[GRASS-SVN] r55560 - in grass-addons/grass7/raster/r.agent: libagent tests
Wed Mar 27 09:05:15 PDT 2013
Author: mic
Date: 2013-03-27 09:05:14 -0700 (Wed, 27 Mar 2013)
New Revision: 55560
   grass-addons/grass7/raster/r.agent/libagent/grassland.py
   grass-addons/grass7/raster/r.agent/tests/test_grassland.py
implement write grass layer
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-03-27 15:41:58 UTC (rev 55559)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py	2013-03-27 16:05:14 UTC (rev 55560)
@@ -78,10 +78,15 @@
                 raise error.DataError("r.agent::libagent.grassland.Grassland()",
                                         "Grass Map name is empty.")
         if self.layers.has_key(layername):
-            if force:
-                force="force"
-            self.layers[layername].write(self.grassmapnames[layername],
-                                                        overwrite=force)
+            if grassmapname in \
+                    grass.list_grouped('rast')[grass.gisenv()['MAPSET']]:
+                if force:
+                    force="force"
+                else:
+                    raise error.DataError(
+                        "r.agent::libagent.grassland.Grassland()",
+                        "Grass map already exists.")
+            self.layers[layername].write(grassmapname, overwrite=force)
     def parsevectorlayer(self, layername, grassmapname, value=1, force=False):
Modified: grass-addons/grass7/raster/r.agent/tests/test_grassland.py
--- grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-03-27 15:41:58 UTC (rev 55559)
+++ grass-addons/grass7/raster/r.agent/tests/test_grassland.py	2013-03-27 16:05:14 UTC (rev 55560)
@@ -107,9 +107,20 @@
     def test_writelayer(self):
         if self.rastlayername:
+            # create an empty test map
             layer = garray.array()
-# TODO
-        pass
+            self.pg.createlayer(self.rastlayername, self.rastlayername)
+            # write it once
+            self.pg.writelayer(self.rastlayername)
+            # now remove it from the internal grasslayer list
+            self.pg.grassmapnames.pop(self.rastlayername)
+            self.assertRaises(error.DataError, self.pg.writelayer,
+                                self.rastlayername)
+            # try again, this time being explicit, but still fail
+                                *[self.rastlayername, self.rastlayername])
+            # force write it again..
+            self.pg.writelayer(self.rastlayername, self.rastlayername, True)
     def test_parsegrasslayer(self):
         if self.vectlayername:
