[GRASS-SVN] r55413 - in grass/trunk: . include/Make
Sun Mar 17 14:49:29 PDT 2013
Author: glynn
Date: 2013-03-17 14:49:29 -0700 (Sun, 17 Mar 2013)
New Revision: 55413
   grass/trunk/aclocal.m4
   grass/trunk/configure
   grass/trunk/include/Make/Platform.make.in
Remove unused variables
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2013-03-17 17:24:46 UTC (rev 55412)
+++ grass/trunk/aclocal.m4	2013-03-17 21:49:29 UTC (rev 55413)
@@ -475,38 +475,31 @@
 AC_DEFUN([SC_CONFIG_CFLAGS], [
     SHLIB_CFLAGS=""
     SHLIB_LD_FLAGS=""
-    SHLIB_LD_LIBS=""
     SHLIB_SUFFIX=""
     SHLIB_LD=""
     STLIB_LD='${AR} cr'
     STLIB_SUFFIX='.a'
     LDFLAGS=""
-    CC_SEARCH_FLAGS=""
     LD_SEARCH_FLAGS=""
     LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
-    PLAT_OBJS=""
     case $host in
         *-linux-*)
 	    SHLIB_CFLAGS="-fPIC"
             SHLIB_LD_FLAGS=""
-	    SHLIB_LD_LIBS='${LIBS}'
 	    SHLIB_SUFFIX=".so"
 	    SHLIB_LD="${CC} -shared"
             LDFLAGS="-Wl,--export-dynamic"
-            CC_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
-            LD_SEARCH_FLAGS=${CC_SEARCH_FLAGS}
+            LD_SEARCH_FLAGS='-Wl,-rpath-link,${LIB_RUNTIME_DIR}'
         *-pc-cygwin)
             SHLIB_SUFFIX=".dll"
 	    LD_LIBRARY_PATH_VAR="PATH"
         *-pc-mingw32 | *-pc-msys)
             SHLIB_SUFFIX=".dll"
             LDFLAGS="-Wl,--export-dynamic,--enable-runtime-pseudo-reloc"
@@ -514,7 +507,6 @@
 	*-apple-darwin*)
 	    SHLIB_CFLAGS="-fno-common"
 	    SHLIB_SUFFIX=".dylib"
 	    SHLIB_LD="cc -dynamiclib -compatibility_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -current_version \${GRASS_VERSION_MAJOR}.\${GRASS_VERSION_MINOR} -install_name \${INST_DIR}/lib/lib\${LIB_NAME}\${SHLIB_SUFFIX}"
 	    LD_LIBRARY_PATH_VAR="DYLD_LIBRARY_PATH"
@@ -529,15 +521,13 @@
             if test "$GCC" = "yes" ; then
                 SHLIB_LD="$CC -shared"
-                CC_SEARCH_FLAGS='-Wl,-R,${LIB_RUNTIME_DIR}'
+                LD_SEARCH_FLAGS='-Wl,-R,${LIB_RUNTIME_DIR}'
             else
                 SHLIB_CFLAGS="-KPIC"
                 SHLIB_LD="/usr/ccs/bin/ld -G -z text"
-                CC_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
+                LD_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
             fi
             SHLIB_SUFFIX=".so"
@@ -545,15 +535,12 @@
     esac
-    AC_SUBST(PLAT_OBJS)
     AC_SUBST(LDFLAGS)
-    AC_SUBST(CC_SEARCH_FLAGS)
     AC_SUBST(LD_SEARCH_FLAGS)
     AC_SUBST(LD_LIBRARY_PATH_VAR)
     AC_SUBST(SHLIB_LD)
     AC_SUBST(SHLIB_LD_FLAGS)
-    AC_SUBST(SHLIB_LD_LIBS)
     AC_SUBST(SHLIB_CFLAGS)
     AC_SUBST(SHLIB_SUFFIX)
Modified: grass/trunk/configure
--- grass/trunk/configure	2013-03-17 17:24:46 UTC (rev 55412)
+++ grass/trunk/configure	2013-03-17 21:49:29 UTC (rev 55413)
@@ -1473,38 +1473,31 @@
     SHLIB_CFLAGS=""
     SHLIB_LD_FLAGS=""
-    SHLIB_LD_LIBS=""
     SHLIB_SUFFIX=""
     SHLIB_LD=""
     STLIB_LD='${AR} cr'
     STLIB_SUFFIX='.a'
     LDFLAGS=""
     LD_SEARCH_FLAGS=""
-    PLAT_OBJS=""
     case $host in
         *-linux-*)
             SHLIB_LD_FLAGS=""
 	    SHLIB_SUFFIX=".so"
         *-pc-cygwin)
             SHLIB_SUFFIX=".dll"
             SHLIB_SUFFIX=".dll"
@@ -1512,7 +1505,6 @@
 	*-apple-darwin*)
@@ -1533,15 +1525,13 @@
             else
             fi
             SHLIB_SUFFIX=".so"
@@ -1552,14 +1542,11 @@
@@ -2230,7 +2217,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2234: checking for additional include dirs" >&5
+echo "configure:2221: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2253,7 +2240,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2257: checking for additional library dirs" >&5
+echo "configure:2244: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2287,7 +2274,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2291: checking for a BSD compatible install" >&5
+echo "configure:2278: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2340,7 +2327,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2344: checking for $ac_word" >&5
+echo "configure:2331: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2371,13 +2358,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2375: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2362: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 2381 "configure"
+#line 2368 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2388,7 +2375,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2413,7 +2400,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2417: checking for $ac_word" >&5
+echo "configure:2404: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2453,7 +2440,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2457: checking for $ac_word" >&5
+echo "configure:2444: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2484,7 +2471,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2488: checking for $ac_word" >&5
+echo "configure:2475: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2522,7 +2509,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2526: checking for $ac_word" >&5
+echo "configure:2513: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2551,7 +2538,7 @@
-echo "configure:2555: checking for $ac_word" >&5
+echo "configure:2542: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2582,7 +2569,7 @@
-echo "configure:2586: checking for $ac_word" >&5
+echo "configure:2573: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2611,7 +2598,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2615: checking for $ac_word" >&5
+echo "configure:2602: checking for $ac_word" >&5
 case "$PERL" in
@@ -2642,7 +2629,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2646: checking how to run the C preprocessor" >&5
+echo "configure:2633: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2655,13 +2642,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2659 "configure"
+#line 2646 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2672,13 +2659,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2676 "configure"
+#line 2663 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2689,13 +2676,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2693 "configure"
