[GRASS-SVN] r58324 - in grass/trunk: include/defs lib/vector/Vlib
Fri Nov 29 00:27:31 PST 2013
Author: martinl
Date: 2013-11-29 00:27:30 -0800 (Fri, 29 Nov 2013)
New Revision: 58324
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/vector/Vlib/build_pg.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/close_pg.c
   grass/trunk/lib/vector/Vlib/local_proto.h
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_pg.c
   grass/trunk/lib/vector/Vlib/pg_local_proto.h
   grass/trunk/lib/vector/Vlib/read_pg.c
   grass/trunk/lib/vector/Vlib/rewind_pg.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_pg.c
vlib/pg: fix building PostGIS Topology in update mode (line deleted)
         add 'line' topo DB table into topology schema (full mode only)
         various related fixes and improvements
(work in progress)
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/include/defs/vector.h	2013-11-29 08:27:30 UTC (rev 58324)
@@ -477,7 +477,6 @@
 const char *Vect_maptype_info(const struct Map_info *);
 int Vect_maptype(const struct Map_info *);
 int Vect_open_topo(struct Map_info *, int);
-int Vect_open_topo_pg(struct Map_info *, int);
 int Vect_save_topo(struct Map_info *);
 int Vect_open_sidx(struct Map_info *, int);
 int Vect_save_sidx(struct Map_info *);
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/build_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -31,6 +31,7 @@
 static int create_topo_grass(const struct Format_info_pg *);
 static int has_topo_grass(const struct Format_info_pg *);
 static int write_nodes(const struct Plus_head *, const struct Format_info_pg *);
+static int write_lines(const struct Plus_head *, const struct Format_info_pg *);
 static int write_areas(const struct Plus_head *, const struct Format_info_pg *);
 static int write_isles(const struct Plus_head *, const struct Format_info_pg *);
 static void build_stmt_id(const void *, int, int, const struct Plus_head *, char **, size_t *);
@@ -160,8 +161,30 @@
     /* cache features to speed-up random access (when attaching isles
        to areas) */
-    if (build >= GV_BUILD_BASE)
+    if (build >= GV_BUILD_BASE) {
         pg_info->cache.ctype = CACHE_MAP;
+        if (Map->mode == GV_MODE_RW &&
+            pg_info->cache.lines_num > 0) {
+            /* read line cache from scratch when map is open in update
+             * mode, before building native topology read nodes from
+             * PostGIS Topology */
+            /* clean-up spatial a category indeces */
+            dig_free_plus(&(Map->plus));
+            dig_init_plus(&(Map->plus));
+            plus->Spidx_new = TRUE;
+            plus->update_cidx = TRUE;
+            /* reset cache for reading features */
+            Vect__free_cache(&(pg_info->cache));
+            /* force loading nodes from DB to get up-to-date node
+             * offsets */
+            Vect__free_offset(&(pg_info->offset));
+            Map->plus.n_nodes = Vect__load_map_nodes_pg(Map, TRUE);
     /* update TopoGeometry based on GRASS-like topology */
     Vect_build_nat(Map, build);
@@ -177,6 +200,7 @@
     /* write full node topo info to DB if requested */
     if (!pg_info->topo_geo_only) {
         write_nodes(plus, pg_info);
+        write_lines(plus, pg_info);
     /* update faces from GRASS Topology */
@@ -604,6 +628,70 @@
+  \brief Insert lines into 'line_grass' table
+  Writes (see P_line struct) - only for boundaries:
+   - left, right area
+  Already stored in Topo-Geo:
+   - edge_id, left_face, right_face
+  \param plus pointer to Plus_head struct
+  \param pg_info pointer to Format_info_pg struct
+  \return 0 on success
+  \return -1 on error
+int write_lines(const struct Plus_head *plus,
+                const struct Format_info_pg *pg_info)
+    int i, row, offset;
+    char stmt[DB_SQL_MAX];
+    const struct P_line *Line;
+    const struct P_topo_b *topo;
+    PGresult *res;
+    sprintf(stmt, "SELECT edge_id FROM \"%s\".edge_data WHERE "
+            "left_face != 0 OR right_face != 0 ORDER BY edge_id",
+            pg_info->toposchema_name);
+    G_debug(2, "SQL: %s", stmt);
+    res = PQexec(pg_info->conn, stmt);
+    if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
+        (PQntuples(res) > 0 && PQntuples(res) != plus->n_blines)) {
+        G_warning(_("Inconsistency in topology: number of "
+                    "boundaries %d (should be %d)"),
+                  PQntuples(res), plus->n_blines);
+        if (res)
+            PQclear(res);
+        return -1;
+    for (row = 0, i = 1; i <= plus->n_lines; i++) {
+        Line = plus->Line[i];
+        if (!Line || Line->type != GV_BOUNDARY)
+            continue;
+        if (Line->offset == 0L)
+            offset = atoi(PQgetvalue(res, row++, 0));
+        else
+            offset = (int)Line->offset;
+        topo = (struct P_topo_b *)Line->topo;
+        sprintf(stmt, "INSERT INTO \"%s\".%s VALUES ("
+                "%d, %d, %d)", pg_info->toposchema_name, TOPO_TABLE_LINE,
+                offset, topo->left, topo->right);
+        if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
+            G_warning(_("Unable to write lines"));
+            return -1;
+    return 0;
   \brief Insert area into 'area_grass' table
   Writes (see P_area struct):
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/close.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -305,8 +305,20 @@
     G_free(cache->lines);
     G_free(cache->lines_types);
     G_free(cache->lines_cats);
