[GRASS-SVN] r56391 - in grass/branches/releasebranch_6_4/vector: v.net v.net.alloc v.net.bridge v.net.centrality v.net.components v.net.connectivity v.net.distance v.net.flow v.net.iso v.net.path v.net.salesman v.net.spanningtree v.net.timetable v.net.visibility
Thu May 23 13:01:56 PDT 2013
Author: neteler
Date: 2013-05-23 13:01:55 -0700 (Thu, 23 May 2013)
New Revision: 56391
   grass/branches/releasebranch_6_4/vector/v.net.alloc/description.html
   grass/branches/releasebranch_6_4/vector/v.net.bridge/description.html
   grass/branches/releasebranch_6_4/vector/v.net.centrality/description.html
   grass/branches/releasebranch_6_4/vector/v.net.components/description.html
   grass/branches/releasebranch_6_4/vector/v.net.connectivity/description.html
   grass/branches/releasebranch_6_4/vector/v.net.distance/description.html
   grass/branches/releasebranch_6_4/vector/v.net.flow/description.html
   grass/branches/releasebranch_6_4/vector/v.net.iso/description.html
   grass/branches/releasebranch_6_4/vector/v.net.path/description.html
   grass/branches/releasebranch_6_4/vector/v.net.salesman/description.html
   grass/branches/releasebranch_6_4/vector/v.net.spanningtree/description.html
   grass/branches/releasebranch_6_4/vector/v.net.timetable/description.html
   grass/branches/releasebranch_6_4/vector/v.net.visibility/description.html
   grass/branches/releasebranch_6_4/vector/v.net/description.html
v.net.*: HTML layout fixes; typos fixed
Modified: grass/branches/releasebranch_6_4/vector/v.net/description.html
--- grass/branches/releasebranch_6_4/vector/v.net/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,16 +1,17 @@
 <h2>DESCRIPTION</h2>
-<em>v.net</em> is used for network preparation and maintenance. Its main
-use is to create a vector network from vector lines (<em>arcs</em>) and points
-(<em>nodes</em>) by creating nodes from intersections in a map of vector
-lines (<em>node</em> operator), by connecting a vector lines map with a points map
-(<em>connect</em> operator), and by creating new lines between pairs of vector points
+<em>v.net</em> is used for network preparation and maintenance. Its
+main use is to create a vector network from vector lines (<em>arcs
+</em>) and points (<em>nodes</em>) by creating nodes from
+intersections in a map of vector lines (<em>node</em> operator), by
+connecting a vector lines map with a points map (<em>connect</em>
+operator), and by creating new lines between pairs of vector points
 (<em>arcs</em> operator).
 <p>
 A GIS network consists of topologically correct lines (arcs). That is,
 the lines must be connected by shared vertices where real connections exist.
-In GRASS you also can add nodes to the network. These are specially
+In GRASS GIS you also can add nodes to the network. These are specially
 designated vertices used for analyzing network properties or computing
 cost/distance measures. That is, not all vertices are treated as nodes by
 default. Only <em><a href="v.net.path.html">v.net.path</a></em> can use a
@@ -55,7 +56,7 @@
 (method 2 above), it is possible to create an attribute table for the
 new nodes in layer 2 using the attribute table manager and connect it to
 layer 2 ("manage layers" tab) or to create a table with
-<em><a href="v.db.addtable.html">v.db.addtable</a>,
+<em><a href="v.db.addtable.html">v.db.addtable</a></em>,
 connect it to layer 2 with <em><a href="v.db.connect.html">v.db.connect</a></em>,
 and update the new table with cat values with <em><a href="v.to.db.html">v.to.db</a></em>.
@@ -115,17 +116,20 @@
 Merge in nodes from a separate map within given threshold:
 <div class="code"><pre>
-v.net input=streets_wake points=firestations out=streets_net operation=connect thresh=500
+v.net input=streets_wake points=firestations out=streets_net \
+      operation=connect thresh=500
 </pre></div>
-For generating network for given vector point map is required input file in format
+For generating network for given vector point map is required input
+file in format:
 [category of edge] [category of start node] [category of end node]
 </pre></div>
-v.net points=geodetic_swwake_pts output=geodetic_swwake_pts_net operation=arcs file=- << EOF
+v.net points=geodetic_swwake_pts output=geodetic_swwake_pts_net \
+      operation=arcs file=- << EOF
 > 1 28000 28005
 > 2 27945 27958
 > 3 27886 27897
@@ -136,7 +140,11 @@
 <em>
 <a href="wxGUI.Vector_Digitizer.html">wxGUI vector digitizer</a>,
-<a href="v.edit.html">v.edit</a>,<br>
+<a href="v.edit.html">v.edit</a>
+</em>
+<p>
+<em>
 <a href="v.net.alloc.html">v.net.alloc</a>,
 <a href="v.net.allpairs.html">v.net.allpairs</a>,
 <a href="v.net.bridge.html">v.net.bridge</a>,
Modified: grass/branches/releasebranch_6_4/vector/v.net.alloc/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.alloc/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.alloc/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,15 +1,17 @@
-<em>v.net.alloc</em> allocates subnets for nearest centers (direction from
-center). center nodes must be opened (costs >= 0). Costs of center nodes are
-used in the calculation.
