[GRASS-SVN] r56116 - grass/trunk/gui/wxpython/nviz
Sat May 4 03:17:39 PDT 2013
Author: martinl
Date: 2013-05-04 03:17:39 -0700 (Sat, 04 May 2013)
New Revision: 56116
   grass/trunk/gui/wxpython/nviz/mapwindow.py
wxGUI/nviz: m.nviz.image do not require elev map to be defined
            switchPage -> priority
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2013-05-04 10:06:13 UTC (rev 56115)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2013-05-04 10:17:39 UTC (rev 56116)
@@ -2247,8 +2247,8 @@
                 volumes.append(item)
             elif self.tree.GetLayerInfo(item, key = 'type') == 'vector':
                 vectors.append(item)
-        if not rasters and not self.constants:
-            return _("At least one raster map required")
+        ### if not rasters and not self.constants:
+        ###     return _("At least one raster map required")
         # elevation_map/elevation_value
         if self.constants:
             subcmd = "elevation_value="
@@ -2513,7 +2513,7 @@
     def OnNvizCmd(self):
         """!Generate and write command to command output"""
-        self.log.WriteLog(self.NvizCmdCommand(), switchPage = True)
+        self.log.WriteLog(self.NvizCmdCommand(), priority = 3)
     def SaveToFile(self, FileName, FileType, width, height):
         """!This draws the DC to a buffer that can be saved to a file.
