[GRASS-SVN] r56252 - grass/trunk/vector/v.generalize
Tue May 14 07:44:32 PDT 2013
Author: mmetz
Date: 2013-05-14 07:44:32 -0700 (Tue, 14 May 2013)
New Revision: 56252
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.generalize/operators.h
   grass/trunk/vector/v.generalize/point.c
   grass/trunk/vector/v.generalize/point.h
   grass/trunk/vector/v.generalize/smoothing.c
v.generalize: add loop support
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2013-05-14 13:35:52 UTC (rev 56251)
+++ grass/trunk/vector/v.generalize/main.c	2013-05-14 14:44:32 UTC (rev 56252)
@@ -54,13 +54,14 @@
     struct Option *angle_thresh_opt, *degree_thresh_opt,
 	*closeness_thresh_opt;
     struct Option *betweeness_thresh_opt;
-    struct Flag *notab_flag;
+    struct Flag *notab_flag, *loop_support_flag;
     int with_z;
     int total_input, total_output;	/* Number of points in the input/output map respectively */
     double thresh, alpha, beta, reduction, slide, angle_thresh;
     double degree_thresh, closeness_thresh, betweeness_thresh;
     int method;
     int look_ahead, iterations;
+    int loop_support;
     int layer;
     int n_lines;
     int simplification, mask_type;
@@ -225,6 +226,10 @@
     where_opt = G_define_standard_option(G_OPT_DB_WHERE);
     where_opt->guisection = _("Selection");
+    loop_support_flag = G_define_flag();
+    loop_support_flag->key = 'l';
+    loop_support_flag->description = _("Loop support");
     notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
     notab_flag->description = _("Do not copy attributes");
     notab_flag->guisection = _("Attributes");
@@ -447,6 +452,20 @@
 	    /* copy points */
 	    Vect_reset_line(Points);
 	    Vect_append_points(Points, APoints, GV_FORWARD);
+	    loop_support = 0;
+	    if (loop_support_flag->answer) {
+		int n1, n2;
+		Vect_get_line_nodes(&Out, i, &n1, &n2);
+		if (n1 == n2) {
+		    if (Vect_get_node_n_lines(&Out, n1) == 2) {
+			if (abs(Vect_get_node_line(&Out, n1, 0)) == i &&
+			    abs(Vect_get_node_line(&Out, n1, 1)) == i)
+			    loop_support = 1;
 	    for (iter = 0; iter < iterations; iter++) {
 		switch (method) {
@@ -470,7 +489,7 @@
 		    boyle(Points, look_ahead, with_z);
 		    break;
 		case SLIDING_AVERAGING:
-		    sliding_averaging(Points, slide, look_ahead, with_z);
+		    sliding_averaging(Points, slide, look_ahead, loop_support, with_z);
 		    break;
 		case DISTANCE_WEIGHTING:
 		    distance_weighting(Points, slide, look_ahead, with_z);
@@ -487,6 +506,7 @@
+        if (method != SLIDING_AVERAGING || loop_support == 0){
 	    /* safety check, BUG in method if not passed */
 	    if (APoints->x[0] != Points->x[0] ||
 		APoints->y[0] != Points->y[0] ||
@@ -498,6 +518,8 @@
 		APoints->z[APoints->n_points - 1] != Points->z[Points->n_points - 1])
 		G_fatal_error(_("Method '%s' did not preserve last point"), method_opt->answer);
 	    Vect_line_prune(Points);
 	    /* oversimplified line */
Modified: grass/trunk/vector/v.generalize/operators.h
--- grass/trunk/vector/v.generalize/operators.h	2013-05-14 13:35:52 UTC (rev 56251)
+++ grass/trunk/vector/v.generalize/operators.h	2013-05-14 14:44:32 UTC (rev 56252)
@@ -12,7 +12,7 @@
 /* smoothing.c */
 int boyle(struct line_pnts *Points, int look_ahead, int with_z);
 int sliding_averaging(struct line_pnts *Points, double slide, int look_ahead,
-		      int with_z);
+		      int loop_support, int with_z);
 int distance_weighting(struct line_pnts *Points, double slide, int look_ahead,
 		       int with_z);
 int chaiken(struct line_pnts *Points, double thresh, int with_z);
Modified: grass/trunk/vector/v.generalize/point.c
--- grass/trunk/vector/v.generalize/point.c	2013-05-14 13:35:52 UTC (rev 56251)