+#line 2680 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2719,10 +2706,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2723: checking for ANSI C header files" >&5
+echo "configure:2710: checking for ANSI C header files" >&5
-#line 2726 "configure"
+#line 2713 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2730,7 +2717,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2747,7 +2734,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2751 "configure"
+#line 2738 "configure"
 #include <string.h>
 EOF
@@ -2765,7 +2752,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2769 "configure"
+#line 2756 "configure"
 #include <stdlib.h>
 EOF
@@ -2786,7 +2773,7 @@
 else
-#line 2790 "configure"
+#line 2777 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2797,7 +2784,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2824,15 +2811,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2828: checking for $ac_hdr" >&5
+echo "configure:2815: checking for $ac_hdr" >&5
-#line 2831 "configure"
+#line 2818 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2861,15 +2848,15 @@
 do
-echo "configure:2865: checking for $ac_hdr" >&5
+echo "configure:2852: checking for $ac_hdr" >&5
-#line 2868 "configure"
+#line 2855 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2860: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2898,15 +2885,15 @@
 do
-echo "configure:2902: checking for $ac_hdr" >&5
+echo "configure:2889: checking for $ac_hdr" >&5
-#line 2905 "configure"
+#line 2892 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2897: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2935,15 +2922,15 @@
 do
-echo "configure:2939: checking for $ac_hdr" >&5
+echo "configure:2926: checking for $ac_hdr" >&5
-#line 2942 "configure"
+#line 2929 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2972,15 +2959,15 @@
 do
-echo "configure:2976: checking for $ac_hdr" >&5
+echo "configure:2963: checking for $ac_hdr" >&5
-#line 2979 "configure"
+#line 2966 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3006,10 +2993,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3010: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:2997: checking whether time.h and sys/time.h may both be included" >&5
-#line 3013 "configure"
+#line 3000 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3018,7 +3005,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3009: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3038,10 +3025,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3042: checking for off_t" >&5
+echo "configure:3029: checking for off_t" >&5
-#line 3045 "configure"
+#line 3032 "configure"
 #if STDC_HEADERS
@@ -3068,10 +3055,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3072: checking for uid_t in sys/types.h" >&5
+echo "configure:3059: checking for uid_t in sys/types.h" >&5
-#line 3075 "configure"
+#line 3062 "configure"
 EOF
@@ -3099,10 +3086,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3103: checking return type of signal handlers" >&5
+echo "configure:3090: checking return type of signal handlers" >&5
-#line 3106 "configure"
+#line 3093 "configure"
 #include <signal.h>
@@ -3119,7 +3106,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3110: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3137,10 +3124,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3141: checking for Cygwin environment" >&5
+echo "configure:3128: checking for Cygwin environment" >&5
-#line 3144 "configure"
+#line 3131 "configure"
 int main() {
@@ -3151,7 +3138,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3142: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3169,10 +3156,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3173: checking for $ac_func" >&5
+echo "configure:3160: checking for $ac_func" >&5
-#line 3176 "configure"
+#line 3163 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3195,7 +3182,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3221,10 +3208,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3225: checking for $ac_func" >&5
+echo "configure:3212: checking for $ac_func" >&5
-#line 3228 "configure"
+#line 3215 "configure"
@@ -3247,7 +3234,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3273,10 +3260,10 @@
 for ac_func in drand48
 do
-echo "configure:3277: checking for $ac_func" >&5
+echo "configure:3264: checking for $ac_func" >&5
-#line 3280 "configure"
+#line 3267 "configure"
@@ -3299,7 +3286,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3325,10 +3312,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3329: checking for $ac_func" >&5
+echo "configure:3316: checking for $ac_func" >&5
-#line 3332 "configure"
+#line 3319 "configure"
@@ -3351,7 +3338,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3377,10 +3364,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3381: checking for $ac_func" >&5
+echo "configure:3368: checking for $ac_func" >&5
-#line 3384 "configure"
+#line 3371 "configure"
@@ -3403,7 +3390,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3428,13 +3415,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3432: checking whether setpgrp takes no argument" >&5
+echo "configure:3419: checking whether setpgrp takes no argument" >&5
 if test "$cross_compiling" = yes; then
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3438 "configure"
+#line 3425 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3454,7 +3441,7 @@
 EOF
-if { (eval echo configure:3458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3482,16 +3469,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3486: checking for long long int" >&5
+echo "configure:3473: checking for long long int" >&5
-#line 3488 "configure"
+#line 3475 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3495: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3482: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -3511,7 +3498,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3515: checking for W11" >&5
+echo "configure:3502: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3539,7 +3526,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3543: checking for X" >&5
+echo "configure:3530: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3599,12 +3586,12 @@