+    G_zero(cache, sizeof(struct Format_info_cache));
+/*! Free memory of offset array
+  \param cache pointer to offset array to be freed
+void Vect__free_offset(struct Format_info_offset *offset)
+    G_free(offset->array);
+    G_zero(offset, sizeof(struct Format_info_offset));
 void unlink_file(const struct Map_info *Map, const char *name)
     char *path;
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -104,7 +104,7 @@
 	G_warning(_("Unable to save feature index file for vector map <%s>"),
 		  Map->name);
-    G_free(ogr_info->offset.array);
+    Vect__free_offset(&(ogr_info->offset));
     return 0;
 #else
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/close_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -137,7 +137,7 @@
                   Map->name);
-    G_free(Map->fInfo.pg.offset.array);
+    Vect__free_offset(&(Map->fInfo.pg.offset));
     return 0;
 #else
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/local_proto.h	2013-11-29 08:27:30 UTC (rev 58324)
@@ -16,6 +16,7 @@
 /* close.c */
 void Vect__free_cache(struct Format_info_cache *);
+void Vect__free_offset(struct Format_info_offset *);
 /* map.c */
 int Vect__delete(const char *, int);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/open.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -322,7 +322,7 @@
         ret = -1;
         if (Map->format == GV_FORMAT_POSTGIS)
             /* try to read full-topology for PostGIS links */
-            ret = Vect_open_topo_pg(Map, head_only);
+          ret = Vect__open_topo_pg(Map, head_only, update);
         if (ret != 0) {
             /* read topology for native format
@@ -361,6 +361,7 @@
                     level = 1;
         /* open category index */
         if (level >= 2) {
             ret = Vect_cidx_open(Map, head_only);
@@ -1268,7 +1269,7 @@
     Plus->Spidx_built = TRUE;
     return 0;
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -43,20 +43,18 @@
 static int parse_bbox(const char *, struct bound_box *);
 static struct P_node *read_p_node(struct Plus_head *, int, int,
                                   const char *, const char *, const char *,
-                                  struct Format_info_pg *);
+                                  struct Format_info_pg *, int);
 static struct P_line *read_p_line(struct Plus_head *, int,
-                                  const struct line_data *,
+                                  const struct line_data *, int,
 static struct P_area *read_p_area(struct Plus_head *, int,
                                   const char *, int, const char *);
 static struct P_isle *read_p_isle(struct Plus_head *, int,
                                   const char *, int);
-static int load_plus_head(struct Format_info_pg *, struct Plus_head *);
 static void notice_processor(void *, const char *);
 static char **scan_array(const char *);
 static int remap_node(const struct Format_info_offset *, int);
 static int remap_line(const struct Plus_head*, off_t, int);
-static void reset_cache(struct Format_info_cache *);
 #endif
@@ -135,8 +133,8 @@
     PQclear(res);
-    /* no feature in cache */
-    pg_info->cache.fid = -1;
+    /* fid -1 for empty / -2 for full cache */
+    pg_info->cache.fid = pg_info->cache.ctype != CACHE_MAP ? -1 : -2;
     if (!found) {
         G_warning(_("Feature table <%s> not found in 'geometry_columns'"),
@@ -324,14 +322,16 @@
   \param[in,out] Map pointer to Map_info structure
   \param head_only TRUE to read only header
+  \param update TRUE for update mode (reloading topology)
   \return 1 topology layer does not exist
   \return -1 on error
-int Vect_open_topo_pg(struct Map_info *Map, int head_only)
+int Vect__open_topo_pg(struct Map_info *Map, int head_only, int update)
 #ifdef HAVE_POSTGRES
+    int ret;
     struct Plus_head *plus;
     struct Format_info_pg *pg_info;
@@ -344,12 +344,36 @@
     if (check_topo(pg_info, plus) != 0)
         return 1;
-    /* free and init plus structure */
+    /* free and init plus structure, update spatial and category
+     * indeces  */
     dig_init_plus(plus);
-    plus->Spidx_new = TRUE;   /* force to create new spatial index */
-    plus->update_cidx = TRUE; /* force to update category index */
+    ret = Vect__load_plus_pg(Map, head_only);
-    return Vect__load_plus_pg(Map, head_only);
+    /* clean-up GRASS-like topology tables on update mode */
+    if (update && !pg_info->topo_geo_only && ret == 0) {
+        sprintf(stmt, "DELETE FROM \"%s\".\"%s\"",
+                pg_info->toposchema_name, TOPO_TABLE_NODE);
+        Vect__execute_pg(pg_info->conn, stmt);
+                pg_info->toposchema_name, TOPO_TABLE_LINE);
+                pg_info->toposchema_name, TOPO_TABLE_AREA);
+                pg_info->toposchema_name, TOPO_TABLE_ISLE);
+    return 0;
 #else
     G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
     return -1;
@@ -671,13 +695,15 @@
   \param lines_data lines array or NULL
   \param angles_data angles array or NULL
   \param pg_info pointer to Format_info_pg sttucture
+  \param geom_only TRUE to read node's geometry
   \return pointer to new P_node struct
   \return NULL on error
 struct P_node *read_p_node(struct Plus_head *plus, int n,
                            int id, const char *wkb_data, const char *lines_data,
-                           const char *angles_data, struct Format_info_pg *pg_info)
+                           const char *angles_data, struct Format_info_pg *pg_info,
