[GRASS-SVN] r56479 - grass/trunk/lib/vector/Vlib
Wed May 29 07:45:36 PDT 2013
Author: martinl
Date: 2013-05-29 07:45:36 -0700 (Wed, 29 May 2013)
New Revision: 56479
   grass/trunk/lib/vector/Vlib/header_finfo.c
vlib: Vect_get_finfo() returns for native format NULL
      warning -> debug (native format detected)
Modified: grass/trunk/lib/vector/Vlib/header_finfo.c
--- grass/trunk/lib/vector/Vlib/header_finfo.c	2013-05-29 14:25:56 UTC (rev 56478)
+++ grass/trunk/lib/vector/Vlib/header_finfo.c	2013-05-29 14:45:36 UTC (rev 56479)
@@ -49,8 +49,8 @@
         return Map->fInfo.pg.db_name;
-    G_warning(_("Native vector format detected for <%s>"),
-              Vect_get_full_name(Map));
+    G_debug(1, "Native vector format detected for <%s>",
+            Vect_get_full_name(Map));
     return NULL;
@@ -89,7 +89,7 @@
                    Map->fInfo.pg.table_name);
     else {
@@ -217,17 +217,18 @@
   \brief Get header info for non-native formats
-  Prints a warning for native format.
+  \param Map pointer to Map_info structure
-  \param Map pointer to Ma_info structure
   \return pointer to Format_info structure
+  \return NULL for native format
 const struct Format_info* Vect_get_finfo(const struct Map_info *Map)
-    if (Map->format == GV_FORMAT_NATIVE)
+    /* do not check Map-format which is native (see
+     * GRASS_VECTOR_EXTERNAL_IMMEDIATE) */
-    return &(Map->fInfo);
+    if (Map->fInfo.ogr.driver_name || Map->fInfo.pg.conninfo)
+        return &(Map->fInfo);
+    return NULL;