   # First, try using that file with no special directory specified.
-#line 3603 "configure"
+#line 3590 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3595: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3673,14 +3660,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3677 "configure"
+#line 3664 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3785,17 +3772,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3789: checking whether -R must be followed by a space" >&5
+echo "configure:3776: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3792 "configure"
+#line 3779 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3811,14 +3798,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3815 "configure"
+#line 3802 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3850,13 +3837,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3854: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3841: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3860 "configure"
+#line 3847 "configure"
@@ -3867,7 +3854,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3888,13 +3875,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3892: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3879: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3898 "configure"
+#line 3885 "configure"
@@ -3905,7 +3892,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3933,10 +3920,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3937: checking for gethostbyname" >&5
+echo "configure:3924: checking for gethostbyname" >&5
-#line 3940 "configure"
+#line 3927 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -3959,7 +3946,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -3979,13 +3966,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:3983: checking for gethostbyname in -lnsl" >&5
+echo "configure:3970: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 3989 "configure"
+#line 3976 "configure"
@@ -3996,7 +3983,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4025,10 +4012,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4029: checking for connect" >&5
+echo "configure:4016: checking for connect" >&5
-#line 4032 "configure"
+#line 4019 "configure"
     which can conflict with char connect(); below.  */
@@ -4051,7 +4038,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4071,13 +4058,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4075: checking for connect in -lsocket" >&5
+echo "configure:4062: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4081 "configure"
+#line 4068 "configure"
@@ -4088,7 +4075,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4111,10 +4098,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4115: checking for remove" >&5
+echo "configure:4102: checking for remove" >&5
-#line 4118 "configure"
+#line 4105 "configure"
     which can conflict with char remove(); below.  */
@@ -4137,7 +4124,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4157,13 +4144,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4161: checking for remove in -lposix" >&5
+echo "configure:4148: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4167 "configure"
+#line 4154 "configure"
@@ -4174,7 +4161,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4197,10 +4184,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4201: checking for shmat" >&5
+echo "configure:4188: checking for shmat" >&5
-#line 4204 "configure"
+#line 4191 "configure"
     which can conflict with char shmat(); below.  */
@@ -4223,7 +4210,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4243,13 +4230,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4247: checking for shmat in -lipc" >&5
+echo "configure:4234: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4253 "configure"
+#line 4240 "configure"
@@ -4260,7 +4247,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4292,13 +4279,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4296: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4283: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4302 "configure"
+#line 4289 "configure"
@@ -4309,7 +4296,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4349,12 +4336,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4353: checking for library containing cuserid" >&5
+echo "configure:4340: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4358 "configure"
+#line 4345 "configure"
@@ -4365,7 +4352,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4376,7 +4363,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4380 "configure"
+#line 4367 "configure"
@@ -4387,7 +4374,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4413,10 +4400,10 @@
 for ac_func in asprintf
 do
-echo "configure:4417: checking for $ac_func" >&5
+echo "configure:4404: checking for $ac_func" >&5
-#line 4420 "configure"
+#line 4407 "configure"
@@ -4439,7 +4426,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4466,10 +4453,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4470: checking for atan" >&5
+echo "configure:4457: checking for atan" >&5
-#line 4473 "configure"
+#line 4460 "configure"
     which can conflict with char atan(); below.  */
@@ -4492,7 +4479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4510,13 +4497,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4514: checking for atan in -lm" >&5
+echo "configure:4501: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4520 "configure"
+#line 4507 "configure"
@@ -4527,7 +4514,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4554,10 +4541,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4558: checking for dlsym" >&5
+echo "configure:4545: checking for dlsym" >&5
-#line 4561 "configure"
+#line 4548 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4580,7 +4567,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4598,13 +4585,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4602: checking for dlsym in -ldl" >&5
+echo "configure:4589: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4608 "configure"
+#line 4595 "configure"
@@ -4615,7 +4602,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4642,10 +4629,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4646: checking for iconv" >&5
+echo "configure:4633: checking for iconv" >&5
-#line 4649 "configure"
+#line 4636 "configure"
     which can conflict with char iconv(); below.  */
@@ -4668,7 +4655,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4686,13 +4673,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4690: checking for iconv in -liconv" >&5
+echo "configure:4677: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4696 "configure"
+#line 4683 "configure"
@@ -4703,7 +4690,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4722,13 +4709,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4726: checking for iconv in -lgiconv" >&5
+echo "configure:4713: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4732 "configure"
+#line 4719 "configure"
@@ -4739,7 +4726,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4758,10 +4745,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4762: checking for libiconv" >&5
+echo "configure:4749: checking for libiconv" >&5
-#line 4765 "configure"
+#line 4752 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4784,7 +4771,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4802,13 +4789,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4806: checking for libiconv in -liconv" >&5
+echo "configure:4793: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4812 "configure"
+#line 4799 "configure"
@@ -4819,7 +4806,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4838,13 +4825,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4842: checking for libiconv in -lgiconv" >&5
+echo "configure:4829: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4848 "configure"
+#line 4835 "configure"
@@ -4855,7 +4842,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4892,10 +4879,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4896: checking for socket" >&5
+echo "configure:4883: checking for socket" >&5
-#line 4899 "configure"
+#line 4886 "configure"
     which can conflict with char socket(); below.  */
@@ -4918,7 +4905,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -4936,13 +4923,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:4940: checking for socket in -lsocket" >&5
+echo "configure:4927: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 4946 "configure"
+#line 4933 "configure"
@@ -4953,7 +4940,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:4957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5001,7 +4988,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5005: checking for location of zlib includes" >&5
+echo "configure:4992: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5027,15 +5014,15 @@
 do
-echo "configure:5031: checking for $ac_hdr" >&5
+echo "configure:5018: checking for $ac_hdr" >&5
-#line 5034 "configure"
+#line 5021 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5069,7 +5056,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5073: checking for location of zlib library" >&5
+echo "configure:5060: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5094,13 +5081,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5098: checking for deflate in -lz" >&5
+echo "configure:5085: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5104 "configure"
+#line 5091 "configure"
@@ -5111,7 +5098,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5159,7 +5146,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5163: checking for location of External PROJ.4 includes" >&5
+echo "configure:5150: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5185,15 +5172,15 @@
 do
-echo "configure:5189: checking for $ac_hdr" >&5
+echo "configure:5176: checking for $ac_hdr" >&5
-#line 5192 "configure"
+#line 5179 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5230,7 +5217,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5234: checking External PROJ.4 version" >&5
+echo "configure:5221: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5238,7 +5225,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5242 "configure"
+#line 5229 "configure"
 #include <stdio.h>
@@ -5250,7 +5237,7 @@
 EOF
-if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5275,7 +5262,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5279: checking for location of External PROJ.4 library" >&5
+echo "configure:5266: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5300,13 +5287,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5304: checking for pj_get_def in -lproj" >&5
