[GRASS-SVN] r57947 - grass/trunk/raster/r.in.lidar
Sun Oct 6 06:16:40 PDT 2013
Author: neteler
Date: 2013-10-06 06:16:40 -0700 (Sun, 06 Oct 2013)
New Revision: 57947
Added:
   grass/trunk/raster/r.in.lidar/r_in_lidar_dem_mean3D.jpg
   grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar manual: major update
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html	2013-10-06 12:09:31 UTC (rev 57946)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html	2013-10-06 13:16:40 UTC (rev 57947)
@@ -9,11 +9,13 @@
 region settings (extent and resolution), as default the current
 region extents and resolution are used for the import. When using
 the <em>-e</em> flag along with the <em>resolution=value</em>
-parameter, the region extents are based on new dataset. It is therefore
+parameter, the region extents will be based on new dataset. It is therefore
 recommended to first use the <em>-s</em> flag to get the extents of the
-LiDAR point cloud to be imported, then adjust the current region or the
-<em>resolution</em> parameter accordingly, and only then proceed with
-the actual import.
+LiDAR point cloud to be imported, then adjust the current region extent
+and resolution accordingly, and only then proceed with the actual import.
+Another option is to automatically set the region extents based on the
+LAS dataset itself along with the desired raster resolution. See below
+for details.
 <p>
 <em>r.in.lidar</em> is designed for processing massive point cloud
@@ -60,8 +62,8 @@
 <em>r.in.lidar</em>'s <b>-s</b> (or <b>-g</b>) flag to find the input
 data's bounds.<br>
-LAS dataset (<b>-e</b> flag) along with the target raster resolution using
-the <em>resolution</em> parameter.
+LAS dataset extent (<b>-e</b> flag) along with the desired raster
+resolution using the <em>resolution</em> parameter.
 <h3>Memory use</h3>
@@ -89,33 +91,76 @@
 <h3>Setting region bounds and resolution</h3>
-You can use the <b>-s</b> scan flag to find the extent of the input data
-(and thus point density) before performing the full import. Use
-<em>g.region</em> to adjust the region bounds to match. The <b>-g</b> shell
-style flag prints the extent suitable as parameters for <em>g.region</em>.
-A suitable resolution can be found by dividing the number of input points
-by the area covered. e.g.
+Using the <b>-s</b> scan flag, the extent of the input data (and thus
+point density) is printed. To check this is recommended before performing
+the full import. The <b>-g</b> shell style flag prints the extent suitable
+as command line parameters for <em>g.region</em>.<br>
+A simpler option is to automatically set the region extents based on the
+LAS dataset (<b>-e</b> flag) along with the target raster resolution using
+the <em>resolution</em> parameter. Also here it is recommended to verify
+and optimize the resulting region settings with <em>g.region</em> prior
+to importing the dataset.
+<p>
+For the output raster map, a <b>suitable resolution</b> can be found by
+dividing the number of input points by the area covered (this requires
+an iterative approach as outlined here):
 <div class="code"><pre>
-  wc -l inputfile.txt
-  g.region -p
-  # points_per_cell = n_points / (rows * cols)
+# North Carolina (http://grass.osgeo.org/sampledata/north_carolina/points.las)
-  g.region -e
-  # UTM location:
+# print LAS metadata (Number of Points)
+r.in.lidar -p input=points.las
+#   Number of Point Records: 1287775
+# scan for LAS points cloud extent
+r.in.lidar -sg input=points.las output=dummy -o
+# n=2193507.740000 s=2190053.450000 e=6070237.920000 w=6066629.860000 b=-3.600000 t=906.000000
+# set computation region to this extent
+g.region n=2193507.740000 s=2190053.450000 e=6070237.920000 w=6066629.860000 -p
+# print resulting extent
+g.region -p
+#  rows:       3454
+#  cols:       3608
+# points_per_cell = n_points / (rows * cols)
+# Here: 1287775 / (3454 * 3608) = 0.1033359 LiDAR points/raster cell
+# As this is too low, we need to select a lower raster resolution
+g.region res=5 -ap
+#  rows:       692
+#  cols:       723
+#  Now: 1287775 / (692 * 723) = 2.573923 LiDAR points/raster cell
+# import as mean
+r.in.lidar input=points.las output=lidar_dem_mean method=mean -o
+# import as max
+r.in.lidar input=points.las output=lidar_dem_max method=max -o
+# import as p'th percentile of the values
+r.in.lidar input=points.las output=lidar_dem_percentile_95 \
+           method=percentile pth=95 -o
+</pre></div>
+<center>
+<img src="r_in_lidar_dem_mean3D.jpg" alt="Mean value DEM in perspective view"><br>
+<i>Mean value DEM in perspective view, imported from LAS file</i>
+</center>
+<p>
+Further hints: how to calculate number of LiDAR points/square meter:
+<div class="code"><pre>
+g.region -e
+  # Metric location:
   # points_per_sq_m = n_points / (ns_extent * ew_extent)
   # Lat/Lon location:
   # points_per_sq_m = n_points / (ns_extent * ew_extent*cos(lat) * (1852*60)^2)
 </pre></div>
-<p>
-If you only intend to interpolate the data with <em>r.to.vect</em> and
-<em>v.surf.rst</em>, then there is little point to setting the region
-resolution so fine that you only catch one data point per cell -- you might
-as well use "<tt>v.in.ascii -zbt</tt>" directly.
