[GRASS-SVN] r57940 - grass/trunk/vector/v.category
svn_grass at osgeo.org
Sat Oct 5 06:14:42 PDT 2013
Author: mmetz
Date: 2013-10-05 06:14:42 -0700 (Sat, 05 Oct 2013)
New Revision: 57940
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.category/v.category.html
v.category: fix manual for option=del
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2013-10-04 12:47:27 UTC (rev 57939)
+++ grass/trunk/vector/v.category/main.c 2013-10-05 13:14:42 UTC (rev 57940)
@@ -113,7 +113,7 @@
"print;%s;"
"layers;%s",
_("add a new category"),
- _("delete category (-1 to delete all categories of given layer)"),
+ _("delete category (cat=-1 to delete all categories of given layer)"),
_("change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"),
_("add the value specified by cat option to the current category value"),
_("copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"),
@@ -397,7 +397,7 @@
n = TCats->n_cats;
for (i = 0; i < n; i++) {
scat = TCats->cat[i];
- for (i = 0; i < nfields; i++) {
+ for (i = 1; i < nfields; i++) {
if (Vect_cat_set(Cats, fields[i], scat) > 0) {
G_debug(4, "Copy cat %i of field %i to into field %i", scat, fields[0], fields[i]);
Modified: grass/trunk/vector/v.category/v.category.html
--- grass/trunk/vector/v.category/v.category.html 2013-10-04 12:47:27 UTC (rev 57939)
+++ grass/trunk/vector/v.category/v.category.html 2013-10-05 13:14:42 UTC (rev 57940)
@@ -39,9 +39,16 @@
an area without a centroid; in this case, the module places new
centroids in areas automatically.
-<p>The <b>cat</b> parameter is only used with <b>option</b>=<i>add</i> and
-<b>option</b>=<i>sum</i>.
+<p>The <b>cat</b> parameter is only used with <b>option</b>=<i>add</i>,
+<b>option</b>=<i>sum</i> and <b>option</b>=<i>del</i>.
+<p>Categories can be deleted for the given layer with <em>option=del</em>.
+If <b>cat</b> is set to <i>-1</i>, all categories for the given layer
+are deleted. If <b>cat</b> is zero or positive, only this category value
+will be deleted. By default, <b>cat</b> is set to <i>1</i> which means
+that only categories of value <i>1</i> will be deleted.
<p>The <b>ids</b> parameter specifies the list of feature IDs to which the
operation is performed; by default, all vector feature ids are processed.
The <i>feature ID</i> is an internal (unique) geometry ID that all vector
@@ -73,7 +80,7 @@
<h3>Delete all vector categories in layer 1</h3>
<div class="code"><pre>
-v.category input=testmap output=outmap option=del
+v.category input=testmap output=outmap option=del cat=-1
</pre></div>
<h3>Add vector categories in layer 1 with step=2</h3>