+echo "configure:5291: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5310 "configure"
+#line 5297 "configure"
@@ -5317,7 +5304,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5351,7 +5338,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5355: checking for location of External PROJ.4 data files" >&5
+echo "configure:5342: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5375,14 +5362,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5379: checking for epsg" >&5
+echo "configure:5366: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5386: checking for $PROJSHARE/epsg" >&5
+echo "configure:5373: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5414,7 +5401,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5418: checking for $ac_word" >&5
+echo "configure:5405: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5454,7 +5441,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5458: checking whether to use regex" >&5
+echo "configure:5445: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5474,7 +5461,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5478: checking for location of regex includes" >&5
+echo "configure:5465: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5500,15 +5487,15 @@
 do
-echo "configure:5504: checking for $ac_hdr" >&5
+echo "configure:5491: checking for $ac_hdr" >&5
-#line 5507 "configure"
+#line 5494 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5542,7 +5529,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5546: checking for location of regex library" >&5
+echo "configure:5533: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5567,10 +5554,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5571: checking for regcomp" >&5
+echo "configure:5558: checking for regcomp" >&5
-#line 5574 "configure"
+#line 5561 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5593,7 +5580,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5620,13 +5607,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5624: checking for regcomp in -lregex" >&5
+echo "configure:5611: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5630 "configure"
+#line 5617 "configure"
@@ -5637,7 +5624,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5687,7 +5674,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5691: checking whether to use Readline" >&5
+echo "configure:5678: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5708,7 +5695,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5712: checking for location of Readline includes" >&5
+echo "configure:5699: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5734,15 +5721,15 @@
 do
-echo "configure:5738: checking for $ac_hdr" >&5
+echo "configure:5725: checking for $ac_hdr" >&5
-#line 5741 "configure"
+#line 5728 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5778,15 +5765,15 @@
 do
-echo "configure:5782: checking for $ac_hdr" >&5
+echo "configure:5769: checking for $ac_hdr" >&5
-#line 5785 "configure"
+#line 5772 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5820,7 +5807,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5824: checking for location of Readline library" >&5
+echo "configure:5811: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5845,13 +5832,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5849: checking for readline in -lreadline" >&5
+echo "configure:5836: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 5855 "configure"
+#line 5842 "configure"
@@ -5862,7 +5849,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:5866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5897,13 +5884,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5901: checking for add_history in -lhistory" >&5
+echo "configure:5888: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 5907 "configure"
+#line 5894 "configure"
@@ -5914,7 +5901,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:5918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5956,7 +5943,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:5960: checking whether to use GDAL" >&5
+echo "configure:5947: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -5974,7 +5961,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:5978: checking for $ac_word" >&5
+echo "configure:5965: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6029,14 +6016,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6033 "configure"
+#line 6020 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6045,14 +6032,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6049 "configure"
+#line 6036 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6084,7 +6071,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6088: checking whether to use libLAS" >&5
+echo "configure:6075: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6101,7 +6088,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6105: checking for $ac_word" >&5
+echo "configure:6092: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6149,14 +6136,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6153 "configure"
+#line 6140 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6164,14 +6151,14 @@
   rm -rf conftest*
-#line 6168 "configure"
+#line 6155 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6203,7 +6190,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6207: checking whether to use NetCDF" >&5
+echo "configure:6194: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6220,7 +6207,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6224: checking for $ac_word" >&5
+echo "configure:6211: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6267,14 +6254,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6271 "configure"
+#line 6258 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6282,14 +6269,14 @@
   rm -rf conftest*
-#line 6286 "configure"
+#line 6273 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6320,7 +6307,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6324: checking whether to use GEOS" >&5
+echo "configure:6311: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6338,7 +6325,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6342: checking for $ac_word" >&5
+echo "configure:6329: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6386,15 +6373,15 @@
 do
-echo "configure:6390: checking for $ac_hdr" >&5
+echo "configure:6377: checking for $ac_hdr" >&5
-#line 6393 "configure"
+#line 6380 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6385: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6433,13 +6420,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6437: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6424: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6443 "configure"
+#line 6430 "configure"
@@ -6450,7 +6437,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6494,7 +6481,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6498: checking whether to use TIFF" >&5
+echo "configure:6485: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6514,7 +6501,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6518: checking for location of TIFF includes" >&5
+echo "configure:6505: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6540,15 +6527,15 @@
 do
-echo "configure:6544: checking for $ac_hdr" >&5
+echo "configure:6531: checking for $ac_hdr" >&5
-#line 6547 "configure"
+#line 6534 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6582,7 +6569,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6586: checking for location of TIFF library" >&5
+echo "configure:6573: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6613,13 +6600,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6617: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6604: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6623 "configure"
+#line 6610 "configure"
@@ -6630,7 +6617,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6649,13 +6636,13 @@
-echo "configure:6653: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6640: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6659 "configure"
+#line 6646 "configure"
@@ -6666,7 +6653,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6685,13 +6672,13 @@
-echo "configure:6689: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6676: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6695 "configure"
+#line 6682 "configure"
@@ -6702,7 +6689,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6721,13 +6708,13 @@
-echo "configure:6725: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6712: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6731 "configure"
+#line 6718 "configure"
@@ -6738,7 +6725,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6757,13 +6744,13 @@
-echo "configure:6761: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6748: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6767 "configure"
+#line 6754 "configure"
@@ -6774,7 +6761,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6793,13 +6780,13 @@
-echo "configure:6797: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6784: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6803 "configure"
+#line 6790 "configure"
@@ -6810,7 +6797,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6829,13 +6816,13 @@
-echo "configure:6833: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6820: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6839 "configure"
+#line 6826 "configure"
@@ -6846,7 +6833,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6865,13 +6852,13 @@
-echo "configure:6869: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6856: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6875 "configure"
+#line 6862 "configure"
@@ -6882,7 +6869,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6980,7 +6967,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:6984: checking whether to use PNG" >&5
+echo "configure:6971: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -6999,7 +6986,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7003: checking for location of PNG includes" >&5
+echo "configure:6990: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7025,15 +7012,15 @@
 do
-echo "configure:7029: checking for $ac_hdr" >&5
+echo "configure:7016: checking for $ac_hdr" >&5
-#line 7032 "configure"
+#line 7019 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7067,7 +7054,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7071: checking for location of PNG library" >&5