 <h3>Filtering</h3>
 Points falling outside the current region will be skipped. This includes
@@ -135,7 +180,7 @@
 In varied terrain the user may find that <em>min</em> maps make for a good
 noise filter as most LIDAR noise is from premature hits. The <em>min</em> map
 may also be useful to find the underlying topography in a forested or urban
-environment if the cells are over sampled.
+environment if the cells are oversampled.
 <p>
 The user can use a combination of <em>r.in.lidar</em> <b>output</b> maps to create
@@ -145,33 +190,21 @@
 <em>r.neighbors</em> to smooth the stddev map before further use.]
-<h3>Interpolation into a DEM</h3>
+<h2>EXAMPLE</h2>
-The vector engine's topological abilities introduce a finite memory overhead
-per vector point which will limit the size a vector map relative to
-available RAM. If you want more, use the <em>r.to.vect</em>
-<b>-b</b> flag to skip building topology. Without topology, however, all
-you'll be able to do with the vector map is display with <em>d.vect</em> and
-interpolate with <em>v.surf.rst</em>.
-Run <em>r.univar</em> on your raster map to check the number of non-NULL cells
-and adjust bounds and/or resolution as needed before proceeding.
+North Carolina sample dataset: Import of the
+<a href="http://grass.osgeo.org/sampledata/north_carolina/points.las">sample LAS file</a>
+into the existing mapset:
-<p>
-Typical commands to create a DEM using a regularized spline fit:
-  r.univar lidar_min
-  r.to.vect -z feature=point in=lidar_min out=lidar_min_pt
-  v.surf.rst layer=0 in=lidar_min_pt elev=lidar_min.rst
+# set the computational region automatically, raster resolution for binning is 5m
+r.in.lidar -e -o input=points.las resolution=5 output=lidar_dem_mean
+g.region rast=lidar_dem_mean -p
+r.univar lidar_dem_mean
 </pre></div>
-Typical commands to create a DEM using bsplines:
-<div class="code"><pre>
-  r.resamp.bspline in=lidar_min out=lidar_min.bspline
-</pre></div>
-<br>
-<h2>EXAMPLE</h2>
+<p>
+Serpent Mound dataset:
 This example is analogous to the example used in the GRASS wiki page for
 <a href="http://grasswiki.osgeo.org/wiki/LIDAR#Import_LAS_as_raster_DEM">importing LAS as raster DEM</a>.