+<em>v.net.alloc</em> allocates subnets for nearest centers
+(direction from center). center nodes must be opened (costs >= 0).
+Costs of center nodes are used in the calculation.
 <p>
-Costs may be either line lengths, or attributes saved in a database
-table. These attribute values are taken as costs of whole segments, not
-as costs to traverse a length unit (e.g. meter) of the segment.
-For example, if the speed limit is 100 km / h, the cost to traverse a
-10 km long road segment must be calculated as
+Costs may be either line lengths, or attributes saved in a
+database table. These attribute values are taken as costs of whole
+segments, not as costs to traverse a length unit (e.g. meter) of the
+segment. For example, if the speed limit is 100 km / h, the cost to
+traverse a 10 km long road segment must be calculated as
+<br>
 length / speed = 10 km / (100 km/h) = 0.1 h.
+<br>
 Supported are cost assignments for both arcs and nodes,
 and also different costs for both directions of a vector line.
 For areas, costs will be calculated along boundary lines.
Modified: grass/branches/releasebranch_6_4/vector/v.net.bridge/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.bridge/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.bridge/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,27 +1,41 @@
-<em>v.net.bridge</em> finds bridges and articulation points in a network.
+<em>v.net.bridge</em> finds bridges and articulation points in a network.
 <h2>NOTES</h2>
-Bridge in a network is an edge/line whose removal would disconnect the (sub-)network. A node is an articulation point if its removal would disconnect the (sub-)network. For more information and formal definitions check the wikipedia entries: <a href="http://en.wikipedia.org/wiki/Bridge_%28graph_theory%29">bridge</a> and <a href="http://en.wikipedia.org/wiki/Cut_vertex">articulation point</a>.<br><br>
-The output of the module contains the selected features. If <b>method=bridge</b> then lines corresponding to bridges are copied from the input map to the output map. On the other hand, if <b>method=articulation</b> then point are created on the positions of articulation points.<br><br>
+Bridge in a network is an edge/line whose removal would disconnect
+the (sub-)network. A node is an articulation point if its removal
+would disconnect the (sub-)network. For more information and formal
+definitions check the wikipedia entries:
+<a href="http://en.wikipedia.org/wiki/Bridge_%28graph_theory%29">bridge</a>
+and <a href="http://en.wikipedia.org/wiki/Cut_vertex">articulation
+point</a>.
+<p>
+The output of the module contains the selected
+features. For <b>method=bridge</b>, lines corresponding to
+bridges are copied from the input map to the output map. On the
+other hand, for <b>method=articulation</b>, points are created on
+the positions of articulation points.
+<p>
+<br>In GRASS GIS, <em>line</em> is not always a single line
+segment. It might be, and often is, a sequence of line segments
+between two intersections. Also, articulation point is a standard
+graph theoretic terminology which is slightly misleading in GRASS.
+An articulation point in graph theory is an articulation
+<em>node</em> in GRASS terminology.
-<br>In GRASS, <em>line</em> is not always a single line segments. It might be, and often is, a sequence of line segments between two intersections. Also, articulation point is a standard graph theoretic terminology which is slightly  misleading in GRASS. An articulation point in graph theory is an articulation <em>node</em> in GRASS terminology.
 <h2>EXAMPLES</h2>
+	TBD
 </pre></div>
-<p>
-<div class="code"><pre>
-</pre></div>
 <h2>SEE ALSO</h2>
 <em>
+<a href="v.net.html">v.net</a>,
 <a href="v.category.html">v.category</a>,
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.centrality/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.centrality/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.centrality/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,26 +1,43 @@
-<em>v.net.centrality</em> computes degree, closeness, betweenness and eigenvector centrality measures.
+<em>v.net.centrality</em> computes degree, closeness, betweenness
+and eigenvector centrality measures.
 <h2>NOTES</h2>
-The module computes various centrality measures for each node and stores them in the given columns of an attribute table, which is created and linked to the output map. For the description of these, please check the following <a href="http://en.wikipedia.org/wiki/Centrality">wikipedia article</a>. If the column name is not given for a measure then that measure is not computed. If <b>-a</b> flag is set then points are added on nodes without points. Also, the points for which the output is computed can be specified by <b>cats</b>, <b>layer</b> and <b>where</b> parameters. However, if any of these parameters is present then <b>-a</b> flag is ingored and no new points are added.<br>
-Betwenness measure is not normalised. In order to get the normalised values (between 0 and 1), each number needs to be divided by <em>N choose 2=N*(N-1)/2</em> where N is the number of nodes in the connected component. Computation of eigenvector measure terminates if the given number of iterations is reached or the cummulative <em>squared</em> error between the successive iterations is less than <b>error</b>.