+echo "configure:7058: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7092,13 +7079,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7096: checking for png_read_image in -lpng" >&5
+echo "configure:7083: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7102 "configure"
+#line 7089 "configure"
@@ -7109,7 +7096,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7151,7 +7138,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7155: checking whether to use PostgreSQL" >&5
+echo "configure:7142: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7178,7 +7165,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7182: checking for location of PostgreSQL includes" >&5
+echo "configure:7169: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7204,15 +7191,15 @@
 do
-echo "configure:7208: checking for $ac_hdr" >&5
+echo "configure:7195: checking for $ac_hdr" >&5
-#line 7211 "configure"
+#line 7198 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7250,7 +7237,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7254: checking for location of PostgreSQL library" >&5
+echo "configure:7241: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7279,13 +7266,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7283: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7270: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7289 "configure"
+#line 7276 "configure"
@@ -7296,7 +7283,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7315,13 +7302,13 @@
-echo "configure:7319: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7306: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7325 "configure"
+#line 7312 "configure"
@@ -7332,7 +7319,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7351,13 +7338,13 @@
-echo "configure:7355: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7342: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7361 "configure"
+#line 7348 "configure"
@@ -7368,7 +7355,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7387,13 +7374,13 @@
-echo "configure:7391: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7378: checking for PQsetdbLogin in -lpq" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7397 "configure"
+#line 7384 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7404,7 +7391,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7461,13 +7448,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7465: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7452: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7471 "configure"
+#line 7458 "configure"
@@ -7478,7 +7465,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7500,13 +7487,13 @@
-echo "configure:7504: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7491: checking for PQcmdTuples in -lpq" >&5
-#line 7510 "configure"
+#line 7497 "configure"
@@ -7517,7 +7504,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7560,7 +7547,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7564: checking whether to use MySQL" >&5
+echo "configure:7551: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7580,7 +7567,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7584: checking for location of MySQL includes" >&5
+echo "configure:7571: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7606,15 +7593,15 @@
 do
-echo "configure:7610: checking for $ac_hdr" >&5
+echo "configure:7597: checking for $ac_hdr" >&5
-#line 7613 "configure"
+#line 7600 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7651,7 +7638,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7655: checking for location of MySQL library" >&5
+echo "configure:7642: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7682,13 +7669,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7686: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7673: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7692 "configure"
+#line 7679 "configure"
@@ -7699,7 +7686,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7718,13 +7705,13 @@
-echo "configure:7722: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7709: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7728 "configure"
+#line 7715 "configure"
@@ -7735,7 +7722,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7754,13 +7741,13 @@
-echo "configure:7758: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7745: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7764 "configure"
+#line 7751 "configure"
@@ -7771,7 +7758,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7790,13 +7777,13 @@
-echo "configure:7794: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7781: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7800 "configure"
+#line 7787 "configure"
@@ -7807,7 +7794,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7826,13 +7813,13 @@
-echo "configure:7830: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7817: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7836 "configure"
+#line 7823 "configure"
@@ -7843,7 +7830,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7862,13 +7849,13 @@
-echo "configure:7866: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7853: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7872 "configure"
+#line 7859 "configure"
@@ -7879,7 +7866,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7898,13 +7885,13 @@
-echo "configure:7902: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7889: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7908 "configure"
+#line 7895 "configure"
@@ -7915,7 +7902,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7934,13 +7921,13 @@
-echo "configure:7938: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7925: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 7944 "configure"
+#line 7931 "configure"
@@ -7951,7 +7938,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8041,7 +8028,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8045: checking for $ac_word" >&5
+echo "configure:8032: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8090,10 +8077,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8094: checking for mysql_server_init" >&5
+echo "configure:8081: checking for mysql_server_init" >&5
-#line 8097 "configure"
+#line 8084 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8119,7 +8106,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8171,7 +8158,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8175: checking whether to use SQLite" >&5
+echo "configure:8162: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8191,7 +8178,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8195: checking for location of SQLite includes" >&5
+echo "configure:8182: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8217,15 +8204,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8221: checking for $ac_hdr" >&5
+echo "configure:8208: checking for $ac_hdr" >&5
-#line 8224 "configure"
+#line 8211 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8268,7 +8255,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8272: checking for location of SQLite library" >&5
+echo "configure:8259: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8297,13 +8284,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8301: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8288: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8307 "configure"
+#line 8294 "configure"
@@ -8314,7 +8301,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8333,13 +8320,13 @@
-echo "configure:8337: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8324: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8343 "configure"
+#line 8330 "configure"
@@ -8350,7 +8337,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8369,13 +8356,13 @@
-echo "configure:8373: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8360: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8379 "configure"
+#line 8366 "configure"
@@ -8386,7 +8373,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8405,13 +8392,13 @@
-echo "configure:8409: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8396: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8415 "configure"
+#line 8402 "configure"
@@ -8422,7 +8409,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8491,7 +8478,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8495: checking whether to use FFMPEG" >&5
+echo "configure:8482: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8511,7 +8498,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8515: checking for location of FFMPEG includes" >&5
+echo "configure:8502: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8537,15 +8524,15 @@
 do
-echo "configure:8541: checking for $ac_hdr" >&5
+echo "configure:8528: checking for $ac_hdr" >&5
-#line 8544 "configure"
+#line 8531 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8581,15 +8568,15 @@
 do
-echo "configure:8585: checking for $ac_hdr" >&5
+echo "configure:8572: checking for $ac_hdr" >&5
-#line 8588 "configure"
+#line 8575 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8580: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8625,15 +8612,15 @@
 do
-echo "configure:8629: checking for $ac_hdr" >&5
+echo "configure:8616: checking for $ac_hdr" >&5
-#line 8632 "configure"
+#line 8619 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8676,7 +8663,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8680: checking for location of FFMPEG library" >&5
+echo "configure:8667: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8703,13 +8690,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8707: checking for av_free in -lavutil" >&5
+echo "configure:8694: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8713 "configure"
+#line 8700 "configure"
@@ -8720,7 +8707,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8739,13 +8726,13 @@
-echo "configure:8743: checking for av_free in -lavutil" >&5
+echo "configure:8730: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8749 "configure"
+#line 8736 "configure"
@@ -8756,7 +8743,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8801,13 +8788,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8805: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8792: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8811 "configure"
+#line 8798 "configure"
@@ -8818,7 +8805,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8837,13 +8824,13 @@
-echo "configure:8841: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8828: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8847 "configure"
+#line 8834 "configure"
