[GRASS-SVN] r56357 - in grass-addons/grass7/raster/r.agent: libagent tests
Tue May 21 14:52:13 PDT 2013
Author: mic
Date: 2013-05-21 14:52:12 -0700 (Tue, 21 May 2013)
New Revision: 56357
   grass-addons/grass7/raster/r.agent/libagent/ant.py
   grass-addons/grass7/raster/r.agent/tests/test_ant.py
implement first version of walk back home
Modified: grass-addons/grass7/raster/r.agent/libagent/ant.py
--- grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-21 16:27:24 UTC (rev 56356)
+++ grass-addons/grass7/raster/r.agent/libagent/ant.py	2013-05-21 21:52:12 UTC (rev 56357)
@@ -24,9 +24,9 @@
         @param list coordinate of the current position
         super(Ant, self).__init__(timetolive, world, position)
-        self.position.extend([None,None])
+        self.position = [position[0], position[1], None, 0]
         self.home = self.position[:]
-        self.laststeps = [self.position[:]]
+        self.laststeps = []
         self.visitedsteps = []
         self.done = False
         self.nextstep = [None,None,None,0]
@@ -72,6 +72,7 @@
                     # now, head back home..
                     self.nextstep = self.laststeps.pop()
                     return True
+                    # TODO instead of work and walk reset work, which initially points to walkaround, to to headhome here!
         return False
     def choose(self):
@@ -88,12 +89,24 @@
     def walk(self):
         Do all the things necessary for performing a regualar step when
-        walking around.
+        walking around or going back home.
-        self.laststeps.append(self.position)
-        self.position = self.nextstep
-        self.nextstep = [None,None,None,0]
-        self.world.setsteppheromone(self.position)
+        if self.done:
+            self.position = self.nextstep
+            if len(self.laststeps) > 1:
+                # walk only up to the gates of the hometown
+                self.nextstep = self.laststeps.pop()
+                self.penalty += self.nextstep[3] + \
+                                  self.world.getpenalty(self.nextstep)
+            else:
+                # retire after work.
+                self.snuffit()
+            self.world.setpathpheromone(self.position)
+        else:
+            self.laststeps.append(self.position)
+            self.nextstep = [None,None,None,0]
+            self.world.setsteppheromone(self.position)
     def work(self):
@@ -106,6 +119,7 @@
             return False
         # past this point we must have decided yet where to go to next..
         if self.nextstep[0] == None:
+            # so we decide it now if it is not clear yet
             self.choose()
Modified: grass-addons/grass7/raster/r.agent/tests/test_ant.py
--- grass-addons/grass7/raster/r.agent/tests/test_ant.py	2013-05-21 16:27:24 UTC (rev 56356)
+++ grass-addons/grass7/raster/r.agent/tests/test_ant.py	2013-05-21 21:52:12 UTC (rev 56357)
@@ -14,7 +14,7 @@
     def test_check(self):
         positions = [[0,0],[1,1]]
-        self.laststeps = [1,1]
+        self.agent.laststeps = [[1,1]]
         # An empty test
         self.pg.layers[anthill.Anthill.SITE][0][0] = 0
         self.pg.layers[anthill.Anthill.SITE][1][1] = 0
@@ -36,6 +36,7 @@
         pass
     def test_walk(self):
+        #TODO walking home
         self.agent.position = [0,0]
         self.agent.nextstep = [1,1]
         self.agent.walk()