+The module computes various centrality measures for each node and
+stores them in the given columns of an attribute table, which is
+created and linked to the output map. For the description of these,
+please check the following
+<a href="http://en.wikipedia.org/wiki/Centrality">wikipedia article</a>.
+If the column name is not given for a measure then that measure is not
+computed. If <b>-a</b> flag is set then points are added on nodes
+without points. Also, the points for which the output is computed
+can be specified by <b>cats</b>, <b>layer</b> and <b>where</b>
+parameters. However, if any of these parameters is present then
+<b>-a</b> flag is ignored and no new points are added.
+<br>
+Betweenness measure is not normalised. In order to get the normalised
+values (between 0 and 1), each number needs to be divided by <em>N
+choose 2=N*(N-1)/2</em> where N is the number of nodes in the
+connected component. Computation of eigenvector measure terminates
+if the given number of iterations is reached or the cummulative <em>
+squared</em> error between the successive iterations is less than <b>
+error</b>.
 <h2>EXAMPLES</h2>
-Compute closeness and betweenness centrality measures for each node and produce a map containing not only points already present in the input map but a map with point on every node.
+Compute closeness and betweenness centrality measures for each node
+and produce a map containing not only points already present in the
+input map but a map with point on every node.
-v.net.centrality input=roads output=roads_cent closeness=close betweenness=betw -a
+v.net.centrality input=roads output=roads_cent closeness=closeness \
+      betweenness=betweenness -a
 </pre></div>
-<p>
-</pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.generalize.html">v.generalize</a>
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.components/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.components/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.components/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,28 +1,38 @@
-<em>v.net.components</em> computes the weakly and strongly connected components in a network.
+<em>v.net.components</em> computes the weakly and strongly connected
+components in a network.
 <h2>NOTES</h2>
-Two nodes, <em>u</em> and <em>v</em> are in the same strongly connected component if there are directed paths from <em>u</em> to <em>v</em> and from <em>v</em> to <em>u</em>. The nodes are in the same weakly connected component if, ignoring orientation of the edges, there is a path between them.<br>
+Two nodes, <em>u</em> and <em>v</em> are in the same strongly
+connected component if there are directed paths from <em>u</em> to
+<em>v</em> and from <em>v</em> to <em>u</em>. The nodes are in the
+same weakly connected component if, ignoring orientation of the
+edges, there is a path between them.
+<br>
-The type of components is specified by <b>method</b> parameter. Module creates a table and links it to the given <b>layer</b>. This table contains only two integer columns: <em>cat</em> and <em>comp</em>. If a point or both endpoints of a line belong to the same component then the point/line is written to the output map and appropriate information is stored in the table. If <b>-a</b> flag is set then new points are added on the nodes without points. These points have category numbers larger than any category used in the input map.
+The type of components is specified by <b>method</b> parameter.
+<em>v.net.components</em> creates a table and links it to the given <b>layer</b>.
+This table contains only two integer columns: <em>cat</em> and <em>comp
+</em>. If a point or both endpoints of a line belong to the same
+component then the point/line is written to the output map and
+appropriate information is stored in the table. If <b>-a</b> flag is
+set then new points are added on the nodes without points. These
+points have category numbers larger than any category used in the
+input map.
 <h2>EXAMPLES</h2>
-Any road network should form a single strongly connected components. Otherwise,
-it is impossible to travel between some places.
+Any road network should form a single strongly connected component.
+Otherwise, it is impossible to travel between some places.
 v.net.components input=roads output=roads_components method=strong
 </pre></div>
-<p>
-</pre></div>
 <h2>SEE ALSO</h2>
 <em>
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.connectivity/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.connectivity/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.connectivity/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -17,18 +17,21 @@
 The following command finds the minimum number of intersections separating
 roads on the left bank from roads on the right bank.
-v.net.connectivity input=roads output=roads_conn set1_where="bank=left" set2_where="bank=right"
+v.net.connectivity input=roads output=roads_conn set1_where="bank=left" \
+      set2_where="bank=right"
 </pre></div>
 <p>
-v.net.connectivity input=airtraffic output=connectivity set1_where="name=JFK" set2_where="name=Heathrow" ncolumn=capacity
+v.net.connectivity input=airtraffic output=connectivity \
+      set1_where="name=JFK" set2_where="name=Heathrow" ncolumn=capacity
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.net.flow.html">v.net.flow</a>,
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.distance/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.distance/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.distance/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,28 +1,50 @@
-<em>v.net.distance</em> finds the nearast element from set <em>to</em> for every element in set <em>from</em>.
