[GRASS-SVN] r57957 - grass/trunk/imagery/i.landsat.toar
Tue Oct 8 13:25:45 PDT 2013
Author: mmetz
Date: 2013-10-08 13:25:44 -0700 (Tue, 08 Oct 2013)
New Revision: 57957
   grass/trunk/imagery/i.landsat.toar/main.c
i.landsat.toar: fix window handling
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c	2013-10-08 14:22:49 UTC (rev 57956)
+++ grass/trunk/imagery/i.landsat.toar/main.c	2013-10-08 20:25:44 UTC (rev 57957)
@@ -35,7 +35,7 @@
     struct GModule *module;
     char *desc;
-    struct Cell_head cellhd;
+    struct Cell_head cellhd, orig_cellhd;
     void *inrast, *outrast;
     int infd, outfd;
@@ -245,6 +245,8 @@
     overwrite = G_check_overwrite(argc, argv);
+    Rast_get_window(&orig_cellhd);
     G_zero(&lsat, sizeof(lsat));
     if (adate->answer != NULL) {
@@ -397,10 +399,10 @@
 		hist[q] = 0L;
 	    sprintf(band_in, "%s%d", inputname, lsat.band[i].code);
+	    Rast_get_cellhd(band_in, "", &cellhd);
+	    Rast_set_window(&cellhd);
 	    if ((infd = Rast_open_old(band_in, "")) < 0)
 		G_fatal_error(_("Unable to open raster map <%s>"), band_in);
-	    Rast_get_cellhd(band_in, "", &cellhd);
-	    G_set_window(&cellhd);
 	    in_data_type = Rast_get_map_type(infd);
 	    if (in_data_type < 0)
@@ -535,6 +537,9 @@
 		(named->answer ? lsat.band[i].number : lsat.band[i].code));
 	sprintf(band_out, "%s%d", outputname, lsat.band[i].code);
+	/* set same size as original band raster */
@@ -552,11 +557,7 @@
 	    G_fatal_error(_("Unable to read data type of raster map <%s>"), band_in);
-	/* set same size as original band raster */
 	/* controlling, if we can write the raster */
 	if (G_legal_filename(band_out) < 0)
 	    G_fatal_error(_("<%s> is an illegal file name"), band_out);
@@ -722,6 +723,7 @@
 	else
 	    Rast_write_units(band_out, "unitless");
+    Rast_set_window(&orig_cellhd);
     exit(EXIT_SUCCESS);
