[GRASS-SVN] r57591 - grass/trunk/display/d.vect.chart
Tue Sep 3 18:07:54 PDT 2013
Author: martinl
Date: 2013-09-03 18:07:53 -0700 (Tue, 03 Sep 2013)
New Revision: 57591
   grass/trunk/display/d.vect.chart/main.c
d.vect.chart: use standardized option for columns
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c	2013-09-03 21:07:58 UTC (rev 57590)
+++ grass/trunk/display/d.vect.chart/main.c	2013-09-04 01:07:53 UTC (rev 57591)
@@ -84,11 +84,8 @@
     ctype_opt->description = _("Chart type");
     ctype_opt->guisection = _("Chart properties");
-    columns_opt = G_define_option();
-    columns_opt->key = "columns";
-    columns_opt->type = TYPE_STRING;
+    columns_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
     columns_opt->required = YES;
-    columns_opt->multiple = YES;
     columns_opt->description = _("Attribute columns containing data");
     sizecol_opt = G_define_option();