+<em>v.net.distance</em> finds the nearest element in set <em>to</em>
+for every point in set <em>from</em>.
 <h2>NOTES</h2>
-These two sets are given by the respective <b>layer</b>, <b>where</b> and <b>cats</b> parameters. The type of <em>to</em> features is specified by <b>to_type</b> parameter and all <em>from</em> features are <em>points</em>. A table is linked to <b>output</b> map containing various information about the relation. More specifically, the table has three columns: <em>cat</em>, <em>tcat</em> and <em>dist</em> storing category of each <em>from</em> feature, category of the nearest <em>to</em> feature and the distance between them respectively. Furthemore, <b>output</b> map contains the shorest path between each <em>cat</em>, <em>tcat</em> pair. Each path consist of several lines. If a line is on the shorest path from a point then the category of this point is assigned to the line. Note that every line may contain more than one category value since single line may be on the shortest path for more than one <em>from</em> feature. And so the shortest paths can be easily obtained by qu
 erying lines with corresponding category number.<br>
-The costs of arcs in forward and backward direction are specified by <b>afcolumn</b> and <b>abcolumn</b> columns respectively. If <b>abcolumn</b> is not given, the same cost is used in both directions.
+These two sets are given by the respective <b>layer</b>, <b>where</b>
+and <b>cats</b> parameters. The type of <em>to</em> features is
+specified by <b>to_type</b> parameter. All <em>from</em> features
+are <em>points</em>. A table is linked to <b>output</b> map
+containing various information about the relation. More
+specifically, the table has three columns: <em>cat</em>, <em>tcat</em>
+and <em>dist</em> storing category of each <em>from</em>
+feature, category of the nearest <em>to</em> feature and the
+distance between them respectively. Furthemore, <b>output</b> map
+contains the shorest path between each <em>cat</em>, <em>tcat</em>
+pair. Each path consist of several lines. If a line is on the
+shorest path from a point then the category of this point is
+assigned to the line. Note that every line may contain more than one
+category value since a single line may be on the shortest path for
+more than one <em>from</em> feature. And so the shortest paths can
+be easily obtained by querying lines with corresponding category
+number.
+<br>
+The costs of arcs in forward and backward direction are specified by
+<b>afcolumn</b> and <b>abcolumn</b> columns respectively. If
+<b>abcolumn</b> is not given, the same cost is used in both directions.
 <p>
-<em>v.net.distance</em> will not work if you are trying to find the nearest
-neighbors within a group of nodes, i.e. where <em>to</em> and <em>from</em>
-are the same set of nodes, as the closest node will be the node itself and
-the result will be zero-length paths. In order to find nearest neighbors
-within a group of nodes, you can either loop through each node as <em>to</em>
-and all other nodes as <em>from</em> or create a complete distance matrix with
-<a href="v.net.allpairs.html">v.net.allpairs</a> and select the lowest non-zero
-distance for each node.
+<em>v.net.distance</em> will not work if you are trying to find the
+nearest neighbors within a group of nodes, i.e. where <em>to</em>
+and <em>from</em> are the same set of nodes, as the closest node
+will be the node itself and the result will be zero-length paths. In
+order to find nearest neighbors within a group of nodes, you can
+either loop through each node as <em>to</em> and all other nodes as
+<em>from</em> or create a complete distance matrix with
+<a href="v.net.allpairs.html">v.net.allpairs</a> and select the
+lowest non-zero distance for each node.
 <h2>EXAMPLES</h2>
-Find shortest path and distance from every school to the nearest hospital and show path from school number one.
+Find shortest path and distance from every school to the nearest
+hospital and show path from school number one.
-v.net.distance input=city output=nearest from_where="type=school" to_where="type=hospital" afcolumn=SHAPE_LEN
+v.net.distance input=city output=nearest from_where="type=school" \
+               to_where="type=hospital" afcolumn=SHAPE_LEN
 d.vect nearest cats=1
 </pre></div>
-<p>
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_6_4/vector/v.net.flow/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.flow/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.flow/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,29 +1,52 @@
-<em>v.net.flow</em> computes the maximum flow and minimum cut between two sets of nodes.
+<em>v.net.flow</em> computes the maximum flow and minimum cut
+between two sets of nodes.
