[GRASS-SVN] r56271 - grass-addons/grass7/raster/r.shalstab
Wed May 15 15:17:29 PDT 2013
Author: kikapu
Date: 2013-05-15 15:17:28 -0700 (Wed, 15 May 2013)
New Revision: 56271
Added:
   grass-addons/grass7/raster/r.shalstab/r.shalstab.py
R.shalstab: A model for shallow landslide susceptibility
Added: grass-addons/grass7/raster/r.shalstab/r.shalstab.py
--- grass-addons/grass7/raster/r.shalstab/r.shalstab.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.shalstab/r.shalstab.py	2013-05-15 22:17:28 UTC (rev 56271)
@@ -0,0 +1,187 @@
+#!/usr/bin/env python
+# MODULE:      r.shalstab
+# VERSION:     1.0
+# AUTHOR(S):   Andrea Filipello & Daniele Strigaro
+# PURPOSE:     A model based on the algorithm developet by Montgomery and Dietrich (1994)
+# COPYRIGHT:   (C) 2013 by Andrea Filipello & Daniele Strigaro
+#              andrea.filipello at gmail.com; daniele.strigaro at gmail.com
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+#%module
+#%  description: A model for shallow landslide susceptibility
+#%  keywords: raster, critical rainfall, landslide
+#%end
+#%option
+#%  key: dem
+#%  type: string
+#%  gisprompt: old,raster,raster
+#%  key_desc: name
+#%  description: Name of input elevation raster map
+#%  required: yes
+#%end
+#%option
+#%  key: phy
+#%  type: string
+#%  key_desc: name
+#%  description: Soil friction angle (angle)
+#%  required: yes
+#%end
+#%option
+#%  key: c_soil
+#%  type: string
+#%  key_desc: name
+#%  description: Soil cohesion (N/m^2)
+#%  required: yes
+#%end
+#%option
+#%  key: gamma
+#%  type: string
+#%  key_desc: name
+#%  description: Soil density(Kg/m^3)
+#%  required: yes
+#%end
+#%option
+#%  key: z
+#%  type: string
+#%  key_desc: name
+#%  description: Vertical thickness of soil (m)
+#%  required: yes
+#%end
+#%option
+#%  key: k
+#%  type: string
+#%  key_desc: name
+#%  description: hydraulic conductivity (m/h)
+#%  required: yes
+#%end
+#%option
+#%  key: gamma_wet
+#%  type: string
+#%  key_desc: name
+#%  description: Wet soil density (kg/m^3)
+#%  answer: 2100
+#%  required: no
+#%end
+#%option
+#%  key: root
+#%  type: string
+#%  key_desc: name
+#%  description: Root cohesion k (N/m^2)
+#%  required: no
+#%end
+# output
+#%option
+#% key: susceptibility
+#% type: string
+#% gisprompt: new,cell,raster
+#% key_desc: susceptibility
+#% description: Name for output landslide susceptibility map (from 1 to 7)
+#% required : yes
+#%end
+#%option
+#% key: critic_rain
+#% type: string
+#% key_desc: critical rain
+#% description: Name for output critical rainfall map (mm/day)
+#% required : yes
+#%END
+import sys
+import os
+try:
+    import grass.script as grass
+except:
+    try:
+        from grass.script import core as grass
+    except:
+        sys.exit("grass.script can't be imported.")
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+    r_elevation = options['dem'].split('@')[0]
+    mapname = options['dem'].replace("@", " ")
+    mapname = mapname.split()
+    mapname[0] = mapname[0].replace(".", "_")
+    c_soil = options['c_soil']
+    phy = options['phy']
+    gamma = options['gamma']
+    gamma_wet = options['gamma_wet']
+    z = options['z']
+    #b = options['b']
+    k = options['k']
+    root = options['root']
+    susceptibility = options['susceptibility']
+    critic_rain = options['critic_rain']
+    if root == '':
+        root = 0
+    if gamma_wet == '':
+        gamma_wet = 2100
+    # calculate slope
+    grass.run_command('r.slope.aspect', elevation=r_elevation, slope='slopes',
+                      min_slp_allowed=0.0, overwrite='True') #format = 'degrees', precision = float,
+    # calculate soil transmissivity T (m^2/day)
+    grass.mapcalc("T=$k*24*$z*cos(slopes)", k=k, z=z)
+    # calculate dimensionless
+    grass.mapcalc("C=($root+$c_soil)/($z*cos(slopes)*9.81*$gamma_wet)",
+                  root=root, c_soil=c_soil, z=z, gamma_wet=gamma_wet)
+    # calculate contribution area
+    grass.run_command('r.watershed', elevation=r_elevation,
+                      accumulation='accum')
+    grass.mapcalc("A=accum*((ewres()+nsres())/2)*((ewres()+nsres())/2)")
+    # calculate 1(m/day)
+    grass.mapcalc("i_crit_m=T*sin(slopes)*((ewres()+nsres())/2)/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes)))*tan(slopes)/tan($phy)))",
+                  phy=phy, gamma=gamma)
+    # Calculation of critical rain (mm / hr) and riclassification
+    grass.mapcalc("i_cri_mm=i_crit_m*24000")
+    reclass_rules = "0 thru 50 = 0\n50 thru 100 = 3\n100 thru 200 = 4\n" \
+                    "200 thru 400 = 5\n400 thru 999 = 6"
+    grass.write_command('r.reclass', input='i_cri_mm', output='i_recl',
+                        overwrite='True', rules='-', stdin=reclass_rules)
+    grass.mapcalc("copia_reclass=i_recl+0")
+    grass.run_command('r.null', map='copia_reclass', null=0)
+    grass.mapcalc("Stable=if (i_cri_mm>1000, 7, 0)")
+    grass.mapcalc("Unstable=if (i_cri_mm<0, 1, 0)")
+    grass.mapcalc("Icritica=copia_reclass+Unstable+Stable")
+    colors_rules = "1 255:85:255\n2 255:0:0\n3 255:170:0\n4 255:255:0\n" \
+                   "5 85:255:0\n6 170:255:255\n7 255:255:255"
+    grass.write_command('r.colors', map='Icritica', rules='-',
+                        stdin=colors_rules, quiet=True)
+    grass.run_command('r.neighbors', input='Icritica', method='average',
+                      size=3, output='I_cri_average')
+    # rename maps
+    grass.run_command('g.rename', rast=("I_cri_average", susceptibility))
+    grass.run_command('g.rename', rast=("i_cri_mm", critic_rain))
+    # remove temporary map
+    grass.run_command('g.remove', rast=("A", "copia_reclass", "i_crit_m",
+                                        "i_recl", "accum", "slopes", "Stable",
+                                        "T", "Unstable", "C"))
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
