[GRASS-SVN] r56204 - grass/trunk/vector/v.to.3d
Sat May 11 09:59:16 PDT 2013
Author: martinl
Date: 2013-05-11 09:59:16 -0700 (Sat, 11 May 2013)
New Revision: 56204
   grass/trunk/vector/v.to.3d/local_proto.h
   grass/trunk/vector/v.to.3d/main.c
   grass/trunk/vector/v.to.3d/trans2.c
   grass/trunk/vector/v.to.3d/trans3.c
v.to.3d: call G_fatal_error() immediately
Modified: grass/trunk/vector/v.to.3d/local_proto.h
--- grass/trunk/vector/v.to.3d/local_proto.h	2013-05-11 16:50:19 UTC (rev 56203)
+++ grass/trunk/vector/v.to.3d/local_proto.h	2013-05-11 16:59:16 UTC (rev 56204)
@@ -14,9 +14,9 @@
 void parse_args(struct opts *);
 /* trans2.c */
-int trans2d(struct Map_info *, struct Map_info *, int,
-	    double, const char *, const char *);
+void trans2d(struct Map_info *, struct Map_info *, int,
+             double, const char *, const char *);
 /* trans3.c */
-int trans3d(struct Map_info *, struct Map_info *, int,
-	    const char *, const char *);
+void trans3d(struct Map_info *, struct Map_info *, int,
+             const char *, const char *);
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c	2013-05-11 16:50:19 UTC (rev 56203)
+++ grass/trunk/vector/v.to.3d/main.c	2013-05-11 16:59:16 UTC (rev 56204)
@@ -29,7 +29,6 @@
     struct Map_info In, Out;
     struct bound_box box;
     int type;
-    int ret;
     G_gisinit(argv[0]);
@@ -100,10 +99,9 @@
-    ret = 0;
     if (opt.reverse->answer) {
 	/* 3d -> 2d */
-	ret = trans3d(&In, &Out, type, opt.field->answer, opt.column->answer);
+        trans3d(&In, &Out, type, opt.field->answer, opt.column->answer);
     else {
 	/* 2d -> 3d */
@@ -112,13 +110,9 @@
 	if (opt.height->answer) {
 	    height = atof(opt.height->answer);
-	ret = trans2d(&In, &Out, type, height, opt.field->answer, opt.column->answer);
+	trans2d(&In, &Out, type, height, opt.field->answer, opt.column->answer);
-    if (ret < 0) {
-	G_fatal_error(_("%s failed"), G_program_name());
     if (!opt.reverse->answer && !opt.table->answer) {
 	G_message(_("Copying attributes..."));
 	if (Vect_copy_tables(&In, &Out, 0) == -1) {
Modified: grass/trunk/vector/v.to.3d/trans2.c
--- grass/trunk/vector/v.to.3d/trans2.c	2013-05-11 16:50:19 UTC (rev 56203)
+++ grass/trunk/vector/v.to.3d/trans2.c	2013-05-11 16:59:16 UTC (rev 56204)
@@ -14,11 +14,8 @@
    \param height fixed height (used only if column is NULL)
    \param field layer number
    \param column attribute column used for height
-   \return number of writen features
-   \return -1 on error
-int trans2d(struct Map_info *In, struct Map_info *Out, int type,
+void trans2d(struct Map_info *In, struct Map_info *Out, int type,
 	    double height, const char *field_name, const char *column)
     int i, ltype, line, field;
@@ -49,28 +46,25 @@
 	Fi = Vect_get_field(In, field);
 	if (!Fi) {
-	    G_warning(_("Database connection not defined for layer <%s>"),
-		      field_name);
-	    return -1;
+	    G_fatal_error(_("Database connection not defined for layer <%s>"),
+                          field_name);
 	driver = db_start_driver_open_database(Fi->driver, Fi->database);
 	if (!driver) {
-	    G_warning(_("Unable to open database <%s> by driver <%s>"),
-		      Fi->database, Fi->driver);
-	    return -1;
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+                          Fi->database, Fi->driver);
+        db_set_error_handler_driver(driver);
 	/* column type must numeric */
 	ctype = db_column_Ctype(driver, Fi->table, column);
 	if (ctype == -1) {
-	    G_warning(_("Column <%s> not found in table <%s>"),
-		      column, Fi->table);
-	    return -1;
+	    G_fatal_error(_("Column <%s> not found in table <%s>"),
+                          column, Fi->table);
 	if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
-	    G_warning(_("Column must be numeric"));
-	    return -1;
+	    G_fatal_error(_("Column must be numeric"));
         G_message(_("Fetching height from <%s> column..."), column);
@@ -87,8 +81,7 @@
     while (1) {
 	ltype = Vect_read_next_line(In, Points, Cats);
 	if (ltype == -1) {
-	    G_warning(_("Unable to read vector map"));
-	    return -1;
+	    G_fatal_error(_("Unable to read vector map"));
 	if (ltype == -2) {	/* EOF */
 	    break;
@@ -136,6 +129,4 @@
     Vect_destroy_line_struct(Points);
     Vect_destroy_cats_struct(Cats);
-    return line - 1;
Modified: grass/trunk/vector/v.to.3d/trans3.c
--- grass/trunk/vector/v.to.3d/trans3.c	2013-05-11 16:50:19 UTC (rev 56203)
+++ grass/trunk/vector/v.to.3d/trans3.c	2013-05-11 16:59:16 UTC (rev 56204)
@@ -16,11 +16,8 @@
    \param type feature type to be transformed
    \param zcolumn attribute column where to store height
-int trans3d(struct Map_info *In, struct Map_info *Out, int type,
+void trans3d(struct Map_info *In, struct Map_info *Out, int type,
 	    const char *field_name, const char *zcolumn)
     int ltype, line;
@@ -51,28 +48,25 @@
 	Fi = Vect_get_field(Out, field);
 	if (!Fi) {
-		      field_name);
-	    return -1;
+                          field_name);
 	if (!driver) {
-	    return -1;
 	ctype = db_column_Ctype(driver, Fi->table, zcolumn);
 	if (ctype == -1) {
-		      zcolumn, Fi->table);
-	    return -1;
+                          zcolumn, Fi->table);
-	    return -1;
 	db_begin_transaction(driver);
@@ -88,8 +82,7 @@
     while (1) {
 	if (ltype == -1) {
-	    return -1;
 	    break;
@@ -155,8 +148,6 @@
-    return line - 1;
 int srch(const void *pa, const void *pb)