+                           int geom_only)
     int i, cnt;
     char **lines, **angles;
@@ -688,81 +714,86 @@
     PGresult *res;
     /* get lines connected to the node */
+    cnt = 0;
     lines = angles = NULL;
-    if (!lines_data && !angles_data) { /* pg_info->topo_geo_only == TRUE */
-        char stmt[DB_SQL_MAX];
+    if (!geom_only) {
+        if (!lines_data && !angles_data) { /* pg_info->topo_geo_only == TRUE */
+            sprintf(stmt,
+                    "SELECT edge_id,'s' as node,"
+                    "ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) AS angle"
+                    " FROM \"%s\".edge WHERE start_node = %d UNION ALL "
+                    "SELECT edge_id,'e' as node,"
+                    "ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom) - 1)) AS angle"
+                    " FROM \"%s\".edge WHERE end_node = %d"
+                    " ORDER BY angle DESC",
+                    pg_info->toposchema_name, id,
+                    pg_info->toposchema_name, id);
+            if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
+                G_warning(_("Inconsistency in topology: unable to read node %d"), id);
+                if (res)
+                    PQclear(res);
+                return NULL;
+            cnt = PQntuples(res);
+        else { /* pg_info->topo_geo_only != TRUE */
+            lines  = scan_array(lines_data);
+            angles = scan_array(angles_data);
+            cnt = G_number_of_tokens(lines);
+            if (cnt != G_number_of_tokens(angles))
+                return NULL; /* 'lines' and 'angles' array must have the same size */
-        sprintf(stmt,
-                "SELECT edge_id,'s' as node,"
-                "ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) AS angle"
-                " FROM \"%s\".edge WHERE start_node = %d UNION ALL "
-                "SELECT edge_id,'e' as node,"
-                "ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom) - 1)) AS angle"
-                " FROM \"%s\".edge WHERE end_node = %d"
-                " ORDER BY angle DESC",
-                pg_info->toposchema_name, id,
-                pg_info->toposchema_name, id);
-        G_debug(2, "SQL: %s", stmt);
-        res = PQexec(pg_info->conn, stmt);
-        if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
-            G_warning(_("Inconsistency in topology: unable to read node %d"), id);
-            if (res)
-                PQclear(res);
+        if (cnt == 0) { /* dead */
+            plus->Node[n] = NULL;
             return NULL;
-        cnt = PQntuples(res);
-    else { /* pg_info->topo_geo_only != TRUE */
-        lines  = scan_array(lines_data);
-        angles = scan_array(angles_data);
-        cnt = G_number_of_tokens(lines);
-        if (cnt != G_number_of_tokens(angles))
-            return NULL; /* 'lines' and 'angles' array must have the same size */
-    if (cnt == 0) { /* dead */
-        plus->Node[n] = NULL;
-        return NULL;
     node = dig_alloc_node();
     node->n_lines = cnt;
     G_debug(4, "read_p_node(): id = %d, n_lines = %d", id, cnt);
-    if (dig_node_alloc_line(node, node->n_lines) == -1)
-        return NULL;
-    /* lines / angles */
-    if (lines) {
-        for (i = 0; i < node->n_lines; i++) {
-            node->lines[i] = atoi(lines[i]);
-            node->angles[i] = atof(angles[i]);
-            G_debug(5, "\tline = %d angle = %f", node->lines[i],
-                    node->angles[i]);
+    if (!geom_only) {
+        if (dig_node_alloc_line(node, node->n_lines) == -1)
+            return NULL;
-        G_free_tokens(lines);
-        G_free_tokens(angles);
-    else {
-            node->lines[i] = atoi(PQgetvalue(res, i, 0));
-            if (strcmp(PQgetvalue(res, i, 1), "s") != 0) {
-                /* end node */
-                node->lines[i] *= -1;
+        /* lines / angles */
+        if (lines) {
+            for (i = 0; i < node->n_lines; i++) {
+                node->lines[i] = atoi(lines[i]);
+                node->angles[i] = atof(angles[i]);
+                G_debug(5, "\tline = %d angle = %f", node->lines[i],
+                        node->angles[i]);
-            node->angles[i] = M_PI / 2 - atof(PQgetvalue(res, i, 2));
-            /* angles range <-PI; PI> */
-            if (node->angles[i] > M_PI)
-                node->angles[i] = node->angles[i] - 2 * M_PI;
-            if (node->angles[i] < -1.0 * M_PI)
-                node->angles[i] = node->angles[i] + 2 * M_PI;
-                    node->angles[i]);
+            G_free_tokens(lines);
+            G_free_tokens(angles);
-        PQclear(res);
+        else {
+                node->lines[i] = atoi(PQgetvalue(res, i, 0));
+                if (strcmp(PQgetvalue(res, i, 1), "s") != 0) {
+                    /* end node */
+                    node->lines[i] *= -1;
+                node->angles[i] = M_PI / 2 - atof(PQgetvalue(res, i, 2));
+                /* angles range <-PI; PI> */
+                if (node->angles[i] > M_PI)
+                    node->angles[i] = node->angles[i] - 2 * M_PI;
+                if (node->angles[i] < -1.0 * M_PI)
+                    node->angles[i] = node->angles[i] + 2 * M_PI;
+                        node->angles[i]);
+            PQclear(res);
     /* get node coordinates */
@@ -805,13 +836,14 @@
   \param plus pointer to Plus_head structure
   \param n index (starts at 1)
   \param data edge data (id, start/end node, left/right face, ...)