 <h2>NOTES</h2>
-The two sets of nodes are called <em>sources</em> and <em>sink</em> and <em>v.net.flow</em> finds the maximimum flow from the former to the latter ones. Edge capacities can be specified by <b>afcolumn</b> for forward direction and <b>abcolumn</b> for backward direction. If the latter parameter is ommited then the same capacity is used in either direction. The sets are given by the respective <b>cats</b>, <b>layer</b> and <b>where</b> parameters. Maximum flow corresponds to the maximum amount of water possibly flowing through the network preserving the capacity constraints and minimum cut to set of edges of minimum total capacity completely separating sources from sinks. The cut produced by this module corresponds to the first fully saturated edges from sources to sinks. An attribute table containing the flow information is linked to the <b>output</b> map. The table consists of two columns: <em>cat</em> and <em>flow</em> and stores the flow along each line. Negative flow mean
 s that "water" is flowing in the backward direction. <b>Cut</b> map contains the edges in the minimum cut. <br>
-A famous <a href="http://en.wikipedia.org/wiki/Max-flow_min-cut_theorem">result</a> says that the total amount of water flowing is equal to the minimum cut.
+The two sets of nodes are called <em>sources</em> and <em>sink</em>
+and <em>v.net.flow</em> finds the maximimum flow from the former to
+the latter ones. Edge capacities can be specified by <b>afcolumn</b>
+for forward direction and <b>abcolumn</b> for backward direction. If
+the latter parameter is ommited then the same capacity is used in
+either direction. The sets are given by the respective <b>cats</b>,
+<b>layer</b> and <b>where</b> parameters. Maximum flow corresponds
+to the maximum amount of water possibly flowing through the network
+preserving the capacity constraints and minimum cut to the set of edges
+of minimum total capacity completely separating sources from sinks.
+The cut produced by this module corresponds to the first fully
+saturated edges from sources to sinks. An attribute table containing
+the flow information is linked to the <b>output</b> map. The table
+consists of two columns: <em>cat</em> and <em>flow</em> and stores
+the flow along each line. Negative flow means that "water" is
+flowing in the backward direction. <b>Cut</b> map contains the edges
+in the minimum cut.
+<br>
+A famous <a href="http://en.wikipedia.org/wiki/Max-flow_min-cut_theorem">result</a>
+says that the total amount of water flowing is equal to the minimum
+cut.
 <h2>EXAMPLES</h2>
 Find maximum flow from factories to stores using SPEED for the capacities.
-v.net.flow input=roads output=roads_flow cut=roads_cut afcolumn=SPEED source_where="type=factory" sink_where="type=store"
+v.net.flow input=roads output=roads_flow cut=roads_cut afcolumn=SPEED \
+           source_where="type=factory" sink_where="type=store"
 </pre></div>
 <p>
-If all the capacties are one then the minimum cut corresponds to the minimum number of edges separating sources from sinks.
+If all the capacties are one then the minimum cut corresponds to the
+minimum number of edges separating sources from sinks.
-v.net.flow input=network output=flow cut=cut afcolumn=ones source_cats=1-10 sink_cats=100-100
+v.net.flow input=network output=flow cut=cut afcolumn=ones \
+           source_cats=1-10 sink_cats=100-100
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.net.connectivity.html">v.net.connectivity</a>
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.iso/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.iso/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.iso/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -9,7 +9,9 @@
+<br>
+<br>
@@ -23,7 +25,6 @@
 <p>
 Nodes must be on the isolines.
 <h2>EXAMPLES</h2>
 The map must contain at least one center (point) on the vector network
Modified: grass/branches/releasebranch_6_4/vector/v.net.path/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.path/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.path/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -9,7 +9,9 @@
+<br>
+<br>
Modified: grass/branches/releasebranch_6_4/vector/v.net.salesman/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.salesman/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.salesman/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -8,8 +8,10 @@
+10 km long road segment must be calculated as
+<br>
+<br>
 Supported are cost assignments for arcs,
Modified: grass/branches/releasebranch_6_4/vector/v.net.spanningtree/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.spanningtree/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.spanningtree/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,9 +1,18 @@
-<em>v.net.spanningtree</em> find the minimum spanning tree in a network.
+<em>v.net.spanningtree</em> finds the minimum spanning tree in a
+network.
 <h2>NOTES</h2>
-Spanning tree is a minimum cost subnetwork connecting all nodes in a network. Or, if a network is disconnected then the module computes the minimum spanning tree for each (weakly) connected component. So, strictly speaking, module does not compute spanning tree but a spanning forest. As the name suggests spanning tree is a tree. That is, it contains no cycles and if a component has N nodes that the tree has N-1 edges and connected all nodes. <b>Accol</b> is used to specify the costs of the edges. The <b>output</b> consists of the edges in the spanning tree.
+A spanning tree is a minimum cost subnetwork connecting all nodes in a
+network. Or, if a network is disconnected then the module computes
+the minimum spanning tree for each (weakly) connected component. So,
+strictly speaking, <em>v.net.spanningtree</em> does not compute spanning tree
+but a spanning forest. As the name suggests, a spanning tree is a tree. That
+is, it contains no cycles and if a component has N nodes then the
+tree has N-1 edges connecting all nodes. <b>Accol</b> is used to
+specify the costs of the edges. The <b>output</b> consists of the
+edges in the spanning tree.
