[GRASS-SVN] r57970 - grass/trunk/lib/python/script
Thu Oct 10 00:14:45 PDT 2013
Author: huhabla
Date: 2013-10-10 00:14:45 -0700 (Thu, 10 Oct 2013)
New Revision: 57970
   grass/trunk/lib/python/script/core.py
Fixed spelling mistakes
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py	2013-10-10 02:45:16 UTC (rev 57969)
+++ grass/trunk/lib/python/script/core.py	2013-10-10 07:14:45 UTC (rev 57970)
@@ -810,11 +810,11 @@
 def compare_key_value_text_files(filename_a, filename_b, sep=":",
                                  val_sep=",", precision=0.000001):
-    !Compare two key-value text two files
+    !Compare two key-value text files
     This method will print a warning in case keys that are present in the first
     file are not present in the second one.
-    The comparison method tries to convert the values into there native format
+    The comparison method tries to convert the values into their native format
     (float, int or string) to allow correct comparison.
     An example key-value text file may have this content:
@@ -829,7 +829,7 @@
     @param filenmae_b name of the second key-value text file
     @param sep character that separates the keys and values, default is ":"
     @param val_sep character that separates the values of a single key, default is ","
-    @param precision precision with which the floating point values are compares
+    @param precision precision with which the floating point values are compared
     @return True if full or almost identical, False if different
