[GRASS-SVN] r56474 - grass/trunk/scripts/i.pansharpen
Wed May 29 05:43:15 PDT 2013
Author: neteler
Date: 2013-05-29 05:43:15 -0700 (Wed, 29 May 2013)
New Revision: 56474
   grass/trunk/scripts/i.pansharpen/i.pansharpen.py
i.pansharpen: raise fatal error if input data pixels are NULL only
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2013-05-29 12:12:04 UTC (rev 56473)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2013-05-29 12:43:15 UTC (rev 56474)
@@ -214,6 +214,9 @@
         #initial PCA with RGB channels
         pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0', input='%s,%s,%s' % (ms1, ms2, ms3), output_prefix='tmp%s.pca' % pid)
+        if len(pca_out) < 1:
+            grass.fatal(_("Input has no data. Check region settings."))
         b1evect = []
         b2evect = []
         b3evect = []
@@ -365,7 +368,10 @@
             stats_dict[j] = int(stats_dict[j])
             if j != '*':
                 total_cells += stats_dict[j]
+        if total_cells < 1:
         # Make a 2x256 structured array for each image with a
         #   cumulative distribution function (CDF) for each grey value.
         #   Grey value is the integer (i4) and cdf is float (f4).