 <h2>EXAMPLES</h2>
@@ -11,11 +20,11 @@
 v.net.spanningtree input=projected_pipelines output=spanningtree accol=cost
 </pre></div>
-<p>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.net.steiner.html">v.net.steiner</a>
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.timetable/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.timetable/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.timetable/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -1,12 +1,28 @@
-<em>v.net.timetable</em> finds the shortest path between two points using timetables. Module reads input, one query per line, from the standard input and writes output to the standard output as well as to the <b>output</b> map and to tables linked to layers 1 and 2. Each line of input must follow one of the following formats:
-<pre>
+<em>v.net.timetable</em> finds the shortest path between two points
+using timetables. <em>v.net.timetable</em> reads input, one query per line,
+from the standard input and writes output to the standard output as well as
+to the <b>output</b> map and to tables linked to layers 1 and 2.
+Each line of input must follow one of the following formats:
+<div class="code"><pre>
 PATH_ID FROM_X FROM_Y TO_X TO_Y START_TIME MIN_CHANGE MAX_CHANGES WALK_CHANGE
 PATH_ID FROM_STOP TO_STOP START_TIME MIN_CHANGE MAX_CHANGES WALK_CHANGE
-</pre>
-where PATH_ID is the identificator of a query that is used in the output map to differentiate between queries. Search begins at START_TIME. MIN_CHANGE gives the minimum number of time (inclusively) for a change from one route to another. MAX_CHANGES denotes the maximum number of changes allowed or -1 if infinity. WALK_CHANGE is 1 or 0 depending whether walking from a stop to another stop is considered a change or not. Finally, the path is found from FROM_STOP to TO_STOP in latter case and from the stop closest to (FROM_X, FROM_Y) coordinates to the stop closest to (TO_X, TO_Y) coordinates in former case.<br>
-For each input query, module outputs a description of the shortest path to the standard output. For example, using the tables given below, for the following input:
+</pre></div>
+where PATH_ID is the identificator of a query that is used in the
+output map to differentiate between queries. Search begins at
+START_TIME. MIN_CHANGE gives the minimum number of time
+(inclusively) for a change from one route to another. MAX_CHANGES
+denotes the maximum number of changes allowed or -1 if infinity.
+WALK_CHANGE is 1 or 0 depending whether walking from a stop to
+another stop is considered a change or not. Finally, the path is
+found from FROM_STOP to TO_STOP in latter case and from the stop
+closest to (FROM_X, FROM_Y) coordinates to the stop closest to
+(TO_X, TO_Y) coordinates in former case.
+<br>
+For each input query, module outputs a description of the shortest
+path to the standard output. For example, using the tables given
+below, for the following input:
 47 130 300 0 1 5 0
 </pre></div>
@@ -15,26 +31,64 @@
 Route 15, from 130 leaving at 15 arriving to 250 at 22
 Walk from 250 leaving at 22 arriving to 300 at 24
 </pre></div>
-Moreover, the module writes the path to the <b>output</b> map and stores all the information necesasary to reconstruct the path to the tables. Table corresponding to stops/points is linked to layer 1 and looks, after the query, as follows:
+Moreover, the module writes the path to the <b>output</b> map and
+stores all the information necessary to reconstruct the path to the
+tables. Table corresponding to stops/points is linked to layer 1 and
+looks, after the query, as follows:
 cat|path_id|stop_id|index|arr_time|dep_time
 1|47|130|1|0|15
 2|47|250|2|22|22
 3|47|300|3|24|24
 </pre></div>
-where CAT is the category of a point in the map, PATH_ID is the path identificator, STOP_ID is the identificator of the stop as used in the intput map, INDEX is the index of the stop on the path (i.e, index=1 is the first stop visited, ...) and ARR_TIME and DEP_TIME denote the arrival time and departure time respectively. Arrival time for the first stop on the path is always equal to START_TIME and departure time for the last stop is always equal to the arrival time.<br>
-Table linked to the second layer corresponds to subroutes taken between stops. The following table is obtainedd for the above query:
+where CAT is the category of a point in the map, PATH_ID is the path
+identificator, STOP_ID is the identificator of the stop as used in
+the input map, INDEX is the index of the stop on the path (i.e,
+index=1 is the first stop visited, ...) and ARR_TIME and DEP_TIME
+denote the arrival time and departure time respectively. Arrival
+time for the first stop on the path is always equal to START_TIME
+and departure time for the last stop is always equal to the arrival
+time.