-  \param pg_info pointer to Format_info_pg sttucture
+  \param topo_geo_only TRUE for topo-geo-only mode
+  \param cache pointer to Format_info_cache structure
   \return pointer to P_line struct
 struct P_line *read_p_line(struct Plus_head *plus, int n,
-                           const struct line_data *data,
+                           const struct line_data *data, int topo_geo_only,
                            struct Format_info_cache *cache)
     int tp, cat;
@@ -866,9 +898,13 @@
             topo->N1    = data->start_node;
             topo->N2    = data->end_node;
-            /* skip left/right area - will be detected when building
-               areas/isles */
-            topo->left = topo->right = 0;
+            if (topo_geo_only) {
+                topo->left = topo->right = 0;
+            else {
+                topo->left  = data->left_face;
+                topo->right = data->right_face;
         /* centroids */
         else if (line->type == GV_CENTROID) {
@@ -1025,12 +1061,18 @@
   \return -1 on error
-int load_plus_head(struct Format_info_pg *pg_info, struct Plus_head *plus)
+int Vect__load_plus_head(struct Map_info *Map)
+    struct Format_info_pg *pg_info;
+    struct Plus_head *plus;
     PGresult *res;
+    plus = &(Map->plus);
+    pg_info = &(Map->fInfo.pg);
     plus->off_t_size = -1;
     /* get map bounding box
@@ -1201,12 +1243,10 @@
 int Vect__load_plus_pg(struct Map_info *Map, int head_only)
-    int i, side, line, id, ntuples;
+    int i, side, line;
-    struct line_data line_data;
-    struct Format_info_offset *offset;
     struct line_pnts *Points;
@@ -1217,9 +1257,8 @@
-    offset = &(pg_info->offset);
-    if (load_plus_head(pg_info, plus) != 0)
+    if (Vect__load_plus_head(Map) != 0)
         return -1;
     if (head_only)
@@ -1231,8 +1270,172 @@
     /* read nodes (GRASS Topo)
        note: standalone nodes (ie. points/centroids) are ignored
-    if (pg_info->topo_geo_only)
+    Vect__load_map_nodes_pg(Map, FALSE);
+    /* read lines (GRASS Topo)
+       - standalone nodes -> points|centroids
+       - edges -> lines/boundaries
+    pg_info->cache.ctype = CACHE_MAP;
+    Vect__load_map_lines_pg(Map);
+    /* build areas */
+    if (pg_info->topo_geo_only) {
+        /* build areas for boundaries
+           reset values -> build from scratch */
+        plus->n_areas = plus->n_isles = 0;
+        for (line = 1; line <= plus->n_lines; line++) {
+            Line = plus->Line[line]; /* centroids: Line is NULL */
+                continue;
+            for (i = 0; i < 2; i++) { /* for both sides build an area/isle */
+                side = i == 0 ? GV_LEFT : GV_RIGHT;
+                G_debug(3, "Build area for line = %d, side = %d",
+                        i, side);
+                Vect_build_line_area(Map, line, side);
+    else {
+        int cat;
+        /* read areas from 'area_grass' table */
         sprintf(stmt,
+                "SELECT area_id,lines,centroid,isles FROM \"%s\".%s ORDER BY area_id",
+            plus->n_areas != PQntuples(res)) {
+            if (res)
+                PQclear(res);
+            return -1;
+        dig_alloc_areas(plus, plus->n_areas);
+        G_zero(plus->Area, sizeof(struct P_area *) * (plus->n_areas + 1)); /* index starts at 1 */
+        G_debug(3, "Vect_open_topo_pg(): n_areas=%d", plus->n_areas);
+        for (i = 0; i < plus->n_areas; i++) {
+            read_p_area(plus, i + 1, (char *)PQgetvalue(res, i, 1),
+                        atoi(PQgetvalue(res, i, 2)), (char *)PQgetvalue(res, i, 3));
+            if (plus->Spidx_new) {
+                /* update spatial index */
+                Vect_get_area_points(Map, i+1, Points);
+                dig_line_box(Points, &box);
+                dig_spidx_add_area(&(Map->plus), i+1, &box);
+            if (plus->update_cidx) {
+                /* update category index */
+                cat = pg_info->cache.lines_cats[plus->Area[i+1]->centroid-1];
+                dig_cidx_add_cat(plus, cat > 0 ? 1 : 0, cat > 0 ? cat : 0, i+1, GV_AREA);
+        PQclear(res);
+    plus->built = GV_BUILD_AREAS;
+    /* attach isles */
+        plus->n_isles = 0; /* reset isles */
+        G_warning(_("To be implemented: isles not attached in Topo-Geo-only mode"));
+    else {
+        /* read isles from 'isle_grass' table */
+        sprintf(stmt,
+                "SELECT isle_id,lines,area FROM \"%s\".%s ORDER BY isle_id",
+            plus->n_isles != PQntuples(res)) {
+            if (res)
+                PQclear(res);
+            return -1;
+        dig_alloc_isles(plus, plus->n_isles);
+        G_zero(plus->Isle, sizeof(struct P_isle *) * (plus->n_isles + 1)); /* index starts at 1 */
+        G_debug(3, "Vect_open_topo_pg(): n_isles=%d", plus->n_isles);
+        for (i = 0; i < plus->n_isles; i++) {
+            read_p_isle(plus, i + 1, (char *)PQgetvalue(res, i, 1),