+++ grass/trunk/vector/v.generalize/point.c	2013-05-14 14:44:32 UTC (rev 56252)
@@ -63,6 +63,21 @@
     return;
+inline void point_assign_loop(struct line_pnts *Points, int index, int with_z,
+			 POINT * res)
+    index = index % Points->n_points;
+    res->x = Points->x[index];
+    res->y = Points->y[index];
+    if (with_z) {
+	res->z = Points->z[index];
+    else {
+	res->z = 0;
+    return;
 inline void point_scalar(POINT a, double k, POINT * res)
     res->x = a.x * k;
Modified: grass/trunk/vector/v.generalize/point.h
--- grass/trunk/vector/v.generalize/point.h	2013-05-14 13:35:52 UTC (rev 56251)
+++ grass/trunk/vector/v.generalize/point.h	2013-05-14 14:44:32 UTC (rev 56252)
@@ -50,6 +50,12 @@
 extern inline void point_assign(struct line_pnts *Points, int index,
 				int with_z, POINT * res);
+/* assign point Points[index] to the res
+ * if with z = 0 then res.z = 0
+ * loop to infinite
+extern inline void point_assign_loop(struct line_pnts *Points, int index,
+				int with_z, POINT * res);
 /* res = k * a */
 extern inline void point_scalar(POINT a, double k, POINT * res);
Modified: grass/trunk/vector/v.generalize/smoothing.c
--- grass/trunk/vector/v.generalize/smoothing.c	2013-05-14 13:35:52 UTC (rev 56251)
+++ grass/trunk/vector/v.generalize/smoothing.c	2013-05-14 14:44:32 UTC (rev 56252)
@@ -25,6 +25,8 @@
 #include "point.h"
 #include "matrix.h"
+/* TODO: add loop support where possible */
 /* boyle's forward looking algorithm
  * return the number of points in the result = Points->n_points
@@ -70,18 +72,31 @@
 /* mcmaster's sliding averaging algorithm. Return the number of points
  * in the output line. This equals to the number of points in the
  * input line */
-int sliding_averaging(struct line_pnts *Points, double slide, int look_ahead,
-		      int with_z)
+int sliding_averaging(struct line_pnts *Points, double slide, int look_ahead,
     int n, half, i;
     double sc;
     POINT p, tmp, s;
     POINT *res;
+    int is_loop, count;
+    is_loop=0;
     n = Points->n_points;
     half = look_ahead / 2;
+    count = n - half;
+    /* is it loop ?*/
+    if (Points->x[0] == Points->x[n-1]
+        && Points->y[0] == Points->y[n-1]
+        && (Points->z[0] == Points->z[n-1] || with_z == 0) && loop_support){
+        is_loop = 1;
+        count = n + half;
     if (look_ahead % 2 == 0) {
 	G_fatal_error(_("Look ahead parameter must be odd"));
 	return n;
@@ -90,7 +105,7 @@
     if (look_ahead >= n || look_ahead == 1)
 	return n;
-    res = G_malloc(sizeof(POINT) * n);
+    res = G_malloc(sizeof(POINT) * (n + half));
     if (!res) {
 	G_fatal_error(_("Out of memory"));
 	return n;
@@ -105,29 +120,37 @@
     /* and calculate the average of remaining points */
-    for (i = half; i + half < n; i++) {
-	point_assign(Points, i, with_z, &s);
+    for (i = half; i < count; i++) {
+	point_assign_loop(Points, i, with_z, &s);
 	point_scalar(s, 1.0 - slide, &s);
 	point_scalar(p, sc * slide, &tmp);
 	point_add(tmp, s, &res[i]);
-	if (i + half + 1 < n) {
-	    point_assign(Points, i - half, with_z, &tmp);
+	if ((i + half + 1 < n) || is_loop ) {
+	    point_assign_loop(Points, i - half, with_z, &tmp);
 	    point_subtract(p, tmp, &p);
-	    point_assign(Points, i + half + 1, with_z, &tmp);
+	    point_assign_loop(Points, i + half + 1, with_z, &tmp);
 	    point_add(p, tmp, &p);
 	Points->x[i] = res[i].x;
 	Points->y[i] = res[i].y;
 	Points->z[i] = res[i].z;
+    if (is_loop) {
+        for (i = 0; i < half; i++) {
+        Points->x[i] = res[n + i - 1].x;
+        Points->y[i] = res[n + i - 1].y;
+        Points->z[i] = res[n + i - 1].z;
     G_free(res);
     return Points->n_points;
 /* mcmaster's distance weighting algorithm. Return the number