+<br>
+The table linked to the second layer corresponds to subroutes taken
+between stops. The following table is obtainedd for the above query:
 cat|path_id|from_id|to_id|route_id|index|from_time|to_time
 1|47|130|250|15|1|15|22
 2|47|250|300|-1|2|22|24
 </pre></div>
-where CAT is the category of lines of subroute between stops FROM_ID to TO_ID, ROUTE_ID is the identificator of the route taken or -1 if walking, INDEX and PATH_ID are as above and FROM_TIME and TO_TIME denote the times between which the route is taken.<br>
-The <b>output</b> map contains the points on the positions of used stops. If a subroute is taken between two stops then a line segment is added between two corresponding points. Finally, instead of straight line segment, the actual paths of routes can be given in <b>paths</b> layer. If this parameter is used then each line in the input map must contain identificators as category numbers of all routes passing through the line. The module then finds the path between two stops and writes this path instead. In case of walking from one stop to another, straight line between the stops is used.
+where CAT is the category of lines of subroute between stops FROM_ID
+to TO_ID, ROUTE_ID is the identificator of the route taken or -1 if
+walking, INDEX and PATH_ID are as above and FROM_TIME and TO_TIME
+denote the times between which the route is taken.
+<br>
+The <b>output</b> map contains the points on the positions of used
+stops. If a subroute is taken between two stops then a line segment
+is added between two corresponding points. Finally, instead of
+straight line segment, the actual paths of routes can be given in <b>
+paths</b> layer. If this parameter is used then each line in the
+input map must contain identificators as category numbers of all
+routes passing through the line. The module then finds the path
+between two stops and writes this path instead. In case of walking
+from one stop to another, straight line between the stops is used.
 <h2>NOTES</h2>
-Timetables are stored in a table linked to the given <b>layer</b> of the <b>input</b> map. Timetable consists of routes and each route is just a sequence of stops with specified arrival times. If two sequences of stops differ only in times then they still correspond to two routes. For example, if there is a bus line that leaves every 20 minutes and follow exactly the same path every time then there still needs to be a separate route for every time. For each stop (given by the category number of the point) the table storing information about the routes must contain the list of all routes stopping at the stop(given by route identificators) together with arrival times. That is, the table must contain three columns: stop - which is the key of the table, <b>route_id</b> and <b>stop_time</b> where each triple corresponds to a route arriving to a stop and a certain time. For example, a valid table might look as follows:
+Timetables are stored in a table linked to the given <b>layer</b> of
+the <b>input</b> map. Timetable consists of routes and each route is
+just a sequence of stops with specified arrival times. If two
+sequences of stops differ only in times then they still correspond
+to two routes. For example, if there is a bus line that leaves every
+20 minutes and follow exactly the same path every time then there
+still needs to be a separate route for every time. For each stop
+(given by the category number of the point) the table storing
+information about the routes must contain the list of all routes
+stopping at the stop(given by route identificators) together with
+arrival times. That is, the table must contain three columns: stop -
+which is the key of the table, <b>route_id</b> and <b>stop_time</b>
+where each triple corresponds to a route arriving to a stop and a
+certain time. For example, a valid table might look as
+follows:
 cat|route_id|stop_time
 100|5|0
@@ -50,29 +104,44 @@
 300|35|37
 100|35|50
 </pre></div>
-Note that <b>stop_time</b> is an integer and so you can use any units and offest to specify arrival times.<br>
-Also, walking connections between stops can be given by a table linked to <b>walking</b> layer of the <b>input</b> map. If this parameter is -1 then walking between stops is not allowed. The table must contain three columns: stop - which is the key of the table, <b>to_stop</b> and <b>length</b>. A record in the table says that it takes <b>lenght</b> units of time to walk from stop to <b>to_stop</b>. The following is a valid table:
+Note that <b>stop_time</b> is an integer and so you can use any
+units and offest to specify arrival times.<br> Also, walking
+connections between stops can be given by a table linked to <b>
+walking</b> layer of the <b>input</b> map. If this parameter is -1
+then walking between stops is not allowed. The table must contain
+three columns: stop - which is the key of the table, <b>to_stop</b>
+and <b>length</b>. A record in the table says that it takes <b>length
+</b> units of time to walk from stop to <b>to_stop</b>. The
+following is a valid table:
 cat|length|to_stop
 250|2|300
 </pre></div>
-Beware that this only means that it is possible to walk from stop 250 to stop 300 but the other way round.
+Beware that this only means that it is possible to walk from stop
+250 to stop 300 but not the other way round.