 <p>The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
@@ -179,26 +212,25 @@
 <a href="http://www.appliedimagery.com/downloads/sampledata/Serpent%20Mound%20Model%20LAS%20Data.las">appliedimagery.com</a>
-  # using v.in.lidar to print file info and to create a new location
+# print LAS file info
+r.in.lidar -p input="Serpent Mound Model LAS Data.las"
-  # print LAS file info
-  v.in.lidar -p input="Serpent Mound Model LAS Data.las"
+# using v.in.lidar to create a new location
+# create location with projection information of the LAS data
+v.in.lidar -i input="Serpent Mound Model LAS Data.las" location=Serpent_Mound
-  # create location with projection information of the LAS data
-  v.in.lidar -i input="Serpent Mound Model LAS Data.las" location=Serpent_Mound
+# quit and restart GRASS in the newly created location "Serpent_Mound"
-  # quit and restart GRASS in the newly created location "Serpent_Mound"
+# scan the extents of the LAS data
+r.in.lidar -sg input="Serpent Mound Model LAS Data.las"
-  # scan the extents of the LAS data
-  r.in.lidar -sg input="Serpent Mound Model LAS Data.las"
+# set the region to the extents of the LAS data, align to resolution
+g.region n=4323641.57 s=4320942.61 w=289020.90 e=290106.02 res=1 -ap
-  # set the region to the extents of the LAS data, align to resolution
-  g.region n=4323641.57 s=4320942.61 w=289020.90 e=290106.02 res=1 -ap
-  # import as raster DEM
-  r.in.lidar input="Serpent Mound Model LAS Data.las" output=Serpent_Mound_Model_LAS_Data method=mean
+# import as raster DEM
+r.in.lidar input="Serpent Mound Model LAS Data.las" \
+           output=Serpent_Mound_Model_LAS_Data method=mean
 </pre></div>
-<br>
 <h2>TODO</h2>
@@ -206,17 +238,16 @@
 <ul>
 <li> Support for multiple map output from a single run.<br>
      <tt>method=string[,string,...] output=name[,name,...]</tt>
+<li> add option to import only one, not all returns</li>
+<!-- not really:
 <li> Merge with r.in.xyz.
      <!-- Bob Covill has supplied patches for MBIO interface already -->
 </ul>
 <h2>BUGS</h2>
 <ul>
-<li> <em>n</em> map sum can be ever-so-slightly more than `<tt>wc -l</tt>`
-  with e.g. <tt>percent=10</tt> or less.
-  <br>Cause unknown.
 <li> <em>n</em> map <tt>percent=100</tt> and <tt>percent=xx</tt> maps
   differ slightly (point will fall above/below the segmentation line)
   <br>Investigate with "<tt>r.mapcalc diff = bin_n.100 - bin_n.33</tt>" etc.
@@ -232,33 +263,20 @@
 <h2>SEE ALSO</h2>
-<i>
-<a href="g.region.html">g.region</a><br>
-<a href="m.proj.html">m.proj</a><br>
-<a href="r.in.xyz.html">r.in.xyz</a><br>
-<a href="r.fillnulls.html">r.fillnulls</a><br>
-<a href="r.in.ascii.html">r.in.ascii</a><br>
-<a href="r.mapcalc.html">r.mapcalc</a><br>
-<a href="r.neighbors.html">r.neighbors</a><br>
-<a href="r.out.xyz.html">r.out.xyz</a><br>
-<a href="r.to.rast3.html">r.to.rast3</a><br>
-<a href="r.to.vect.html">r.to.vect</a><br>
-<a href="r.univar.html">r.univar</a><br>
-<a href="v.in.lidar.html">v.in.lidar</a><br>
-<a href="v.in.ascii.html">v.in.ascii</a><br>
-<a href="v.surf.rst.html">v.surf.rst</a><br>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.in.xyz.html">r.in.xyz</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.univar.html">r.univar</a>,
+<a href="v.in.lidar.html">v.in.lidar</a>
 <br>
 <a href="v.lidar.correction.html">v.lidar.correction</a>,
 <a href="v.lidar.edgedetection.html">v.lidar.edgedetection</a>,
 <a href="v.lidar.growing.html">v.lidar.growing</a>,
 <a href="v.outlier.html">v.outlier</a>,
 <a href="v.surf.bspline.html">v.surf.bspline</a>
-</i>
-<p><i><a href="http://www.ivarch.com/programs/pv.shtml">pv</a></i>
- - The UNIX pipe viewer utility
-<br><br>
+</em>
 <h2>AUTHORS</h2>
 Markus Metz<br>
Added: grass/trunk/raster/r.in.lidar/r_in_lidar_dem_mean3D.jpg
(Binary files differ)
Property changes on: grass/trunk/raster/r.in.lidar/r_in_lidar_dem_mean3D.jpg
___________________________________________________________________
Added: svn:mime-type
   + image/jpeg
