[GRASS-SVN] r56261 - grass-addons/grass6/raster/r.fidimo
Wed May 15 05:45:37 PDT 2013
Author: jradinger
Date: 2013-05-15 05:45:35 -0700 (Wed, 15 May 2013)
New Revision: 56261
   grass-addons/grass6/raster/r.fidimo/description.html
   grass-addons/grass6/raster/r.fidimo/r.fidimo.py
changed the term clearance to passability
Modified: grass-addons/grass6/raster/r.fidimo/description.html
--- grass-addons/grass6/raster/r.fidimo/description.html	2013-05-15 12:45:08 UTC (rev 56260)
+++ grass-addons/grass6/raster/r.fidimo/description.html	2013-05-15 12:45:35 UTC (rev 56261)
@@ -33,9 +33,9 @@
 <dl>
 <dt><b>barriers</b></dt>
 <dd>Name of input barrier text-file indicating the geographical position
-and permeabilty of barriers e.g. weirs. The file should contain the
+and passability of barriers e.g. weirs. The file should contain the
 X and Y coordinate and a value for permeability (0-1 where 0 is
-non-permeable and 1 is 100% passable). The values must be |-separated:
+non-passable and 1 is 100% passable). The values must be |-separated:
 </dd>
 </dl>
Modified: grass-addons/grass6/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-05-15 12:45:08 UTC (rev 56260)
+++ grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-05-15 12:45:35 UTC (rev 56261)
@@ -343,7 +343,7 @@
 						  overwrite = True,
 						  input=input_barriers,
 						  output="barriers_tmp_%d" % os.getpid(),
-						  columns="x DOUBLE, y DOUBLE, clearance DOUBLE")
+						  columns="x DOUBLE, y DOUBLE, passability DOUBLE")
 		grass.run_command("v.db.addcol",
 						  map ="barriers_tmp_%d" % os.getpid(),
 						  columns="new_X DOUBLE, new_Y DOUBLE")
@@ -761,7 +761,7 @@
 				# Loop over the affected barriers (from most downstream barrier to most upstream barrier)
 				# Initally affected = all barriers where density > 0
-				for cat,X,Y,dist,clearance in db.execute('SELECT cat, X, Y, dist, clearance FROM barriers_%d WHERE affected_barriers > 0 AND dist > 0 ORDER BY dist' % os.getpid()):
+				for cat,X,Y,dist,passability in db.execute('SELECT cat, X, Y, dist, passability FROM barriers_%d WHERE affected_barriers > 0 AND dist > 0 ORDER BY dist' % os.getpid()):
 					coors_barriers = str(X)+","+str(Y)
 					grass.debug(_("Starting with corrections for barriers"))
@@ -787,7 +787,7 @@
 					else:
 						grass.fatal(_("Error with upstream density/barriers. The error is for coors_barriers (X,Y): "+coors_barriers))
-					density_for_downstream = upstream_density*(1-clearance)
+					density_for_downstream = upstream_density*(1-passability)
 					# barrier_effect = Length of Effect of barriers (linear decrease up to max (barrier_effect)
@@ -831,21 +831,21 @@
 					grass.run_command("r.null", map="density_segment_"+str(Segment[0]), null="0")
 					grass.run_command("r.null", map="density_below_barrier_tmp_%d" % os.getpid(), null="0")
-					grass.mapcalc("$density_segment = if(isnull($upstream_barrier), $density_below_barrier+$density_segment, $upstream_density*$clearance)",
+					grass.mapcalc("$density_segment = if(isnull($upstream_barrier), $density_below_barrier+$density_segment, $upstream_density*$passability)",
 								density_segment = "density_segment_"+str(Segment[0]),
 								upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
 								density_below_barrier = "density_below_barrier_tmp_%d" % os.getpid(),
 								upstream_density = "upstream_density_tmp_%d" % os.getpid(),
-								clearance=clearance)
+								passability=passability)
 					if dist == last_barrier :
 						grass.run_command("r.null", map="density_segment_"+segment_cat, null="0")
 					else:
 						grass.run_command("r.null", map="density_segment_"+segment_cat, setnull="0")
-					#If the barrier in the loop was impermeable (clearance=0)
+					#If the barrier in the loop was impermeable (passability=0)
 					#than no more upstream barriers need to be considered --> break
-					if clearance == 0:
+					if passability == 0:
 						break
 			grass.run_command("r.null", map="density_segment_"+segment_cat, null="0") # Final density map per segment
