[GRASS-SVN] r57900 - grass-addons/grass7/raster/r.fidimo
Tue Oct 1 02:08:36 PDT 2013
Author: jradinger
Date: 2013-10-01 02:08:35 -0700 (Tue, 01 Oct 2013)
New Revision: 57900
   grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Implemenation of seed for realisation step
Minor changes/improvements in the g.parser options (set output to gisprompt: new)
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2013-10-01 03:31:44 UTC (rev 57899)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2013-10-01 09:08:35 UTC (rev 57900)
@@ -114,7 +114,7 @@
 #% key: habitat_attract
 #% type: string
 #% gisprompt: old,cell,raster
-#% description: Or: Attractiveness of habitat used as weighting factor (sink efffect, habitat-dependent dispersal)
+#% description: Attractiveness of habitat used as weighting factor (sink effect, habitat-dependent dispersal)
 #% required: no
 #% guisection: Habitat dependency
 #%end
@@ -122,7 +122,7 @@
 #% key: habitat_p
 #% type: string
-#% description: Or: Spatially varying and habitat-dependent p factor (float: 0-1, source effect, habitat-dependent dispersal)
+#% description: Spatially varying and habitat-dependent p factor (float: 0-1, source effect, habitat-dependent dispersal)
 #% required: no
 #%end
@@ -153,12 +153,13 @@
 #% type: integer
 #% required: no
 #% multiple: no
-#% description: fixed seed for generating dispersal parameters via fishmove
+#% description: fixed seed for generating dispersal parameters and for multinomial realisation step
 #% guisection: Optional
 #%End
 #%Option
 #% key: output
 #% type: string
+#% gisprompt: new
 #% required: no
 #% multiple: no
 #% key_desc: name
@@ -281,12 +282,8 @@
 	else:
 		interval = "confidence"
-	#Set fixed seed if specified
-	if options['seed']:
-		seed = ",seed="+str(options['seed'])
-	else:
-		seed = ""
 	#Output
 	output_fidimo = options['output']
 	if (grass.find_file(name = output_fidimo+"_"+"fit", element = 'cell')['file'] and not grass.overwrite()):
@@ -322,6 +319,12 @@
 	##### Calculating 'fishmove' depending on species or L & AR
+	#Set fixed seed if specified
+	if options['seed']:
+		seed = ",seed="+str(options['seed'])
+	else:
+		seed = ""
 	if species == "Custom species":
 		fishmove = eval("fm.fishmove(L=L,AR=AR,SO=SO,T=T,interval=interval,rep=200%s)"%(seed))
 	else:
@@ -971,6 +974,8 @@
 					RealisedDensity = garray.array()
+						numpy.random.seed(seed=int(options['seed']))
 					RealisedDensity[...] = numpy.random.multinomial(n_fish, (CorrectedDensity/numpy.sum(CorrectedDensity)).flat, size=1).reshape(CorrectedDensity.shape)
 					RealisedDensity.write("realised_density_"+str(cat))