+                        atoi(PQgetvalue(res, i, 2)));
+                Vect_get_isle_points(Map, i+1, Points);
+                dig_spidx_add_isle(&(Map->plus), i+1, &box);
+        PQclear(res);
+    plus->built = GV_BUILD_ATTACH_ISLES;
+    /* attach centroids */
+    if (pg_info->topo_geo_only && plus->n_areas > 0) {
+        int area;
+        struct P_area   *Area;
+        struct P_topo_c *topo;
+            if (Line->type != GV_CENTROID)
+                continue;
+            Vect_read_line(Map, Points, NULL, line);
+            area = Vect_find_area(Map, Points->x[0], Points->y[0]);
+            topo = (struct P_topo_c *)Line->topo;
+            topo->area = area;
+            Area = plus->Area[topo->area];
+            Area->centroid = Line->offset;
+    plus->built = GV_BUILD_CENTROIDS;
+    /* done */
+    plus->built = GV_BUILD_ALL;
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_list(List);
+    return 0;
+  \brief Read nodes from DB
+  \param Map pointer to Map_info struct
+  \param geom_only read only node's geometry
+  \return number of nodes
+int Vect__load_map_nodes_pg(struct Map_info *Map, int geom_only)
+    int i, id, n_nodes;
+    struct Format_info_offset *offset;
+    PGresult *res;
+    offset = &(pg_info->offset);
+    if (pg_info->topo_geo_only || geom_only)
+        sprintf(stmt,
                 "SELECT node_id,geom FROM \"%s\".node WHERE node_id IN "
                 "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
                 "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
@@ -1247,7 +1450,7 @@
-        PQntuples(res) != plus->n_nodes) {
+        (!geom_only && PQntuples(res) != plus->n_nodes)) {
                     "nodes %d (should be %d)"),
                   PQntuples(res), plus->n_nodes);
@@ -1256,31 +1459,54 @@
         return -1;
-    G_debug(3, "load_plus(): n_nodes = %d", plus->n_nodes);
-    dig_alloc_nodes(plus, plus->n_nodes);
-    offset->array = (int *) G_malloc (sizeof(int) * plus->n_nodes);
-    offset->array_num = offset->array_alloc = plus->n_nodes;
-    for (i = 0; i < plus->n_nodes; i++) {
+    n_nodes = PQntuples(res);
+    G_debug(3, "load_plus(): n_nodes = %d", n_nodes);
+    dig_alloc_nodes(plus, n_nodes);
+    offset->array = (int *) G_malloc (sizeof(int) * n_nodes);
+    offset->array_num = offset->array_alloc = n_nodes;
+    for (i = 0; i < n_nodes; i++) {
         G_debug(5, "node: %d", i);
         id = atoi(PQgetvalue(res, i, 0));
         read_p_node(plus, i + 1, /* node index starts at 1 */
                     id, (const char *) PQgetvalue(res, i, 1),
                     !pg_info->topo_geo_only ? (const char *) PQgetvalue(res, i, 2) : NULL,
                     !pg_info->topo_geo_only ? (const char *) PQgetvalue(res, i, 3) : NULL,
-                    pg_info);
+                    pg_info, geom_only);
         /* update offset */
         offset->array[i] = id;
     PQclear(res);
-    /* read lines (GRASS Topo)
-       - standalone nodes -> points|centroids
-       - edges -> lines/boundaries
-    G_debug(3, "load_plus(): n_lines = %d", plus->n_lines);
+    return n_nodes;
+  \brief Read features from DB
+  \return number of features
+int Vect__load_map_lines_pg(struct Map_info *Map)
+    int i, id, ntuples;
+    struct line_data line_data;
+    PGresult *res;
     dig_alloc_lines(plus, plus->n_lines);
     G_zero(plus->Line, sizeof(struct P_line *) * (plus->n_lines + 1)); /* index starts at 1 */
     /* read PostGIS Topo standalone nodes (containing_face is null)
        -> points
@@ -1316,10 +1542,7 @@
             PQclear(res);
         return -1;
-    reset_cache(&(pg_info->cache));
-    pg_info->cache.ctype = CACHE_MAP; /* experimental - cache all features */
     ntuples = PQntuples(res); /* plus->n_plines */
     G_zero(&line_data, sizeof(struct line_data));
     for (i = 0; i < ntuples; i++) {
@@ -1328,7 +1551,7 @@
         line_data.wkb_geom = (char *) PQgetvalue(res, i, 1);
         line_data.fid = atoi(PQgetvalue(res, i, 2)); /* feature id */
-        read_p_line(plus, i + 1, &line_data, &(pg_info->cache));
+        read_p_line(plus, i + 1, &line_data, pg_info->topo_geo_only, &(pg_info->cache));
     PQclear(res);
@@ -1336,12 +1559,22 @@
        -> lines
        -> boundaries
-    sprintf(stmt, /* fix fid column */
-            "SELECT edge_id,start_node,end_node,left_face,right_face,tt.geom,ft.%s "
-            "FROM \"%s\".edge AS tt LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND "
-            "(%s).id = edge_id ORDER BY edge_id",
-            "fid", pg_info->toposchema_name, pg_info->table_name,
-            pg_info->topogeom_column, pg_info->topogeom_column);
+        sprintf(stmt, /* TODO: fix fid column! */
+                "SELECT edge_id,start_node,end_node,left_face,right_face AS right_area,tt.geom,ft.%s "
+                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND "
+                "(%s).id = edge_id ORDER BY edge_id",
+                "fid", pg_info->toposchema_name, pg_info->table_name,
+                pg_info->topogeom_column, pg_info->topogeom_column);
+    else
+                "SELECT edge_id,start_node,end_node,left_area,right_area,tt.geom,ft.%s "
+                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\".%s ON "
+                "edge_id = line_id LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND "
+                "fid", pg_info->toposchema_name, pg_info->toposchema_name, TOPO_TABLE_LINE,
+                pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column);
@@ -1366,7 +1599,7 @@
         line_data.fid        = atoi(PQgetvalue(res, i, 6)); /* feature id */
         id = plus->n_plines + i + 1; /* points already registered */
-        read_p_line(plus, id, &line_data, &(pg_info->cache));
+        read_p_line(plus, id, &line_data, pg_info->topo_geo_only, &(pg_info->cache));
     PQclear(res);
@@ -1417,140 +1650,13 @@
         line_data.fid = atoi(PQgetvalue(res, i, 3)); /* feature id */
         /* area id and face id can be different */
-        read_p_line(plus, id + i, &line_data, &(pg_info->cache));
+        read_p_line(plus, id + i, &line_data, pg_info->topo_geo_only, &(pg_info->cache));
     PQclear(res);
     plus->built = GV_BUILD_BASE;
-    /* build areas */
-    if (pg_info->topo_geo_only) {
-        /* build areas for boundaries
-           reset values -> build from scratch */
-        plus->n_areas = plus->n_isles = 0;
-        for (line = 1; line <= plus->n_lines; line++) {
-            Line = plus->Line[line]; /* centroids: Line is NULL */
-            if (!Line || Line->type != GV_BOUNDARY)
-                continue;
-            for (i = 0; i < 2; i++) { /* for both sides build an area/isle */
-                side = i == 0 ? GV_LEFT : GV_RIGHT;
-                G_debug(3, "Build area for line = %d, side = %d",
-                        id, side);
-                Vect_build_line_area(Map, line, side);
-    else {
-        int cat;
-        /* read areas from 'area_grass' table */
-        sprintf(stmt,
-                "SELECT area_id,lines,centroid,isles FROM \"%s\".%s ORDER BY area_id",
-                pg_info->toposchema_name, TOPO_TABLE_AREA);
-        if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
-            plus->n_areas != PQntuples(res)) {
-            if (res)
-                PQclear(res);
-            return -1;
-        dig_alloc_areas(plus, plus->n_areas);
-        G_zero(plus->Area, sizeof(struct P_area *) * (plus->n_areas + 1)); /* index starts at 1 */
-        G_debug(3, "Vect_open_topo_pg(): n_areas=%d", plus->n_areas);
-        for (i = 0; i < plus->n_areas; i++) {
-            read_p_area(plus, i + 1, (char *)PQgetvalue(res, i, 1),
-                        atoi(PQgetvalue(res, i, 2)), (char *)PQgetvalue(res, i, 3));
-            if (plus->Spidx_new) {
-                /* update spatial index */
-                Vect_get_area_points(Map, i+1, Points);
-                dig_line_box(Points, &box);
-                dig_spidx_add_area(&(Map->plus), i+1, &box);
-            if (plus->update_cidx) {
-                /* update category index */
-                cat = pg_info->cache.lines_cats[plus->Area[i+1]->centroid-1];
-                dig_cidx_add_cat(plus, cat > 0 ? 1 : 0, cat > 0 ? cat : 0, i+1, GV_AREA);
-        PQclear(res);
-    plus->built = GV_BUILD_AREAS;
-    /* attach isles */
-        plus->n_isles = 0; /* reset isles */
-        G_warning(_("To be implemented: isles not attached in Topo-Geo-only mode"));
-    else {
-        /* read isles from 'isle_grass' table */
-        sprintf(stmt,
-                "SELECT isle_id,lines,area FROM \"%s\".%s ORDER BY isle_id",
-                pg_info->toposchema_name, TOPO_TABLE_ISLE);
-            plus->n_isles != PQntuples(res)) {
-            if (res)
-                PQclear(res);
-            return -1;
-        dig_alloc_isles(plus, plus->n_isles);
-        G_zero(plus->Isle, sizeof(struct P_isle *) * (plus->n_isles + 1)); /* index starts at 1 */
-        G_debug(3, "Vect_open_topo_pg(): n_isles=%d", plus->n_isles);
-        for (i = 0; i < plus->n_isles; i++) {
-            read_p_isle(plus, i + 1, (char *)PQgetvalue(res, i, 1),
-                        atoi(PQgetvalue(res, i, 2)));
-                Vect_get_isle_points(Map, i+1, Points);
-                dig_spidx_add_isle(&(Map->plus), i+1, &box);
-        PQclear(res);
-    plus->built = GV_BUILD_ATTACH_ISLES;
-    /* attach centroids */
-    if (pg_info->topo_geo_only && plus->n_areas > 0) {
-        int area;
-        struct P_area   *Area;
-        struct P_topo_c *topo;
-            if (Line->type != GV_CENTROID)
-                continue;
-            Vect_read_line(Map, Points, NULL, line);
-            area = Vect_find_area(Map, Points->x[0], Points->y[0]);
