03-16 17:21:16 UTC (rev 55403)
+++ grass/trunk/lib/init/variables.html	2013-03-16 17:37:26 UTC (rev 55404)
@@ -237,6 +237,13 @@
     consumption will be reduced when building vector topology
     support structures. Recommended for creating large vectors.</dd>
+  <dt>GRASS_VECTOR_OGR</dt>
+  <dd>[vectorlib, v.external.out]<br> If the environment variable
+    GRASS_VECTOR_OGR exists and vector output format defined
+    by <em><a href="v.external.out.html">v.external.out</a></em> is
+    PostgreSQL, vector data is written by OGR data provider even
+    the native PostGIS data provider is available.</dd>
   <dt>GRASS_WXBUNDLED</dt>
   <dd>[wxGUI]<br>
     set to tell wxGUI that a bundled wxPython will be used.<br>
