[GRASS-SVN] r58121 - grass/trunk/lib/raster
Tue Oct 29 14:39:09 PDT 2013
Author: hcho
Date: 2013-10-29 14:39:09 -0700 (Tue, 29 Oct 2013)
New Revision: 58121
   grass/trunk/lib/raster/window.c
Added a space between sentences.
Modified: grass/trunk/lib/raster/window.c
--- grass/trunk/lib/raster/window.c	2013-10-29 13:40:47 UTC (rev 58120)
+++ grass/trunk/lib/raster/window.c	2013-10-29 21:39:09 UTC (rev 58121)
@@ -16,7 +16,7 @@
     if (R__.split_window)
 	G_fatal_error(_("Internal error: Rast_get_window() called with split window."
-			"Use Rast_get_input_window() or Rast_get_output_window() instead."));
+			" Use Rast_get_input_window() or Rast_get_output_window() instead."));
     *window = R__.wr_window;
@@ -75,7 +75,7 @@
 	G_fatal_error(_("Internal error: Rast_window_rows() called with split window."
-			"Use Rast_input_window_rows() or Rast_output_window_rows() instead."));
+			" Use Rast_input_window_rows() or Rast_output_window_rows() instead."));
     return R__.wr_window.rows;
@@ -110,7 +110,7 @@
 	G_fatal_error(_("Internal error: Rast_window_cols() called with split window."
-			"Use Rast_input_window_cols() or Rast_output_window_cols() instead."));
+			" Use Rast_input_window_cols() or Rast_output_window_cols() instead."));
     return R__.wr_window.cols;