@@ -8854,7 +8841,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8899,13 +8886,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8903: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8890: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 8909 "configure"
+#line 8896 "configure"
@@ -8916,7 +8903,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:8920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8935,13 +8922,13 @@
-echo "configure:8939: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8926: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 8945 "configure"
+#line 8932 "configure"
@@ -8952,7 +8939,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9011,7 +8998,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9015: checking whether to use OpenGL" >&5
+echo "configure:9002: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9045,7 +9032,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9049: checking for location of OpenGL includes" >&5
+echo "configure:9036: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9071,15 +9058,15 @@
 do
-echo "configure:9075: checking for $ac_hdr" >&5
+echo "configure:9062: checking for $ac_hdr" >&5
-#line 9078 "configure"
+#line 9065 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9113,7 +9100,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9117: checking for location of OpenGL library" >&5
+echo "configure:9104: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9142,13 +9129,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9146: checking for glBegin in -lGL" >&5
+echo "configure:9133: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9152 "configure"
+#line 9139 "configure"
@@ -9159,7 +9146,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9178,13 +9165,13 @@
-echo "configure:9182: checking for glBegin in -lGL" >&5
+echo "configure:9169: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9188 "configure"
+#line 9175 "configure"
@@ -9195,7 +9182,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9214,13 +9201,13 @@
-echo "configure:9218: checking for glBegin in -lGL" >&5
+echo "configure:9205: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9224 "configure"
+#line 9211 "configure"
@@ -9231,7 +9218,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9250,13 +9237,13 @@
-echo "configure:9254: checking for glBegin in -lGL" >&5
+echo "configure:9241: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9260 "configure"
+#line 9247 "configure"
@@ -9267,7 +9254,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9329,13 +9316,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9333: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9320: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9339 "configure"
+#line 9326 "configure"
@@ -9346,7 +9333,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9365,13 +9352,13 @@
-echo "configure:9369: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9356: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9375 "configure"
+#line 9362 "configure"
@@ -9382,7 +9369,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9429,10 +9416,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9433: checking for glXCreatePbuffer" >&5
+echo "configure:9420: checking for glXCreatePbuffer" >&5
-#line 9436 "configure"
+#line 9423 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9455,7 +9442,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9492,10 +9479,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9496: checking for glXCreateGLXPixmap" >&5
+echo "configure:9483: checking for glXCreateGLXPixmap" >&5
-#line 9499 "configure"
+#line 9486 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9518,7 +9505,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9561,7 +9548,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9565: checking for location of OpenGL framework" >&5
+echo "configure:9552: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9585,15 +9572,15 @@
 do
-echo "configure:9589: checking for $ac_hdr" >&5
+echo "configure:9576: checking for $ac_hdr" >&5
-#line 9592 "configure"
+#line 9579 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9597: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9629,10 +9616,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9633: checking for glBegin" >&5
+echo "configure:9620: checking for glBegin" >&5
-#line 9636 "configure"
+#line 9623 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9655,7 +9642,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9692,10 +9679,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9696: checking for gluBeginCurve" >&5
+echo "configure:9683: checking for gluBeginCurve" >&5
-#line 9699 "configure"
+#line 9686 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9718,7 +9705,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9766,7 +9753,7 @@
-echo "configure:9770: checking for location of OpenGL includes" >&5
+echo "configure:9757: checking for location of OpenGL includes" >&5
@@ -9792,15 +9779,15 @@
 do
-echo "configure:9796: checking for $ac_hdr" >&5
+echo "configure:9783: checking for $ac_hdr" >&5
-#line 9799 "configure"
+#line 9786 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9804: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9791: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9834,7 +9821,7 @@
-echo "configure:9838: checking for location of OpenGL library" >&5
+echo "configure:9825: checking for location of OpenGL library" >&5
@@ -9859,18 +9846,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9863: checking for OpenGL library" >&5
+echo "configure:9850: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9867 "configure"
+#line 9854 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9894,18 +9881,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9898: checking for GLU library" >&5
+echo "configure:9885: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 9902 "configure"
+#line 9889 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:9909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9954,7 +9941,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9958: checking whether to use ODBC" >&5
+echo "configure:9945: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -9973,7 +9960,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9977: checking for location of ODBC includes" >&5
+echo "configure:9964: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9999,15 +9986,15 @@
 do
-echo "configure:10003: checking for $ac_hdr" >&5
+echo "configure:9990: checking for $ac_hdr" >&5
-#line 10006 "configure"
+#line 9993 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10041,7 +10028,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10045: checking for location of ODBC library" >&5
+echo "configure:10032: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10066,13 +10053,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10070: checking for SQLConnect in -lodbc" >&5
+echo "configure:10057: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10076 "configure"
+#line 10063 "configure"
@@ -10083,7 +10070,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10108,13 +10095,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10112: checking for SQLConnect in -liodbc" >&5
+echo "configure:10099: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10118 "configure"
+#line 10105 "configure"
@@ -10125,7 +10112,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10150,11 +10137,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10154: checking for ODBC library" >&5
+echo "configure:10141: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10158 "configure"
+#line 10145 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10162,7 +10149,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10211,7 +10198,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10215: checking whether to use FFTW" >&5
+echo "configure:10202: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10230,7 +10217,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10234: checking for location of FFTW includes" >&5
+echo "configure:10221: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10256,15 +10243,15 @@
 do
-echo "configure:10260: checking for $ac_hdr" >&5
+echo "configure:10247: checking for $ac_hdr" >&5
-#line 10263 "configure"
+#line 10250 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10268: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10292,15 +10279,15 @@
 do
-echo "configure:10296: checking for $ac_hdr" >&5
+echo "configure:10283: checking for $ac_hdr" >&5
-#line 10299 "configure"
+#line 10286 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10304: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10291: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10328,15 +10315,15 @@
 do
-echo "configure:10332: checking for $ac_hdr" >&5
+echo "configure:10319: checking for $ac_hdr" >&5
-#line 10335 "configure"
+#line 10322 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10382,7 +10369,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10386: checking for location of FFTW library" >&5
+echo "configure:10373: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10407,13 +10394,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10411: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10398: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10417 "configure"
+#line 10404 "configure"
@@ -10424,7 +10411,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10449,13 +10436,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10453: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10440: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10459 "configure"
+#line 10446 "configure"
@@ -10466,7 +10453,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10491,13 +10478,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10495: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10482: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10501 "configure"
+#line 10488 "configure"
@@ -10508,7 +10495,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10565,7 +10552,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10569: checking whether to use BLAS" >&5
+echo "configure:10556: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10586,7 +10573,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10590: checking for location of BLAS includes" >&5
+echo "configure:10577: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10606,7 +10593,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10610: checking for location of BLAS library" >&5
