[GRASS-SVN] r58115 - grass/trunk/lib/python/pygrass
Mon Oct 28 07:08:03 PDT 2013
Author: zarch
Date: 2013-10-28 07:08:02 -0700 (Mon, 28 Oct 2013)
New Revision: 58115
   grass/trunk/lib/python/pygrass/functions.py
Add a function to look for a map in a different mapset, location, gisdbase
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py	2013-10-28 12:35:12 UTC (rev 58114)
+++ grass/trunk/lib/python/pygrass/functions.py	2013-10-28 14:08:02 UTC (rev 58115)
@@ -44,6 +44,53 @@
     return res
+def findmaps(type, pattern=None, mapset='', location='', gisdbase=''):
+    """Return a list of tuple contining the names of the:
+        * map
+        * mapset,
+        * location,
+        * gisdbase
+    from grass.pygrass.gis import Gisdbase, Location, Mapset
+    def find_in_location(type, pattern, location):
+        res = []
+        for msetname in location.mapsets():
+            mset = Mapset(msetname, location.name, location.gisdbase)
+            res.extend([(m, mset.name, mset.location, mset.gisdbase)
+                        for m in mset.glist(type, pattern)])
+        return res
+    def find_in_gisdbase(type, pattern, gisdbase):
+        res = []
+        for loc in gisdbase.locations():
+            res.extend(find_in_location(type, pattern,
+                                        Location(loc, gisdbase.name)))
+        return res
+    if gisdbase and location and mapset:
+        mset = Mapset(mapset, location, gisdbase)
+        return [(m, mset.name, mset.location, mset.gisdbase)
+    elif gisdbase and location:
+        loc = Location(location, gisdbase)
+        return find_in_location(type, pattern, loc)
+    elif gisdbase:
+        gis = Gisdbase(gisdbase)
+        return find_in_gisdbase(type, pattern, gis)
+    elif location:
+        loc = Location(location)
+    elif mapset:
+        mset = Mapset(mapset)
+    else:
+        gis = Gisdbase()
 def remove(oldname, maptype):
     """Remove a map"""
     grasscore.run_command('g.remove', quiet=True,