-            topo = (struct P_topo_c *)Line->topo;
-            topo->area = area;
-            Area = plus->Area[topo->area];
-            Area->centroid = Line->offset;
-    plus->built = GV_BUILD_CENTROIDS;
-    /* done */
-    plus->built = GV_BUILD_ALL;
-    Vect_destroy_line_struct(Points);
-    Vect_destroy_list(List);
-    return 0;
+    return plus->n_lines;
@@ -1648,12 +1754,4 @@
     return -1;
-/*! Reset lines cache */
-void reset_cache(struct Format_info_cache *cache)
-    Vect__free_cache(cache);
-    G_zero(cache, sizeof(struct Format_info_cache));
-    cache->fid = -1;
 #endif
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h	2013-11-29 08:27:30 UTC (rev 58324)
@@ -13,8 +13,9 @@
 #define TOPO_ID     "topology_id"
 #define TOPO_TABLE  "grass"
 #define TOPO_BBOX   "bbox"
-#define TOPO_TABLE_NUM  3
+#define TOPO_TABLE_NUM  4
 #define TOPO_TABLE_NODE "node_grass"
+#define TOPO_TABLE_LINE "line_grass"
 #define TOPO_TABLE_AREA "area_grass"
 #define TOPO_TABLE_ISLE "isle_grass"
@@ -78,8 +79,12 @@
 int Vect__insert_face_pg(struct Map_info *, int);
 /* open_pg.c */
+int Vect__load_plus_head(struct Map_info *);
 int Vect__load_plus_pg(struct Map_info *, int);
 int Vect__open_new_pg(struct Map_info *, int);
+int Vect__open_topo_pg(struct Map_info *, int, int);
+int Vect__load_map_nodes_pg(struct Map_info *, int);
+int Vect__load_map_lines_pg(struct Map_info *);
 #endif /* HAVE_POSTGRES */
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/read_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -459,6 +459,12 @@
         /* read feature to cache if necessary */
         while (pg_info->cache.lines_next == pg_info->cache.lines_num) {
+            if (pg_info->cache.ctype == CACHE_MAP &&
+                pg_info->cache.fid == -2) {
+                /* stop reading - last cached line */
+                return -2;
             /* cache feature -> line_p & line_c */
             sf_type = get_feature(pg_info, -1, -1);
@@ -467,8 +473,11 @@
                 return -1;
-            if ((int)sf_type < 0)       /* -1 || - 2 */
+            if ((int)sf_type < 0) {      /* -1 || - 2 */
+                if (pg_info->cache.ctype == CACHE_MAP)
+                    pg_info->cache.fid = -2; /* last line cached */
                 return (int)sf_type;
             if (sf_type == SF_UNKNOWN || sf_type == SF_NONE) {
                 G_warning(_("Feature without geometry. Skipped."));
@@ -481,10 +490,14 @@
             Map->head.last_offset = pg_info->cache.fid;
-        /* get data from cache */
-        itype = pg_info->cache.lines_types[pg_info->cache.lines_next];
-        iline = pg_info->cache.lines[pg_info->cache.lines_next];
+        /* get data from cache, skip dead lines (NULL) */
+        do {
+            itype = pg_info->cache.lines_types[pg_info->cache.lines_next];
+            iline = pg_info->cache.lines[pg_info->cache.lines_next];
+            pg_info->cache.lines_next++; /* read next line from cache */
+        } while (iline == NULL);
         G_debug(4, "read next cached line %d (type = %d)",
                 pg_info->cache.lines_next, itype);
@@ -514,15 +527,15 @@
                 cat = (int)pg_info->cache.fid;
             else {                           /* PostGIS Topology (cats are cached) */
-                cat = pg_info->cache.lines_cats[pg_info->cache.lines_next];
+                cat = pg_info->cache.lines_cats[pg_info->cache.lines_next-1];
                 if (cat == 0) { /* not cached yet */
                     int col_idx;
                     col_idx = itype & GV_POINTS ? 2 : 3;
-                    if (!PQgetisnull(pg_info->res, pg_info->cache.lines_next, col_idx))
+                    if (!PQgetisnull(pg_info->res, pg_info->cache.lines_next-1, col_idx))
                         cat = pg_info->cache.lines_cats[Map->next_line-1] =
-                        atoi(PQgetvalue(pg_info->res, pg_info->cache.lines_next, col_idx));
+                        atoi(PQgetvalue(pg_info->res, pg_info->cache.lines_next-1, col_idx));
                     else
                         pg_info->cache.lines_cats[Map->next_line-1] = -1; /* no cat */
@@ -531,8 +544,6 @@
                 Vect_cat_set(line_c, 1, cat);
-        pg_info->cache.lines_next++; /* read next line from cache */
         return itype;
Modified: grass/trunk/lib/vector/Vlib/rewind_pg.c
--- grass/trunk/lib/vector/Vlib/rewind_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/rewind_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -44,10 +44,11 @@
     pg_info->next_line = 0;
     /* reset cache */
-    if (pg_info->cache.ctype != CACHE_MAP)
+    if (pg_info->cache.ctype != CACHE_MAP) {
         pg_info->cache.lines_num = 0;
+        pg_info->cache.fid = -1;
     pg_info->cache.lines_next = 0;
     /* close DB cursor if necessary */
     return Vect__close_cursor_pg(pg_info);
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -516,7 +516,7 @@