+echo "configure:10597: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10632,15 +10619,15 @@
 do
-echo "configure:10636: checking for $ac_hdr" >&5
+echo "configure:10623: checking for $ac_hdr" >&5
-#line 10639 "configure"
+#line 10626 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10631: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10675,13 +10662,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10679: checking for dnrm2_ in -lblas" >&5
+echo "configure:10666: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10685 "configure"
+#line 10672 "configure"
@@ -10692,7 +10679,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10711,13 +10698,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10715: checking for dnrm2_ in -lblas" >&5
+echo "configure:10702: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10721 "configure"
+#line 10708 "configure"
@@ -10728,7 +10715,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10772,13 +10759,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10776: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10763: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10782 "configure"
+#line 10769 "configure"
@@ -10789,7 +10776,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10804,13 +10791,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10808: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10795: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10814 "configure"
+#line 10801 "configure"
@@ -10821,7 +10808,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10836,13 +10823,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10840: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10827: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10846 "configure"
+#line 10833 "configure"
@@ -10853,7 +10840,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10899,16 +10886,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10903: checking for sgemm in $vlib_flags" >&5
+echo "configure:10890: checking for sgemm in $vlib_flags" >&5
-#line 10905 "configure"
+#line 10892 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -10926,13 +10913,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10930: checking for sgemm_ in -lblas" >&5
+echo "configure:10917: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 10936 "configure"
+#line 10923 "configure"
@@ -10943,7 +10930,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10958,13 +10945,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10962: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10949: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 10968 "configure"
+#line 10955 "configure"
@@ -10975,7 +10962,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10990,13 +10977,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10994: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10981: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11000 "configure"
+#line 10987 "configure"
@@ -11007,7 +10994,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11041,13 +11028,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11045: checking for acosp in -lsunmath" >&5
+echo "configure:11032: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11051 "configure"
+#line 11038 "configure"
@@ -11058,7 +11045,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11073,13 +11060,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11077: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11064: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11083 "configure"
+#line 11070 "configure"
@@ -11090,7 +11077,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11120,13 +11107,13 @@
 # Generic BLAS library
-echo "configure:11124: checking for sgemm_ in -lblas" >&5
+echo "configure:11111: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11130 "configure"
+#line 11117 "configure"
@@ -11137,7 +11124,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11176,7 +11163,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11180: checking whether to use LAPACK" >&5
+echo "configure:11167: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11201,7 +11188,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11205: checking for location of LAPACK includes" >&5
+echo "configure:11192: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11221,7 +11208,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11225: checking for location of LAPACK library" >&5
+echo "configure:11212: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11247,15 +11234,15 @@
 do
-echo "configure:11251: checking for $ac_hdr" >&5
+echo "configure:11238: checking for $ac_hdr" >&5
-#line 11254 "configure"
+#line 11241 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11287,10 +11274,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11291: checking for dsegv_" >&5
+echo "configure:11278: checking for dsegv_" >&5
-#line 11294 "configure"
+#line 11281 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11313,7 +11300,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11340,13 +11327,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11344: checking for desgv_ in -llapack" >&5
+echo "configure:11331: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11350 "configure"
+#line 11337 "configure"
@@ -11357,7 +11344,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11389,13 +11376,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11393: checking for dgesv_ in -llapack" >&5
+echo "configure:11380: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11399 "configure"
+#line 11386 "configure"
@@ -11406,7 +11393,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11425,13 +11412,13 @@
-echo "configure:11429: checking for dgesv_ in -llapack" >&5
+echo "configure:11416: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11435 "configure"
+#line 11422 "configure"
@@ -11442,7 +11429,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11498,7 +11485,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11502: checking whether to use Cairo" >&5
+echo "configure:11489: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11530,7 +11517,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11534: checking for location of cairo includes" >&5
+echo "configure:11521: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11556,15 +11543,15 @@
 do
-echo "configure:11560: checking for $ac_hdr" >&5
+echo "configure:11547: checking for $ac_hdr" >&5
-#line 11563 "configure"
+#line 11550 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11568: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11555: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11600,7 +11587,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11604: checking for location of cairo library" >&5
+echo "configure:11591: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11620,7 +11607,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11624: checking for cairo linking flags" >&5
+echo "configure:11611: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11636,10 +11623,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11640: checking for cairo_create" >&5
+echo "configure:11627: checking for cairo_create" >&5
-#line 11643 "configure"
+#line 11630 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11662,7 +11649,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11696,10 +11683,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11700: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11687: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11703 "configure"
+#line 11690 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11722,7 +11709,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11755,10 +11742,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11759: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11746: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11762 "configure"
+#line 11749 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11781,7 +11768,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11823,7 +11810,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11827: checking whether to use FreeType" >&5
+echo "configure:11814: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11842,7 +11829,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11846: checking for location of FreeType includes" >&5
+echo "configure:11833: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11868,15 +11855,15 @@
 do
-echo "configure:11872: checking for $ac_hdr" >&5
+echo "configure:11859: checking for $ac_hdr" >&5
-#line 11875 "configure"
+#line 11862 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11910,7 +11897,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11914: checking for location of FreeType library" >&5
+echo "configure:11901: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11935,13 +11922,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11939: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11926: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 11945 "configure"
+#line 11932 "configure"
@@ -11952,7 +11939,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:11956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11993,7 +11980,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11997: checking whether to use NLS" >&5
+echo "configure:11984: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12013,10 +12000,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12017: checking for gettext" >&5
+echo "configure:12004: checking for gettext" >&5
-#line 12020 "configure"
+#line 12007 "configure"
     which can conflict with char gettext(); below.  */
@@ -12039,7 +12026,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12057,13 +12044,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12061: checking for gettext in -lintl" >&5
+echo "configure:12048: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12067 "configure"
+#line 12054 "configure"
@@ -12074,7 +12061,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12109,7 +12096,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12113: checking whether to use C++" >&5
+echo "configure:12100: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12125,7 +12112,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:12129: checking for $ac_word" >&5
