[GRASS-SVN] r57927 - in grass/branches/develbranch_6/imagery: i.cluster i.gensig i.gensigset
Thu Oct 3 15:16:56 PDT 2013
Author: neteler
Date: 2013-10-03 15:16:55 -0700 (Thu, 03 Oct 2013)
New Revision: 57927
   grass/branches/develbranch_6/imagery/i.cluster/main.c
   grass/branches/develbranch_6/imagery/i.gensig/parse.c
   grass/branches/develbranch_6/imagery/i.gensigset/parse.c
i.cluster, i.gensig, i.gensigset: make signature list browseable
Modified: grass/branches/develbranch_6/imagery/i.cluster/main.c
--- grass/branches/develbranch_6/imagery/i.cluster/main.c	2013-10-03 22:16:14 UTC (rev 57926)
+++ grass/branches/develbranch_6/imagery/i.cluster/main.c	2013-10-03 22:16:55 UTC (rev 57927)
@@ -94,6 +94,7 @@
     parm.out_sig->type = TYPE_STRING;
     parm.out_sig->key_desc = "name";
     parm.out_sig->required = YES;
+    parm.out_sig->gisprompt = "old,sig,sigfile";
     parm.out_sig->description = _("Name for output file containing result signatures");
     parm.class = G_define_option();
Modified: grass/branches/develbranch_6/imagery/i.gensig/parse.c
--- grass/branches/develbranch_6/imagery/i.gensig/parse.c	2013-10-03 22:16:14 UTC (rev 57926)
+++ grass/branches/develbranch_6/imagery/i.gensig/parse.c	2013-10-03 22:16:55 UTC (rev 57927)
@@ -19,9 +19,11 @@
     sigfile = G_define_option();
     sigfile->key = "signaturefile";
+    sigfile->type = TYPE_STRING;
+    sigfile->key_desc = "name";
+    sigfile->required = YES;
+    sigfile->gisprompt = "old,sig,sigfile";
     sigfile->description = _("Name for output file containing result signatures");
-    sigfile->required = YES;
-    sigfile->type = TYPE_STRING;
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
Modified: grass/branches/develbranch_6/imagery/i.gensigset/parse.c
--- grass/branches/develbranch_6/imagery/i.gensigset/parse.c	2013-10-03 22:16:14 UTC (rev 57926)
+++ grass/branches/develbranch_6/imagery/i.gensigset/parse.c	2013-10-03 22:16:55 UTC (rev 57927)
@@ -11,16 +11,18 @@
     trainingmap = G_define_standard_option(G_OPT_R_MAP);
     trainingmap->key = "trainingmap";
     trainingmap->description = _("Ground truth training map");
     group = G_define_standard_option(G_OPT_I_GROUP);
     subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
     maxsig = G_define_option();
     maxsig->key = "maxsig";
