[GRASS-SVN] r56141 - in grass/branches/develbranch_6/gui/wxpython: core gui_core
Mon May 6 04:32:02 PDT 2013
Author: annakrat
Date: 2013-05-06 04:32:01 -0700 (Mon, 06 May 2013)
New Revision: 56141
   grass/branches/develbranch_6/gui/wxpython/core/utils.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
wxGUI: sync fixes for #1605
Modified: grass/branches/develbranch_6/gui/wxpython/core/utils.py
--- grass/branches/develbranch_6/gui/wxpython/core/utils.py	2013-05-06 11:28:07 UTC (rev 56140)
+++ grass/branches/develbranch_6/gui/wxpython/core/utils.py	2013-05-06 11:32:01 UTC (rev 56141)
@@ -331,6 +331,41 @@
     return layers
+def GetAllVectorLayers(vector):
+    """!Returns list of all vector layers as strings.
+    @param vector name of vector map
+    layers = []
+    if not vector:
+        return layers
+    fullname = grass.find_file(name = vector, element = 'vector')['fullname']
+    if not fullname:
+        Debug.msg(3, "utils.GetAllVectorLayers(): vector map <%s> not found" % vector)
+        return layers
+    ret, out, msg = RunCommand('v.category',
+                               getErrorMsg = True,
+                               read = True,
+                               quiet = True,
+                               option = 'layers',
+                               input = fullname)
+    if ret != 0:
+        sys.stderr.write(_("Vector map <%(map)s>: %(msg)s\n") % { 'map' : fullname, 'msg' : msg })
+        return layers
+    Debug.msg(1, "utils.GetAllVectorLayers(): ret %s" % ret)
+    for layer in out.splitlines():
+        layers.append(layer)
+    Debug.msg(3, "utils.GetAllVectorLayers(): vector=%s -> %s" % \
+                  (fullname, ','.join(layers)))
+    return layers
 def Deg2DMS(lon, lat, string = True, hemisphere = True, precision = 3):
     """!Convert deg value to dms string
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py	2013-05-06 11:28:07 UTC (rev 56140)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py	2013-05-06 11:32:01 UTC (rev 56141)
@@ -48,7 +48,7 @@
 from core.gcmd     import RunCommand, GError, GMessage
 from core.utils    import GetListOfLocations, GetListOfMapsets, GetFormats
-from core.utils    import GetSettingsPath, GetValidLayerName, ListSortLower, GetVectorNumberOfLayers
+from core.utils    import GetSettingsPath, GetValidLayerName, ListSortLower, GetAllVectorLayers
 from core.settings import UserSettings
 from core.debug    import Debug
@@ -696,7 +696,7 @@
         if vector:
-            layers = GetVectorNumberOfLayers(vector)
+            layers = GetAllVectorLayers(vector)
         else:
             layers = list()