+echo "configure:12116: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12154,7 +12141,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12158: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12145: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12165,12 +12152,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12169 "configure"
+#line 12156 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12196,19 +12183,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12200: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12187: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12205: checking whether we are using GNU C++" >&5
+echo "configure:12192: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12199: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12226,7 +12213,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12230: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12217: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12267,7 +12254,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12271: checking whether to use openDWG" >&5
+echo "configure:12258: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12287,7 +12274,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12291: checking for location of openDGW includes" >&5
+echo "configure:12278: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12313,15 +12300,15 @@
 do
-echo "configure:12317: checking for $ac_hdr" >&5
+echo "configure:12304: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12320 "configure"
+#line 12307 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12355,7 +12342,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12359: checking for location of openDWG library" >&5
+echo "configure:12346: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12396,7 +12383,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12400: checking whether to use POSIX threads" >&5
+echo "configure:12387: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12416,7 +12403,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12420: checking for location of POSIX threads includes" >&5
+echo "configure:12407: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12442,15 +12429,15 @@
 do
-echo "configure:12446: checking for $ac_hdr" >&5
+echo "configure:12433: checking for $ac_hdr" >&5
-#line 12449 "configure"
+#line 12436 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12454: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12484,7 +12471,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12488: checking for location of POSIX threads library" >&5
+echo "configure:12475: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12509,10 +12496,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12513: checking for pthread_create" >&5
+echo "configure:12500: checking for pthread_create" >&5
-#line 12516 "configure"
+#line 12503 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12535,7 +12522,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12562,13 +12549,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12566: checking for pthread_create in -lpthread" >&5
+echo "configure:12553: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12572 "configure"
+#line 12559 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12579,7 +12566,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12629,7 +12616,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12633: checking whether to use OpenMP" >&5
+echo "configure:12620: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12650,7 +12637,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12654: checking for location of OpenMP includes" >&5
+echo "configure:12641: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12676,15 +12663,15 @@
 do
-echo "configure:12680: checking for $ac_hdr" >&5
+echo "configure:12667: checking for $ac_hdr" >&5
-#line 12683 "configure"
+#line 12670 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12675: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12722,7 +12709,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12726: checking for location of OpenMP library" >&5
+echo "configure:12713: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12747,10 +12734,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12751: checking for GOMP_parallel_start" >&5
+echo "configure:12738: checking for GOMP_parallel_start" >&5
-#line 12754 "configure"
+#line 12741 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12773,7 +12760,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12800,13 +12787,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12804: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12791: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12810 "configure"
+#line 12797 "configure"
@@ -12817,7 +12804,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12896,7 +12883,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12900: checking for special C compiler options needed for large files" >&5
+echo "configure:12887: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -12904,7 +12891,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 12908 "configure"
+#line 12895 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -12920,7 +12907,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12924: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12911: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -12929,7 +12916,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 12933 "configure"
+#line 12920 "configure"
@@ -12945,7 +12932,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12949: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12936: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -12965,11 +12952,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12969: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12956: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 12973 "configure"
+#line 12960 "configure"
@@ -12985,14 +12972,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 12996 "configure"
+#line 12983 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13010,7 +12997,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13029,11 +13016,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13033: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13020: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13037 "configure"
+#line 13024 "configure"
@@ -13049,14 +13036,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13060 "configure"
+#line 13047 "configure"
 #define _LARGE_FILES 1
@@ -13074,7 +13061,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13078: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13093,25 +13080,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13097: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13084: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13101 "configure"
+#line 13088 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13108: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13095: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13115 "configure"
+#line 13102 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13120,7 +13107,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13111: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13141,25 +13128,25 @@
    fi
-echo "configure:13145: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13132: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13149 "configure"
+#line 13136 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13143: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13163 "configure"
+#line 13150 "configure"
 #include <stdio.h>
@@ -13168,7 +13155,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13172: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13159: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13191,18 +13178,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13195: checking for fseeko" >&5
+echo "configure:13182: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13199 "configure"
+#line 13186 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13219,10 +13206,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13223: checking if system supports Large Files at all" >&5
+echo "configure:13210: checking if system supports Large Files at all" >&5
-#line 13226 "configure"
+#line 13213 "configure"
 #include <stdio.h>
@@ -13254,7 +13241,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13258: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13245: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13283,7 +13270,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13287: checking whether to use wxWidgets" >&5
+echo "configure:13274: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13304,7 +13291,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13308: checking for $ac_word" >&5
+echo "configure:13295: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13352,7 +13339,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13356: checking wxWidgets version" >&5
+echo "configure:13343: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13375,15 +13362,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13379: checking for $ac_hdr" >&5
+echo "configure:13366: checking for $ac_hdr" >&5
-#line 13382 "configure"
+#line 13369 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13374: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13577,13 +13564,10 @@
 s%@MACOSX_SDK@%$MACOSX_SDK%g
 s%@INSTDIR@%$INSTDIR%g
 s%@GRASS_LIBRARY_TYPE@%$GRASS_LIBRARY_TYPE%g
-s%@PLAT_OBJS@%$PLAT_OBJS%g
-s%@CC_SEARCH_FLAGS@%$CC_SEARCH_FLAGS%g
 s%@LD_SEARCH_FLAGS@%$LD_SEARCH_FLAGS%g
 s%@LD_LIBRARY_PATH_VAR@%$LD_LIBRARY_PATH_VAR%g
 s%@SHLIB_LD@%$SHLIB_LD%g
 s%@SHLIB_LD_FLAGS@%$SHLIB_LD_FLAGS%g
-s%@SHLIB_LD_LIBS@%$SHLIB_LD_LIBS%g
 s%@SHLIB_CFLAGS@%$SHLIB_CFLAGS%g
 s%@SHLIB_SUFFIX@%$SHLIB_SUFFIX%g
 s%@STLIB_LD@%$STLIB_LD%g
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2013-03-17 17:24:46 UTC (rev 55412)
+++ grass/trunk/include/Make/Platform.make.in	2013-03-17 21:49:29 UTC (rev 55413)
@@ -48,9 +48,7 @@
 GRASS_VERSION_DATE  = @GRASS_VERSION_DATE@
 GRASS_VERSION_SVN   = @GRASS_VERSION_SVN@
-PLAT_OBJS           = @PLAT_OBJS@
 STRIPFLAG           = @STRIPFLAG@
-CC_SEARCH_FLAGS     = @CC_SEARCH_FLAGS@
 LD_SEARCH_FLAGS     = @LD_SEARCH_FLAGS@
 LD_LIBRARY_PATH_VAR = @LD_LIBRARY_PATH_VAR@
@@ -65,8 +63,7 @@
 #shared libs
 SHLIB_PREFIX        = lib
 SHLIB_LD            = @SHLIB_LD@
-SHLIB_LD_FLAGS      = @SHLIB_LD_FLAGS@
-SHLIB_LD_LIBS       = @SHLIB_LD_LIBS@
+SHLIB_LDFLAGS       = @SHLIB_LD_FLAGS@
 SHLIB_CFLAGS        = @SHLIB_CFLAGS@
 SHLIB_SUFFIX        = @SHLIB_SUFFIX@
 EXE                 = @EXEEXT@