 <h2>EXAMPLES</h2>
-To find a path from stop with identificator 130 to stop with category 300, starting at time 0, with one time unit for change, maximum of 5 changes and with walking not considered a change of route, we use the following command:
+To find a path from stop with identificator 130 to stop with
+category 300, starting at time 0, with one time unit for change,
+maximum of 5 changes and with walking not considered a change of
+route, we use the following command:
-echo "47 130 300 0 1 5 0" | v.net.timetable input=buses output=path layer=5 walking=6 path=7
+echo "47 130 300 0 1 5 0" | v.net.timetable \
+     input=buses output=path layer=5 walking=6 path=7
 </pre></div>
-If on the other, hand we know the coordinates of the places then the following command might be used
+If, on the other hand, we know the coordinates of the places then the
+following command might be used:
-echo "47 10.31 54.31 90.21 28.21 0 1 5 0" | v.net.timetable input=buses output=path layer=5 walking=6 path=7
+echo "47 10.31 54.31 90.21 28.21 0 1 5 0" | v.net.timetable \
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.net.path.html">v.net.path</a>,
 <a href="v.net.distance.html">v.net.distance</a>
 </em>
Modified: grass/branches/releasebranch_6_4/vector/v.net.visibility/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.visibility/description.html	2013-05-23 20:00:25 UTC (rev 56390)
+++ grass/branches/releasebranch_6_4/vector/v.net.visibility/description.html	2013-05-23 20:01:55 UTC (rev 56391)
@@ -11,8 +11,7 @@
 the visibility graph and from it compute the shortest path using
 <em>v.net.path</em> or <em>d.path</em>.
-<b>IMPORTANT : the algorithm doesn't work well with intersecting lines
+<b>IMPORTANT: the algorithm doesn't work well with intersecting lines
 (that includes overlapping)</b>
 <p>
@@ -26,26 +25,29 @@
 </pre></div>
 <p>
-The first argument is the input map. It supports lines, boudaries (so areas)
-and points. For the algorithm to work lines and boundaries must not be
-intersecting (that includes overlapping).
+The first argument is the input map. It supports lines, boudaries
+(so areas) and points. For the algorithm to work lines and
+boundaries must not be intersecting (that includes overlapping).
+<br>
 The result map containing the visibility graph is given in the output map.
-If you need to add additional points to compute a shortest path between them
-afterwards you can use the <em>coordinate</em> parameter.
+If you need to add additional points to compute a shortest path
+between them afterwards you can use the <em>coordinate</em> parameter.
 coordinate=25556200,6686400,25556400,6686600
 </pre></div>
-where 25556200,6686400 are the coordinate of the first point and 25556400,6686600
-are the coordinates of the second point. Of course you can give as many points as
-you want. They will be added to the visibility graph and edges from them will be
-computed. You can always add those points after computing the visibility graph.
-Simply use the <em>vis</em> parameter. The input will be the original vector map,
-the vis will be the computed visibility graph and the output the new visibility
-graph which will be the vis + the new points given with coordinate (edges will
-be computed as well).
+where 25556200,6686400 are the coordinate of the first point and
+25556400,6686600 are the coordinates of the second point. Of course
+you can give as many points as you want. They will be added to the
+visibility graph and edges from them will be computed. You can
+always add those points after computing the visibility graph. Simply
+use the <em>vis</em> parameter. The input will be the original
+vector map, the vis will be the computed visibility graph and the
+output the new visibility graph which will be the vis + the new
+points given with coordinate (edges will be computed as well).
-v.net.visibility input=map vis=vis_map output=new_vis_map coordinate=25556200,6686400,25556400,6686600
+v.net.visibility input=map vis=vis_map output=new_vis_map \
+      coordinate=25556200,6686400,25556400,6686600
 </pre></div>
 <h2>EXAMPLE 1</h2>
@@ -70,7 +72,7 @@
 An example on how to use the coordinate parameter. This will compute the
 visibility graph of the vector map lines with the point 2555678,6686343
-v.net.visibility input=lines output=graph coordinate=2555678,6686343<br>
+v.net.visibility input=lines output=graph coordinate=2555678,6686343
 d.vect graph
 d.vect lines col=red
 </pre></div>
@@ -83,7 +85,8 @@
 d.vect graph
-v.net.visibility input=lines vis=graph output=new_graph coordinate=2555678,6686343
+v.net.visibility input=lines vis=graph output=new_graph \
+      coordinate=2555678,6686343
 d.erase
 d.vect new_graph
@@ -101,10 +104,10 @@
 </pre></div>
 <h2>KNOWN BUGS</h2>
-In some cases when 3 points or nodes are collinear, some wrong edges are added.
-This happens only really rarly and shouldn't be a big problem.
-When two points have the exact same x coordinate and are visible, some wrong
-edges are added.
+In some cases when 3 points or nodes are collinear, some wrong edges
+are added. This happens only really rarly and shouldn't be a big
+problem. When two points have the exact same x coordinate and are
+visible, some wrong edges are added.
 <h2>SEE ALSO</h2>