     if (!Cats)
 	Cats = Vect_new_cats_struct();
-    V2_read_line_nat(Map, NULL, Cats, Area->centroid);
+    Vect_read_line(Map, NULL, Cats, Area->centroid);
     for (i = 0; i < Cats->n_cats; i++) {
 	dig_cidx_del_cat(&(Map->plus), Cats->field[i], Cats->cat[i], area,
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2013-11-28 16:32:12 UTC (rev 58323)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2013-11-29 08:27:30 UTC (rev 58324)
@@ -366,6 +366,7 @@
 int V2_delete_line_pg(struct Map_info *Map, int line)
+    int ret;
@@ -395,7 +396,9 @@
             G_warning(_("Attempt to access dead feature %d"), line);
             return -1;
+        Vect__execute_pg(pg_info->conn, "BEGIN");
         if (Line->type & GV_POINTS) {
             table_name = keycolumn = "node";
@@ -441,9 +444,23 @@
             Vect__execute_pg(pg_info->conn, "ROLLBACK");
             return -1;
+        if (pg_info->cache.ctype == CACHE_MAP) {
+            /* delete from cache */
+            Vect_destroy_line_struct(pg_info->cache.lines[line-1]);
+            pg_info->cache.lines[line-1] = NULL;
+            pg_info->cache.lines_types[line-1] = 0;
+            pg_info->cache.lines_cats[line-1] = 0;
         /* update topology */
-        return delete_line_from_topo_pg(Map, line, type, Points);
+        ret = delete_line_from_topo_pg(Map, line, type, Points);
+        if (ret == 0)
+            Vect__execute_pg(pg_info->conn, "COMMIT");
+        return ret;
 #else
@@ -781,8 +798,6 @@
     char *def_file;
-    PGresult *result;
     def_file = getenv("GRASS_VECTOR_PGFILE");
     /* read default values from PG file*/
@@ -899,8 +914,28 @@
             return -1;
-        /* (2) create 'area_grass' (see P_area struct)
+        /* (2) create 'line_grass' (see P_line struct)
+        sprintf(stmt, "CREATE TABLE \"%s\".%s (line_id SERIAL PRIMARY KEY, "
+                "left_area integer, right_area integer)",
+            Vect__execute_pg(pg_info->conn, "ROLLBACK");
+            return -1;
+        sprintf(stmt, "ALTER TABLE \"%s\".%s ADD CONSTRAINT line_exists "
+                "FOREIGN KEY (line_id) REFERENCES \"%s\".edge_data (edge_id) "
+                "DEFERRABLE INITIALLY DEFERRED",
+                pg_info->toposchema_name, TOPO_TABLE_LINE, pg_info->toposchema_name);
+            return -1;
+        /* (3) create 'area_grass' (see P_area struct)
            todo: add constraints for lines, centtroid and isles
         sprintf(stmt, "CREATE TABLE \"%s\".%s (area_id SERIAL PRIMARY KEY, "
@@ -911,7 +946,7 @@
             return -1;
-        /* (3) create 'isle_grass' (see P_isle struct)
+        /* (4) create 'isle_grass' (see P_isle struct)
            todo: add constraints for lines and area
@@ -2675,8 +2710,6 @@
   \brief Delete line from native and PostGIS topology
-  \todo Implement deleting nodes on request
   \param Map vector map
   \param line feature id to remove from topo
   \param type feature type
@@ -2688,47 +2721,44 @@
 int delete_line_from_topo_pg(struct Map_info *Map, int line, int type,
                              const struct line_pnts *Points)
-    Vect_reset_updated(Map);
-    if (0 != V2__delete_line_from_topo_nat(Map, line, type, Points, NULL))
-        return -1;
+    int N1, N2, node_id;
-    /* disabled: remove isolated nodes when closing the map
-       note: node id cannot be used as node_id
-       delete nodes from 'node' table
-    int n_nodes;
-    struct Plus_head *plus;
+    struct P_node *Node;
-    plus    = &(Map->plus);
-    n_nodes = Vect_get_num_updated_nodes(Map);
-    if (n_nodes > 0) {
-        int i, node;
-        for (i = 0; i < n_nodes; i++) {
-            node = Vect_get_updated_node(Map, i);
-            if (node > 0 || plus->Node[abs(node)] != NULL)
-                continue;
-            node = abs(node);
-            G_debug(3, "delete node %d from 'node' table", node);
-            sprintf(stmt, "DELETE FROM \"%s\".\"node\" WHERE node_id = %d",
-                    pg_info->toposchema_name, node);
-            if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
-                G_warning(_("Unable to delete node %d"), node);
-                Vect__execute_pg(pg_info->conn, "ROLLBACK");
-                return -1;
+    Vect_reset_updated(Map);
+    Vect_get_line_nodes(Map, line, &N1, &N2);
+    if (0 != V2__delete_line_from_topo_nat(Map, line, type, Points, NULL))
+        return -1;
+    Node = Map->plus.Node[N1];
+    if (!Node || Node->n_lines == 0) {
+        node_id = pg_info->offset.array[N1-1];
+        sprintf(stmt, "DELETE FROM \"%s\".\"node\" WHERE node_id = %d",
+                pg_info->toposchema_name, node_id);
+            G_warning(_("Unable to delete node %d"), node_id);
+            return -1;
+    Node = Map->plus.Node[N2];
+        node_id = pg_info->offset.array[N2-1];
+            return -1;
     return 0;
